[GRASS-SVN] r38638 - grass/trunk
svn_grass at osgeo.org
Sat Aug 8 05:52:05 EDT 2009
Author: neteler
Date: 2009-08-08 05:52:05 -0400 (Sat, 08 Aug 2009)
New Revision: 38638
grass/trunk/configure
grass/trunk/configure.in
check if GEOS is sufficiently new
Modified: grass/trunk/configure
--- grass/trunk/configure 2009-08-08 09:50:20 UTC (rev 38637)
+++ grass/trunk/configure 2009-08-08 09:52:05 UTC (rev 38638)
@@ -7735,7 +7735,58 @@
CPPFLAGS=$ac_save_cppflags
+ac_save_ldflags="$LDFLAGS"
+LDFLAGS="$GEOS_LIBS $LDFLAGS"
+echo $ac_n "checking for GEOSGeom_createLinearRing in -lgeos""... $ac_c" 1>&6
+echo "configure:7745: checking for GEOSGeom_createLinearRing in -lgeos" >&5
+ac_lib_var=`echo geos'_'GEOSGeom_createLinearRing | sed 'y%./+-%__p_%'`
+ac_save_LIBS="$LIBS"
+LIBS="-lgeos $LIBS"
+cat > conftest.$ac_ext <<EOF
+#line 7751 "configure"
+#include "confdefs.h"
+/* Override any gcc2 internal prototype to avoid an error. */
+/* We use char because int might match the return type of a gcc2
+ builtin and then its argument prototype would still apply. */
+char GEOSGeom_createLinearRing();
+int main() {
+GEOSGeom_createLinearRing()
+; return 0; }
+EOF
+if { (eval echo configure:7762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+ rm -rf conftest*
+ eval "ac_cv_lib_$ac_lib_var=yes"
+else
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -rf conftest*
+ eval "ac_cv_lib_$ac_lib_var=no"
+fi
+rm -f conftest*
+LIBS="$ac_save_LIBS"
+if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
+ echo "$ac_t""yes" 1>&6
+ GEOS_LIBS="$GEOS_LIBS -lgeos "
+else
+ echo "$ac_t""no" 1>&6
+LDFLAGS=${ac_save_ldflags}
+ { echo "configure: error: *** Unable to locate GEOS library." 1>&2; exit 1; }
+fi
cat >> confdefs.h <<\EOF
#define HAVE_GEOS 1
EOF
@@ -7750,7 +7801,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7754: checking whether to use TIFF" >&5
+echo "configure:7805: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -7770,7 +7821,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7774: checking for location of TIFF includes" >&5
+echo "configure:7825: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7796,15 +7847,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:7800: checking for $ac_hdr" >&5
+echo "configure:7851: checking for $ac_hdr" >&5
-#line 7803 "configure"
+#line 7854 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7808: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7859: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7838,7 +7889,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7842: checking for location of TIFF library" >&5
+echo "configure:7893: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7869,13 +7920,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7873: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7924: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 7879 "configure"
+#line 7930 "configure"
@@ -7886,7 +7937,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7941: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7905,13 +7956,13 @@
-echo "configure:7909: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7960: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 7915 "configure"
+#line 7966 "configure"
@@ -7922,7 +7973,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7941,13 +7992,13 @@
-echo "configure:7945: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7996: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 7951 "configure"
+#line 8002 "configure"
@@ -7958,7 +8009,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7977,13 +8028,13 @@
-echo "configure:7981: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8032: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7987 "configure"
+#line 8038 "configure"
@@ -7994,7 +8045,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8013,13 +8064,13 @@
-echo "configure:8017: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8068: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8023 "configure"
+#line 8074 "configure"
@@ -8030,7 +8081,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8085: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8049,13 +8100,13 @@
-echo "configure:8053: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8104: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8059 "configure"
+#line 8110 "configure"
@@ -8066,7 +8117,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8085,13 +8136,13 @@
-echo "configure:8089: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8140: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8095 "configure"
+#line 8146 "configure"
@@ -8102,7 +8153,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8157: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8121,13 +8172,13 @@
-echo "configure:8125: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8176: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8131 "configure"
+#line 8182 "configure"
@@ -8138,7 +8189,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8236,7 +8287,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8240: checking whether to use PNG" >&5
+echo "configure:8291: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -8255,7 +8306,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8259: checking for location of PNG includes" >&5
+echo "configure:8310: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8281,15 +8332,15 @@
do
-echo "configure:8285: checking for $ac_hdr" >&5
+echo "configure:8336: checking for $ac_hdr" >&5
-#line 8288 "configure"
+#line 8339 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8293: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8344: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8323,7 +8374,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8327: checking for location of PNG library" >&5
+echo "configure:8378: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8348,13 +8399,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8352: checking for png_read_image in -lpng" >&5
+echo "configure:8403: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8358 "configure"
+#line 8409 "configure"
@@ -8365,7 +8416,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:8369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8420: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8407,7 +8458,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8411: checking whether to use PostgreSQL" >&5
+echo "configure:8462: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -8434,7 +8485,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8438: checking for location of PostgreSQL includes" >&5
+echo "configure:8489: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8460,15 +8511,15 @@
do
-echo "configure:8464: checking for $ac_hdr" >&5
+echo "configure:8515: checking for $ac_hdr" >&5
-#line 8467 "configure"
+#line 8518 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8472: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8523: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8506,7 +8557,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:8510: checking for location of PostgreSQL library" >&5
