[GRASS-SVN] r38720 - grass/branches/develbranch_6/scripts/v.db.droprow
Fri Aug 14 06:30:46 EDT 2009
Author: neteler
Date: 2009-08-14 06:30:46 -0400 (Fri, 14 Aug 2009)
New Revision: 38720
   grass/branches/develbranch_6/scripts/v.db.droprow/v.db.droprow
input map can be anywhere in search path
Modified: grass/branches/develbranch_6/scripts/v.db.droprow/v.db.droprow
--- grass/branches/develbranch_6/scripts/v.db.droprow/v.db.droprow	2009-08-14 10:21:50 UTC (rev 38719)
+++ grass/branches/develbranch_6/scripts/v.db.droprow/v.db.droprow	2009-08-14 10:30:46 UTC (rev 38720)
@@ -83,9 +83,9 @@
 : ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
 # does map exist in CURRENT mapset?
-eval `g.findfile element=vector file=$GIS_OPT_INPUT mapset=$MAPSET`
+eval `g.findfile element=vector file=$GIS_OPT_INPUT`
 if [ ! "$file" ] ; then
-   g.message -e "Vector map <$GIS_OPT_INPUT> not found in current mapset"
+   g.message -e "Vector map <$GIS_OPT_INPUT> not found"
    exit 1
 fi
