[GRASS-SVN] r38604 - in
grass/branches/develbranch_6/visualization/nviz: scripts src
svn_grass at osgeo.org
Mon Aug 3 12:54:56 EDT 2009
Author: marisn
Date: 2009-08-03 12:54:56 -0400 (Mon, 03 Aug 2009)
New Revision: 38604
grass/branches/develbranch_6/visualization/nviz/scripts/extra_bindings.tcl
grass/branches/develbranch_6/visualization/nviz/scripts/panel_vquery.tcl
grass/branches/develbranch_6/visualization/nviz/src/site_attr_commands.c
NVIZ vector query port from sites to vectors
Modified: grass/branches/develbranch_6/visualization/nviz/scripts/extra_bindings.tcl
--- grass/branches/develbranch_6/visualization/nviz/scripts/extra_bindings.tcl 2009-08-03 16:49:30 UTC (rev 38603)
+++ grass/branches/develbranch_6/visualization/nviz/scripts/extra_bindings.tcl 2009-08-03 16:54:56 UTC (rev 38604)
@@ -62,7 +62,7 @@
#$Nv_(AREA).menu.wait_pls configure -fg red -bg black
pack $Nv_(AREA).menu.wait_pls
- grab $Nv_(AREA).menu.wait_pls
+#grab $Nv_(AREA).menu.wait_pls
update
Modified: grass/branches/develbranch_6/visualization/nviz/scripts/panel_vquery.tcl
--- grass/branches/develbranch_6/visualization/nviz/scripts/panel_vquery.tcl 2009-08-03 16:49:30 UTC (rev 38603)
+++ grass/branches/develbranch_6/visualization/nviz/scripts/panel_vquery.tcl 2009-08-03 16:54:56 UTC (rev 38604)
@@ -25,7 +25,7 @@
namespace eval NV_panel_vquery {
- variable maxdist # snapping distance for selecting objects to query
+ variable maxdist ;# snapping distance for selecting objects to query
variable array highlight
Modified: grass/branches/develbranch_6/visualization/nviz/src/site_attr_commands.c
--- grass/branches/develbranch_6/visualization/nviz/src/site_attr_commands.c 2009-08-03 16:49:30 UTC (rev 38603)
+++ grass/branches/develbranch_6/visualization/nviz/src/site_attr_commands.c 2009-08-03 16:54:56 UTC (rev 38604)
@@ -152,6 +152,7 @@
#include <stdlib.h>
#include <grass/Vect.h>
#include <grass/site.h>
+#include <grass/dbmi.h>
#include "interface.h"
#define R_G_B_2_RGB(r,g,b) ((b) & 0xff) | (((g) & 0xff) << 8) | (((r) & 0xff) << 16)
@@ -275,29 +276,77 @@
int argc; /* Number of arguments. */
char **argv; /* Argument strings. */
- struct Map_info *Map;
- int *ctypes;
- char **cnames;
- int *ndx;
- int ncols, i;
- char buf[1024];
+ struct Map_info Map;
+ int ncols, col;
+ char buf[9182];
+ struct field_info *Fi;
+ dbDriver *driver;
+ dbHandle handle;
+ dbTable *table;
+ dbColumn *column;
+ dbString table_name, dbsql, valstr;
+ char *mapset;
- if (argc != 2)
+ if (argc != 2) {
+ G_warning("Wrong argument count for Nsite_attr_get_fields_name");
return (TCL_ERROR);
- Map =
- (struct Map_info *)G_sites_open_old(argv[1],
- G_find_vector2(argv[1], ""));
- ncols = G_sites_get_fields(Map, &cnames, &ctypes, &ndx);
+ if ((mapset = G_find_vector2(argv[1], "")) == NULL) {
+ G_warning("Vector map <%s> not found", argv[1]);
+ return TCL_ERROR;
- for (i = 0; i < ncols; i++) {
- sprintf(buf, "%s", cnames[i]);
+ if (Vect_open_old_head(&Map, argv[1], mapset) < 0) {
+ G_warning("Failed to open vector map <%s>", argv[1]);
+ return TCL_ERROR;
+ Fi = Vect_get_field(&Map, 1); /* FIXME: only layer 1 is supported. Requires GUI changes. */
+ if (!Fi) {
+ Vect_close(&Map);
+ G_warning("Failed to get database information for vector map <%s>",
+ argv[1]);
+ return TCL_ERROR;
+ /* Prepeare strings for use in db_* calls */
+ db_init_string(&dbsql);
+ db_init_string(&valstr);
+ db_init_string(&table_name);
+ db_init_handle(&handle);
+ /* Prepearing database for use */
+ driver = db_start_driver(Fi->driver);
+ if (driver == NULL) {
+ Vect_close(&Map);
+ G_warning("Unable to start driver <%s>", Fi->driver);
+ return TCL_ERROR;
+ db_set_handle(&handle, Fi->database, NULL);
+ if (db_open_database(driver, &handle) != DB_OK) {
+ Vect_close(&Map);
+ G_warning("Unable to open database <%s> by driver <%s>",
+ Fi->database, Fi->driver);
+ return TCL_ERROR;
+ db_set_string(&table_name, Fi->table);
+ if (db_describe_table(driver, &table_name, &table) != DB_OK) {
+ Vect_close(&Map);
+ G_warning("Unable to describe table <%s>", Fi->table);
+ return TCL_ERROR;
+ ncols = db_get_table_number_of_columns(table);
+ for (col = 0; col < ncols; col++) {
+ column = db_get_table_column(table, col);
+ sprintf(buf, "%s", db_get_column_name(column));