+echo "configure:8561: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -8535,13 +8586,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:8539: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8590: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 8545 "configure"
+#line 8596 "configure"
@@ -8552,7 +8603,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:8556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8607: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8571,13 +8622,13 @@
-echo "configure:8575: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8626: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 8581 "configure"
+#line 8632 "configure"
@@ -8588,7 +8639,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:8592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8607,13 +8658,13 @@
-echo "configure:8611: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8662: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 8617 "configure"
+#line 8668 "configure"
@@ -8624,7 +8675,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:8628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8679: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8643,13 +8694,13 @@
-echo "configure:8647: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8698: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 8653 "configure"
+#line 8704 "configure"
@@ -8660,7 +8711,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:8664: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8717,13 +8768,13 @@
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:8721: checking for PQcmdTuples in -lpq" >&5
+echo "configure:8772: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 8727 "configure"
+#line 8778 "configure"
@@ -8734,7 +8785,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:8738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8756,13 +8807,13 @@
-echo "configure:8760: checking for PQcmdTuples in -lpq" >&5
+echo "configure:8811: checking for PQcmdTuples in -lpq" >&5
-#line 8766 "configure"
+#line 8817 "configure"
@@ -8773,7 +8824,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:8777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8816,7 +8867,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:8820: checking whether to use MySQL" >&5
+echo "configure:8871: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -8836,7 +8887,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:8840: checking for location of MySQL includes" >&5
+echo "configure:8891: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -8862,15 +8913,15 @@
do
-echo "configure:8866: checking for $ac_hdr" >&5
+echo "configure:8917: checking for $ac_hdr" >&5
-#line 8869 "configure"
+#line 8920 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8874: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8925: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8907,7 +8958,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:8911: checking for location of MySQL library" >&5
+echo "configure:8962: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -8938,13 +8989,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:8942: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8993: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 8948 "configure"
+#line 8999 "configure"
@@ -8955,7 +9006,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8974,13 +9025,13 @@
-echo "configure:8978: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9029: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 8984 "configure"
+#line 9035 "configure"
@@ -8991,7 +9042,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9010,13 +9061,13 @@
-echo "configure:9014: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9065: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9020 "configure"
+#line 9071 "configure"
@@ -9027,7 +9078,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9046,13 +9097,13 @@
-echo "configure:9050: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9101: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9056 "configure"
+#line 9107 "configure"
@@ -9063,7 +9114,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9118: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9082,13 +9133,13 @@
-echo "configure:9086: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9137: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9092 "configure"
+#line 9143 "configure"
@@ -9099,7 +9150,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9118,13 +9169,13 @@
-echo "configure:9122: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9173: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9128 "configure"
+#line 9179 "configure"
@@ -9135,7 +9186,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9190: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9154,13 +9205,13 @@
-echo "configure:9158: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9209: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9164 "configure"
+#line 9215 "configure"
@@ -9171,7 +9222,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9226: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9190,13 +9241,13 @@
-echo "configure:9194: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9245: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9200 "configure"
+#line 9251 "configure"
@@ -9207,7 +9258,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9262: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9297,7 +9348,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:9301: checking for $ac_word" >&5
+echo "configure:9352: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -9346,10 +9397,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9350: checking for mysql_server_init" >&5
+echo "configure:9401: checking for mysql_server_init" >&5
-#line 9353 "configure"
+#line 9404 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -9375,7 +9426,7 @@
; return 0; }
EOF
-if { (eval echo configure:9379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -9427,7 +9478,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9431: checking whether to use SQLite" >&5
+echo "configure:9482: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -9447,7 +9498,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9451: checking for location of SQLite includes" >&5
+echo "configure:9502: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9473,15 +9524,15 @@
do
-echo "configure:9477: checking for $ac_hdr" >&5
+echo "configure:9528: checking for $ac_hdr" >&5
-#line 9480 "configure"
+#line 9531 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9485: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9536: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9524,7 +9575,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:9528: checking for location of SQLite library" >&5
+echo "configure:9579: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -9551,13 +9602,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:9555: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9606: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 9561 "configure"
