[GRASS-SVN] r38655 - grass/trunk/lib/vector/diglib
svn_grass at osgeo.org
Sun Aug 9 11:58:48 EDT 2009
Author: mmetz
Date: 2009-08-09 11:58:48 -0400 (Sun, 09 Aug 2009)
New Revision: 38655
grass/trunk/lib/vector/diglib/port_init.c
grass/trunk/lib/vector/diglib/port_test.c
grass/trunk/lib/vector/diglib/spindex_rw.c
spindex_rw adjusted to new rtree, safer portability
Modified: grass/trunk/lib/vector/diglib/port_init.c
--- grass/trunk/lib/vector/diglib/port_init.c 2009-08-09 15:56:35 UTC (rev 38654)
+++ grass/trunk/lib/vector/diglib/port_init.c 2009-08-09 15:58:48 UTC (rev 38655)
@@ -83,7 +83,7 @@
#include <grass/glocale.h>
#define TEST_PATTERN 1.3333
-#define OFF_T_TEST 0x0102030405060708
+#define OFF_T_TEST 0x0102030405060708LL
#define LONG_TEST 0x01020304
#define INT_TEST 0x01020304
#define SHORT_TEST 0x0102
Modified: grass/trunk/lib/vector/diglib/port_test.c
--- grass/trunk/lib/vector/diglib/port_test.c 2009-08-09 15:56:35 UTC (rev 38654)
+++ grass/trunk/lib/vector/diglib/port_test.c 2009-08-09 15:58:48 UTC (rev 38655)
@@ -58,7 +58,7 @@
Modified: grass/trunk/lib/vector/diglib/spindex_rw.c
--- grass/trunk/lib/vector/diglib/spindex_rw.c 2009-08-09 15:56:35 UTC (rev 38654)
+++ grass/trunk/lib/vector/diglib/spindex_rw.c 2009-08-09 15:58:48 UTC (rev 38655)
@@ -244,7 +244,7 @@
G_debug(1, "spidx body offset %lu", length);
if (ptr->spidx_head_size != length)
- G_fatal_error("wrong sidx head length %d", ptr->spidx_head_size);
+ G_fatal_error("wrong sidx head length %ld", ptr->spidx_head_size);
return (0);
@@ -514,13 +514,13 @@
r = &(b->rect);
if (level == 0)
- fprintf(fp, " id = %d ", (int)b->child);
+ fprintf(fp, " id = %d ", b->child.id);
fprintf(fp, " %f %f %f %f %f %f\n", r->boundary[0], r->boundary[1],
r->boundary[2], r->boundary[3], r->boundary[4], r->boundary[5]);
if (level > 0) {
- rtree_dump_node(fp, b->child, with_z);
+ rtree_dump_node(fp, b->child.ptr, with_z);
return 0;
@@ -536,25 +536,29 @@
int rtree_dump_node(FILE * fp, struct Node *n, int with_z)
- int i, nn;
+ int i;
- /* yuck! recursive traversal filling up memory */
- /* TODO: change to non-recursive method as used in rtree_copy_inorder */
+ /* recursive nearly-but-a-bit-messy depth-first pre-order traversal
+ * potentially filling up memory */
+ /* TODO: change to non-recursive depth-first post-order traversal */
/* left for comparison with GRASS6.x */
fprintf(fp, "Node level=%d count=%d\n", n->level, n->count);
if (n->level > 0)
- nn = NODECARD;
+ for (i = 0; i < NODECARD; i++) {
+ if (n->branch[i].child.ptr) {
+ fprintf(fp, " Branch %d", i);
+ rtree_dump_branch(fp, &n->branch[i], with_z, n->level);
else
- nn = LEAFCARD;
- for (i = 0; i < nn; i++) {
- if (n->branch[i].child) {
- fprintf(fp, " Branch %d", i);
- rtree_dump_branch(fp, &n->branch[i], with_z, n->level);
+ for (i = 0; i < LEAFCARD; i++) {
+ if (n->branch[i].child.id) {
return 0;
@@ -629,9 +633,9 @@
if (s[top].sn->level > 0) { /* this is an internal node in the tree */
for (i = s[top].branch_id; i < t->nodecard; i++) {
s[top].pos[i] = 0;
- if (n->branch[i].child != NULL) {
+ if (n->branch[i].child.ptr != NULL) {
s[top++].branch_id = i + 1;
- s[top].sn = n->branch[i].child;
+ s[top].sn = n->branch[i].child.ptr;
s[top].branch_id = 0;
writeout = 0;
break;
@@ -654,7 +658,7 @@
dig__fwrite_port_D(s[top].sn->branch[j].rect.boundary,
NUMSIDES, fp);
if (s[top].sn->level == 0) /* leaf node */
- s[top].pos[j] = (off_t) s[top].sn->branch[j].child;
+ s[top].pos[j] = (off_t) s[top].sn->branch[j].child.id;
dig__fwrite_port_O(&(s[top].pos[j]), 1, fp, off_t_size);
@@ -688,7 +692,7 @@
struct RTree *t, int off_t_size)
struct Node *newnode = NULL;
- int i, j, writeout;
+ int i, j, loadnode;
struct spidxstack
off_t childpos[MAXCARD];
@@ -710,12 +714,16 @@
for (j = 0; j < MAXCARD; j++) {
dig__fread_port_D(s[top].sn.branch[j].rect.boundary, NUMSIDES, fp);
dig__fread_port_O(&(s[top].childpos[j]), 1, fp, off_t_size);
- if (s[top].sn.level == 0 && s[top].childpos[j]) { /* leaf node */
- s[top].sn.branch[j].child =
- (struct Node *)s[top].childpos[j];
+ if (s[top].sn.level == 0) {
+ if (s[top].childpos[j]) { /* leaf node */
+ s[top].sn.branch[j].child.id =
+ (int)s[top].childpos[j];
+ else
+ s[top].sn.branch[j].child.id = 0;
else {
- s[top].sn.branch[j].child = NULL;
+ s[top].sn.branch[j].child.ptr = NULL;
@@ -726,7 +734,7 @@
while (top >= 0) {
last = &(s[top]);
- writeout = 1;
+ loadnode = 1;
if (s[top].sn.level > 0) { /* this is an internal node in the tree */
if (s[top].childpos[i] > 0) {
@@ -741,30 +749,34 @@
NUMSIDES, fp);
off_t_size);
+ else
else {
- writeout = 0;
+ loadnode = 0;
break;
else if (last->childpos[i] < 0)
G_fatal_error("corrupt spatial index");
- if (writeout) {
- /* nothing else found, ready to write out */
+ if (loadnode) {
+ /* nothing else found, ready to load */
s[top].branch_id = t->nodecard;
- if (writeout) {
+ if (loadnode) {
/* not writeout but load node to memory */
- newnode = RTreeNewNode(t);
+ newnode = RTreeNewNode(t, s[top].sn.level);
/* copy from stack node */
newnode->level = s[top].sn.level;
newnode->count = s[top].sn.count;
@@ -776,7 +788,7 @@
top--;
/* update child of parent node */
if (top >= 0) {
- s[top].sn.branch[s[top].branch_id - 1].child = newnode;
+ s[top].sn.branch[s[top].branch_id - 1].child.ptr = newnode;
