[GRASS-SVN] r38602 - in grass/trunk/scripts: d.correlate d.polar d.rast.leg db.dropcolumn db.droptable db.in.ogr db.out.ogr db.test g.extension g.manual i.fusion.brovey i.image.mosaic i.in.spotvgt i.landsat.rgb i.spectral i.tasscap m.proj r.blend r.buffer r.fillnulls r.grow r.in.aster r.in.srtm r.in.wms r.mask r.plane r.reclass.area r.regression.line r.rgb r.shaded.relief r.tileset v.build.all v.centroids v.colors v.convert.all v.db.addcol v.db.addtable v.db.dropcolumn v.db.droptable v.db.join v.db.reconnect.all v.db.renamecolumn v.db.univar v.db.update v.dissolve v.in.e00 v.in.geonames v.in.gns v.in.mapgen v.in.sites.all v.in.wfs v.out.gps v.rast.stats v.report
Mon Aug 3 12:32:35 EDT 2009
Author: martinl
Date: 2009-08-03 12:32:35 -0400 (Mon, 03 Aug 2009)
New Revision: 38602
   grass/trunk/scripts/d.correlate/d.correlate.py
   grass/trunk/scripts/d.polar/d.polar.py
   grass/trunk/scripts/d.rast.leg/d.rast.leg.py
   grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py
   grass/trunk/scripts/db.droptable/db.droptable.py
   grass/trunk/scripts/db.in.ogr/db.in.ogr.py
   grass/trunk/scripts/db.out.ogr/db.out.ogr.py
   grass/trunk/scripts/db.test/db.test.py
   grass/trunk/scripts/g.extension/g.extension.py
   grass/trunk/scripts/g.manual/g.manual.py
   grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py
   grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py
   grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
   grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
   grass/trunk/scripts/i.spectral/i.spectral.py
   grass/trunk/scripts/i.tasscap/i.tasscap.py
   grass/trunk/scripts/m.proj/m.proj.py
   grass/trunk/scripts/r.blend/r.blend.py
   grass/trunk/scripts/r.buffer/r.buffer.py
   grass/trunk/scripts/r.fillnulls/r.fillnulls.py
   grass/trunk/scripts/r.grow/r.grow.py
   grass/trunk/scripts/r.in.aster/r.in.aster.py
   grass/trunk/scripts/r.in.srtm/r.in.srtm.py
   grass/trunk/scripts/r.in.wms/gdalwarp.py
   grass/trunk/scripts/r.in.wms/r.in.wms.py
   grass/trunk/scripts/r.in.wms/wms_download.py
   grass/trunk/scripts/r.in.wms/wms_request.py
   grass/trunk/scripts/r.mask/r.mask.py
   grass/trunk/scripts/r.plane/r.plane.py
   grass/trunk/scripts/r.reclass.area/r.reclass.area.py
   grass/trunk/scripts/r.regression.line/r.regression.line.py
   grass/trunk/scripts/r.rgb/r.rgb.py
   grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py
   grass/trunk/scripts/r.tileset/r.tileset.py
   grass/trunk/scripts/v.build.all/v.build.all.py
   grass/trunk/scripts/v.centroids/v.centroids.py
   grass/trunk/scripts/v.colors/v.colors.py
   grass/trunk/scripts/v.convert.all/v.convert.all.py
   grass/trunk/scripts/v.db.addcol/v.db.addcol.py
   grass/trunk/scripts/v.db.addtable/v.db.addtable.py
   grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py
   grass/trunk/scripts/v.db.droptable/v.db.droptable.py
   grass/trunk/scripts/v.db.join/v.db.join.py
   grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
   grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py
   grass/trunk/scripts/v.db.univar/v.db.univar.py
   grass/trunk/scripts/v.db.update/v.db.update.py
   grass/trunk/scripts/v.dissolve/v.dissolve.py
   grass/trunk/scripts/v.in.e00/v.in.e00.py
   grass/trunk/scripts/v.in.geonames/v.in.geonames.py
   grass/trunk/scripts/v.in.gns/v.in.gns.py
   grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py
   grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py
   grass/trunk/scripts/v.in.wfs/v.in.wfs.py
   grass/trunk/scripts/v.out.gps/v.out.gps.py
   grass/trunk/scripts/v.rast.stats/v.rast.stats.py
   grass/trunk/scripts/v.report/v.report.py
scripts: use _() macro around messages
Modified: grass/trunk/scripts/d.correlate/d.correlate.py
--- grass/trunk/scripts/d.correlate/d.correlate.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/d.correlate/d.correlate.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -44,7 +44,7 @@
     for map in layers:
 	if not grass.find_file(map, element = 'cell')['file']:
-	    grass.fatal("Input map <%s> not found" % map)
+	    grass.fatal(_("Input map <%s> not found") % map)
     grass.write_command('d.text', color = 'black', size = 4, line = 1, stdin = "CORRELATION")
Modified: grass/trunk/scripts/d.polar/d.polar.py
--- grass/trunk/scripts/d.polar/d.polar.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/d.polar/d.polar.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -180,7 +180,7 @@
 def plot_eps(psout):
     # EPS output (by M.Neteler and Bruno Caprile, ITC-irst)
-    grass.message("Generating %s ..." % psout)
+    grass.message(_("Generating %s ...") % psout)
     outerradius = maxradius
     epsscale = 0.1
@@ -381,7 +381,7 @@
     outf.close()
-    grass.message("Done.")
+    grass.message(_("Done."))
 def main():
     global tmp
@@ -396,11 +396,11 @@
     tmp = grass.tempfile()
     if eps and xgraph:
-	grass.fatal("Please select only one output method")
+	grass.fatal(_("Please select only one output method"))
     #### check if we have xgraph (if no EPS output requested)
     if xgraph and not grass.find_program('xgraph'):
-	grass.fatal("xgraph required, please install first (www.xgraph.org)")
+	grass.fatal(_("xgraph required, please install first (www.xgraph.org)"))
     # this file contains everthing:
@@ -415,7 +415,7 @@
 	totalnumber += 1
     rawf.close()
-    grass.message("Calculating statistics for polar diagram... (be patient)")
+    grass.message(_("Calculating statistics for polar diagram... (be patient)"))
     #wipe out NULL data and undef data if defined by user
     # - generate degree binned to integer, eliminate NO DATA (NULL):
@@ -445,7 +445,7 @@
     totalvalidnumber = nvals
     if totalvalidnumber == 0:
-	grass.fatal("No data pixel found")
+	grass.fatal(_("No data pixel found"))
     # unit vector on raw data converted to radians without no data:
@@ -494,9 +494,9 @@
     else:
 	plot_dgraph()
-    grass.message("Average vector:")
-    grass.message("direction: %.1f degrees CCW from East" % math.degrees(math.atan2(unitvector[1], unitvector[0])))
-    grass.message("magnitude: %.1f percent of fullscale" % (100 * math.hypot(unitvector[0], unitvector[1])))
+    grass.message(_("Average vector:"))
+    grass.message(_("direction: %.1f degrees CCW from East") % math.degrees(math.atan2(unitvector[1], unitvector[0])))
+    grass.message(_("magnitude: %.1f percent of fullscale") % (100 * math.hypot(unitvector[0], unitvector[1])))
 if __name__ == "__main__":
     options, flags = grass.parser()
Modified: grass/trunk/scripts/d.rast.leg/d.rast.leg.py
--- grass/trunk/scripts/d.rast.leg/d.rast.leg.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/d.rast.leg/d.rast.leg.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -97,11 +97,11 @@
     #for -n flag of d.legend
     if not grass.find_file(map)['file']:
-	grass.fatal("Raster map <%s> not found in mapset search path" % map)
+	grass.fatal(_("Raster map <%s> not found in mapset search path") % map)
     # for rast=
     if rast and not grass.find_file(rast)['file']:
-	grass.fatal("Raster map <%s> not found in mapset search path" % rast)
+	grass.fatal(_("Raster map <%s> not found in mapset search path") % rast)
     s = grass.read_command('d.info', flags = 'f')
     f = tuple([float(x) for x in s.split()[1:5]])
Modified: grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py
--- grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -64,19 +64,19 @@
     # schema needed for PG?
     if force:
-	grass.message("Forcing ...")
+	grass.message(_("Forcing ..."))
     if column == "cat":
-	grass.warning("Deleting <%s> column which may be needed to keep table connected to a vector map" % column)
+	grass.warning(_("Deleting <%s> column which may be needed to keep table connected to a vector map") % column)
     cols = [f[0] for f in grass.db_describe()['cols']]
     if column not in cols:
-	grass.fatal("Column <%s> not found in table" % column)
+	grass.fatal(_("Column <%s> not found in table") % column)
     if not force:
-	grass.message("Column <%s> would be deleted." % column)
+	grass.message(_("Column <%s> would be deleted.") % column)
 	grass.message("")
-	grass.message("You must use the force flag to actually remove it. Exiting.")
+	grass.message(_("You must use the force flag to actually remove it. Exiting."))
 	sys.exit(0)
     if driver == "sqlite":
@@ -110,7 +110,7 @@
     if grass.write_command('db.execute', input = '-', database = database, driver = driver,
 			   stdin = sql) != 0:
-	grass.fatal("Cannot continue (problem deleting column).")
+	grass.fatal(_("Cannot continue (problem deleting column)."))
Modified: grass/trunk/scripts/db.droptable/db.droptable.py
--- grass/trunk/scripts/db.droptable/db.droptable.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/db.droptable/db.droptable.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -52,12 +52,12 @@
     if force:
     # check if table exists
     nuldev = file(os.devnull, 'w')
     if not grass.db_describe(table, stdout = nuldev, stderr = nuldev):
-	grass.fatal("Table <%s> not found in current mapset" % table)
+	grass.fatal(_("Table <%s> not found in current mapset") % table)
     # check if table is used somewhere (connected to vector map)
     used = []
@@ -70,14 +70,14 @@
 		used.append(vect)
 		break
     if used:
-	grass.warning("Deleting table <%s> which is attached to following map(s):" % table)
+	grass.warning(_("Deleting table <%s> which is attached to following map(s):") % table)
 	for vect in used:
 	    grass.message(vect)
     if not force:
-	grass.message("The table <%s> would be deleted." % table)
+	grass.message(_("The table <%s> would be deleted.") % table)
 	grass.message("")
 	sys.exit(0)
     p = grass.feed_command('db.execute', input = '-', database = database, driver = driver)
@@ -85,7 +85,7 @@
     p.stdin.close()
     p.wait()
     if p.returncode != 0:
-  	grass.fatal("Cannot continue (problem deleting table).")
+  	grass.fatal(_("Cannot continue (problem deleting table)."))
Modified: grass/trunk/scripts/db.in.ogr/db.in.ogr.py
--- grass/trunk/scripts/db.in.ogr/db.in.ogr.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/db.in.ogr/db.in.ogr.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -76,7 +76,7 @@
 	s = grass.read_command('db.tables', flags = 'p')
 	for l in s.splitlines():
 	    if l == output:
-		grass.fatal("Table <%s> already exists" % output)
+		grass.fatal(_("Table <%s> already exists") % output)
     else:
 	grass.write_command('db.execute', input = '-', stdin = "DROP TABLE %s" % output)
@@ -89,9 +89,9 @@
     if grass.run_command('v.in.ogr', flags = 'o', dsn = dsn, output = output,
 			 layer = layer, quiet = True) != 0:
 	if db_table:
-	    grass.fatal("Input table <%s> not found or not readable" % input)
+	    grass.fatal(_("Input table <%s> not found or not readable") % input)
 	else:
-	    grass.fatal("Input DSN <%s> not found or not readable" % input)
+	    grass.fatal(_("Input DSN <%s> not found or not readable") % input)
@@ -107,7 +107,7 @@
     # ... and immediately drop the empty geometry
     vectfile = grass.find_file(output, element = 'vector', mapset = mapset)['file']
     if not vectfile:
-	grass.fatal("Something went wrong. Should not happen")
+	grass.fatal(_("Something went wrong. Should not happen"))
     else:
 	# remove the vector part
 	grass.try_remove(vectfile)
@@ -117,7 +117,7 @@
 		      colum = 'cat', stdout = nuldev, stderr = nuldev)
     records = grass.db_describe(output)['nrows']
-    grass.message("Imported table <%s> with %d rows" % (output, records))
+    grass.message(_("Imported table <%s> with %d rows") % (output, records))
Modified: grass/trunk/scripts/db.out.ogr/db.out.ogr.py
--- grass/trunk/scripts/db.out.ogr/db.out.ogr.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/db.out.ogr/db.out.ogr.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -75,7 +75,7 @@
     #is there a simpler way of testing for --overwrite?
     dbffile = input + '.dbf'
     if os.path.exists(dbffile) and not grass.overwrite():
-	grass.fatal("File <%s> already exists" % dbffile)
+	grass.fatal(_("File <%s> already exists") % dbffile)
     if grass.run_command('v.out.ogr', quiet = True, input = input, dsn = dsn,
 			 format = format, type = 'point', olayer = olayer) != 0:
@@ -97,7 +97,7 @@
     else:
 	outname = input
-    grass.message("Exported table <%s>" % outname)
+    grass.message(_("Exported table <%s>") % outname)
Modified: grass/trunk/scripts/db.test/db.test.py
--- grass/trunk/scripts/db.test/db.test.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/db.test/db.test.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -60,7 +60,7 @@
 	if r != 0:
 	    grass.error("EXECUTE: ******** ERROR ********")
 	else:
-	    grass.message("EXECUTE: OK")
+	    grass.message(_("EXECUTE: OK"))
 	expf = file(expected, 'w')
 	while True:
@@ -74,7 +74,7 @@
 	    if grass.call(['diff', result, expected]) != 0:
 		grass.error("RESULT: ******** ERROR ********")
 	    else:
-		grass.message("RESULT: OK")
+		grass.message(_("RESULT: OK"))
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/g.extension/g.extension.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -88,7 +88,7 @@
 def check():
     # check if we have the svn client
     if not grass.find_program('svn'):
-        grass.fatal('svn client required. Please install subversion first.')
