[GRASS-SVN] r38658 - grass/trunk/raster3d/r3.out.v5d
svn_grass at osgeo.org
Sun Aug 9 12:11:10 EDT 2009
Author: mmetz
Date: 2009-08-09 12:11:10 -0400 (Sun, 09 Aug 2009)
New Revision: 38658
grass/trunk/raster3d/r3.out.v5d/Makefile
grass/trunk/raster3d/r3.out.v5d/main.c
grass/trunk/raster3d/r3.out.v5d/v5d.c
grass/trunk/raster3d/r3.out.v5d/v5d.h
r3.out.v5d LFS-safe, awaits testing
Modified: grass/trunk/raster3d/r3.out.v5d/Makefile
--- grass/trunk/raster3d/r3.out.v5d/Makefile 2009-08-09 16:03:50 UTC (rev 38657)
+++ grass/trunk/raster3d/r3.out.v5d/Makefile 2009-08-09 16:11:10 UTC (rev 38658)
@@ -5,6 +5,11 @@
#for Linux/x86 et al. (needs fix for MacOSX)
EXTRA_CFLAGS = -DLITTLE
+#compile if LFS Large File Support present:
+ifneq ($(USE_LARGEFILES),)
+ EXTRA_CFLAGS += -D_FILE_OFFSET_BITS=64
+endif
LIBES = $(G3DLIB) $(GISLIB)
DEPENDENCIES = $(G3DDEP) $(GISDEP)
Modified: grass/trunk/raster3d/r3.out.v5d/main.c
--- grass/trunk/raster3d/r3.out.v5d/main.c 2009-08-09 16:03:50 UTC (rev 38657)
+++ grass/trunk/raster3d/r3.out.v5d/main.c 2009-08-09 16:11:10 UTC (rev 38658)
@@ -256,7 +256,7 @@
/* Create the output v5d file */
/*AV*/
- if (!v5dCreate(fileout, NumTimes, NumVars, rows, cols, Nl, VarName,
+ if (!v5dCreate(fileout, NumTimes, NumVars, rows, cols, Nl, (const char (*)[10])VarName,
TimeStamp, DateStamp, CompressMode, Projection,
ProjArgs, Vertical, VertArgs))
G_fatal_error(_("Error: couldn't create %s"), fileout);
Modified: grass/trunk/raster3d/r3.out.v5d/v5d.c
--- grass/trunk/raster3d/r3.out.v5d/v5d.c 2009-08-09 16:03:50 UTC (rev 38657)
+++ grass/trunk/raster3d/r3.out.v5d/v5d.c 2009-08-09 16:11:10 UTC (rev 38658)
@@ -64,12 +64,12 @@
+#include <grass/config.h>
#include <assert.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <math.h>
-#include <grass/config.h>
#include <grass/gis.h>
#include "binio.h"
#include "v5d.h"
@@ -337,8 +337,8 @@
else {
printf("Compression: %d bytes per gridpoint.\n", v->CompressMode);
- printf("header size=%d\n", v->FirstGridPos);
- printf("sizeof(v5dstruct)=%d\n", sizeof(v5dstruct));
+ printf("header size=%d\n", (int)v->FirstGridPos);
+ printf("sizeof(v5dstruct)=%d\n", (int)sizeof(v5dstruct));
printf("\n");
printf("NumVars = %d\n", v->NumVars);
@@ -465,9 +465,10 @@
* time, var - which timestep and variable.
* Return: file offset in bytes
-static int grid_position(const v5dstruct * v, int time, int var)
+static off_t grid_position(const v5dstruct * v, int time, int var)
- int pos, i;
+ int i;
+ off_t pos;
assert(time >= 0);
assert(var >= 0);
@@ -1309,7 +1310,7 @@
/* Older COMP5D format */
int gridtimes, gridparms;
int i, j, it, iv, nl;
- int gridsize;
+ off_t gridsize;
float hgttop, hgtinc;
/*char *compgrid; */
@@ -2026,7 +2027,8 @@
int v5dReadCompressedGrid(v5dstruct * v, int time, int var,
float *ga, float *gb, void *compdata)
- int pos, n, k;
+ int n, k;
+ off_t pos;
if (time < 0 || time >= v->NumTimes) {
printf("Error in v5dReadCompressedGrid: bad timestep argument (%d)\n",
@@ -2178,7 +2180,8 @@
static int write_v5d_header(v5dstruct * v)
- int var, time, filler, maxnl;
+ int var, time, maxnl;
+ off_t filler;
int f;
int newfile;
@@ -2407,7 +2410,8 @@
const float *ga, const float *gb,
const void *compdata)
- int pos, n, k;
+ int n, k;
+ off_t pos;
/* simple error checks */
if (v->Mode != 'w') {
Modified: grass/trunk/raster3d/r3.out.v5d/v5d.h
--- grass/trunk/raster3d/r3.out.v5d/v5d.h 2009-08-09 16:03:50 UTC (rev 38657)
+++ grass/trunk/raster3d/r3.out.v5d/v5d.h 2009-08-09 16:11:10 UTC (rev 38658)
@@ -26,6 +26,7 @@
#ifndef V5D_H
#define V5D_H
+#include <sys/types.h>
* A numeric version number which we can test for in utility programs which
@@ -232,10 +233,10 @@
unsigned int FileFormat; /* COMP5D file version or 0 if .v5d */
int FileDesc; /* Unix file descriptor */
char Mode; /* 'r' = read, 'w' = write */
- int CurPos; /* current position of file pointer */
- int FirstGridPos; /* position of first grid in file */
- int GridSize[MAXVARS]; /* size of each grid */
- int SumGridSizes; /* sum of GridSize[0..NumVars-1] */
+ off_t CurPos; /* current position of file pointer */
+ off_t FirstGridPos; /* position of first grid in file */
+ off_t GridSize[MAXVARS]; /* size of each grid */
+ off_t SumGridSizes; /* sum of GridSize[0..NumVars-1] */
} v5dstruct;