Tcl_AppendElement(interp, buf);
- if (ncols > 0)
- G_sites_free_fields(ncols, cnames, ctypes, ndx);
- G_sites_close(Map);
+ db_close_database_shutdown_driver(driver);
+ Vect_close(&Map);
return (TCL_OK);
@@ -347,29 +396,81 @@
- int *ctypes;
- char **cnames;
- int *ndx;
- int ncols, i;
- char buf[2048];
+ int ncols, col, type;
+ char buf[9182];
+ dbDriver *driver;
+ dbHandle handle;
+ dbTable *table;
+ dbColumn *column;
+ char *mapset;
- if (argc != 2)
+ if (argc != 2) {
+ G_warning
+ ("Wrong argument count for Nsite_attr_get_fields_name_and_type");
return (TCL_ERROR);
- Map = G_sites_open_old(argv[1], G_find_vector2(argv[1], ""));
+ return TCL_ERROR;
+ return TCL_ERROR;
+ if (!Fi) {
+ Vect_close(&Map);
+ argv[1]);
+ return TCL_ERROR;
+ Vect_close(&Map);
+ return TCL_ERROR;
+ Vect_close(&Map);
+ return TCL_ERROR;
+ Vect_close(&Map);
+ return TCL_ERROR;
- sprintf(buf, "%c", ctypes[i]);
+ type = db_sqltype_to_Ctype(db_get_column_sqltype(column));
+ sprintf(buf, "%c", type);
- if (ncols > 0)
+ Vect_close(&Map);
return (TCL_OK);
@@ -444,39 +545,111 @@
- int *ctypes;
- char **cnames;
- int *ndx;
- int ncols, i, index;
+ int ncols, nrows, type, index, col, more;
char buf[9182];
- SITE_ATT *sa;
+ dbDriver *driver;
+ dbHandle handle;
+ dbCursor cursor;
+ dbTable *table;
+ dbColumn *column;
+ char *mapset;
- if (argc != 3)
+ if (argc != 3) {
+ G_message
+ ("Wrong argument count for Nsite_attr_get_field_not_emtpy_cats");
return (TCL_ERROR);
index = atoi(argv[2]);
+ return TCL_ERROR;
- for (i = 0; i < Map->n_site_att; i++) {
- sa = &(Map->site_att[i]);
- /* printf("@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ i=%d cat=%d field=%s\n", i, sa->cat, sa->str[ndx[index]]); */
- switch (ctypes[index]) {
- case 's': /* string */
- if (strlen(sa->str[ndx[index]]) > 0) {
- sprintf(buf, "%d", sa->cat);
- Tcl_AppendElement(interp, buf);
+ return TCL_ERROR;
+ Fi = Vect_get_field(&Map, index);
+ if (!Fi) {
+ Vect_close(&Map);
+ argv[1]);
+ return TCL_ERROR;
+ Vect_close(&Map);
+ return TCL_ERROR;
+ Vect_close(&Map);
+ return TCL_ERROR;
+ Vect_close(&Map);
+ return TCL_ERROR;
+ db_set_string(&dbsql, "select * from ");
+ db_append_string(&dbsql, Fi->table);
+ if (db_open_select_cursor(driver, &dbsql, &cursor, DB_SEQUENTIAL)
+ != DB_OK) {
+ G_warning("Unabale to get attribute data");
+ return TCL_ERROR;
+ else {
+ nrows = db_get_num_rows(&cursor);
+ table = db_get_cursor_table(&cursor);
+ if (nrows > 0) {
+ if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK) {
+ G_warning("Error while retreiving database record");
- break;
+ else {
+ /* Same as str type in sites_att. No idea why only str are used here */
+ if (type == DB_C_TYPE_STRING ||
+ type == DB_C_TYPE_DATETIME) {
+ db_convert_column_value_to_string(column, &valstr);
+ if (strlen(db_get_string(&valstr)) > 0) {
+ sprintf(buf, "%s", db_get_string(&valstr));
+ Tcl_AppendElement(interp, buf);
+ db_close_cursor(&cursor);
- if (ncols > 0)
+ Vect_close(&Map);
return (TCL_OK);
@@ -497,45 +670,105 @@
- int *ctypes;
- char **cnames;
- int *ndx;
- int ncols, i, cat;
+ int ncols, nrows, cat, col, more;
char buf[9182];
- SITE_ATT *sa;
+ dbDriver *driver;
+ dbHandle handle;
+ dbCursor cursor;
+ dbTable *table;
+ dbColumn *column;
+ char *mapset;
- if (argc != 3)
+ if (argc != 3) {
+ G_message("Wrong argument count for Nsite_attr_get_record_values");
return (TCL_ERROR);
cat = atoi(argv[2]);
+ return TCL_ERROR;
+ return TCL_ERROR;
- if ((sa = (SITE_ATT *) G_sites_get_atts(Map, &cat)) == NULL)
- return (TCL_ERROR);
+ if (!Fi) {
+ Vect_close(&Map);
+ argv[1]);
+ return TCL_ERROR;
- switch (ctypes[i]) {
- case 'c': /* category */
- break;
- case 'd': /* double */
- sprintf(buf, "%f", sa->dbl[ndx[i]]);
- break;
- sprintf(buf, "%s", sa->str[ndx[i]]);
- break;
+ Vect_close(&Map);
+ return TCL_ERROR;
+ Vect_close(&Map);
+ return TCL_ERROR;
+ Vect_close(&Map);
+ return TCL_ERROR;
+ sprintf(buf, "select * from %s where %s=%d", Fi->table, Fi->key, cat);
+ db_set_string(&dbsql, buf);
+ != DB_OK) {
+ G_warning("Unabale to get attribute data for cat %d", cat);
+ return TCL_ERROR;
+ else {
+ if (nrows > 0) {
+ G_warning("Error while retreiving database record for cat %d",
+ cat);
+ else {
- if (ncols > 0)
+ Vect_close(&Map);
return (TCL_OK);