+#line 9612 "configure"
@@ -9568,7 +9619,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:9572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9623: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9587,13 +9638,13 @@
-echo "configure:9591: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9642: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 9597 "configure"
+#line 9648 "configure"
@@ -9604,7 +9655,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:9608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9657,7 +9708,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:9661: checking whether to use FFMPEG" >&5
+echo "configure:9712: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -9677,7 +9728,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:9681: checking for location of FFMPEG includes" >&5
+echo "configure:9732: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -9703,15 +9754,15 @@
do
-echo "configure:9707: checking for $ac_hdr" >&5
+echo "configure:9758: checking for $ac_hdr" >&5
-#line 9710 "configure"
+#line 9761 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9715: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9766: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9747,15 +9798,15 @@
do
-echo "configure:9751: checking for $ac_hdr" >&5
+echo "configure:9802: checking for $ac_hdr" >&5
-#line 9754 "configure"
+#line 9805 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9759: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9810: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9791,15 +9842,15 @@
do
-echo "configure:9795: checking for $ac_hdr" >&5
+echo "configure:9846: checking for $ac_hdr" >&5
-#line 9798 "configure"
+#line 9849 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9803: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9854: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9842,7 +9893,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:9846: checking for location of FFMPEG library" >&5
+echo "configure:9897: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -9869,13 +9920,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:9873: checking for av_free in -lavutil" >&5
+echo "configure:9924: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 9879 "configure"
+#line 9930 "configure"
@@ -9886,7 +9937,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:9890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9941: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9905,13 +9956,13 @@
-echo "configure:9909: checking for av_free in -lavutil" >&5
+echo "configure:9960: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 9915 "configure"
+#line 9966 "configure"
@@ -9922,7 +9973,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:9926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9967,13 +10018,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:9971: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10022: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 9977 "configure"
+#line 10028 "configure"
@@ -9984,7 +10035,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:9988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10003,13 +10054,13 @@
-echo "configure:10007: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10058: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10013 "configure"
+#line 10064 "configure"
@@ -10020,7 +10071,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10065,13 +10116,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10069: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10120: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 10075 "configure"
+#line 10126 "configure"
@@ -10082,7 +10133,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10101,13 +10152,13 @@
-echo "configure:10105: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10156: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10111 "configure"
+#line 10162 "configure"
@@ -10118,7 +10169,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10177,7 +10228,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10181: checking whether to use OpenGL" >&5
+echo "configure:10232: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -10211,7 +10262,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10215: checking for location of OpenGL includes" >&5
+echo "configure:10266: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10237,15 +10288,15 @@
do
-echo "configure:10241: checking for $ac_hdr" >&5
+echo "configure:10292: checking for $ac_hdr" >&5
-#line 10244 "configure"
+#line 10295 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10249: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10300: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10279,7 +10330,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10283: checking for location of OpenGL library" >&5
+echo "configure:10334: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10308,13 +10359,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10312: checking for glBegin in -lGL" >&5
+echo "configure:10363: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10318 "configure"
+#line 10369 "configure"
@@ -10325,7 +10376,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10380: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10344,13 +10395,13 @@
-echo "configure:10348: checking for glBegin in -lGL" >&5
+echo "configure:10399: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10354 "configure"
+#line 10405 "configure"
@@ -10361,7 +10412,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10380,13 +10431,13 @@
-echo "configure:10384: checking for glBegin in -lGL" >&5
+echo "configure:10435: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10390 "configure"
+#line 10441 "configure"
@@ -10397,7 +10448,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10416,13 +10467,13 @@
-echo "configure:10420: checking for glBegin in -lGL" >&5
+echo "configure:10471: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10426 "configure"
+#line 10477 "configure"
@@ -10433,7 +10484,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10495,13 +10546,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:10499: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10550: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10505 "configure"
+#line 10556 "configure"
@@ -10512,7 +10563,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:10516: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10567: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10531,13 +10582,13 @@
-echo "configure:10535: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10586: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 10541 "configure"
+#line 10592 "configure"
@@ -10548,7 +10599,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:10552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10595,10 +10646,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:10599: checking for glXCreatePbuffer" >&5
+echo "configure:10650: checking for glXCreatePbuffer" >&5
-#line 10602 "configure"
