[GRASS-SVN] r38630 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Fri Aug 7 06:15:56 EDT 2009
Author: aghisla
Date: 2009-08-07 06:15:54 -0400 (Fri, 07 Aug 2009)
New Revision: 38630
grass-addons/vector/v.krige/v.krige.py
better handling of unsuitable data in GUI - impossible to run command or plot variogram on bad/no data
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-08-06 15:25:42 UTC (rev 38629)
+++ grass-addons/vector/v.krige/v.krige.py 2009-08-07 10:15:54 UTC (rev 38630)
@@ -105,6 +105,7 @@
import wx
import wx.lib.flatnotebook as FN
+import wx.lib.plot as plot # for plotting the variogram.
### i18N
import gettext
@@ -361,19 +362,20 @@
def OnInputDataChanged(self, event):
""" Refreshes list of columns and fills output map name TextCtrl """
MapName = event.GetString()
+ self.InputDataColumn.InsertColumns(vector = MapName,
+ layer = 1, excludeKey = True,
+ type = ['integer', 'double precision'])
+ self.InputDataColumn.SetSelection(0)
- if len(MapName) is not 0: # or is spaces! see how to test that
- self.InputDataColumn.InsertColumns(vector = MapName,
- layer = 1, excludeKey = True,
- type = ['integer', 'double precision'])
- self.InputDataColumn.SetSelection(0)
+ if self.InputDataColumn.GetSelection() is not -1:
self.OutputMapName.SetValue(MapName.split("@")[0]+"_kriging")
- if self.InputDataColumn.GetSelection() is not -1: # there is no suitable z column for the layer
- self.RunButton.Enable(True)
+ self.RunButton.Enable(True)
+ self.RBookgstatPanel.PlotButton.Enable(True)
else:
+ #self.InputDataColumn.SetSelection(0)
self.OutputMapName.SetValue('')
self.RunButton.Enable(False)
+ self.RBookgstatPanel.PlotButton.Enable(False)
def OnRunButton(self,event):
""" Execute R analysis. """
@@ -453,9 +455,10 @@
self.VariogramSizer.Add(self.RightSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=parent.border)
# left side of Variogram fitting. The checkboxes and spinctrls.
- PlotButton = wx.Button(self, id=wx.ID_ANY, label=_("Plot/refresh variogram")) # no stock ID for Run button..
- PlotButton.Bind(wx.EVT_BUTTON, self.OnPlotButton)
- self.LeftSizer.Add(PlotButton, proportion=0, flag=wx.EXPAND | wx.ALL, border=parent.border)
+ self.PlotButton = wx.Button(self, id=wx.ID_ANY, label=_("Plot/refresh variogram")) # no stock ID for Run button..
+ self.PlotButton.Bind(wx.EVT_BUTTON, self.OnPlotButton)
+ self.PlotButton.Enable(False) # grey it out until a suitable layer is available
+ self.LeftSizer.Add(self.PlotButton, proportion=0, flag= wx.ALL, border=parent.border)
self.LeftSizer.Add(self.ParametersSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=parent.border)
self.ParametersList = ["Sill", "Nugget", "Range"]
@@ -481,7 +484,6 @@
# right side of the Variogram fitting. The plot area.
Plot = wx.StaticText(self, id= wx.ID_ANY, label = "Check Plot Variogram to interactively fit model.")
- #Plot = wx.StaticBitmap(self, bitmap=wx.Bitmap('/home/anne/raster/Muppet-Bunsen.jpg'), size=(200,200))
self.RightSizer.Add(Plot, proportion=0, flag= wx.ALIGN_CENTER | wx.ALL, border=parent.border)
self.KrigingSizer = wx.StaticBoxSizer(wx.StaticBox(self,
@@ -518,6 +520,7 @@
robjects.r.writeRAST6(map, vname = name, zcol = col, overwrite = overwrite)
def OnPlotButton(self,event):
pass
def UseValue(self, event):
