[GRASS-SVN] r38716 - in grass/trunk/scripts: . v.db.droprow
svn_grass at osgeo.org
Fri Aug 14 04:13:39 EDT 2009
Author: martinl
Date: 2009-08-14 04:13:38 -0400 (Fri, 14 Aug 2009)
New Revision: 38716
Added:
grass/trunk/scripts/v.db.droprow/
grass/trunk/scripts/v.db.droprow/Makefile
grass/trunk/scripts/v.db.droprow/v.db.droprow.html
grass/trunk/scripts/v.db.droprow/v.db.droprow.py
grass/trunk/scripts/Makefile
v.db.droprow backported from devbr6, pythonized
Modified: grass/trunk/scripts/Makefile
--- grass/trunk/scripts/Makefile 2009-08-14 03:03:09 UTC (rev 38715)
+++ grass/trunk/scripts/Makefile 2009-08-14 08:13:38 UTC (rev 38716)
@@ -44,6 +44,7 @@
v.db.addtable \
v.db.join \
v.db.dropcolumn \
+ v.db.droprow \
v.db.droptable \
v.db.renamecolumn \
v.db.reconnect.all \
Added: grass/trunk/scripts/v.db.droprow/Makefile
--- grass/trunk/scripts/v.db.droprow/Makefile (rev 0)
+++ grass/trunk/scripts/v.db.droprow/Makefile 2009-08-14 08:13:38 UTC (rev 38716)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.db.droprow
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass/trunk/scripts/v.db.droprow/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-sh
Added: svn:keywords
+ Author Date Id
Added: svn:eol-style
+ native
Added: grass/trunk/scripts/v.db.droprow/v.db.droprow.html
--- grass/trunk/scripts/v.db.droprow/v.db.droprow.html (rev 0)
+++ grass/trunk/scripts/v.db.droprow/v.db.droprow.html 2009-08-14 08:13:38 UTC (rev 38716)
@@ -0,0 +1,53 @@
+<h2>DESCRIPTION</h2>
+<em>v.db.droprow</em> removes vector object(s) (point, line, area, face etc.)
+from a vector map through attribute selection in the table connected
+to the given vector map. It automatically checks the connection for the specified
+layer.
+<h2>NOTES</h2>
+v.db.droprow is a front-end to <em>v.extract</em> (reverse selection)
+to allow easier usage.
+The existing database connection(s) can be verified with <em>v.db.connect</em>.
+<h2>EXAMPLES</h2>
+Dropping all vector points without elevation attribute (Spearfish data set):<br>
+<div class="code"><pre>
+g.region rast=elevation.10m
+v.random output=rand5k_elev n=5000
+v.db.addtable map=rand5k_elev column="elevation double precision"
+v.what.rast vect=rand5k_elev rast=elevation.10m column=elevation
+# verify absence of some elevation attributes ("number of NULL attributes"):
+v.univar rand5k_elev type=point column=elevation
+# Remove all vector points lacking elevation attribute
+v.db.droprow rand5k_elev output=rand5k_elev_filt where="elevation IS NULL"
+# verify:
+v.univar rand5k_elev_filt type=point column=elevation
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a HREF="db.droptable.html">db.droptable</a></em>,
+<em><a HREF="db.execute.html">db.execute</a></em>,
+<em><a HREF="v.db.addcol.html">v.db.addcol</a></em>,
+<em><a HREF="v.db.addtable.html">v.db.addtable</a></em>,
+<em><a HREF="v.db.connect.html">v.db.connect</a></em>,
+<em><a HREF="v.db.dropcol.html">v.db.dropcol</a></em>,
+<em><a HREF="v.db.droptable.html">v.db.droptable</a></em>,
+<em><a HREF="v.db.select.html">v.db.select</a></em>,
+<em><a HREF="v.db.update.html">v.db.update</a></em>
+<h2>AUTHOR</h2>
+Markus Neteler
+<p><i>Last changed: $Date$</i>
Property changes on: grass/trunk/scripts/v.db.droprow/v.db.droprow.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass/trunk/scripts/v.db.droprow/v.db.droprow.py
--- grass/trunk/scripts/v.db.droprow/v.db.droprow.py (rev 0)
+++ grass/trunk/scripts/v.db.droprow/v.db.droprow.py 2009-08-14 08:13:38 UTC (rev 38716)
@@ -0,0 +1,84 @@
+#!/usr/bin/env python
+# MODULE: v.db.droprow
+# AUTHOR(S): Markus Neteler
+# Pythonized by Martin Landa
+# PURPOSE: Interface to v.extract -r to drop ...
+# COPYRIGHT: (C) 2009 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Removes a vector object (point, line, area, face etc.) from a vector map through attribute selection.
+#% keywords: vector
+#% keywords: database
+#% keywords: attribute table
+#%end
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,vector,vector
+#% key_desc : name
+#% description: Vector map for which to drop vector objects
+#% required : yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new,vector,vector
+#% key_desc : name
+#% description: Name for output vector map
+#% required : yes
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% description: Layer of attribute table to use for selection
+#% answer: 1
+#% required : no
+#%end
+#%option
+#% key: where
+#% type: string
+#% description: WHERE conditions for vector delete, without 'where' keyword (e.g. "elevation IS NULL")
+#% required : yes
+#%end
+import sys
+import grass.script as grass
+def main():
+ file = grass.find_file(element = 'vector', name = options['input'],
+ mapset = grass.gisenv()['MAPSET'])['name']
+ if not file:
+ grass.fatal(_("Vector map <%s> not found in current mapset") % \
+ options['input'])
+ # delete vectors via reverse selection
+ ret = grass.run_command('v.extract',
+ flags = 'r',
+ input = options['input'], layer = options['layer'],
+ output = options['output'], where = options['where'])
+ if ret != 0:
+ grass.fatal(_("Error in 'where' statement"))
+ # write cmd history:
+ grass.vector_history(map = options['output'])
+ return 0
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Property changes on: grass/trunk/scripts/v.db.droprow/v.db.droprow.py
Added: svn:executable
+ text/x-python
Added: svn:keywords
+ Author Date Id
+ native