+#line 10653 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -10621,7 +10672,7 @@
; return 0; }
EOF
-if { (eval echo configure:10625: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10676: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -10658,10 +10709,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:10662: checking for glXCreateGLXPixmap" >&5
+echo "configure:10713: checking for glXCreateGLXPixmap" >&5
-#line 10665 "configure"
+#line 10716 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -10684,7 +10735,7 @@
; return 0; }
EOF
-if { (eval echo configure:10688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -10727,7 +10778,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:10731: checking for location of OpenGL framework" >&5
+echo "configure:10782: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -10751,15 +10802,15 @@
do
-echo "configure:10755: checking for $ac_hdr" >&5
+echo "configure:10806: checking for $ac_hdr" >&5
-#line 10758 "configure"
+#line 10809 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10763: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10814: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10795,10 +10846,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:10799: checking for glBegin" >&5
+echo "configure:10850: checking for glBegin" >&5
-#line 10802 "configure"
+#line 10853 "configure"
which can conflict with char glBegin(); below. */
@@ -10821,7 +10872,7 @@
; return 0; }
EOF
-if { (eval echo configure:10825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -10858,10 +10909,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:10862: checking for gluBeginCurve" >&5
+echo "configure:10913: checking for gluBeginCurve" >&5
-#line 10865 "configure"
+#line 10916 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -10884,7 +10935,7 @@
; return 0; }
EOF
-if { (eval echo configure:10888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10939: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -10932,7 +10983,7 @@
-echo "configure:10936: checking for location of OpenGL includes" >&5
+echo "configure:10987: checking for location of OpenGL includes" >&5
@@ -10958,15 +11009,15 @@
do
-echo "configure:10962: checking for $ac_hdr" >&5
+echo "configure:11013: checking for $ac_hdr" >&5
-#line 10965 "configure"
+#line 11016 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10970: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11021: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11000,7 +11051,7 @@
-echo "configure:11004: checking for location of OpenGL library" >&5
+echo "configure:11055: checking for location of OpenGL library" >&5
@@ -11025,18 +11076,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11029: checking for OpenGL library" >&5
+echo "configure:11080: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 11033 "configure"
+#line 11084 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11040: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11091: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -11060,18 +11111,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11064: checking for GLU library" >&5
+echo "configure:11115: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 11068 "configure"
+#line 11119 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11120,7 +11171,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11124: checking whether to use Tcl/Tk" >&5
+echo "configure:11175: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -11140,7 +11191,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11144: checking for location of Tcl/Tk includes" >&5
+echo "configure:11195: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11166,15 +11217,15 @@
do
-echo "configure:11170: checking for $ac_hdr" >&5
+echo "configure:11221: checking for $ac_hdr" >&5
-#line 11173 "configure"
+#line 11224 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11178: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11229: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11211,15 +11262,15 @@
do
-echo "configure:11215: checking for $ac_hdr" >&5
+echo "configure:11266: checking for $ac_hdr" >&5
-#line 11218 "configure"
+#line 11269 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11223: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11274: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11253,7 +11304,7 @@
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11257: checking Tcl version" >&5
+echo "configure:11308: checking Tcl version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -11261,7 +11312,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 11265 "configure"
+#line 11316 "configure"
#include <stdio.h>
@@ -11273,7 +11324,7 @@
EOF
-if { (eval echo configure:11277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -11291,7 +11342,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11295: checking Tk version" >&5
+echo "configure:11346: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11299,7 +11350,7 @@
else
-#line 11303 "configure"
+#line 11354 "configure"
#include <stdio.h>
@@ -11311,7 +11362,7 @@
EOF
-if { (eval echo configure:11315: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -11340,7 +11391,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:11344: checking for location of Tcl/Tk library" >&5
+echo "configure:11395: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -11388,13 +11439,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:11392: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11443: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 11398 "configure"
+#line 11449 "configure"
@@ -11405,7 +11456,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11424,13 +11475,13 @@
-echo "configure:11428: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11479: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 11434 "configure"
+#line 11485 "configure"
@@ -11441,7 +11492,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11468,13 +11519,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11472: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11523: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 11478 "configure"
+#line 11529 "configure"
@@ -11485,7 +11536,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11489: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11504,13 +11555,13 @@
-echo "configure:11508: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11559: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 11514 "configure"
+#line 11565 "configure"
@@ -11521,7 +11572,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11548,13 +11599,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:11552: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:11603: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 11558 "configure"
+#line 11609 "configure"
@@ -11565,7 +11616,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11584,13 +11635,13 @@
-echo "configure:11588: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:11639: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 11594 "configure"
+#line 11645 "configure"
