[GRASS-SVN] r38701 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Wed Aug 12 12:37:48 EDT 2009
Author: aghisla
Date: 2009-08-12 12:37:47 -0400 (Wed, 12 Aug 2009)
New Revision: 38701
grass-addons/vector/v.krige/v.krige.py
added Help button - if input data has null z values, abort instead of crashing - output raster history includes kriging options [on the train back from Trento]
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-08-12 15:53:03 UTC (rev 38700)
+++ grass-addons/vector/v.krige/v.krige.py 2009-08-12 16:37:47 UTC (rev 38701)
@@ -148,14 +148,15 @@
if not haveRpy2:
sys.exit(1)
-# R packages gstat or geoR
+# R packages check.
+#@FIXME: it leaves a Rtmpxxxx folder into the make tempfolder and causes make complain. [markus]
for each in ["gstat", "spgrass6"]:
if not robjects.r.require(each, quietly=True)[0]:
sys.exit(_("R package " + each + " is missing. Install it and re-run v.krige."))
# globals
maxint = 1e6 # instead of sys.maxint, not working with SpinCtrl on 64bit [reported by Bob Moskovitz]
+Region = grass.region()
Command = None
InputData = None
Variogram = None
@@ -166,9 +167,9 @@
class Controller():
""" Executes analysis. For the moment, only with gstat functions."""
- def ImportMap(self, map):
- """ Adds x,y columns to the GRASS map and then imports it in R. """
- # adds x, y columns if needed.
+ def ImportMap(self, map, column):
+ """ Adds x,y columns to the GRASS map and then imports it in R.
+ Checks for NULL values in the provided column and exits if they are present."""
#@NOTE: it alters original data. Is it correct? Shall I remove those columns
# if they were absent from original data?
cols = grass.vector_columns(map=map, layer=1)
@@ -176,10 +177,14 @@
grass.run_command('v.db.addcol', map = map,
columns = 'x double precision, y double precision')
grass.run_command('v.to.db', map = map, option = 'coor', col = 'x,y')
+ nulls = int(grass.parse_command('v.univar', map=map, column=column, type='point', \
+ parse = (grass.parse_key_val, \
+ {'sep':': '}))['number of NULL attributes'])
+ if nulls > 0:
+ grass.fatal(_("%d NULL value(s) in the selected column - unable to perform kriging.") % nulls)
return robjects.r.readVECT6(map, type= 'point')
def CreateGrid(self, inputdata):
- Region = grass.region()
Grid = robjects.r.gmeta2grd()
# addition of coordinates columns into dataframe.
@@ -232,22 +237,21 @@
KrigingResult = robjects.r.krige(formula, inputdata, grid, model, **DottedParams)
return KrigingResult
- def ExportMap(self, map, column, name, overwrite):
+ def ExportMap(self, map, column, name, overwrite, command):
# add kriging parameters to raster map history
+ robjects.r.writeRAST6(map, vname = name, zcol = column, overwrite = overwrite)
grass.run_command('r.support',
- map = map,
+ map = name,
title = 'Kriging output',
- history = 'Issued from command: ')
+ history = 'Issued from command v.krige ' + command) #@TODO: add parameters
- robjects.r.writeRAST6(map, vname = name, zcol = column, overwrite = overwrite)
def Run(self, input, column, output, package, sill, nugget, range, logger, \
- overwrite, model, block, output_var, **kwargs):
- """ Wrapper for all functions above. """
+ overwrite, model, block, output_var, command, **kwargs):
+ """ Wrapper for all functions above. """
+ logger.message(_("Processing %d cells. Computing time raises exponentially with resolution." % Region['cells']))
logger.message(_("Importing data..."))
if globals()["InputData"] is None:
- globals()["InputData"] = self.ImportMap(input)
+ globals()["InputData"] = self.ImportMap(input, column)
#print(robjects.r.slot(InputData, 'data').names)
logger.message("Imported.")
GridPredicted = self.CreateGrid(InputData)
@@ -270,12 +274,14 @@
self.ExportMap(map = KrigingResult,
column='var1.pred',
name = output,
- overwrite = overwrite)
+ overwrite = overwrite,
+ command = command)
if output_var is not '':
column='var1.var',
name = output_var,
class KrigingPanel(wx.Panel):
""" Main panel. Contains all widgets except Menus and Statusbar. """
@@ -675,17 +681,8 @@
else:
#CLI
options, flags = argv
- globals()['Command'] = " ".join(["%s=%s" % (k, v) for k, v in options.items()])
- print Command
#@TODO: Work on verbosity. Sometimes it's too verbose (R), sometimes not enough.
- #print options
- # re-cast integers from strings, as parser() cast everything to string.
- for each in ("sill","nugget","range"):
- if options[each] is not '':
- options[each] = int(options[each])
- else:
- options[each] = robjects.r('''NA''')
if grass.find_file(options['input'], element = 'vector')['fullname'] is '':
grass.fatal(_("option: <input>: Vector map not found."))
@@ -710,8 +707,23 @@
robjects.r.require("automap")
except ImportError, e:
grass.fatal(_("R package automap is missing, no variogram autofit available."))
- #print options
+ #@TODO: let GRASS remount its commandstring. Until then, keep that 4 lines below.
+ #print grass.write_command(argv)
+ command = ""
+ notnulloptions = {}
+ for k, v in options.items():
+ if v is not '':
+ notnulloptions[k] = v
+ command = command.join("%s=%s " % (k, v) for k, v in notnulloptions.items())
+ #print command
+ # re-cast integers from strings, as parser() cast everything to string.
+ for each in ("sill","nugget","range"):
+ if options[each] is not '':
+ options[each] = int(options[each])
+ else:
+ options[each] = robjects.r('''NA''')
controller = Controller()
controller.Run(input = options['input'],
column = options['column'],
@@ -724,6 +736,7 @@
nugget = options['nugget'],
range = options['range'],
output_var = options['output_var'],
+ command = command,
logger = grass)
if __name__ == '__main__':