+        grass.fatal(_('svn client required. Please install subversion first.'))
 def expand_module_class_name(c):
     name = { 'd'  : 'display',
@@ -109,7 +109,7 @@
     return c
 def list_available_modules(svnurl):
-    grass.message('Fetching list of modules from GRASS-Addons SVN (be patient)...')
+    grass.message(_('Fetching list of modules from GRASS-Addons SVN (be patient)...'))
     pattern = re.compile(r'(<li><a href=".+">)(.+)(</a></li>)', re.IGNORECASE)
     for d in ['d', 'db', 'g', 'i', 'ps',
               'p', 'r', 'r3', 'v']:
@@ -117,7 +117,7 @@
         url = svnurl + '/' + modclass
         f = urllib.urlopen(url)
         if not f:
-            grass.warning("Unable to fetch '%s'" % url)
+            grass.warning(_("Unable to fetch '%s'") % url)
             continue
         for line in f.readlines():
             sline = pattern.search(line)
@@ -131,29 +131,29 @@
 def install_extension(svnurl, prefix, module):
     gisbase = os.getenv('GISBASE')
     if not gisbase:
-        grass.fatal('$GISBASE not defined')
+        grass.fatal(_('$GISBASE not defined'))
     if grass.find_program(module):
-        grass.warning("Extension '%s' already installed. Will be updated..." % module)
+        grass.warning(_("Extension '%s' already installed. Will be updated...") % module)
     classchar = module.split('.', 1)[0]
     moduleclass = expand_module_class_name(classchar)
     url = svnurl + '/' + moduleclass + '/' + module
-    grass.message("Fetching '%s' from GRASS-Addons SVN (be patient)..." % module)
+    grass.message(_("Fetching '%s' from GRASS-Addons SVN (be patient)...") % module)
     global tmpdir
     os.chdir(tmpdir)
     if grass.call(['svn', 'checkout',
                    url]) != 0:
-        grass.fatal("GRASS Addons '%s' not found in repository" % module)
+        grass.fatal(_("GRASS Addons '%s' not found in repository") % module)
     os.chdir(os.path.join(tmpdir, module))
-    grass.message("Compiling '%s'..." % module)
+    grass.message(_("Compiling '%s'...") % module)
     if grass.call(['make',
                    'MODULE_TOPDIR=%s' % gisbase]) != 0:
-        grass.fatal('Compilation failed, sorry. Please check above error messages.')
+        grass.fatal(_('Compilation failed, sorry. Please check above error messages.'))
-    grass.message("Installing '%s'..." % module)
+    grass.message(_("Installing '%s'...") % module)
     # can we write ?
     try:
         # replace with something better
@@ -173,14 +173,14 @@
                           'install'])
     if ret != 0:
-        grass.warning('Installation failed, sorry. Please check above error messages.')
+        grass.warning(_('Installation failed, sorry. Please check above error messages.'))
     else:
-        grass.message("Installation of '%s' successfully finished." % module)
+        grass.message(_("Installation of '%s' successfully finished.") % module)
 def remove_extension(prefix, module):
     # is module available?
     if not grass.find_program(module):
-        grass.fatal("'%s' not found" % module)
+        grass.fatal(_("'%s' not found") % module)
     for file in [os.path.join(prefix, 'bin', module),
                  os.path.join(prefix, 'scripts', module),
@@ -188,10 +188,10 @@
         if os.path.isfile(file):
             os.remove(file)
-    grass.message("'%s' successfully uninstalled." % module)
+    grass.message(_("'%s' successfully uninstalled.") % module)
 def update_menu(menuitem, module, operation):
-    grass.warning('Not implemented')
+    grass.warning(_('Not implemented'))
     if operation == 'add':
         pass
     else: # remove
@@ -207,7 +207,7 @@
         return 0
     else:
         if not options['extension']:
-            grass.fatal('You need to define an extension name or use -l')
+            grass.fatal(_('You need to define an extension name or use -l'))
     # TODO: check more variable
     if '$(HOME)' in options['prefix']:
@@ -217,9 +217,9 @@
         try:
             os.makedirs(options['prefix'])
         except OSError, e:
-            grass.fatal("Unable to create '%s'\n%s" % (options['prefix'], e))
+            grass.fatal(_("Unable to create '%s'\n%s") % (options['prefix'], e))
-        grass.warning("'%s' created" % options['prefix'])
+        grass.warning(_("'%s' created") % options['prefix'])
     if options['operation'] == 'add':
         install_extension(options['svnurl'], options['prefix'], options['extension'])
Modified: grass/trunk/scripts/g.manual/g.manual.py
--- grass/trunk/scripts/g.manual/g.manual.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/g.manual/g.manual.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -42,20 +42,20 @@
 def start_browser(entry):
     path = os.path.join(gisbase, 'docs', 'html', entry + '.html')
     if not os.path.exists(path):
-	grass.fatal("No HTML manual page entry for <%s>." % entry)
+	grass.fatal(_("No HTML manual page entry for <%s>.") % entry)
     verbose = os.getenv("GRASS_VERBOSE")
     if not verbose or int(verbose) > 1:
-	grass.message("Starting browser <%s> for module %s..." % (browser_name, entry))
+	grass.message(_("Starting browser <%s> for module %s...") % (browser_name, entry))
     os.execlp(browser, browser_name, "file://%s/docs/html/%s.html" % (gisbase, entry))
-    grass.fatal("Error starting browser <%s> for HTML file <%s>" % (browser, entry))
+    grass.fatal(_("Error starting browser <%s> for HTML file <%s>") % (browser, entry))
 def start_man(entry):
     path = os.path.join(gisbase, 'man', 'man1', entry + '.1')
     for ext in ['', '.gz', '.bz2']:
 	if os.path.exists(path + ext):
 	    os.execlp('man', 'man', path + ext)
-	    grass.fatal("Error starting 'man' for <%s>" % path)
-    grass.fatal("No manual page entry for <%s>." % entry)
+	    grass.fatal(_("Error starting 'man' for <%s>") % path)
+    grass.fatal(_("No manual page entry for <%s>.") % entry)
 def main():
     global gisbase, browser, browser_name
Modified: grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py
--- grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -104,7 +104,7 @@
     tmp = str(os.getpid())
     if not landsat and not quickbird and not spot:
-	grass.fatal("Please select a flag to specify the satellite sensor")
+	grass.fatal(_("Please select a flag to specify the satellite sensor"))
     #get PAN resolution:
     kv = grass.raster_info(map = pan)
@@ -133,7 +133,7 @@
     # r.mapcalc "brov.blue= 1. * spot.ms.1 / (spot.ms.1 + spot.ms.2 + spot.ms.3) * spot.p"
     # note: for RGB composite then revert brov.red and brov.green!
-    grass.message("Calculating %s.{red,green,blue}: ..." % out)
+    grass.message(_("Calculating %s.{red,green,blue}: ...") % out)
     e = '''eval(k = float("$pan") / ("$ms1" + "$ms2" + "$ms3"))
 	   "$out.red"   = "$ms3" * k
 	   "$out.green" = "$ms2" * k
@@ -154,23 +154,23 @@
     if spot:
         #apect table is nice for SPOT:
-	grass.message("Assigning color tables for SPOT...")
+	grass.message(_("Assigning color tables for SPOT..."))
 	for ch in ['red', 'green', 'blue']:
 	    grass.run_command('r.colors', map = "%s.%s" % (out, ch), col = 'aspect')
-	grass.message("Fixing output names...")
+	grass.message(_("Fixing output names..."))
 	for s, d in [('green','tmp'),('red','green'),('tmp','red')]:
 	    src = "%s.%s" % (out, s)
 	    dst = "%s.%s" % (out, d)
 	    grass.run_command('g.rename', rast = (src, dst), quiet = True)
     else:
 	#aspect table is nice for LANDSAT and QuickBird:
-	grass.message("Assigning color tables for LANDSAT or QuickBird...")
+	grass.message(_("Assigning color tables for LANDSAT or QuickBird..."))
-    grass.message("Following pan-sharpened output maps have been generated:")
+    grass.message(_("Following pan-sharpened output maps have been generated:"))
-	grass.message("%s.%s" % (out, ch))
+	grass.message(_("%s.%s") % (out, ch))
     grass.verbose("To visualize output, run:")
     grass.verbose("g.region -p rast=%s.red" % out)
Modified: grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py
--- grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -78,7 +78,7 @@
     count = len(images)
-    grass.warning('Do not forget to set region properly to cover all images.')
+    grass.warning(_('Do not forget to set region properly to cover all images.'))
     offset = 0
     offsets = []
@@ -89,7 +89,7 @@
 	parms['offset%d' % (n + 1)] = offset
 	offset += get_limit(img) + 1
-    grass.message("Mosaicing %d images..." % count)
+    grass.message(_("Mosaicing %d images...") % count)
     grass.mapcalc("$output = " + make_expression(1, count),
 		  output = output, **parms)
@@ -102,7 +102,7 @@
     p.stdin.close()
     p.wait()
-    grass.message("Ready. File %s created." % output)
+    grass.message(_("Ready. File %s created.") % output)
     # write cmd history:
     grass.raster_history(output)
Modified: grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
--- grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -121,7 +121,7 @@
     #### check for gdalinfo (just to check if installation is complete)
     if not grass.find_program('gdalinfo', ['--version']):
-	grass.fatal("'gdalinfo' not found, install GDAL tools first (http://www.gdal.org)")
+	grass.fatal(_("'gdalinfo' not found, install GDAL tools first (http://www.gdal.org)"))
     pid = str(os.getpid())
     tmpfile = grass.tempfile()
@@ -137,17 +137,17 @@
 	name = spotname
     if not grass.overwrite() and grass.find_file(name)['file']:
-	grass.fatal("<%s> already exists. Aborting." % name)
+	grass.fatal(_("<%s> already exists. Aborting.") % name)
     # still a ZIP file?  (is this portable?? see the r.in.srtm script for ideas)
     if infile.lower().endswith('.zip'):
-	grass.fatal("Please extract %s before import." % infile)
+	grass.fatal(_("Please extract %s before import.") % infile)
     try:
 	p = grass.Popen(['file', '-ib', infile], stdout = grass.PIPE)
 	s = p.communicate()[0]
 	if s == "application/x-zip":
     except:
 	pass
@@ -161,11 +161,11 @@
     create_VRT_file(projfile, vrtfile, infile)
     ## let's import the NDVI map...
-    grass.message("Importing SPOT VGT NDVI map...")
+    grass.message(_("Importing SPOT VGT NDVI map..."))
     if grass.run_command('r.in.gdal', input = vrtfile, output = name) != 0:
-	grass.fatal("An error occurred. Stop.")
+	grass.fatal(_("An error occurred. Stop."))
-    grass.message("Imported SPOT VEGETATION NDVI map <%s>." % name)
+    grass.message(_("Imported SPOT VEGETATION NDVI map <%s>.") % name)
     ## http://www.vgt.vito.be/faq/FAQS/faq19.html
@@ -182,7 +182,7 @@
     grass.run_command('g.region', rast = name, quiet = True)
-    grass.message("Remapping digital numbers to NDVI...")
+    grass.message(_("Remapping digital numbers to NDVI..."))
     tmpname = "%s_%s" % (name, pid)
     grass.mapcalc("$tmpname = 0.004 * $name - 0.1", tmpname = tmpname, name = name)
     grass.run_command('g.remove', rast = name, quiet = True)
@@ -220,7 +220,7 @@
     # A good map threshold: >= 248
     if also:
-	grass.message("Importing SPOT VGT NDVI quality map...")
+	grass.message(_("Importing SPOT VGT NDVI quality map..."))
 	grass.try_remove(vrtfile)
 	qfile = infile.replace('NDV','SM')
 	create_VRT_file(projfile, vrtfile, qfile)
@@ -228,7 +228,7 @@
     ## let's import the SM quality map...
     smfile = name + '.sm'
     if grass.run_command('r.in.gdal', input = vrtfile, output = smfile) != 0:
     # some of the possible values:
     rules = [r + '\n' for r in [
@@ -246,23 +246,23 @@
     grass.write_command('r.colors', map = smfile, rules = '-', stdin = rules)
-    grass.message("Imported SPOT VEGETATION SM quality map <%s>." % smfile)
-    grass.message("Note: A snow map can be extracted by category 252 (d.rast %s cat=252)" % smfile)
+    grass.message(_("Imported SPOT VEGETATION SM quality map <%s>.") % smfile)
+    grass.message(_("Note: A snow map can be extracted by category 252 (d.rast %s cat=252)") % smfile)
     grass.message("")
-    grass.message("Filtering NDVI map by Status Map quality layer...")