@@ -11601,7 +11652,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11656: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11679,13 +11730,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:11683: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:11734: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 11689 "configure"
+#line 11740 "configure"
@@ -11696,7 +11747,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:11700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11751: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11715,13 +11766,13 @@
-echo "configure:11719: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:11770: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11725 "configure"
+#line 11776 "configure"
@@ -11732,7 +11783,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:11736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11787: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11759,13 +11810,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11763: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:11814: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 11769 "configure"
+#line 11820 "configure"
@@ -11776,7 +11827,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:11780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11795,13 +11846,13 @@
-echo "configure:11799: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:11850: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11805 "configure"
+#line 11856 "configure"
@@ -11812,7 +11863,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:11816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11839,13 +11890,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:11843: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:11894: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 11849 "configure"
+#line 11900 "configure"
@@ -11856,7 +11907,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:11860: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11875,13 +11926,13 @@
-echo "configure:11879: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:11930: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11885 "configure"
+#line 11936 "configure"
@@ -11892,7 +11943,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:11896: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11991,7 +12042,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11995: checking whether to use ODBC" >&5
+echo "configure:12046: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -12010,7 +12061,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12014: checking for location of ODBC includes" >&5
+echo "configure:12065: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12036,15 +12087,15 @@
do
-echo "configure:12040: checking for $ac_hdr" >&5
+echo "configure:12091: checking for $ac_hdr" >&5
-#line 12043 "configure"
+#line 12094 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12048: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12099: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12078,7 +12129,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12082: checking for location of ODBC library" >&5
+echo "configure:12133: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12103,13 +12154,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12107: checking for SQLConnect in -lodbc" >&5
+echo "configure:12158: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 12113 "configure"
+#line 12164 "configure"
@@ -12120,7 +12171,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12145,13 +12196,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12149: checking for SQLConnect in -liodbc" >&5
+echo "configure:12200: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 12155 "configure"
+#line 12206 "configure"
@@ -12162,7 +12213,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12166: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12187,11 +12238,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12191: checking for ODBC library" >&5
+echo "configure:12242: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 12195 "configure"
+#line 12246 "configure"
#include <windows.h>
#include <sql.h>
@@ -12199,7 +12250,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:12203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12248,7 +12299,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12252: checking whether to use FFTW" >&5
+echo "configure:12303: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12267,7 +12318,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12271: checking for location of FFTW includes" >&5
+echo "configure:12322: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12293,15 +12344,15 @@
do
-echo "configure:12297: checking for $ac_hdr" >&5
+echo "configure:12348: checking for $ac_hdr" >&5
-#line 12300 "configure"
+#line 12351 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12305: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12356: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12329,15 +12380,15 @@
do
-echo "configure:12333: checking for $ac_hdr" >&5
+echo "configure:12384: checking for $ac_hdr" >&5
-#line 12336 "configure"
+#line 12387 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12341: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12392: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12365,15 +12416,15 @@
do
-echo "configure:12369: checking for $ac_hdr" >&5
+echo "configure:12420: checking for $ac_hdr" >&5
-#line 12372 "configure"
+#line 12423 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12377: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12428: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12419,7 +12470,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12423: checking for location of FFTW library" >&5
+echo "configure:12474: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12444,13 +12495,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12448: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12499: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12454 "configure"
+#line 12505 "configure"
@@ -12461,7 +12512,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:12465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12516: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12486,13 +12537,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12490: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12541: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 12496 "configure"
+#line 12547 "configure"
@@ -12503,7 +12554,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12528,13 +12579,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12532: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12583: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12538 "configure"
+#line 12589 "configure"
@@ -12545,7 +12596,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12600: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12602,7 +12653,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12606: checking whether to use BLAS" >&5
