[GRASS-SVN] r38589 - grass/trunk/lib/rst/interp_float
svn_grass at osgeo.org
Sun Aug 2 17:01:47 EDT 2009
Author: neteler
Date: 2009-08-02 17:01:46 -0400 (Sun, 02 Aug 2009)
New Revision: 38589
grass/trunk/lib/rst/interp_float/segmen2d.c
helena: fix for running out of memory problem for large data sets (merge from develbranch_6, r38560)
Modified: grass/trunk/lib/rst/interp_float/segmen2d.c
--- grass/trunk/lib/rst/interp_float/segmen2d.c 2009-08-02 20:35:02 UTC (rev 38588)
+++ grass/trunk/lib/rst/interp_float/segmen2d.c 2009-08-02 21:01:46 UTC (rev 38589)
@@ -190,23 +190,33 @@
return -1;
- if (!
- (point =
- (struct triple *)G_malloc(sizeof(struct triple) *
+ /* allocate memory for CV points only if cv is performed */
+ if (params->cv){
+ if (!
+ (point =
+ (struct triple *)G_malloc(sizeof(struct triple) *
data->n_points))) {
- fprintf(stderr, "Cannot allocate memory for point\n");
- return -1;
+ fprintf(stderr, "Cannot allocate memory for point\n");
+ return -1;
/*normalize the data so that the side of average segment is about 1m */
+ /* put data_points into point only if CV is performed */
for (i = 0; i < data->n_points; i++) {
data->points[i].x = (data->points[i].x - data->x_orig) / dnorm;
+ data->points[i].y = (data->points[i].y - data->y_orig) / dnorm;
+ if (params->cv){
point[i].x = data->points[i].x; /*cv stuff */
- data->points[i].y = (data->points[i].y - data->y_orig) / dnorm;
point[i].y = data->points[i].y; /*cv stuff */
point[i].z = data->points[i].z; /*cv stuff */
/* commented out by Helena january 1997 as this is not necessary
+ although it may be useful to put normalization of z back?
data->points[i].z = data->points[i].z / dnorm;
+ this made smoothing self-adjusting based on dnorm
if (params->rsm < 0.) data->points[i].sm = data->points[i].sm / dnorm;
@@ -217,7 +227,13 @@
else
m_skip = 1;
+ /* remove after cleanup - this is just for testing */
+ skip_point.x = 0.;
+ skip_point.y = 0.;
+ skip_point.z = 0.;
for (skip_index = 0; skip_index < m_skip; skip_index++) {
+ if (params->cv) {
segtest = 0;
j = 0;
xx = point[skip_index].x * dnorm + data->x_orig + params->x_orig;
@@ -240,7 +256,7 @@
} /* segment area test */
if (!params->cv) {
if (params->
matrix_create(params, data->points, data->n_points,
@@ -253,13 +269,13 @@
matrix, indx) < 0)
return -1;
if (!params->cv) {
- b[i + 1] = data->points[i].z;
- b[0] = 0.;
- G_lubksb(matrix, data->n_points + 1, indx, b);
- params->check_points(params, data, b, ertot, zmin, dnorm,
+ b[i + 1] = data->points[i].z;
+ b[0] = 0.;
+ G_lubksb(matrix, data->n_points + 1, indx, b);
+/* put here condition to skip ertot if not needed */
+ params->check_points(params, data, b, ertot, zmin, dnorm,
skip_point);
else if (segtest == 1) {
@@ -270,9 +286,8 @@
skip_point);
+ } /*end of cv loop */
- } /*cv loop */
if (!params->cv)
if ((params->Tmp_fd_z != NULL) || (params->Tmp_fd_dx != NULL) ||
(params->Tmp_fd_dy != NULL) || (params->Tmp_fd_xx != NULL) ||
@@ -292,7 +307,7 @@
if (totsegm != 0) {
G_percent(cursegm, totsegm, 1);
G_free_matrix(matrix);
G_free_ivector(indx);
G_free_vector(b);