+    grass.message(_("Filtering NDVI map by Status Map quality layer..."))
     filtfile = "%s_filt" % name
     grass.mapcalc("$filtfile = if($smfile >= 248, $name, null())",
 		  filtfile = filtfile, smfile = smfile, name = name)
     grass.run_command('r.colors', map = filtfile, color = 'ndvi', quiet = True)
-    grass.message("Filtered SPOT VEGETATION NDVI map <%s>." % filtfile)
+    grass.message(_("Filtered SPOT VEGETATION NDVI map <%s>.") % filtfile)
     grass.raster_history(name)
     grass.raster_history(smfile)
     grass.raster_history(filtfile)
Modified: grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
--- grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -113,7 +113,7 @@
     if not preserve:
 	for i in [red, green, blue]:
-	    grass.message("Processing <%s>..." % i)
+	    grass.message(_("Processing <%s>...") % i)
 	    v0 = get_percentile(i, 2)
 	    v1 = get_percentile(i, brightness)
 	    grass.debug("<%s>:  min=%f   max=%f" % (i, v0, v1))
@@ -122,7 +122,7 @@
 	all_max = 0
 	all_min = 255
Modified: grass/trunk/scripts/i.spectral/i.spectral.py
--- grass/trunk/scripts/i.spectral/i.spectral.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/i.spectral/i.spectral.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -176,14 +176,14 @@
     gnuplot = flags['g']
     if not group and not raster:
-	grass.fatal("Either group= or raster= is required")
+	grass.fatal(_("Either group= or raster= is required"))
     if group and raster:
-	grass.fatal("group= and raster= are mutually exclusive")
+	grass.fatal(_("group= and raster= are mutually exclusive"))
     #check if present
     if gnuplot and not grass.find_program('gnuplot', ['-V']):
-	grass.fatal("gnuplot required, please install first")
+	grass.fatal(_("gnuplot required, please install first"))
     tmp1 = grass.tempfile()
     tmp2 = grass.tempfile()
Modified: grass/trunk/scripts/i.tasscap/i.tasscap.py
--- grass/trunk/scripts/i.tasscap/i.tasscap.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/i.tasscap/i.tasscap.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -125,7 +125,7 @@
 def calcN(options, i, n):
     outpre = options['outprefix']
-    grass.message("LANDSAT-%d..." % n)
+    grass.message(_("LANDSAT-%d...") % n)
     for j, p in enumerate(parms[i]):
 	out = "%s.%d" % (outpre, j + 1)
 	ord = ordinals[j]
@@ -133,7 +133,7 @@
 	    name = ''
 	else:
 	    name = " (%s)" % names[j]
-	grass.message("Calculating %s TC component %s%s ..." % (ord, out, name))
+	grass.message(_("Calculating %s TC component %s%s ...") % (ord, out, name))
 	calc1(out, options, *p)
 def main():
@@ -142,7 +142,7 @@
     flag7 = flags['7']
     if (flag4 and flag5) or (flag4 and flag7) or (flag5 and flag7):
-	grass.fatal("Select only one flag")
+	grass.fatal(_("Select only one flag"))
     if flag4:
 	calcN(options, 0, 4)
@@ -151,9 +151,9 @@
     elif flag7:
 	calcN(options, 2, 7)
     else:
-	grass.fatal("Select LANDSAT satellite by flag!")
+	grass.fatal(_("Select LANDSAT satellite by flag!"))
-    grass.message("Tasseled Cap components calculated.")
+    grass.message(_("Tasseled Cap components calculated."))
Modified: grass/trunk/scripts/m.proj/m.proj.py
--- grass/trunk/scripts/m.proj/m.proj.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/m.proj/m.proj.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -106,20 +106,20 @@
     #### check for cs2cs
     if not grass.find_program('cs2cs'):
-	grass.fatal("cs2cs program not found, install PROJ.4 first: http://proj.maptools.org")
+	grass.fatal(_("cs2cs program not found, install PROJ.4 first: http://proj.maptools.org"))
     #### check for overenthusiasm
     if proj_in and ll_in:
-	grass.fatal("Choose only one input parameter method")
+	grass.fatal(_("Choose only one input parameter method"))
     if proj_out and ll_out:
-	grass.fatal("Choose only one output parameter method")
+	grass.fatal(_("Choose only one output parameter method"))
     if ll_in and ll_out:
-	grass.fatal("Choise only one auto-projection parameter method")
+	grass.fatal(_("Choise only one auto-projection parameter method"))
     if output and not grass.overwrite() and os.path.exists(output):
-	grass.fatal("Output file already exists")
+	grass.fatal(_("Output file already exists"))
     #### parse field separator
     # FIXME: input_x,y needs to split on multiple whitespace between them
@@ -140,11 +140,11 @@
         ifs = ','
     else:
         if len(ifs) > 1:
-            grass.warning("Invalid field separator, using '%s'" % ifs[0])
+            grass.warning(_("Invalid field separator, using '%s'") % ifs[0])
         try:
             ifs = ifs[0]
         except IndexError:
-            grass.fatal("Invalid field separator '%s'" % ifs)
+            grass.fatal(_("Invalid field separator '%s'") % ifs)
     if ofs.lower() == 'space':
         ofs = ' '
@@ -154,17 +154,17 @@
         ofs = ','
     else:
         if len(ofs) > 1:
-            grass.warning("Invalid field separator, using '%s'" % ofs[0])
+            grass.warning(_("Invalid field separator, using '%s'") % ofs[0])
         try:
             ofs = ofs[0]
         except IndexError:
     #### set up projection params
     s = grass.read_command("g.proj", flags='j')
     kv = grass.parse_key_val(s)
     if "XY location" in kv['+proj'] and (ll_in or ll_out):
-	grass.fatal("Unable to project to or from a XY location")
+	grass.fatal(_("Unable to project to or from a XY location"))
     in_proj = None
@@ -198,7 +198,7 @@
 	out_proj = proj_out
     if not out_proj:
-	grass.fatal("Missing output projection parameters ")
+	grass.fatal(_("Missing output projection parameters "))
     out_proj = out_proj.strip()
     grass.verbose("Output parameters: '%s'" % out_proj)
@@ -209,7 +209,7 @@
     else:
 	infile = input
 	if not os.path.exists(infile):
-	    grass.fatal("Unable to read input data")
+	    grass.fatal(_("Unable to read input data"))
 	inf = file(infile)
 	grass.debug("input file=[%s]" % infile)
@@ -253,7 +253,7 @@
     exitcode = p.wait()
     if exitcode != 0:
-	grass.warning("Projection transform probably failed, please investigate")
+	grass.warning(_("Projection transform probably failed, please investigate"))
     if not copy_input:
Modified: grass/trunk/scripts/r.blend/r.blend.py
--- grass/trunk/scripts/r.blend/r.blend.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/r.blend/r.blend.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -67,7 +67,7 @@
 	for ch in ['r','g','b']:
 	    map = '%s.%s' % (output, ch)
 	    if grass.find_file(map, element = 'cell', mapset = mapset)['file']:
-		grass.fatal("Raster map <%s> already exists." % map)
+		grass.fatal(_("Raster map <%s> already exists.") % map)
     percent = int(percent)
     perc_inv = 100 - percent
@@ -75,7 +75,7 @@
     frac1 = percent / 100.0
     frac2 = perc_inv / 100.0
-    grass.message("Calculating the three component maps...")
+    grass.message(_("Calculating the three component maps..."))
     template = string.Template("$$output.$ch = $$frac1 * $ch#$$first + $$frac2 * $ch#$$second")
     cmd = [template.substitute(ch = ch) for ch in ['r','g','b']]
@@ -97,8 +97,8 @@
 			  history = "  %d%% of %s, %d%% of %s" % (percent, first, perc_inv, second))
 	grass.run_command('r.support', map = map, history = os.environ['CMDLINE'])
-    grass.message("Done. Use the following command to visualize the result:")
-    grass.message("d.rgb r=%s.r g=%s.g b=%s.b" % (output, output, output))
+    grass.message(_("Done. Use the following command to visualize the result:"))
+    grass.message(_("d.rgb r=%s.r g=%s.g b=%s.b") % (output, output, output))
Modified: grass/trunk/scripts/r.buffer/r.buffer.py
--- grass/trunk/scripts/r.buffer/r.buffer.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/r.buffer/r.buffer.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -92,7 +92,7 @@
     #check if input file exists
     if not grass.find_file(input)['file']:
-	grass.fatal("<%s> does not exist." % input)
+	grass.fatal(_("<%s> does not exist.") % input)
     scale = scales[units]
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -80,7 +80,7 @@
     mapset = grass.gisenv()['MAPSET']
     unique = str(os.getpid())
@@ -88,7 +88,7 @@
     # check if a MASK is already present:
     usermask = "usermask_mask." + unique
     if grass.find_file('MASK', mapset = mapset)['file']:
-	grass.message("A user raster mask (MASK) is present. Saving it...")
+	grass.message(_("A user raster mask (MASK) is present. Saving it..."))
 	grass.run_command('g.rename', rast = ('MASK',usermask))
     #make a mask of NULL cells
@@ -97,7 +97,7 @@
     # idea: filter all NULLS and grow that area(s) by 3 pixel, then
     # interpolate from these surrounding 3 pixel edge
-    grass.message("Locating and isolating NULL areas...")
+    grass.message(_("Locating and isolating NULL areas..."))
     #creating 0/1 map:
     grass.mapcalc("$tmp1 = if(isnull($input),1,null())",
 		  tmp1 = tmp1, input = input)
@@ -113,65 +113,65 @@
     res = (float(reg['nsres']) + float(reg['ewres'])) * 3 / 2
     if grass.run_command('r.buffer', input = tmp1, distances = res, out = tmp1 + '.buf') != 0:
-	grass.fatal("abandoned. Removing temporary map, restoring user mask if needed:")
+	grass.fatal(_("abandoned. Removing temporary map, restoring user mask if needed:"))
     grass.mapcalc("MASK=if($tmp1.buf==2,1,null())", tmp1 = tmp1)
     # now we only see the outlines of the NULL areas if looking at INPUT.
     # Use this outline (raster border) for interpolating the fill data:
     vecttmp = "vecttmp_fillnulls_" + unique
-    grass.message("Creating interpolation points...")
+    grass.message(_("Creating interpolation points..."))
     if grass.run_command('r.to.vect', input = input, output = vecttmp, feature = 'point'):
-	grass.fatal("abandoned. Removing temporary maps, restoring user mask if needed:")
+	grass.fatal(_("abandoned. Removing temporary maps, restoring user mask if needed:"))
     # count number of points to control segmax parameter for interpolation:
     pointsnumber = grass.vector_info_topo(map = vecttmp)['points']
-    grass.message("Interpolating %d points" % pointsnumber)
+    grass.message(_("Interpolating %d points") % pointsnumber)
     if pointsnumber < 2:
-	grass.fatal("Not sufficient points to interpolate. Maybe no hole(s) to fill in the current map region?")
+	grass.fatal(_("Not sufficient points to interpolate. Maybe no hole(s) to fill in the current map region?"))
-    grass.message("Note: The following warnings may be ignored.")
+    grass.message(_("Note: The following warnings may be ignored."))
     # remove internal MASK first -- WHY???? MN 10/2005
     grass.run_command('g.remove', rast = 'MASK')
     if grass.find_file(usermask, mapset = mapset)['file']:
-	grass.message("Using user mask while interpolating")
+	grass.message(_("Using user mask while interpolating"))
 	maskmap = usermask
     else:
 	maskmap = None
     segmax = 600
     if pointsnumber > segmax:
-	grass.message("Using segmentation for interpolation...")
+	grass.message(_("Using segmentation for interpolation..."))
 	segmax = None
     else:
-	grass.message("Using no segmentation for interpolation as not needed...")
+	grass.message(_("Using no segmentation for interpolation as not needed..."))
     grass.run_command('v.surf.rst', input = vecttmp, elev = tmp1 + '_filled',
 		      zcol = 'value', tension = tension, smooth = smooth,
 		      maskmap = maskmap, segmax = segmax)
-    grass.message("Note: Above warnings may be ignored.")
+    grass.message(_("Note: Above warnings may be ignored."))
     # restoring user's mask, if present:
-	grass.message("Restoring user mask (MASK)...")
+	grass.message(_("Restoring user mask (MASK)..."))
 	grass.run_command('g.rename', rast = (usermask, 'MASK'))
     # patch orig and fill map
-    grass.message("Patching fill data into NULL areas...")
+    grass.message(_("Patching fill data into NULL areas..."))
