[GRASS-SVN] r38692 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Tue Aug 11 09:04:11 EDT 2009
Author: aghisla
Date: 2009-08-11 09:04:10 -0400 (Tue, 11 Aug 2009)
New Revision: 38692
grass-addons/vector/v.krige/v.krige.py
added Help button
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-08-11 12:50:10 UTC (rev 38691)
+++ grass-addons/vector/v.krige/v.krige.py 2009-08-11 13:04:10 UTC (rev 38692)
@@ -103,7 +103,11 @@
GUIModulesPath = os.path.join(os.getenv("GISBASE"), "etc", "wxpython", "gui_modules")
sys.path.append(GUIModulesPath)
+GUIPath = os.path.join(os.getenv("GISBASE"), "etc", "wxpython")
+sys.path.append(GUIPath)
+from gis_set import HelpWindow as HelpWindow
import globalvar
if not os.getenv("GRASS_WXBUNDLED"):
globalvar.CheckForWx()
@@ -209,6 +213,7 @@
FittedVariogram = VariogramModel.r['var_model'][0] # stored in global namespace for further use
return VariogramModel.r['var_model'][0]
#@TODO: write what model automap has chosen. [Markus' suggestion]
+ ##VariogramModel.r['model'][0][1] # in R, Variogram$model[2]
else:
DataVariogram = robjects.r['variogram'](formula, inputdata)
VariogramModel = robjects.r['fit.variogram'](DataVariogram,
@@ -216,7 +221,7 @@
model = model,
nugget = nugget,
range = range))
- print VariogramModel.names # r names() function
+ #print VariogramModel.names # r names() function
def DoKriging(self, formula, inputdata, grid, model, block):
@@ -365,11 +370,14 @@
# 4. Run Button and Quit Button
ButtonSizer = wx.BoxSizer(wx.HORIZONTAL)
+ HelpButton = wx.Button(self, id=wx.ID_HELP)
+ HelpButton.Bind(wx.EVT_BUTTON, self.OnHelpButton)
QuitButton = wx.Button(self, id=wx.ID_EXIT)
QuitButton.Bind(wx.EVT_BUTTON, self.OnCloseWindow)
self.RunButton = wx.Button(self, id=wx.ID_ANY, label=_("Run")) # no stock ID for Run button..
self.RunButton.Bind(wx.EVT_BUTTON, self.OnRunButton)
self.RunButton.Enable(False) # disable it on loading the interface, as input map is not set
+ ButtonSizer.Add(HelpButton, proportion=0, flag=wx.ALIGN_LEFT | wx.ALL, border=self.border)
ButtonSizer.Add(QuitButton, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=self.border)
ButtonSizer.Add(self.RunButton, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=self.border)
@@ -383,6 +391,7 @@
# last action of __init__: update imput data list.
# it's performed in the few seconds gap while user examines interface before clicking anything.
+ #@TODO: implement a splashcreen IF the maps cause a noticeable lag [markus' suggestion]
self.InputDataMap.GetElementList()
def CreatePage(self, package):
@@ -395,12 +404,23 @@
def OnButtonRefresh(self, event):
""" Forces refresh of list of available layers. """
def OnCloseWindow(self, event):
""" Cancel button pressed"""
self.parent.Close()
event.Skip()
+ def OnHelpButton(self, event):
+ #file = os.path.join(self.gisbase, "docs", "html", "helptext.html")
+ file = os.path.join(os.path.curdir, "description.html")
+ helpFrame = HelpWindow(parent=self, id=wx.ID_ANY,
+ title=_("GRASS Quickstart"),
+ size=(640, 480),
+ file=file)
+ helpFrame.Show(True)
+ event.Skip()
def OnInputDataChanged(self, event):
""" Refreshes list of columns and fills output map name TextCtrl """
MapName = event.GetString()
