[GRASS-SVN] r38636 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sat Aug 8 05:39:49 EDT 2009
Author: mmetz
Date: 2009-08-08 05:39:49 -0400 (Sat, 08 Aug 2009)
New Revision: 38636
grass/trunk/lib/vector/Vlib/header.c
grass/trunk/lib/vector/Vlib/init_head.c
grass/trunk/lib/vector/Vlib/open.c
initialize and set proj and zone in vector head
Modified: grass/trunk/lib/vector/Vlib/header.c
--- grass/trunk/lib/vector/Vlib/header.c 2009-08-08 09:34:14 UTC (rev 38635)
+++ grass/trunk/lib/vector/Vlib/header.c 2009-08-08 09:39:49 UTC (rev 38636)
@@ -130,7 +130,7 @@
Vect_set_map_date(Map, "");
Vect_set_scale(Map, 1);
Vect_set_comment(Map, "");
- Vect_set_zone(Map, 0);
+ Vect_set_zone(Map, -1);
Vect_set_thresh(Map, 0.);
G_debug(1, "Vect__read_head(): vector = %s@%s", Map->name, Map->mapset);
@@ -458,7 +458,6 @@
return 0;
\brief Get projection zone from map header
@@ -472,21 +471,39 @@
+ \brief Set projection in map header
+ \param Map vector map
+ PROJECTION_XY 0 - x,y (Raw imagery),
+ PROJECTION_UTM 1 - UTM Universal Transverse Mercator,
+ PROJECTION_SP 2 - State Plane (in feet),
+ PROJECTION_LL 3 - Latitude-Longitude
+ \return 0 on success
+int Vect_set_proj(struct Map_info *Map, int proj)
+ Map->proj = proj;
+ return 0;
\brief Get projection from map header
- \return PROJECTION_XY - x,y (Raw imagery),
- \return PROJECTION_UTM - UTM Universal Transverse Mercator,
- \return PROJECTION_SP - State Plane (in feet),
- \return PROJECTION_LL - Latitude-Longitude
+ \return PROJECTION_XY 0 - x,y (Raw imagery),
+ \return PROJECTION_UTM 1 - UTM Universal Transverse Mercator,
+ \return PROJECTION_SP 2 - State Plane (in feet),
+ \return PROJECTION_LL 3 - Latitude-Longitude
int Vect_get_proj(const struct Map_info *Map)
return (Map->proj);
\brief Query cartographic projection name of vector map
Modified: grass/trunk/lib/vector/Vlib/init_head.c
--- grass/trunk/lib/vector/Vlib/init_head.c 2009-08-08 09:34:14 UTC (rev 38635)
+++ grass/trunk/lib/vector/Vlib/init_head.c 2009-08-08 09:39:49 UTC (rev 38636)
@@ -58,11 +58,14 @@
Map->head.line_3 = NULL;
- /* scale, zone, threshold */
+ /* scale, threshold */
Vect_set_thresh(Map, 0.0);
+ /* proj, zone */
+ Vect_set_proj(Map, -1);
/* support variables */
Map->plus.Spidx_built = 0;
Map->plus.release_support = 0;
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2009-08-08 09:34:14 UTC (rev 38635)
+++ grass/trunk/lib/vector/Vlib/open.c 2009-08-08 09:39:49 UTC (rev 38636)
@@ -224,6 +224,9 @@
Map->format = format;
+ Vect_set_proj(Map, G_projection());
+ Vect_set_zone(Map, G_zone());
/* Read vector head */
if (!ogr_mapset && Vect__read_head(Map) != 0) {
@@ -234,7 +237,11 @@
G_warning(_("Unable to read head file of vector <%s>"),
Vect_get_full_name(Map));
+ /* zone not set */
+ if (Vect_get_zone(Map) == -1)
G_debug(1, "Level request = %d", level_request);
/* There are only 2 possible open levels, 1 and 2. Try first to open 'support' files
@@ -629,6 +636,9 @@
Map->head.with_z = with_z;
Map->plus.do_uplist = 0;
Map->dblnk = Vect_new_dblinks_struct();
return 1;