     # we can use --o here as g.parser already checks on startup
     grass.run_command('r.patch', input = (input,tmp1 + '_filled'), output = output, overwrite = True)
-    grass.message("Filled raster map is: %s" % output)
+    grass.message(_("Filled raster map is: %s") % output)
Modified: grass/trunk/scripts/r.grow/r.grow.py
--- grass/trunk/scripts/r.grow/r.grow.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/r.grow/r.grow.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -119,7 +119,7 @@
     grass.run_command('r.grow.distance',  input = input, metric = metric,
 		      distance = temp_dist, value = temp_val)
Modified: grass/trunk/scripts/r.in.aster/r.in.aster.py
--- grass/trunk/scripts/r.in.aster/r.in.aster.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/r.in.aster/r.in.aster.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -110,7 +110,7 @@
     #check whether gdalwarp is in path and executable
     if not grass.find_program('gdalwarp', ['--version']):
-        grass.fatal("gdalwarp is not in the path and executable")
+        grass.fatal(_("gdalwarp is not in the path and executable"))
     #create temporary file to hold gdalwarp output before importing to GRASS
     tempfile = grass.read_command("g.tempfile", pid = os.getpid()).strip() + '.tif'
@@ -120,7 +120,7 @@
     #currently only runs in projected location
     if "XY location" in proj:
-      grass.fatal("This module needs to be run in a projected location (found: %s)" % proj)
+      grass.fatal(_("This module needs to be run in a projected location (found: %s)") % proj)
     #process list of bands
@@ -138,22 +138,22 @@
                 srcfile = "HDF4_EOS:EOS_SWATH:%s:%s" % (input, dataset)
                 import_aster(proj, srcfile, tempfile, band)
             else:
-                grass.fatal('band %s is not an available Terra/ASTER band' % band)
+                grass.fatal(_('band %s is not an available Terra/ASTER band') % band)
     elif proctype == "DEM":
         srcfile = input
         import_aster(proj, srcfile, tempfile, "DEM")
     #cleanup
-    grass.message("Cleaning up ...")
+    grass.message(_("Cleaning up ..."))
     grass.try_remove(tempfile)
     return
 def import_aster(proj, srcfile, tempfile, band):
     #run gdalwarp with selected options (must be in $PATH)
     #to translate aster image to geotiff
-    grass.message("Georeferencing aster image ...")
+    grass.message(_("Georeferencing aster image ..."))
     grass.debug("gdalwarp -t_srs %s %s %s" % (proj, srcfile, tempfile))
     if platform.system() == "Darwin":
@@ -166,7 +166,7 @@
         return
     #import geotiff to GRASS
-    grass.message("Importing into GRASS ...")
+    grass.message(_("Importing into GRASS ..."))
     outfile = "%s.%s" % (output, band)
     grass.run_command("r.in.gdal", overwrite = flags['o'], input = tempfile, output = outfile)
Modified: grass/trunk/scripts/r.in.srtm/r.in.srtm.py
--- grass/trunk/scripts/r.in.srtm/r.in.srtm.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/r.in.srtm/r.in.srtm.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -136,7 +136,7 @@
     if kv['+proj'] != 'longlat':
-	grass.fatal("This module only operates in LatLong locations")
+	grass.fatal(_("This module only operates in LatLong locations"))
     # use these from now on:
     infile = input
@@ -154,21 +154,21 @@
     if os.path.isfile(zipfile):
         #### check if we have unzip
 	if not grass.find_program('unzip'):
-	    grass.fatal('The "unzip" program is required, please install it first')
+	    grass.fatal(_('The "unzip" program is required, please install it first'))
 	# really a ZIP file?
 	# make it quiet in a safe way (just in case -qq isn't portable)
 	tenv = os.environ.copy()
 	tenv['UNZIP'] = '-qq'
 	if grass.call(['unzip', '-t', zipfile], env = tenv) != 0:
-	    grass.fatal("'%s' does not appear to be a valid zip file." % zipfile)
+	    grass.fatal(_("'%s' does not appear to be a valid zip file.") % zipfile)
 	is_zip = True
     elif os.path.isfile(hgtfile):
 	# try and see if it's already unzipped
 	is_zip = False
     else:
-	grass.fatal("File '%s' or '%s' not found" % (zipfile, hgtfile))
+	grass.fatal(_("File '%s' or '%s' not found") % (zipfile, hgtfile))
     #make a temporary directory
     tmpdir = grass.tempfile()
@@ -190,11 +190,11 @@
     if is_zip:
         #unzip & rename data file:
-	grass.message("Extracting '%s'..." % infile)
+	grass.message(_("Extracting '%s'...") % infile)
 	if grass.call(['unzip', zipfile], env = tenv) != 0:
-	    grass.fatal("Unable to unzip file.")
+	    grass.fatal(_("Unable to unzip file."))
-    grass.message("Converting input file to BIL...")
+    grass.message(_("Converting input file to BIL..."))
     os.rename(hgtfile, bilfile)
     north = tile[0]
@@ -218,7 +218,7 @@
     if not one:
 	tmpl = tmpl3sec
     else:
-	grass.message("Attempting to import 1-arcsec data.")
+	grass.message(_("Attempting to import 1-arcsec data."))
 	tmpl = tmpl1sec
     header = tmpl % (ulxmap, ulymap)
@@ -234,7 +234,7 @@
     outf.close()
     if grass.run_command('r.in.gdal', input = bilfile, out = tileout) != 0:
-	grass.fatal("Unable to import data")
+	grass.fatal(_("Unable to import data"))
     # nice color table
     grass.run_command('r.colors', map = tileout, color = 'srtm')
@@ -242,8 +242,8 @@
     grass.raster_history(tileout)
-    grass.message("Done: generated map " + tileout)
-    grass.message("(Note: Holes in the data can be closed with 'r.fillnulls' using splines)")
+    grass.message(_("Done: generated map ") + tileout)
+    grass.message(_("(Note: Holes in the data can be closed with 'r.fillnulls' using splines)"))
Modified: grass/trunk/scripts/r.in.wms/gdalwarp.py
--- grass/trunk/scripts/r.in.wms/gdalwarp.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/r.in.wms/gdalwarp.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -54,9 +54,9 @@
         for input in self.options['input'].split(','):
             tmptilename = self.options['output'] + '_tile_' + str(tiler)
             if not os.path.exists(input):
-                grass.warning("Missing input '%s'" % input)
+                grass.warning(_("Missing input '%s'") % input)
                 continue
-            grass.info("Importing tile '%s'..." % os.path.basename(input))
+            grass.info(_("Importing tile '%s'...") % os.path.basename(input))
             if self.flags['p']:
                 self.nowarp_import(input, tmptilename)
             else:
@@ -66,7 +66,7 @@
             tiler += 1
         if tiler < 1:
-            grass.message("Nothing imported")
+            grass.message(_("Nothing imported"))
             return 0
         # if there's more than one tile patch them together, otherwise
@@ -81,14 +81,14 @@
                     if grass.run_command('g.rename',
                                          quiet = True,
                                          rast = ffile + ',' + tfile) != 0:
-                        grass.fatal('g.rename failed')
+                        grass.fatal(_('g.rename failed'))
             else: # single-band, single-tile
                 ffile = self.options['output'] + '_tile_0' # + sfx ?
                 tfile = self.options['output'] # + sfx ?
                                      quiet = True,
         else:
             # patch together each channel
             grass.debug('suffixes: %s' % ','.join(suffixes))
@@ -97,21 +97,21 @@
                 for suffix in suffixes:
                     suffix = suffix.replace('.', '_')
                     # patch these together (using nulls only)
-                    grass.message("Patching '%s' channel..." % suffix)
+                    grass.message(_("Patching '%s' channel...") % suffix)
                     if grass.run_command('r.patch',
                                          quiet = True,
                                          input = patches, # ???
                                          output = self.options['output'] + suffix) != 0:
-                        grass.fatal('r.patch failed')
+                        grass.fatal(_('r.patch failed'))
                     # remove the temporary patches we made
                     if grass.run_command('g.remove',
                                          quiet = True,
                                          rast = patches) != 0:
-                        grass.fatal('g.remove failed')
+                        grass.fatal(_('g.remove failed'))
             else:
                 # single-band data
-                grass.info("Patching tiles (this may take some time)...")
+                grass.info(_("Patching tiles (this may take some time)..."))
                 grass.debug("patch list = %s" % ','.join(maplist))
                 # HACK: for 8bit PNG, GIF all the different tiles can have
@@ -128,22 +128,22 @@
                         if grass.run_command('r.mapcalc',
                                              quiet = True,
                                              expression = '%s = %s#%s' % (outmap, color, map)) != 0:
-                            grass.fatal('r.mapcalc failed')
+                            grass.fatal(_('r.mapcalc failed'))
                         if grass.run_command('r.colors',
                                              quiet = True,
                                              map = outmap,
                                              color = 'grey255') != 0:
-                            grass.fatal('r.colors failed')
+                            grass.fatal(_('r.colors failed'))
                         if grass.run_command('r.null',
                                              quiet = True,
                                              map = outmap,
                                              setnull = 255) != 0:
-                            grass.fatal('r.null failed')
+                            grass.fatal(_('r.null failed'))
                                              input = ','.join(maplist_color),
                                              output = outmap + '_all') != 0:
                 if grass.run_command('r.composite',
                                      quiet = True,
@@ -151,13 +151,13 @@
                                      green = map + '_g_all',
                                      blue = map + '_b_all',
                                      output = self.options['output']) != 0:
-                    grass.fatal('r.composite failed')
+                    grass.fatal(_('r.composite failed'))
                 if grass.run_command('g.mremove',
                                      quiet = True,
                                      flags = 'f',
                                      rast = map + '*') != 0:
         # there's already a no suffix, can't make colors
         # can only go up from here ;)
@@ -168,14 +168,14 @@
         # make a composite image if asked for and colors exist
         if colors == 3 and self.flags['c']:
-            grass.message("Building color image <%s>..." % self.options['output'])
+            grass.message(_("Building color image <%s>...") % self.options['output'])
                                  quiet = True,
                                  red = self.options['output'] + '.red',
                                  green = self.options['output'] + '.green',
                                  blue = self.options['output'] + '.blue',
         return 0
@@ -189,7 +189,7 @@
                                    quiet = True,
                                    flags = 'jf').rstrip('\n')
         if not t_srs:
-            grass.fatal('g.proj failed')
+            grass.fatal(_('g.proj failed'))
         grass.debug("gdalwarp -s_srs '%s' -t_srs '%s' -r %s %s %s %s" % \
                         (self.options['srs'], t_srs,
@@ -213,16 +213,16 @@
         ps.wait()
         if ps.returncode != 0 or \
                 not os.path.exists(warpfile):
-            grass.fatal('gdalwarp failed')
+            grass.fatal(_('gdalwarp failed'))
         # import it into a temporary map
-        grass.info('Importing raster map...')
+        grass.info(_('Importing raster map...'))
                              quiet = True,
                              flags = self.gdal_flags,
                              input = warpfile,
                              output = tmpmapname) != 0:
-            grass.fatal('r.in.gdal failed')
+            grass.fatal(_('r.in.gdal failed'))
         os.remove(warpfile)
@@ -272,20 +272,20 @@
                                      quiet = True,
                                      expression = "%s%s = if(%s, %s%s, null())" % \
                                          (map, sfx, alphalayer, tmpmapname, sfx)) != 0:
             else:
                 if grass.run_command('g.copy',
                                      quiet = True,
                                      rast = "%s%s,%s%s" % \
                                          (tmpmapname, suffix, map, suffix)) != 0:
-                    grass.fatal('g.copy failed')
+                    grass.fatal(_('g.copy failed'))
             # copy the color tables
                                  quiet = True,
                                  map = map + suffix,
                                  rast = tmpmapname + suffix) != 0:
             # make patch lists
@@ -302,19 +302,19 @@
                                  quiet = True,
                                  expression = "%s = %s" % \
                                      (map, tmpmapname)) != 0:
                                  quiet = True,
                                  map = map,
                                  rast = tmpmapname) != 0:
         # remove the old channels
                              quiet = True,
                              rast = ','.join(channel_list)) != 0:
     def nowarp_import(self, file, map):
         """Import raster file into GRASS"""
@@ -323,7 +323,7 @@
                              flags = 'o' + self.gdal_flags,
                              input = file,
                              output = map) != 0:
         # get a list of channels:
         pattern = map + '*'
Modified: grass/trunk/scripts/r.in.wms/r.in.wms.py
--- grass/trunk/scripts/r.in.wms/r.in.wms.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/r.in.wms/r.in.wms.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -206,23 +206,23 @@
         else:
             cap_file = urllib.urlopen(url, options['mapserver'] + '?' + qstring)
     except IOError:
-        grass.fatal("Unable to get capabilities of '%s'" % options['mapserver'])
+        grass.fatal(_("Unable to get capabilities of '%s'") % options['mapserver'])
     # check DOCTYPE first
     if options['cap_file']:
         if headers['content-type'] != 'application/vnd.ogc.wms_xml':
-            grass.fatal("Unable to get capabilities: %s" % url)
+            grass.fatal(_("Unable to get capabilities: %s") % url)
     else:
         if cap_file.info()['content-type'] != 'application/vnd.ogc.wms_xml':
     # parse file with sax
     cap_xml = wms_parse.ProcessCapFile()
     try:
         xml.sax.parse(cap_file, cap_xml)
     except xml.sax.SAXParseException, err:
-        grass.fatal("Reading capabilities failed. "
-                    "Unable to parse XML document: %s" % err)
+        grass.fatal(_("Reading capabilities failed. "
+                      "Unable to parse XML document: %s") % err)
     cap_xml.getLayers()
@@ -232,10 +232,10 @@
         list_layers()
         return 0
     elif not options['output']:
-        grass.fatal("No output map specified")
+        grass.fatal(_("No output map specified"))
     if options['cap_file'] and not flags['l']:
-        grass.warning("Option <cap_file> ignored. It requires '-l' flag.")
