[GRASS-SVN] r38632 - grass/trunk/raster/r.drain
svn_grass at osgeo.org
Fri Aug 7 11:26:24 EDT 2009
Author: mmetz
Date: 2009-08-07 11:26:24 -0400 (Fri, 07 Aug 2009)
New Revision: 38632
grass/trunk/raster/r.drain/filldir.c
grass/trunk/raster/r.drain/main.c
grass/trunk/raster/r.drain/resolve.c
grass/trunk/raster/r.drain/tinf.c
grass/trunk/raster/r.drain/tinf.h
LFS-safe r.drain
Modified: grass/trunk/raster/r.drain/filldir.c
--- grass/trunk/raster/r.drain/filldir.c 2009-08-07 14:56:54 UTC (rev 38631)
+++ grass/trunk/raster/r.drain/filldir.c 2009-08-07 15:26:24 UTC (rev 38632)
@@ -1,3 +1,5 @@
+#include <grass/config.h>
+#include <sys/types.h>
#include <stdlib.h>
#include <math.h>
#include <limits.h>
@@ -34,7 +36,8 @@
void build_one_row(int i, int nl, int ns, struct band3 *bnd, CELL * dir,
struct metrics m)
- int j, offset, inc;
+ int j, inc;
+ off_t offset;
CELL sdir;
double slope;
char *center;
@@ -97,7 +100,7 @@
void filldir(int fe, int fd, int nl, struct band3 *bnd, struct metrics *m)
- int i, bufsz;
+ int i, bufsz; /* use off_t bufsz for large files ? MM */
CELL *dir;
/* determine the flow direction in each cell. On outer rows and columns
Modified: grass/trunk/raster/r.drain/main.c
--- grass/trunk/raster/r.drain/main.c 2009-08-07 14:56:54 UTC (rev 38631)
+++ grass/trunk/raster/r.drain/main.c 2009-08-07 15:26:24 UTC (rev 38632)
@@ -25,6 +25,7 @@
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
@@ -87,7 +88,8 @@
struct point *list;
struct point *thispoint;
- int ival, bsz, start_row, start_col, mode;
+ int ival, start_row, start_col, mode;
+ off_t bsz;
int costmode = 0;
double east, north, val;
struct point *drain(int, struct point *, int, int);
Modified: grass/trunk/raster/r.drain/resolve.c
--- grass/trunk/raster/r.drain/resolve.c 2009-08-07 14:56:54 UTC (rev 38631)
+++ grass/trunk/raster/r.drain/resolve.c 2009-08-07 15:26:24 UTC (rev 38632)
@@ -1,3 +1,4 @@
#include <stdlib.h>
#include <string.h>
#include <grass/gis.h>
Modified: grass/trunk/raster/r.drain/tinf.c
--- grass/trunk/raster/r.drain/tinf.c 2009-08-07 14:56:54 UTC (rev 38631)
+++ grass/trunk/raster/r.drain/tinf.c 2009-08-07 15:26:24 UTC (rev 38632)
@@ -1,3 +1,4 @@
/* #include <limits.h> */
#include <float.h>
#include <math.h>
Modified: grass/trunk/raster/r.drain/tinf.h
--- grass/trunk/raster/r.drain/tinf.h 2009-08-07 14:56:54 UTC (rev 38631)
+++ grass/trunk/raster/r.drain/tinf.h 2009-08-07 15:26:24 UTC (rev 38632)
@@ -94,7 +94,7 @@
struct band3
int ns; /* samples per line */
- int sz; /* bytes per line */
+ off_t sz; /* bytes per line */
char *b[3]; /* pointers to start of each line */
