[GRASS-SVN] r38598 - grass/trunk/scripts/v.dissolve
Mon Aug 3 11:19:23 EDT 2009
Author: martinl
Date: 2009-08-03 11:19:22 -0400 (Mon, 03 Aug 2009)
New Revision: 38598
   grass/trunk/scripts/v.dissolve/v.dissolve.py
fix v.dissolve (import grass.script)
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.py
--- grass/trunk/scripts/v.dissolve/v.dissolve.py	2009-08-03 14:53:30 UTC (rev 38597)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.py	2009-08-03 15:19:22 UTC (rev 38598)
@@ -56,9 +56,10 @@
 import sys
 import os
-from grass.script import core as grass
 import atexit
+import grass.script as grass
 def cleanup():
     nuldev = file(os.devnull, 'w')
     grass.run_command('g.remove', vect = '%s_%s' % (output, tmp), quiet = True, stderr = nuldev)