+        grass.warning(_("Option <cap_file> ignored. It requires '-l' flag."))
     # set directory for download
     if not options['folder']:
@@ -244,20 +244,20 @@
     # region settings
     if options['region']:
         if not grass.find_file(name = options['region'], element = 'windows')['name']:
-            grass.fatal("Region <%s> not found" % options['region'])
+            grass.fatal(_("Region <%s> not found") % options['region'])
     request = wms_request.WMSRequest(flags, options)
     if not flags['d']:
         # request data first
         request.GetTiles()
     if not request:
-        grass.fatal("WMS request failed")
+        grass.fatal(_("WMS request failed"))
     if flags['a']:
         # use GDAL WMS driver
         ### TODO: use GDAL Python bindings instead
         if not wms_gdal.checkGdalWms():
-            grass.fatal("GDAL WMS driver is not available")
+            grass.fatal(_("GDAL WMS driver is not available"))
         # create local service description XML file
         gdalWms = wms_gdal.GdalWms(options, request)
Modified: grass/trunk/scripts/r.in.wms/wms_download.py
--- grass/trunk/scripts/r.in.wms/wms_download.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/r.in.wms/wms_download.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -27,7 +27,7 @@
         self.options = options
     def GetTiles(self, requests):
-        grass.message("Downloading tiles...")
+        grass.message(_("Downloading tiles..."))
         i = 0
         for item in requests:
@@ -40,30 +40,30 @@
     def GetData(self, idx, server, query, output):
         """Download data"""
-        grass.message("Downloading data (tile %d)..." % idx)
+        grass.message(_("Downloading data (tile %d)...") % idx)
         grass.verbose("Requesting data: %s" % self.options['mapserver'])
         if not self.flags['g']: # -> post
             try:
                 urllib.urlretrieve(server, output, data = query)
             except IOError:
-                grass.fatal("Failed while downloading the data")
+                grass.fatal(_("Failed while downloading the data"))
             if not os.path.exists(output):
             # work-around for brain-dead ArcIMS servers which want POST-data as part of the GET URL
             #   (this is technically allowed by OGC WMS def v1.3.0 Sec6.3.4)
             if os.path.getsize(output) == 0:
-                grass.warning("Downloaded image file is empty -- trying another method")
+                grass.warning(_("Downloaded image file is empty -- trying another method"))
                 self.flags['g'] = True
         if self.flags['g']: # -> get
             try:
                 urllib.urlretrieve(server + '?' + query, output, data = None)
             except IOError:
             if not os.path.exists(output) or os.path.getsize(output) == 0:
Modified: grass/trunk/scripts/r.in.wms/wms_request.py
--- grass/trunk/scripts/r.in.wms/wms_request.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/r.in.wms/wms_request.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -36,7 +36,7 @@
         if self.flags['p']:
             self.proj_srs = grass.read_command('g.proj', flags='j')
             if not self.proj_srs:
             self.srs_scale = int(grass.parse_key_val(proj_srs['+to_meter']))
         else:
             self.proj_srs = '+init=%s' % self.options['srs'].lower()
@@ -76,7 +76,7 @@
             self.worldfile   = ".gfw"
             self.file_extent = ".gif"
         else:
-            grass.fatal("Uknown image format '%s'" % format_opt)
+            grass.fatal(_("Uknown image format '%s'") % format_opt)
         # create download directory
         if not os.path.exists(self.options['folder']):
@@ -106,7 +106,7 @@
         return ret
     def GetTiles(self):
-        grass.message("Calculating tiles...")
+        grass.message(_("Calculating tiles..."))
         tiles = grass.read_command('r.tileset',
                                 quiet = True,
                                 flags = 'g',
@@ -117,7 +117,7 @@
                                 maxrows = int(self.options['maxrows']),
                                 **self.tileset_options)
         if not tiles:
-            grass.fatal("r.tileset failed")
+            grass.fatal(_("r.tileset failed"))
         tiles = tiles.splitlines()
         if self.flags['c']:
@@ -173,7 +173,7 @@
             i += 1
         rf.close()
-        grass.message("Done: requesting %d tiles" % len(tiles))
+        grass.message(_("Done: requesting %d tiles") % len(tiles))
         if len(tiles) > 200:
 	    grass.warning("Proceed with care. This number of tiles may \
 	      exceed the maximum command line arguments available from \
Modified: grass/trunk/scripts/r.mask/r.mask.py
--- grass/trunk/scripts/r.mask/r.mask.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/r.mask/r.mask.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -58,7 +58,7 @@
     invert = flags['i']
     if not remove and not input:
-	grass.fatal("Required parameter <input> not set")
+	grass.fatal(_("Required parameter <input> not set"))
     exists = bool(grass.find_file('MASK', element = 'cell', mapset = mapset)['file'])
@@ -66,12 +66,12 @@
     if remove:
 	if exists:
-	    grass.message("Raster MASK removed")
+	    grass.message(_("Raster MASK removed"))
  	else:
-	    grass.warning("No existing MASK to remove")
+	    grass.warning(_("No existing MASK to remove"))
     else:
 	if exists and not grass.overwrite():
-	    grass.fatal("MASK already found in current mapset. Delete first or overwrite")
+	    grass.fatal(_("MASK already found in current mapset. Delete first or overwrite"))
 	p = grass.feed_command('r.reclass', input = input, output = 'MASK', overwrite = True)
 	p.stdin.write("%s = 1" % maskcats)
@@ -84,11 +84,11 @@
 	    grass.run_command('g.rename', rast = ('MASK',tmp), quiet = True)
 	    grass.mapcalc("MASK=if(isnull($tmp),1,null())", tmp = tmp)
 	    grass.run_command('g.remove', rast = tmp, quiet = True)
-	    grass.message("Inverted MASK created.")
+	    grass.message(_("Inverted MASK created."))
 	else:
-	    grass.message("MASK created.")
+	    grass.message(_("MASK created."))
-        grass.message("All subsequent raster operations will be limited to MASK area" +
+        grass.message(_("All subsequent raster operations will be limited to MASK area") +
 		      "Removing or renaming raster file named MASK will" +
 		      "restore raster operations to normal")
Modified: grass/trunk/scripts/r.plane/r.plane.py
--- grass/trunk/scripts/r.plane/r.plane.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/r.plane/r.plane.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -89,10 +89,10 @@
     ### test input values ###
     if abs(dip) >= 90:
-	grass.fatal("dip must be between -90 and 90.")
+	grass.fatal(_("dip must be between -90 and 90."))
     if az < 0 or az >= 360:
-	grass.fatal("azimuth must be between 0 and 360")
+	grass.fatal(_("azimuth must be between 0 and 360"))
     ### now the actual algorithm
     az_r  = math.radians(-az)
@@ -116,7 +116,7 @@
     t = string.Template("Raster map <$name> generated by r.plane " +
 			"at point $ea E, $no N, elevation $el with dip = $dip degrees and " +
 			"aspect = $az degrees ccw from north.")
Modified: grass/trunk/scripts/r.reclass.area/r.reclass.area.py
--- grass/trunk/scripts/r.reclass.area/r.reclass.area.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/r.reclass.area/r.reclass.area.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -68,34 +68,34 @@
     kv = grass.parse_key_val(s, sep = ':')
     s = kv['projection'].strip().split()
     if s == '0':
-	grass.fatal("xy-locations are not supported")
-	grass.fatal("Need projected data with grids in meters")
+	grass.fatal(_("xy-locations are not supported"))
+	grass.fatal(_("Need projected data with grids in meters"))
     if not lesser and not greater:
-	grass.fatal("You have to specify either lesser= or greater=")
+	grass.fatal(_("You have to specify either lesser= or greater="))
     if lesser and greater:
-	grass.fatal("lesser= and greater= are mutually exclusive")
+	grass.fatal(_("lesser= and greater= are mutually exclusive"))
     if lesser:
 	limit = float(lesser)
     if greater:
 	limit = float(greater)
     if not grass.find_file(infile)['name']:
-	grass.fatal("Raster map <%s> not found" % infile)
+	grass.fatal(_("Raster map <%s> not found") % infile)
     clumpfile = "%s.clump.%s" % (infile.split('@')[0], outfile)
     if not grass.overwrite():
 	if grass.find_file(clumpfile)['name']:
-	    grass.fatal("Temporary raster map <%s> exists" % clumpfile)
+	    grass.fatal(_("Temporary raster map <%s> exists") % clumpfile)
-    grass.message("Generating a clumped raster file ...")
+    grass.message(_("Generating a clumped raster file ..."))
     grass.run_command('r.clump', input = infile, output = clumpfile)
     if lesser:
-	grass.message("Generating a reclass map with area size less than or equal to %f hectares..." % limit)
+	grass.message(_("Generating a reclass map with area size less than or equal to %f hectares...") % limit)
     else:
-	grass.message("Generating a reclass map with area size greater than or equal to %f hectares..." % limit)
+	grass.message(_("Generating a reclass map with area size greater than or equal to %f hectares...") % limit)
     recfile = outfile + '.recl'
@@ -116,7 +116,7 @@
     p2.stdin.close()
     p2.wait()
-    grass.message("Generating output raster map <$outfile>..." % outfile)
+    grass.message(_("Generating output raster map <$outfile>...") % outfile)
     grass.mapcalc("$outfile = $recfile", outfile = outfile, recfile = recfile)
     grass.run_command('g.remove', rast = [recfile, clumpfile], quiet = True)
Modified: grass/trunk/scripts/r.regression.line/r.regression.line.py
--- grass/trunk/scripts/r.regression.line/r.regression.line.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/r.regression.line/r.regression.line.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -64,9 +64,9 @@
     output = options['output']
     if not grass.find_file(map1)['name']:
-	grass.fatal("Raster map <%s> not found" % map1)
+	grass.fatal(_("Raster map <%s> not found") % map1)
     if not grass.find_file(map2)['name']:
-	grass.fatal("Raster map <%s> not found" % map2)
+	grass.fatal(_("Raster map <%s> not found") % map2)
     #calculate regression equation
     if slow:
Modified: grass/trunk/scripts/r.rgb/r.rgb.py
--- grass/trunk/scripts/r.rgb/r.rgb.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/r.rgb/r.rgb.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -41,7 +41,7 @@
-	grass.fatal("Map <%s> not found." % input)
+	grass.fatal(_("Map <%s> not found.") % input)
     if not output:
 	output = input
Modified: grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py
--- grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -121,10 +121,10 @@
     units = options['units']
     if input == output:
-	grass.fatal("Input elevation map and output relief map must have different names")
+	grass.fatal(_("Input elevation map and output relief map must have different names"))
     elev = input
@@ -152,7 +152,7 @@
     #  this seems to be backwards, but in fact it works so leave it.
     az = float(azimuth) - 90
-    grass.message("Calculating shading, please stand by.")
+    grass.message(_("Calculating shading, please stand by."))
 	r'''eval( \
@@ -173,7 +173,7 @@
     p.stdin.close()
     if p.wait() != 0:
-	grass.fatal("In calculation, script aborted.")
+	grass.fatal(_("In calculation, script aborted."))
     grass.run_command('r.colors', map = elevshade, color = 'grey')
@@ -187,9 +187,9 @@
 	grass.run_command('r.support', map = elevshade, history = "  units=%s (adjusted scale=%s)" % (units, scale))
     if output:
-	grass.message("Shaded relief map created and named <%s>." % elevshade)
+	grass.message(_("Shaded relief map created and named <%s>.") % elevshade)
     else:
-	grass.message("Shaded relief map created and named <%s>. Consider renaming." % elevshade)
+	grass.message(_("Shaded relief map created and named <%s>. Consider renaming.") % elevshade)
     grass.raster_history(elevshade)
Modified: grass/trunk/scripts/r.tileset/r.tileset.py
--- grass/trunk/scripts/r.tileset/r.tileset.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/r.tileset/r.tileset.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -239,7 +239,7 @@
                                        quiet = True,
         if not dest_proj:
     else:
         dest_proj = options['destproj']
     grass.debug("Getting destination projection -> '%s'" % dest_proj)
@@ -250,7 +250,7 @@
                                  quiet = True,
                                  flags = 'j')
         if not ret:
         dest_scale = ret['+to_meter'].strip()
     else:
@@ -319,7 +319,7 @@
     # I'm going to make the numbers all simpler and add this extra cell to
     # every tile.
-    grass.message('Computing tiling...')
+    grass.message(_('Computing tiling...'))
     tiles = [-1, -1]
     tile_base_size = [-1, -1]
     tiles_extra_1 = [-1, -1]
Modified: grass/trunk/scripts/v.build.all/v.build.all.py
--- grass/trunk/scripts/v.build.all/v.build.all.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.build.all/v.build.all.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -26,8 +26,8 @@
     ret = 0
     for vect in grass.list_grouped('vect')[mapset]:
 	map = "%s@%s" % (vect, mapset)
-	grass.message("Build topology for vector '%s'" % map)
-	grass.message("v.build map=%s" % map)
+	grass.message(_("Build topology for vector '%s'") % map)
+	grass.message(_("v.build map=%s") % map)
 	if grass.run_command("v.build", map = map) != 0:
 	    ret = 1
     sys.exit(ret)
Modified: grass/trunk/scripts/v.centroids/v.centroids.py
--- grass/trunk/scripts/v.centroids/v.centroids.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.centroids/v.centroids.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -79,7 +79,7 @@
     if options['option'] == 'add':
         num_bound = grass.vector_info_topo(map = options['input'])['boundaries']
 	if num_bound == 0:
-	    grass.fatal("Input vector map contains no boundaries.")