+echo "configure:12657: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -12623,7 +12674,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12627: checking for location of BLAS includes" >&5
+echo "configure:12678: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12643,7 +12694,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12647: checking for location of BLAS library" >&5
+echo "configure:12698: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12669,15 +12720,15 @@
do
-echo "configure:12673: checking for $ac_hdr" >&5
+echo "configure:12724: checking for $ac_hdr" >&5
-#line 12676 "configure"
+#line 12727 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12681: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12732: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12712,13 +12763,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12716: checking for dnrm2_ in -lblas" >&5
+echo "configure:12767: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 12722 "configure"
+#line 12773 "configure"
@@ -12729,7 +12780,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12733: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12748,13 +12799,13 @@
-echo "configure:12752: checking for dnrm2_ in -lblas" >&5
+echo "configure:12803: checking for dnrm2_ in -lblas" >&5
ac_save_LIBS="$LIBS"
LIBS="-lblas $MATHLIB -lg2c $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 12758 "configure"
+#line 12809 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12765,7 +12816,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12809,13 +12860,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12813: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12864: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 12819 "configure"
+#line 12870 "configure"
@@ -12826,7 +12877,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:12830: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12841,13 +12892,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12845: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12896: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 12851 "configure"
+#line 12902 "configure"
@@ -12858,7 +12909,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12873,13 +12924,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12877: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12928: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12883 "configure"
+#line 12934 "configure"
@@ -12890,7 +12941,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:12894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12935,16 +12986,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12939: checking for sgemm in $vlib_flags" >&5
+echo "configure:12990: checking for sgemm in $vlib_flags" >&5
-#line 12941 "configure"
+#line 12992 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:12948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -12962,13 +13013,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12966: checking for sgemm_ in -lblas" >&5
+echo "configure:13017: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 12972 "configure"
+#line 13023 "configure"
@@ -12979,7 +13030,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12994,13 +13045,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12998: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13049: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 13004 "configure"
+#line 13055 "configure"
@@ -13011,7 +13062,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:13015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13026,13 +13077,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13030: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13081: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 13036 "configure"
+#line 13087 "configure"
@@ -13043,7 +13094,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13047: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13077,13 +13128,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13081: checking for acosp in -lsunmath" >&5
+echo "configure:13132: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 13087 "configure"
+#line 13138 "configure"
@@ -13094,7 +13145,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:13098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13149: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13109,13 +13160,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13113: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13164: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 13119 "configure"
+#line 13170 "configure"
@@ -13126,7 +13177,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13156,13 +13207,13 @@
# Generic BLAS library
-echo "configure:13160: checking for sgemm_ in -lblas" >&5
+echo "configure:13211: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 13166 "configure"
+#line 13217 "configure"
@@ -13173,7 +13224,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13212,7 +13263,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13216: checking whether to use LAPACK" >&5
+echo "configure:13267: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13237,7 +13288,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13241: checking for location of LAPACK includes" >&5
+echo "configure:13292: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13257,7 +13308,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13261: checking for location of LAPACK library" >&5
+echo "configure:13312: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13283,15 +13334,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13287: checking for $ac_hdr" >&5
+echo "configure:13338: checking for $ac_hdr" >&5
-#line 13290 "configure"
+#line 13341 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13295: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13346: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13323,10 +13374,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13327: checking for dsegv_" >&5
+echo "configure:13378: checking for dsegv_" >&5
-#line 13330 "configure"
+#line 13381 "configure"
which can conflict with char dsegv_(); below. */
@@ -13349,7 +13400,7 @@
; return 0; }
EOF
-if { (eval echo configure:13353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13376,13 +13427,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13380: checking for desgv_ in -llapack" >&5
+echo "configure:13431: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 13386 "configure"
+#line 13437 "configure"
@@ -13393,7 +13444,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13448: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13425,13 +13476,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13429: checking for dgesv_ in -llapack" >&5
+echo "configure:13480: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13435 "configure"
+#line 13486 "configure"
@@ -13442,7 +13493,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13497: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13461,13 +13512,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:13465: checking for dgesv_ in -llapack" >&5