+	    grass.fatal(_("Input vector map contains no boundaries."))
 	grass.exec_command("v.category", type = 'area', **options)
Modified: grass/trunk/scripts/v.colors/v.colors.py
--- grass/trunk/scripts/v.colors/v.colors.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.colors/v.colors.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -150,7 +150,7 @@
     else:
 	vect_mapset = vect_mapset[0]
     if not kv['file'] or vect_mapset != mapset:
-	grass.fatal("Vector map <%s> not found in current mapset" % map)
+	grass.fatal(_("Vector map <%s> not found in current mapset") % map)
     vector = map_split[0]
@@ -160,7 +160,7 @@
 	if options[opt]:
 	    ctest += 1
     if ctest != 1:
-	grass.fatal("Pick one of color, rules, or raster options")
+	grass.fatal(_("Pick one of color, rules, or raster options"))
     if color:
 	#### check the color rule is valid
@@ -171,19 +171,19 @@
 			("Valid options are: %s" % ' '.join(color_opts)))
     elif raster:
 	if not grass.find_file(raster)['name']:
-	    grass.fatal("Unable to open raster map <%s>" % raster)
+	    grass.fatal(_("Unable to open raster map <%s>") % raster)
     elif rules:
 	if not os.access(rules, os.R_OK):
-	    grass.fatal("Unable to read color rules file <%s>" % rules)
+	    grass.fatal(_("Unable to read color rules file <%s>") % rules)
     #### column checks
     # check input data column
     cols = grass.vector_columns(map, layer = layer)
-	grass.fatal("Column <%s> not found" % column)
+	grass.fatal(_("Column <%s> not found") % column)
     ncolumn_type = cols[column]
     if ncolumn_type not in ["INTEGER", "DOUBLE PRECISION"]:
-	grass.fatal("Column <%s> is not numeric" % column)
+	grass.fatal(_("Column <%s> is not numeric") % column)
     #g.message "column <$GIS_OPT_COLUMN> is type [$NCOLUMN_TYPE]"
@@ -191,17 +191,17 @@
     table = grass.vector_db(map)[layer]['table']
     if rgb_column not in cols:
         # RGB Column not found, create it
-	grass.message("Creating column <%s> ..." % rgb_column)
+	grass.message(_("Creating column <%s> ...") % rgb_column)
 	if 0 != grass.run_command('v.db.addcol', map = map, layer = layer, column = "%s varchar(11)" % rgb_column):
-	    grass.fatal("Creating color column")
+	    grass.fatal(_("Creating color column"))
     else:
 	column_type = cols[rgb_column]
 	if column_type not in ["CHARACTER", "TEXT"]:
-	    grass.fatal("Column <%s> is not of compatible type (found %s)" % (rgb_column, column_type))
+	    grass.fatal(_("Column <%s> is not of compatible type (found %s)") % (rgb_column, column_type))
 	else:
 	    num_chars = dict([(v[0], int(v[2])) for v in grass.db_describe(table)['cols']])[rgb_column]
 	    if num_chars < 11:
-		grass.fatal("Color column <%s> is not wide enough (needs 11 characters)", rgb_column)
+		grass.fatal(_("Color column <%s> is not wide enough (needs 11 characters)"), rgb_column)
     cvals = grass.vector_db_select(map, layer = layer, column = column)['values'].values()
@@ -210,15 +210,15 @@
 	#order doesn't matter
 	vals = range.split(',')
     else:
-	grass.message("Scanning values ...")
+	grass.message(_("Scanning values ..."))
 	vals = [float(x[0]) for x in cvals]
     minval = min(vals)
     maxval = max(vals)
-    grass.message(" min=[%s]  max=[$%s]" % (minval, maxval))
+    grass.message(_(" min=[%s]  max=[$%s]") % (minval, maxval))
     if not minval or not maxval:
-	grass.fatal("Scanning data range")
+	grass.fatal(_("Scanning data range"))
     # setup internal region
     use_temp_region()
@@ -251,7 +251,7 @@
     # calculate colors and write SQL command file
-    grass.message("Looking up colors ...")
+    grass.message(_("Looking up colors ..."))
     f = open(tmp, 'w')
     p = grass.feed_command('r.what.color', flags = 'i', input = tmp_colr, stdout = f)
@@ -281,18 +281,18 @@
     fo.close()
     if not found:
-	grass.fatal("No values found in color range")
+	grass.fatal(_("No values found in color range"))
     # apply SQL commands to update the table with values
-    grass.message("Writing %s colors ..." % found)
+    grass.message(_("Writing %s colors ...") % found)
     # less "$TMP"
     if 0 != grass.run_command('db.execute', input = tmp_vcol):
-	grass.fatal("Processing SQL transaction")
+	grass.fatal(_("Processing SQL transaction"))
     if flags['s']:
 	vcolors = "vcolors_%d" % pid
 	grass.run_command('g.rename', rast = (tmp_colr, vcolors))
-	grass.message("Raster map containing color rules saved to <%s>" % vcolors)
+	grass.message(_("Raster map containing color rules saved to <%s>") % vcolors)
 	# TODO save full v.colors command line history
 	grass.run_command('r.support', map = vcolors,
 			  history = "",
Modified: grass/trunk/scripts/v.convert.all/v.convert.all.py
--- grass/trunk/scripts/v.convert.all/v.convert.all.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.convert.all/v.convert.all.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -34,14 +34,14 @@
 	if grass.run_command("v.convert", input = inmap, output = outmap) == 0:
 	    converted += 1
 	else:
-	    grass.warning("Error converting map %s to %s" % (inmap, outmap))
+	    grass.warning(_("Error converting map %s to %s") % (inmap, outmap))
 	    ret = 1
 	if converted < 1:
-	    grass.warning("No vector maps converted as no old vector maps present in current mapset.")
+	    grass.warning(_("No vector maps converted as no old vector maps present in current mapset."))
 	else:
-	    grass.message("Total %u vector maps in current mapset converted." % converted)
-	    grass.message("Please verify new vector map(s) before deleting old vector map(s).")
+	    grass.message(_("Total %u vector maps in current mapset converted.") % converted)
+	    grass.message(_("Please verify new vector map(s) before deleting old vector map(s)."))
 	sys.exit(ret)
Modified: grass/trunk/scripts/v.db.addcol/v.db.addcol.py
--- grass/trunk/scripts/v.db.addcol/v.db.addcol.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.db.addcol/v.db.addcol.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -62,12 +62,12 @@
     exists = bool(grass.find_file(map, element = 'vector', mapset = mapset)['file'])
     if not exists:
     try:
         f = grass.vector_db(map)[int(layer)]
     except KeyError:
-	grass.fatal("There is no table connected to this map. Run v.db.connect or v.db.addtable first.")
+	grass.fatal(_("There is no table connected to this map. Run v.db.connect or v.db.addtable first."))
     table = f['table']
     database = f['database']
     driver = f['driver']
@@ -76,13 +76,13 @@
     for col in columns:
 	if not col:
-	    grass.fatal("There is an empty column. Did you leave a trailing comma?")
+	    grass.fatal(_("There is an empty column. Did you leave a trailing comma?"))
 	p.stdin.write("ALTER TABLE %s ADD COLUMN %s" % (table, col))
 	p.stdin.close()
 	if p.wait() != 0:
-	    grass.fatal("Unable to add column <%s>." % col)
+	    grass.fatal(_("Unable to add column <%s>.") % col)
     grass.vector_history(map)
Modified: grass/trunk/scripts/v.db.addtable/v.db.addtable.py
--- grass/trunk/scripts/v.db.addtable/v.db.addtable.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.db.addtable/v.db.addtable.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -65,20 +65,20 @@
     # does map exist in CURRENT mapset?
     if not grass.find_file(map, element = 'vector', mapset = mapset)['file']:
     map_name = map.split('@')[0]
     if not table:
 	if layer == '1':
-	    grass.message("Using vector map name as table name: " + map_name)
+	    grass.message(_("Using vector map name as table name: ") + map_name)
 	    table = map_name
 	else:
 	    # to avoid tables with identical names on higher layers
-	    grass.message("Using vector map name extended by layer number as table name: %s_%s" % (map_name, layer))
+	    grass.message(_("Using vector map name extended by layer number as table name: %s_%s") % (map_name, layer))
 	    table = "%s_%s" % (map_name, layer)
     else:
-	grass.message("Using user specified table name: " + table)
+	grass.message(_("Using user specified table name: ") + table)
     # check if DB parameters are set, and if not set them.
     grass.run_command('db.connect', flags = 'c')
@@ -92,7 +92,7 @@
     else:
 	# nothing defined
-	grass.message("Creating new DB connection based on default mapset settings...")
+	grass.message(_("Creating new DB connection based on default mapset settings..."))
 	kv = grass.db_connection()
 	database = kv['database']
 	driver = kv['driver']
@@ -100,7 +100,7 @@
     # maybe there is already a table linked to the selected layer?
     try:
         grass.vector_db(map, stderr = nuldev)[int(layer)]
-	grass.fatal("There is already a table linked to layer <%s>" % layer)
+	grass.fatal(_("There is already a table linked to layer <%s>") % layer)
     except KeyError:
         pass
@@ -121,21 +121,21 @@
 	    column_def.append("cat integer")
 	column_def = ','.join(column_def)
-	grass.message("Creating table with columns (%s)" % column_def)
+	grass.message(_("Creating table with columns (%s)") % column_def)
 	# take care if the DBF directory is missing (heck, the DBF driver should take care!)
 	if driver == "dbf":
 	    env = grass.gisenv()
 	    path = os.path.join(env['GISDBASE'], env['LOCATION_NAME'], env['MAPSET'], "dbf")
 	    if not os.path.isdir(path):
-		grass.message("Creating missing DBF directory in mapset <%s>" % env['MAPSET'])
+		grass.message(_("Creating missing DBF directory in mapset <%s>") % env['MAPSET'])
 		os.mkdir(path)
 		grass.run_command('db.connect', driver = dbf, database = '$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/')
     sql = "CREATE TABLE %s (%s)" % (table, column_def)
     if grass.write_command('db.execute', input = '-', database = database, driver = driver, stdin = sql) != 0:
-	grass.fatal("Cannot continue.")
+	grass.fatal(_("Cannot continue."))
     # connect the map to the DB:
     grass.run_command('v.db.connect', map = map, database = database, driver = driver,
@@ -147,7 +147,7 @@
                       option = 'cat', column = 'cat', qlayer = layer)
     if grass.verbosity() > 0:
-	grass.message("Current attribute table links:")
+	grass.message(_("Current attribute table links:"))
 	grass.run_command('v.db.connect', flags = 'p', map = map)
Modified: grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py
--- grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -63,7 +63,7 @@
     if not grass.find_file(map, element = 'vector', mapset = mapset):
     f = grass.vector_layer_db(map, layer)
@@ -73,13 +73,13 @@
     if not table:
-	grass.fatal("There is no table connected to the input vector map Cannot delete any column")
+	grass.fatal(_("There is no table connected to the input vector map Cannot delete any column"))
     if column == keycol:
-	grass.fatal("Cannot delete <$col> column as it is needed to keep table <%s> connected to the input vector map <%s>" % (table, map))
+	grass.fatal(_("Cannot delete <$col> column as it is needed to keep table <%s> connected to the input vector map <%s>") % (table, map))
     if not grass.vector_columns(map, layer).has_key(column):
-	grass.fatal("Column <%s> not found in table <%s>" % (column, table))
+	grass.fatal(_("Column <%s> not found in table <%s>") % (column, table))
     if driver == "sqlite":
 	#echo "Using special trick for SQLite"
@@ -112,7 +112,7 @@
 			   stdin = sql) != 0:
-	grass.fatal("Cannot continue (problem deleting column).")
+	grass.fatal(_("Cannot continue (problem deleting column)."))
Modified: grass/trunk/scripts/v.db.droptable/v.db.droptable.py
--- grass/trunk/scripts/v.db.droptable/v.db.droptable.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.db.droptable/v.db.droptable.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -63,39 +63,39 @@
 	# Removing table name connected to selected layer
 	table = f['table']
 	if not table:
-	    grass.fatal("No table assigned to layer <%s>" % layer)
+	    grass.fatal(_("No table assigned to layer <%s>") % layer)
     else:
 	# Removing user specified table
 	existingtable = f['table']
 	if existingtable != table:
-	    grass.fatal("User selected table <%s> but the table <%s> is linked to layer <%s>"
+	    grass.fatal(_("User selected table <%s> but the table <%s> is linked to layer <%s>")
 			% (table, existingtable, layer))
     # we use the DB settings selected layer
-    grass.message("Removing table <%s> linked to layer <%s> of vector map <%s>"
+    grass.message(_("Removing table <%s> linked to layer <%s> of vector map <%s>")
 		  % (table, layer, map))
     if not force:
-	grass.message("You must use the -f (force) flag to actually remove the table. Exiting.")
-	grass.message("Leaving map/table unchanged.")
+	grass.message(_("You must use the -f (force) flag to actually remove the table. Exiting."))
+	grass.message(_("Leaving map/table unchanged."))
 	sys.exit(0)
-    grass.message("Dropping table <%s>..." % table)
+    grass.message(_("Dropping table <%s>...") % table)
     if grass.write_command('db.execute', stdin = "DROP TABLE %s" % table, input = '-') != 0:
-	grass.fatal("An error occured while running db.execute")
+	grass.fatal(_("An error occured while running db.execute"))
     grass.run_command('v.db.connect', flags = 'd', map = map, layer = layer)
-    grass.message("Current attribute table link(s):")
+    grass.message(_("Current attribute table link(s):"))
     # silently test first to avoid confusing error messages
     nuldev = file(os.devnull, 'w')
     if grass.run_command('v.db.connect', flags ='p', map = map, quiet = True,
 			 stdout = nuldev, stderr = nuldev) != 0:
-	grass.message("(No database links remaining)")
+	grass.message(_("(No database links remaining)"))
     else:
 	grass.run_command('v.db.connect', flags ='p', map = map)
Modified: grass/trunk/scripts/v.db.join/v.db.join.py
--- grass/trunk/scripts/v.db.join/v.db.join.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.db.join/v.db.join.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -85,13 +85,13 @@
     if driver == 'dbf':
-	grass.fatal("JOIN is not supported for tables stored in DBF format.")
+	grass.fatal(_("JOIN is not supported for tables stored in DBF format."))
     if not maptable:
-	grass.fatal("There is no table connected to this map. Cannot join any column.")
+	grass.fatal(_("There is no table connected to this map. Cannot join any column."))
-	grass.fatal("Column <%> not found in table <%s> at layer <%s>" % (column, map, layer))
+	grass.fatal(_("Column <%> not found in table <%s> at layer <%s>") % (column, map, layer))
     cols = grass.db_describe(otable, driver = driver, database = database)['cols']
@@ -107,14 +107,14 @@
 	colspec = "%s %s" % (colname, coltype)
 	if grass.run_command('v.db.addcol', map = map, columns = colspec, layer = layer) != 0:
-	    grass.fatal("Error creating column <%s>." % colname)
+	    grass.fatal(_("Error creating column <%s>.") % colname)
 	stmt = template.substitute(table = maptable, column = column,
 				   otable = otable, ocolumn = ocolumn,
 				   colname = colname)
 	if grass.write_command('db.execute', stdin = stmt, input = '-', database = database, driver = driver) != 0:
-	    grass.fatal("Error filling column <%s>." % colname)
+	    grass.fatal(_("Error filling column <%s>.") % colname)
Modified: grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
--- grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -60,7 +60,7 @@
 	vect = "%s@%s" % (vect, mapset)
-	grass.message("Reconnecting vector <%s>" % vect)
+	grass.message(_("Reconnecting vector <%s>") % vect)
 	for f in grass.vector_db(map, stderr = nuldev).itervalues():
 	    layer = f['layer']
 	    schema_table = f['table']
@@ -80,16 +80,16 @@
 	    else:
 		new_schema_table = table
-	    grass.message("SCHEMA = %s TABLE = %s NEW_SCHEMA_TABLE = %s" % (schema, table, new_schema_table))
+	    grass.message(_("SCHEMA = %s TABLE = %s NEW_SCHEMA_TABLE = %s") % (schema, table, new_schema_table))
 	    if database == old_database and schema == old_schema:
-		grass.message("Reconnecting layer " + layer)
-		grass.message("v.db.connect -o map=%s layer=%s driver=%s database=%s table=%s key=%s" %
+		grass.message(_("Reconnecting layer ") + layer)
+		grass.message(_("v.db.connect -o map=%s layer=%s driver=%s database=%s table=%s key=%s") %
 			      (vect, layer, driver, new_database, new_schema_table, key))
 		grass.run_command('v.db.connect', flags = 'o', map = vect,
 				  layer = layer, driver = driver, database = new_database,
 				  table = new_schema_table, key = key)
 	    else:
-		grass.message("Layer <%s> will not be reconnected, database or schema do not match." % layer)
+		grass.message(_("Layer <%s> will not be reconnected, database or schema do not match.") % layer)
 if __name__ == "__main__":
     options, flags = grass.parser()
Modified: grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py
--- grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -62,7 +62,7 @@
@@ -72,7 +72,7 @@
     if not table:
-	grass.fatal("There is no table connected to the input vector map. Cannot rename any column")
+	grass.fatal(_("There is no table connected to the input vector map. Cannot rename any column"))
     cols = column.split(',')
     oldcol = cols[0]
@@ -80,10 +80,10 @@
     if driver == "dbf":
 	if len(newcol) > 10:
-	    grass.fatal("Column name <%s> too long. The DBF driver supports column names not longer than 10 characters" % newcol)
+	    grass.fatal(_("Column name <%s> too long. The DBF driver supports column names not longer than 10 characters") % newcol)
     if oldcol == keycol:
-	grass.fatal("Cannot rename column <%s> as it is needed to keep table <%s> connected to the input vector map" % (oldcol, table))
+	grass.fatal(_("Cannot rename column <%s> as it is needed to keep table <%s> connected to the input vector map") % (oldcol, table))
     # describe old col
     oldcoltype = None
@@ -95,7 +95,7 @@
     # old col there?
     if not oldcol:
-	grass.fatal("Column <%s> not found in table <%s>" % (coldcol, table))
+	grass.fatal(_("Column <%s> not found in table <%s>") % (coldcol, table))
     # some tricks
     if driver in ['sqlite', 'dbf']:
Modified: grass/trunk/scripts/v.db.univar/v.db.univar.py
--- grass/trunk/scripts/v.db.univar/v.db.univar.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.db.univar/v.db.univar.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -74,7 +74,7 @@
 	grass.run_command('sort', flags = 'n', stdin = inf, stdout = outf)
     else:
 	# FIXME: we need a large-file sorting function
-	grass.warning("'sort' not found: sorting in memory")
+	grass.warning(_("'sort' not found: sorting in memory"))
 	lines = inf.readlines()
 	for i in range(len(lines)):
 	    lines[i] = float(lines[i].rstrip('\r\n'))
@@ -96,8 +96,8 @@
     driver = options['driver']
     where = options['where']
-    grass.message("Calculation for column <%s> of table <%s>..." % (column, table))
-    grass.message("Reading column values...")
+    grass.message(_("Calculation for column <%s> of table <%s>...") % (column, table))
+    grass.message(_("Reading column values..."))
     sql = "SELECT %s FROM %s" % (column, table)
     if where:
@@ -118,11 +118,11 @@
     # check if result is empty
     tmpf = file(tmp)
     if tmpf.read(1) == '':
-	grass.fatal("Table <%s> contains no data.", table)
+	grass.fatal(_("Table <%s> contains no data."), table)
     tmpf.close()
     # calculate statistics
-    grass.message("Calculating statistics...")
+    grass.message(_("Calculating statistics..."))
     N = 0
     sum = 0.0
@@ -143,7 +143,7 @@
     tmpf.close()
     if N <= 0:
-	grass.fatal("No non-null values found")
+	grass.fatal(_("No non-null values found"))
     print ""
     print "Number of values:", N
Modified: grass/trunk/scripts/v.db.update/v.db.update.py
--- grass/trunk/scripts/v.db.update/v.db.update.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.db.update/v.db.update.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -79,12 +79,12 @@
-	grass.fatal("Vector map '$GIS_OPT_MAP' not found in current mapset")
+	grass.fatal(_("Vector map '$GIS_OPT_MAP' not found in current mapset"))
     try:
     except KeyError:
-	grass.fatal('There is no table connected to this map. Run v.db.connect or v.db.addtable first.')
+	grass.fatal(_('There is no table connected to this map. Run v.db.connect or v.db.addtable first.'))
     table = f['table']
@@ -94,16 +94,16 @@
     try:
         coltype = grass.vector_columns(map, layer)[column]
     except KeyError:
-	grass.fatal('Column <%s> not found' % column)
+	grass.fatal(_('Column <%s> not found') % column)
     if qcolumn:
 	if value:
-	    grass.fatal('value= and qcolumn= are mutually exclusive')
+	    grass.fatal(_('value= and qcolumn= are mutually exclusive'))
 	# special case: we copy from another column
 	value = qcolumn
     else:
 	if not value:
-	    grass.fatal('Either value= or qcolumn= must be given')
+	    grass.fatal(_('Either value= or qcolumn= must be given'))
 	# we insert a value
 	if coltype.upper() not in ["INTEGER", "DOUBLE PRECISION"]:
 	    value = "'%s'" % value
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.py
--- grass/trunk/scripts/v.dissolve/v.dissolve.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -77,7 +77,7 @@
     # does map exist?
     if not grass.find_file(input, element = 'vector')['file']:
-	grass.fatal("Vector map <%s> not found" % input)
+	grass.fatal(_("Vector map <%s> not found") % input)
     if not column:
 	grass.run_command('v.extract', flags = 'd', input = input,
@@ -86,10 +86,10 @@
         try:
             coltype = grass.vector_columns(input, layer)[column]
         except KeyError:
 	if coltype not in ('INTEGER', 'CHARACTER'):
-	    grass.fatal("Key column must be of type integer or string")
+	    grass.fatal(_("Key column must be of type integer or string"))
         f = grass.vector_layer_db(input, layer)
Modified: grass/trunk/scripts/v.in.e00/v.in.e00.py
--- grass/trunk/scripts/v.in.e00/v.in.e00.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.in.e00/v.in.e00.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -67,19 +67,19 @@
     #### check for avcimport
     if not grass.find_program('avcimport'):
-	grass.fatal("'avcimport' program not found, install it first" +
+	grass.fatal(_("'avcimport' program not found, install it first") +
 		    "\n" +
 		    "http://avce00.maptools.org")
     #### check for e00conv
     if not grass.find_program('e00conv'):
-	grass.fatal("'e00conv' program not found, install it first" +
+	grass.fatal(_("'e00conv' program not found, install it first") +
 		    "\n" +
     # check that the user didn't use all three, which gets past the parser.
     if type not in ['point','line','area']:
-	grass.fatal('Must specify one of "point", "line", or "area".')
+	grass.fatal(_('Must specify one of "point", "line", or "area".'))
     e00name = grass.basename(filename, 'e00')
     # avcimport only accepts 13 chars:
@@ -88,7 +88,7 @@
     #check if this is a split E00 file (.e01, .e02 ...):
     merging = False
     if os.path.exists(e00name + '.e01') or os.path.exists(e00name + '.E01'):
-	grass.message("Found that E00 file is split into pieces (.e01, ...). Merging...")
+	grass.message(_("Found that E00 file is split into pieces (.e01, ...). Merging..."))
 	merging = True
     if vect:
@@ -125,22 +125,22 @@
     nuldev = file(os.devnull, 'w+')
-    grass.message("An error may appear next which will be ignored...")
+    grass.message(_("An error may appear next which will be ignored..."))
     if grass.call(['avcimport', filename, e00shortname], stdout = nuldev, stderr = nuldev) == 1:
-	grass.message("E00 ASCII found and converted to Arc Coverage in current directory")
+	grass.message(_("E00 ASCII found and converted to Arc Coverage in current directory"))
     else:
-	grass.message("E00 Compressed ASCII found. Will uncompress first...")
+	grass.message(_("E00 Compressed ASCII found. Will uncompress first..."))
 	grass.try_remove(e00shortname)
 	grass.try_remove(info)
 	grass.call(['e00conv', filename, e00tmp + '.e00'])
-	grass.message("...converted to Arc Coverage in current directory")
+	grass.message(_("...converted to Arc Coverage in current directory"))
 	grass.call(['avcimport', e00tmp + '.e00', e00shortname], stderr = nuldev)
     #SQL name fix:
     name = name.replace('-', '_')
     ## let's import...
-    grass.message("Importing %ss..." % type)
+    grass.message(_("Importing %ss...") % type)
     layer = dict(point = 'LAB', line = 'ARC', area = ['LAB','ARC'])
     itype = dict(point = 'point', line = 'line', area = 'centroid')
@@ -148,9 +148,9 @@
     if grass.run_command('v.in.ogr', flags = 'o', dsn = e00shortname,
 			 layer = layer[type], type = itype[type],
 			 output = name) != 0:
-	grass.fatal("An error occurred while running v.in.ogr")
+	grass.fatal(_("An error occurred while running v.in.ogr"))
-    grass.message("Imported <%s> vector map <%s>." % (type, name))
+    grass.message(_("Imported <%s> vector map <%s>.") % (type, name))
     #### clean up the mess
     for root, dirs, files in os.walk('.', False):
@@ -165,7 +165,7 @@
     os.rmdir(tmpdir)
     #### end
-    grass.message("Done.")
+    grass.message(_("Done."))