+echo "configure:13516: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13471 "configure"
+#line 13522 "configure"
@@ -13478,7 +13529,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13534,7 +13585,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13538: checking whether to use Cairo" >&5
+echo "configure:13589: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -13560,7 +13611,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:13564: checking for location of cairo includes" >&5
+echo "configure:13615: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -13586,15 +13637,15 @@
do
-echo "configure:13590: checking for $ac_hdr" >&5
+echo "configure:13641: checking for $ac_hdr" >&5
-#line 13593 "configure"
+#line 13644 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13598: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13649: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13630,7 +13681,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:13634: checking for location of cairo library" >&5
+echo "configure:13685: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -13650,7 +13701,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:13654: checking for cairo linking flags" >&5
+echo "configure:13705: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -13666,10 +13717,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13670: checking for cairo_create" >&5
+echo "configure:13721: checking for cairo_create" >&5
-#line 13673 "configure"
+#line 13724 "configure"
which can conflict with char cairo_create(); below. */
@@ -13692,7 +13743,7 @@
; return 0; }
EOF
-if { (eval echo configure:13696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -13726,10 +13777,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:13730: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:13781: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 13733 "configure"
+#line 13784 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -13752,7 +13803,7 @@
; return 0; }
EOF
-if { (eval echo configure:13756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -13785,10 +13836,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:13789: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:13840: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 13792 "configure"
+#line 13843 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -13811,7 +13862,7 @@
; return 0; }
EOF
-if { (eval echo configure:13815: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -13853,7 +13904,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:13857: checking whether to use FreeType" >&5
+echo "configure:13908: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -13872,7 +13923,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13876: checking for location of FreeType includes" >&5
+echo "configure:13927: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13898,15 +13949,15 @@
do
-echo "configure:13902: checking for $ac_hdr" >&5
+echo "configure:13953: checking for $ac_hdr" >&5
-#line 13905 "configure"
+#line 13956 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13910: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13961: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13940,7 +13991,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13944: checking for location of FreeType library" >&5
+echo "configure:13995: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13965,13 +14016,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13969: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14020: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 13975 "configure"
+#line 14026 "configure"
@@ -13982,7 +14033,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:13986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14023,7 +14074,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14027: checking whether to use NLS" >&5
+echo "configure:14078: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -14043,10 +14094,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14047: checking for gettext" >&5
+echo "configure:14098: checking for gettext" >&5
-#line 14050 "configure"
+#line 14101 "configure"
which can conflict with char gettext(); below. */
@@ -14069,7 +14120,7 @@
; return 0; }
EOF
-if { (eval echo configure:14073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -14087,13 +14138,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14091: checking for gettext in -lintl" >&5
+echo "configure:14142: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 14097 "configure"
+#line 14148 "configure"
@@ -14104,7 +14155,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:14108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14139,7 +14190,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14143: checking whether to use C++" >&5
+echo "configure:14194: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -14155,7 +14206,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:14159: checking for $ac_word" >&5
+echo "configure:14210: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14184,7 +14235,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14188: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14239: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14195,12 +14246,12 @@
cat > conftest.$ac_ext << EOF
-#line 14199 "configure"
+#line 14250 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:14204: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -14226,19 +14277,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14230: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14281: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14235: checking whether we are using GNU C++" >&5
+echo "configure:14286: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14242: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14293: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -14256,7 +14307,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14260: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14311: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14297,7 +14348,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14301: checking whether to use openDWG" >&5
+echo "configure:14352: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -14317,7 +14368,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14321: checking for location of openDGW includes" >&5
+echo "configure:14372: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14343,15 +14394,15 @@
do
-echo "configure:14347: checking for $ac_hdr" >&5
+echo "configure:14398: checking for $ac_hdr" >&5
-#line 14350 "configure"
+#line 14401 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14355: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14406: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14385,7 +14436,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14389: checking for location of openDWG library" >&5
+echo "configure:14440: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14426,7 +14477,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:14430: checking whether to use POSIX threads" >&5
+echo "configure:14481: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -14446,7 +14497,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:14450: checking for location of POSIX threads includes" >&5
+echo "configure:14501: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -14472,15 +14523,15 @@
do
-echo "configure:14476: checking for $ac_hdr" >&5
+echo "configure:14527: checking for $ac_hdr" >&5
-#line 14479 "configure"
+#line 14530 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14484: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14535: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14514,7 +14565,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:14518: checking for location of POSIX threads library" >&5
+echo "configure:14569: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -14539,10 +14590,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:14543: checking for pthread_create" >&5
+echo "configure:14594: checking for pthread_create" >&5
-#line 14546 "configure"
+#line 14597 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char pthread_create(); below. */
@@ -14565,7 +14616,7 @@
; return 0; }
EOF
-if { (eval echo configure:14569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -14592,13 +14643,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:14596: checking for pthread_create in -lpthread" >&5
+echo "configure:14647: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
LIBS="-lpthread $LIBS"
-#line 14602 "configure"
+#line 14653 "configure"
@@ -14609,7 +14660,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:14613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14664: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14665,7 +14716,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14669: checking for special C compiler options needed for large files" >&5
+echo "configure:14720: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -14673,7 +14724,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 14677 "configure"
+#line 14728 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -14689,7 +14740,7 @@
; return 0; }
EOF
-if { (eval echo configure:14693: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14744: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -14698,7 +14749,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 14702 "configure"
+#line 14753 "configure"
@@ -14714,7 +14765,7 @@
; return 0; }
EOF
-if { (eval echo configure:14718: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14769: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -14734,11 +14785,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14738: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14789: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 14742 "configure"
+#line 14793 "configure"
@@ -14754,14 +14805,14 @@
; return 0; }
EOF
-if { (eval echo configure:14758: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14809: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 14765 "configure"
+#line 14816 "configure"
#define _FILE_OFFSET_BITS 64
@@ -14779,7 +14830,7 @@
; return 0; }
EOF
-if { (eval echo configure:14783: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14834: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -14798,11 +14849,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14802: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14853: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 14806 "configure"
+#line 14857 "configure"
@@ -14818,14 +14869,14 @@
; return 0; }
EOF
-if { (eval echo configure:14822: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14873: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14829 "configure"
+#line 14880 "configure"
#define _LARGE_FILES 1
@@ -14843,7 +14894,7 @@
; return 0; }
EOF
-if { (eval echo configure:14847: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14898: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -14862,25 +14913,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14866: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14917: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 14870 "configure"
+#line 14921 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14877: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14928: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14884 "configure"
+#line 14935 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -14889,7 +14940,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14893: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14944: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -14910,10 +14961,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14914: checking if system supports Large Files at all" >&5
+echo "configure:14965: checking if system supports Large Files at all" >&5
-#line 14917 "configure"
+#line 14968 "configure"
#include <stdio.h>
@@ -14945,7 +14996,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:14949: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15000: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -14974,7 +15025,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:14978: checking whether to use Python" >&5
+echo "configure:15029: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -14994,7 +15045,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14998: checking for $ac_word" >&5
+echo "configure:15049: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -15036,15 +15087,15 @@
do
-echo "configure:15040: checking for $ac_hdr" >&5
+echo "configure:15091: checking for $ac_hdr" >&5
-#line 15043 "configure"
+#line 15094 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15048: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15099: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15085,7 +15136,7 @@
# Extract the first word of "swig", so it can be a program name with args.
set dummy swig; ac_word=$2
-echo "configure:15089: checking for $ac_word" >&5
+echo "configure:15140: checking for $ac_word" >&5
case "$SWIG" in
@@ -15131,7 +15182,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15135: checking whether to use wxWidgets" >&5
+echo "configure:15186: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -15151,7 +15202,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:15155: checking for $ac_word" >&5
+echo "configure:15206: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -15199,7 +15250,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15203: checking wxWidgets version" >&5
+echo "configure:15254: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -15222,15 +15273,15 @@
do
-echo "configure:15226: checking for $ac_hdr" >&5
+echo "configure:15277: checking for $ac_hdr" >&5
-#line 15229 "configure"
+#line 15280 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15234: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15285: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2009-08-08 09:50:20 UTC (rev 38637)
+++ grass/trunk/configure.in 2009-08-08 09:52:05 UTC (rev 38638)
@@ -761,7 +761,7 @@
fi
LOC_CHECK_INCLUDES(geos_c.h,GEOS,$GEOS_CFLAGS)
+ LOC_CHECK_LIBS(geos,GEOSGeom_createLinearRing,GEOS,$GEOS_LIBS,GEOS_LIBS)
AC_DEFINE(HAVE_GEOS)
fi