     # write cmd history:
     grass.vector_history(name)
Modified: grass/trunk/scripts/v.in.geonames/v.in.geonames.py
--- grass/trunk/scripts/v.in.geonames/v.in.geonames.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.in.geonames/v.in.geonames.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -61,17 +61,17 @@
-	grass.fatal("This module only operates in LatLong/WGS84 locations")
+	grass.fatal(_("This module only operates in LatLong/WGS84 locations"))
     # input test
     if not os.access(infile, os.R_OK):
-	grass.fatal("File <%s> not found" % infile)
+	grass.fatal(_("File <%s> not found") % infile)
     # DBF doesn't support lengthy text fields
     dbfdriver = kv['driver'] == 'dbf'
     if dbfdriver:
-	grass.warning("Since DBF driver is used, the content of the 'alternatenames' column might be cut with respect to the original Geonames.org column content")
+	grass.warning(_("Since DBF driver is used, the content of the 'alternatenames' column might be cut with respect to the original Geonames.org column content"))
     #let's go
     #change TAB to vertical bar
@@ -86,7 +86,7 @@
     outf.close()
     inf.close()
-    grass.message("Converted %d place names." % num_places)
+    grass.message(_("Converted %d place names.") % num_places)
     # pump data into GRASS:
     #  http://download.geonames.org/export/dump/readme.txt
Modified: grass/trunk/scripts/v.in.gns/v.in.gns.py
--- grass/trunk/scripts/v.in.gns/v.in.gns.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.in.gns/v.in.gns.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -60,7 +60,7 @@
     #### setup temporary file
     tmpfile = grass.tempfile()
@@ -122,7 +122,7 @@
     outf.close()
     inf.close()
     #TODO: fix dms_lat,dms_long DDMMSS -> DD:MM:SS
     # Solution:
Modified: grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py
--- grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -78,7 +78,7 @@
     opts = ""
     if not os.path.isfile(infile):
-	grass.fatal("Input file <%s> not found." % infile)
+	grass.fatal(_("Input file <%s> not found.") % infile)
     if output:
 	name = output
@@ -179,18 +179,18 @@
     if not name:
         #### if no name for vector file given, cat to stdout
-	grass.message("Output to stdout")
+	grass.message(_("Output to stdout"))
 	inf = file(digfile)
 	shutil.copyfileobj(inf, sys.stdout)
 	inf.close()
     else:
         #### import to binary vector file
-	grass.message("Importing with v.in.ascii ...")
+	grass.message(_("Importing with v.in.ascii ..."))
 	if grass.run_command('v.in.ascii', flags = do3D, input = digfile,
 			     output = name, format = 'standard') == 0:
-	    grass.message('"%s" successfully created' % name)
+	    grass.message(_('"%s" successfully created') % name)
 	else:
-	    grass.fatal('An error occured on creating "%s", please check' % name)
+	    grass.fatal(_('An error occured on creating "%s", please check') % name)
Modified: grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py
--- grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -31,18 +31,18 @@
     for site in grass.list_grouped('sites')[mapset]:
 	inmap = "%s@%s" % (site, mapset)
 	outmap = site.replace(".", "_") + "_points"
-	grass.message("Processing %s -> %s" % (inmap, outmap))
+	grass.message(_("Processing %s -> %s") % (inmap, outmap))
 	if grass.run_command("v.in.sites", input = inmap, output = outmap) == 0:
 	    converted += 1
 	else:
 	    ret = 1
 	if converted < 1:
-	    grass.warning("No sites maps converted as no old sites maps present in current mapset.")
+	    grass.warning(_("No sites maps converted as no old sites maps present in current mapset."))
 	else:
-	    grass.message("Total %u sites maps in current mapset converted to vector maps (original names extended by '_points')" % converted)
-	    grass.message("Please verify new vector map(s) before deleting old sites map(s).")
+	    grass.message(_("Total %u sites maps in current mapset converted to vector maps (original names extended by '_points')") % converted)
+	    grass.message(_("Please verify new vector map(s) before deleting old sites map(s)."))
 	sys.exit(ret)
Modified: grass/trunk/scripts/v.in.wfs/v.in.wfs.py
--- grass/trunk/scripts/v.in.wfs/v.in.wfs.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.in.wfs/v.in.wfs.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -44,7 +44,7 @@
     tmp = grass.tempfile()
     tmpxml = tmp + '.xml'
-    grass.message("Retrieving data ...")
+    grass.message(_("Retrieving data ..."))
     inf = urllib.urlopen(wfs_url)
     outf = file(tmpxml, 'wb')
     while True:
@@ -58,7 +58,7 @@
     grass.run_command('v.in.ogr', flags = 'o', dsn = tmpxml, out = out)
     grass.try_remove(tmpxml)
-    grass.message("Vector points map <%s> imported from WFS." % out)
+    grass.message(_("Vector points map <%s> imported from WFS.") % out)
Modified: grass/trunk/scripts/v.out.gps/v.out.gps.py
--- grass/trunk/scripts/v.out.gps/v.out.gps.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.out.gps/v.out.gps.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -146,9 +146,9 @@
     nflags = len(filter(None, [wpt, rte, trk]))
     if nflags > 1:
-	grass.fatal("One feature at a time please.")
+	grass.fatal(_("One feature at a time please."))
     if nflags < 1:
-	grass.fatal("No features requested for export.")
+	grass.fatal(_("No features requested for export."))
     # set some reasonable defaults
     if not type:
@@ -160,17 +160,17 @@
     #### check for gpsbabel
     ### FIXME: may need --help or similar?
     if not grass.find_program("gpsbabel"):
-	grass.fatal("The gpsbabel program was not found, please install it first.\n" +
+	grass.fatal(_("The gpsbabel program was not found, please install it first.\n") +
 		    "http://gpsbabel.sourceforge.net")
     #### check for cs2cs
     if not grass.find_program("cs2cs"):
-	grass.fatal("The cs2cs program was not found, please install it first.\n" +
+	grass.fatal(_("The cs2cs program was not found, please install it first.\n") +
 		    "http://proj.osgeo.org")
     # check if we will overwrite data
     if os.path.exists(output) and not grass.overwrite():
-	grass.fatal("Output file already exists.")
+	grass.fatal(_("Output file already exists."))
     #### set temporary files
@@ -183,11 +183,11 @@
 				output = tmp_extr, type = type, layer = layer,
 				where = where, quiet = True)
 	if ret != 0:
-	    grass.fatal("Error executing SQL query")
+	    grass.fatal(_("Error executing SQL query"))
 	kv = grass.vector_info_topo(tmp_extr)
 	if kv['primitives'] == 0:
-	    grass.fatal("SQL query returned an empty map (no %s features?)" % type)
+	    grass.fatal(_("SQL query returned an empty map (no %s features?)") % type)
 	inmap = tmp_extr
     else:
@@ -232,7 +232,7 @@
     p2.wait()
     if p1.returncode != 0 or p2.returncode != 0:
-	grass.fatal("Error reprojecting data")
+	grass.fatal(_("Error reprojecting data"))
     tmp_vogb = "tmp_vogb_epsg4326_%d" % os.getpid()
     p3 = grass.feed_command('v.in.ascii', out = tmp_vogb, format = 'standard', flags = 'n', quiet = True)
@@ -249,7 +249,7 @@
     p3.wait()
     if p3.returncode != 0:
     # don't v.db.connect directly as source table will be removed with
     # temporary map in that case. So we make a temp copy of it to work with.
@@ -268,11 +268,11 @@
 				from_table = db_table,
 				to_table = tmp_vogb)
 	if ret != 0:
-	    grass.fatal("Error copying temporary DB")
+	    grass.fatal(_("Error copying temporary DB"))
 	ret = grass.run_command('v.db.connect', map = tmp_vogb, table = tmp_vogb, quiet = True)
 	if ret != 0:
-	    grass.fatal("Error reconnecting temporary DB")
+	    grass.fatal(_("Error reconnecting temporary DB"))
     # export as GPX using v.out.ogr
     if trk:
@@ -298,7 +298,7 @@
 			    type = type, format = 'GPX', lco = linetype,
 			    dsco = "GPX_USE_EXTENSIONS=YES", quiet = True)
     if ret != 0:
-	grass.fatal("Error exporting data")
+	grass.fatal(_("Error exporting data"))
     if format == 'gpx':
 	# short circuit, we have what we came for.
@@ -327,7 +327,7 @@
 		      '-F', output])
     if ret != 0:
-	grass.fatal("Error running GpsBabel")
+	grass.fatal(_("Error running GpsBabel"))
     grass.verbose("Done.")
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -79,7 +79,7 @@
     grass.run_command('g.remove', rast = '%s_%s' % (vector, tmpname), quiet = True)
     grass.run_command('g.remove', rast = 'MASK', quiet = True, stderr = nuldev)
     if mask_found:
-	grass.message("Restoring previous MASK...")
+	grass.message(_("Restoring previous MASK..."))
 	grass.run_command('g.rename', rast = (tmpname + "_origmask", 'MASK'), quiet = True)
 #    for f in [tmp, tmpname, sqltmp]:
 #	grass.try_remove(f)
@@ -113,18 +113,18 @@
     if vect_mapset != mapset or not grass.find_file(vector, 'vector', mapset)['file']:
-	grass.fatal("Vector map <%s> not found in current mapset" % vector)
+	grass.fatal(_("Vector map <%s> not found in current mapset") % vector)
     vector = vs[0]
     #check the input raster map
     if not grass.find_file(raster, 'cell')['file']:
-	grass.fatal("Raster map <%s> not found" % raster)
+	grass.fatal(_("Raster map <%s> not found") % raster)
     #check presence of raster MASK, put it aside
     mask_found = bool(grass.find_file('MASK', 'cell')['file'])
     if mask_found:
-	grass.message("Raster MASK found, temporarily disabled")
+	grass.message(_("Raster MASK found, temporarily disabled"))
 	grass.run_command('g.rename', rast = ('MASK', tmpname + "_origmask"), quiet = True)
     #get RASTER resolution of map which we want to query:
@@ -143,7 +143,7 @@
     #prepare raster MASK
     if grass.run_command('v.to.rast', input = vector, output = "%s_%s" % (vector, tmpname),
 			 use = 'cat', quiet = True) != 0:
-	grass.fatal("An error occurred while converting vector to raster")
+	grass.fatal(_("An error occurred while converting vector to raster"))
     #dump cats to file to avoid "too many argument" problem:
     p = grass.pipe_command('r.category', map = '%s_%s' % (vector, tmpname), fs = ';', quiet = True)
@@ -155,19 +155,19 @@
     #echo "List of categories found: $CATSLIST"
     number = len(cats)
     if number < 1:
-	grass.fatal("No categories found in raster map")
+	grass.fatal(_("No categories found in raster map"))
     #check if DBF driver used, in this case cut to 10 chars col names:
     try:
         fi = grass.vector_db(map = vector)[int(layer)]
     except KeyError:
     # we need this for non-DBF driver:
     dbfdriver = fi['driver'] == 'dbf'
     #Find out which table is linked to the vector map on the given layer
     if not fi['table']:
     basecols = ['n', 'min', 'max', 'range', 'mean', 'stddev', 'variance', 'cf_var', 'sum']
@@ -208,7 +208,7 @@
     if addcols:
 	grass.verbose("Adding columns <%s>" % addcols)
 	if grass.run_command('v.db.addcol', map = vector, columns = addcols) != 0:
-	    grass.fatal("Cannot continue (problem adding columns).")
+	    grass.fatal(_("Cannot continue (problem adding columns)."))
     #loop over cats and calculate statistics:
     grass.verbose("Processing data ...")
@@ -226,7 +226,7 @@
     currnum = 1
     for i in cats:
-	grass.message("Processing category %s (%d/%d)..." % (i, currnum, number))
+	grass.message(_("Processing category %s (%d/%d)...") % (i, currnum, number))
 	grass.mapcalc("MASK = if($name == $i, 1, null())",
 		      name = "%s_%s" % (vector, tmpname), i = i)
@@ -255,7 +255,7 @@
     f.close()
-    grass.message("Updating the database ...")
+    grass.message(_("Updating the database ..."))
     exitcode = grass.run_command('db.execute', input = sqltmp,
 				 database = fi['database'], driver = fi['driver'])
Modified: grass/trunk/scripts/v.report/v.report.py
--- grass/trunk/scripts/v.report/v.report.py	2009-08-03 15:59:45 UTC (rev 38601)
+++ grass/trunk/scripts/v.report/v.report.py	2009-08-03 16:32:35 UTC (rev 38602)
@@ -71,7 +71,7 @@
 def main():
     if flags['r'] and flags['s']:
-	grass.fatal("Either -r or -s flag")
+	grass.fatal(_("Either -r or -s flag"))
     mapname = options['map']
     option = options['option']
@@ -81,7 +81,7 @@
     if not grass.find_file(mapname, 'vector')['file']:
-	grass.fatal("Vector map '%s' not found in mapset search path." % mapname)
+	grass.fatal(_("Vector map '%s' not found in mapset search path.") % mapname)
     table_exists = grass.vector_columns(mapname, layer, stderr = nuldev)
@@ -120,7 +120,7 @@
 	if len(records1) == 0:
             try:
                 f = grass.vector_db(map = mapname)[int(layer)]
-                grass.fatal("There is a table connected to input vector map '%s', but" +
+                grass.fatal(_("There is a table connected to input vector map '%s', but") +
                             "there are no categories present in the key column '%s'. Consider using" +
                             "v.to.db to correct this." % (mapname, f['key']))
             except KeyError:
