[GRASS-SVN] r38730 - grass-addons/vector/v.in.gshhs
svn_grass at osgeo.org
Fri Aug 14 12:44:27 EDT 2009
Author: mmetz
Date: 2009-08-14 12:44:26 -0400 (Fri, 14 Aug 2009)
New Revision: 38730
grass-addons/vector/v.in.gshhs/gshhs.h
grass-addons/vector/v.in.gshhs/main.c
version 2.0 supported, more reasonable error messages
Modified: grass-addons/vector/v.in.gshhs/gshhs.h
--- grass-addons/vector/v.in.gshhs/gshhs.h 2009-08-14 13:30:34 UTC (rev 38729)
+++ grass-addons/vector/v.in.gshhs/gshhs.h 2009-08-14 16:44:26 UTC (rev 38730)
@@ -48,8 +48,9 @@
#define SEEK_CUR 1
#endif
-#define GSHHS_DATA_VERSION 6 /* For v1.5 data set */
-#define GSHHS_PROG_VERSION "1.9"
+#define GSHHS_DATA_RELEASE 7 /* For v2.0 data set */
+#define GSHHS_DATA_VERSION "2.0" /* For v2.0 data set */
+#define GSHHS_PROG_VERSION "1.12"
#define GSHHS_SCL 1.0e-6 /* COnvert micro-degrees to degrees */
@@ -57,7 +58,7 @@
#define swabi4(i4) (((i4) >> 24) + (((i4) >> 8) & 65280) + (((i4) & 65280) << 8) + (((i4) & 255) << 24))
-struct GSHHS { /* Global Self-consistent Hierarchical High-resolution Shorelines */
+struct GSHHS1 { /* Global Self-consistent Hierarchical High-resolution Shorelines */
int id; /* Unique polygon id number, starting at 0 */
int n; /* Number of points in this polygon */
int flag; /* = level + version << 8 + greenwich << 16 + source << 24 */
@@ -71,6 +72,24 @@
int area; /* Area of polygon in 1/10 km^2 */
+struct GSHHS2 { /* Global Self-consistent Hierarchical High-resolution Shorelines */
+ int id; /* Unique polygon id number, starting at 0 */
+ int n; /* Number of points in this polygon */
+ int flag; /* = level + version << 8 + greenwich << 16 + source << 24 + river << 25 */
+ /* flag contains 5 items, as follows:
+ * low byte: level = flag & 255: Values: 1 land, 2 lake, 3 island_in_lake, 4 pond_in_island_in_lake
+ * 2nd byte: version = (flag >> 8) & 255: Values: Should be 7 for GSHHS release 7
+ * 3rd byte: greenwich = (flag >> 16) & 1: Values: Greenwich is 1 if Greenwich is crossed
+ * 4th byte: source = (flag >> 24) & 1: Values: 0 = CIA WDBII, 1 = WVS
+ * 4th byte: river = (flag >> 25) & 1: Values: 0 = not set, 1 = river-lake and level = 2
+ int west, east, south, north; /* min/max extent in micro-degrees */
+ int area; /* Area of polygon in 1/10 km^2 */
+ int area_full; /* Area of original full-resolution polygon in 1/10 km^2 */
+ int container; /* Id of container polygon that encloses this polygon (-1 if none) */
+ int ancestor; /* Id of ancestor polygon in the full resolution set that was the source of this polygon (-1 if none) */
struct GSHHS_POINT { /* Each lon, lat pair is stored in micro-degrees in 4-byte integer format */
int x;
int y;
Modified: grass-addons/vector/v.in.gshhs/main.c
--- grass-addons/vector/v.in.gshhs/main.c 2009-08-14 13:30:34 UTC (rev 38729)
+++ grass-addons/vector/v.in.gshhs/main.c 2009-08-14 16:44:26 UTC (rev 38730)
@@ -33,10 +33,15 @@
#include <grass/gprojects.h>
#include <grass/glocale.h>
-/* updating to a newer GSHHS version can be as easy as replacing gshhs.h
+/* updating to a newer GSHHS version can be as easy as replacing
+ * struct GSHHS2 und updating GSHHS_DATA_RELEASE in gshhs.h
* if not too many changes were introduced */
#include "gshhs.h"
+/* GSHHS version 1.x import */
+int gshhs_import1(struct Map_info *, FILE *, int, double, double, double, double);
+/* GSHHS version 2.x import */
+int gshhs_import2(struct Map_info *, FILE *, int, double, double, double, double);
int write_line_tiled(struct Map_info *, int, struct line_pnts *,
struct line_cats *, double);
@@ -46,27 +51,22 @@
int main(int argc, char **argv)
- double w, e, s, n, area, lon, lat;
double minx = -180., maxx = 180., miny = -90., maxy = 90.;
char *dataname, *outname;
- char buf[2000], source;
+ char buf[2000];
static char *slevel[] = { "land", "lake", "island in lake",
"pond in island in lake" };
int shore_levels = 4;
/* taken from gshhs.c, keep in sync */
FILE *fp;
- int k, i, n_read, flip, level, version, greenwich, src;
- int max_east = 180000000; /* max_east = 270000000: confuses GRASS */
- int cnt = 0, getme = 0;
- struct GSHHS_POINT p; /* renamed to avoid conflict */
- struct GSHHS h;
+ int i, n_read, flip, version;
+ int cnt = 0;
+ struct GSHHS1 h;
/* GRASS specific */
struct Key_Value *out_proj_keys, *out_unit_keys;
- int type, zone;
+ int zone;
struct Cell_head region;
- struct Map_info VectMap;
- struct line_pnts *Points;
- struct line_cats *Cats;
+ struct Map_info Map;
double lat_nw, lon_nw, lat_ne, lon_ne;
double lat_sw, lon_sw, lat_se, lon_se;
struct
@@ -252,28 +252,163 @@
/* Open new vector */
- if (0 > Vect_open_new(&VectMap, outname, 0)) {
+ if (0 > Vect_open_new(&Map, outname, 0)) {
G_fatal_error(_("Cannot open new vector map <%s>"), outname);
- /* set vector line type to GV_LINE, GV_BOUNDARY is currently not supported */
- type = GV_LINE;
+ /* read header from GSHHS database */
+ n_read = fread((void *)&h, (size_t) sizeof(struct GSHHS1), (size_t) 1, fp);
+ version = (h.flag >> 8) & 255;
- /* Initialize vector line struct */
- Points = Vect_new_line_struct();
+ /* Take as sign that byte-swapping is needed */
+ /* if version < 2, source is read */
+ flip = (version < 2);
+ if (flip) {
+ version = swabi4((unsigned int)h.flag);
+ version = (version >> 8) & 255;
- /* Initialize vector category struct */
- Cats = Vect_new_cats_struct();
+ /* check version support */
+ if (version < 4) /* not sure if that check works... */
+ G_fatal_error("Trying to import version %d, only GSHHS versions 4 to %d (2.0) are supported.", version, (int)GSHHS_DATA_RELEASE);
+ if (version > GSHHS_DATA_RELEASE)
+ G_fatal_error("Import of version %d not yet supported, highest supported version is GSHHS version 7 (2.0).", version);
+ rewind(fp);
+ if (version >= 7)
+ gshhs_import2(&Map, fp, flag.r->answer, minx, maxx, miny, maxy);
+ else
+ gshhs_import1(&Map, fp, flag.r->answer, minx, maxx, miny, maxy);
+ /* done with gshhs file */
+ fclose(fp);
+ /* write out vect header info */
+ Vect_set_scale(&Map, 100000);
+ sprintf(buf, "GSHHS shorelines version %d imported by v.in.gshhs",
+ version);
+ Vect_set_comment(&Map, buf);
+ /* create table for layer 1 and link new vector to table, code taken from v.in.ogr */
+ db_init_string(&sql);
+ db_init_string(&strval);
+ Fi = Vect_default_field_info(&Map, 1, NULL, GV_1TABLE);
+ Vect_map_add_dblink(&Map, 1, NULL, Fi->table,
+ cat_col_name, Fi->database, Fi->driver);
+ sprintf(buf, "create table %s (%s integer, type varchar(25))",
+ Fi->table, cat_col_name);
+ db_set_string(&sql, buf);
+ driver =
+ db_start_driver_open_database(Fi->driver,
+ Vect_subst_var(Fi->database, &Map));
+ if (driver == NULL) {
+ G_fatal_error(_("Cannot open database <%s> by driver <%s>"),
+ Vect_subst_var(Fi->database, &Map), Fi->driver);
+ G_debug(1, "table: %s", Fi->table);
+ G_debug(1, "driver: %s", Fi->driver);
+ G_debug(1, "database: %s", Fi->database);
+ if (db_execute_immediate(driver, &sql) != DB_OK) {
+ db_close_database(driver);
+ db_shutdown_driver(driver);
+ G_fatal_error(_("Cannot create table: <%s>"), db_get_string(&sql));
+ if (db_create_index2(driver, Fi->table, cat_col_name) != DB_OK)
+ G_warning(_("Cannot create index"));
+ if (db_grant_on_table
+ (driver, Fi->table, DB_PRIV_SELECT, DB_GROUP | DB_PUBLIC) != DB_OK)
+ G_fatal_error(_("Cannot grant privileges on table <%s>"), Fi->table);
+ db_begin_transaction(driver);
+ for (i = 0; i < shore_levels; i++) {
+ sprintf(buf, "insert into %s values ( %d, \'%s\')", Fi->table, i + 1,
+ slevel[i]);
+ G_fatal_error(_("Cannot insert new row: <%s>"),
+ db_get_string(&sql));
+ db_commit_transaction(driver);
+ db_close_database_shutdown_driver(driver);
+ /* table for layer 1 created */
+ if (flag.topo->answer) {
+ G_message(_("Run \"v.build map=%s option=build\" to build topology"),
+ outname);
+ else {
+ Vect_build(&Map);
+ Vect_hist_command(&Map);
+ Vect_close(&Map);
+ G_message("--------------------------------------");
+ G_message(_("Skipped GSHHS lines: %d"), cnt);
+ G_message(_("GSHHS shoreline version %d import complete"), version);
+ exit(EXIT_SUCCESS);
+/* GSHHS version 1.x import, works with data releases 4 to 6 */
+int gshhs_import1(struct Map_info *Map, FILE *fp, int limit_to_region,
+ double minx, double maxx, double miny, double maxy)
+ double w, e, s, n, area, lon, lat, a, b, cutx, cuty;
+ char source;
+ /* taken from gshhs.c, keep in sync */
+ int i, n_read, flip, level, version, greenwich, src;
+ int max_east = 180000000; /* max_east = 270000000: confuses GRASS */
+ int cnt = 0, getme = 0;
+ struct GSHHS_POINT p; /* renamed to avoid conflict */
+ struct GSHHS1 h;
+ /* GRASS specific */
+ int type;
+ struct line_pnts *Points, **BPoints;
+ struct line_cats *Cats;
+ int use_bpoints, n_bpoints, bpoints_alloc = 10;
- n_read = fread((void *)&h, (size_t) sizeof(struct GSHHS), (size_t) 1, fp);
- flip = (version < 4); /* Take as sign that byte-swapping is needed */
if (flip) {
+ /* set vector line type to GV_LINE, GV_BOUNDARY is currently not supported */
+ type = GV_LINE;
+ /* Initialize vector line struct */
+ Points = Vect_new_line_struct();
+ BPoints = (struct line_pnts **)G_malloc(bpoints_alloc * sizeof(struct line_pnts *));
+ for (i = 0; i < bpoints_alloc; i++)
+ BPoints[i] = Vect_new_line_struct();
+ /* Initialize vector category struct */
+ Cats = Vect_new_cats_struct();
/* read lines from GSHHS database */
while (n_read == 1) {
@@ -311,7 +446,7 @@
e += 360.;
getme = 1;
- if (flag.r->answer) {
+ if (limit_to_region) {
getme = 0;
/* check gshhs bbox */
if (w >= minx && w < maxx && e <= maxx && e > minx &&
@@ -335,7 +470,10 @@
/* cats for layer 2 are unique ID, same like GSHHS ID */
Vect_cat_set(Cats, 2, h.id);
- for (k = 0; k < h.n; k++) {
+ use_bpoints = 0;
+ n_bpoints = 0;
+ for (i = 0; i < h.n; i++) {
if (fread
((void *)&p, (size_t) sizeof(struct GSHHS_POINT),
(size_t) 1, fp) != 1)
@@ -346,8 +484,11 @@
p.y = swabi4((unsigned int)p.y);
lon = p.x * GSHHS_SCL;
- if (p.x > max_east) /* GSHHS lon coords are 0 - 360 */
+ /* GSHHS lon coords are 0 - 360 */
+ if (p.x > max_east)
lon -= 360.0;
lat = p.y * GSHHS_SCL;
if (getme == 0) { /* overlap */
@@ -367,28 +508,160 @@
/* needed for accurate bboxes */
- if (Points->n_points) {
- if (Points->x[Points->n_points - 1] - lon < -180.)
- lon -= 360.;
- if (Points->x[Points->n_points - 1] - lon > 180.)
- lon += 360.;
+ if (!use_bpoints) {
+ if (Points->n_points) {
+ if ((Points->x[Points->n_points - 1] - lon) > 180.) {
+ lon += 360.;
+ else if ((Points->x[Points->n_points - 1] - lon) < -180.) {
+ lon -= 360.;
+ if (lon > 360 || lon < -360)
+ G_fatal_error("lon %.2f out of bounds, last for p was %.2f", lon, Points->x[Points->n_points - 1]);
+ else {
+ if (BPoints[n_bpoints - 1]->n_points) {
+ if ((BPoints[n_bpoints - 1]->x[BPoints[n_bpoints - 1]->n_points - 1] - lon) > 180.) {
+ lon += 360.;
+ else if ((BPoints[n_bpoints - 1]->x[BPoints[n_bpoints - 1]->n_points - 1] - lon) < -180.) {
+ lon -= 360.;
+ G_fatal_error("lon %.2f out of bounds, last for b was %.2f", lon, BPoints[n_bpoints - 1]->x[BPoints[n_bpoints - 1]->n_points - 1]);
/* The GSHHS Antarctica problem: convert from 0 - 360 to -180 - 180 */
- if (s < -80 && lon < -180) {
- Vect_append_point(Points, lon, lat, 0.);
+ if (s < -80 && lon < -180.) {
+ cutx = -180.;
+ a = (Points->y[Points->n_points - 1] - lat) / (Points->x[Points->n_points - 1] - lon);
+ b = lat - lon * a;
+ cuty = a * cutx + b;
+ Vect_append_point(Points, cutx, cuty, 0.);
/* ...and close polygon */
- Vect_append_point(Points, -180, -90, 0.);
- Vect_append_point(Points, 180, -90, 0.);
- lon += 360;
+ Vect_append_point(Points, cutx, -90, 0.);
+ Vect_append_point(Points, -cutx, -90, 0.);
+ Vect_append_point(Points, -cutx, cuty, 0.);
+ lon += 360.;
- } /* done with line */
+ if (use_bpoints) {
+ if (lon <= -180. || lon >= 180.) {
+ G_debug(2, "come back across datum border");
+ /* coming back over 180E */
+ if (lon <= -180.) {
+ cutx = -180.;
+ /* coming back over 180W */
+ else {
+ cutx = 180.;
+ a = (BPoints[n_bpoints - 1]->y[BPoints[n_bpoints - 1]->n_points - 1] - lat) / (BPoints[n_bpoints - 1]->x[BPoints[n_bpoints - 1]->n_points - 1] - lon);
+ Vect_append_point(Points, lon - 2 * cutx, lat, 0.);
+ Vect_append_point(BPoints[n_bpoints - 1], cutx, cuty, 0.);
+ Vect_append_point(BPoints[n_bpoints - 1], BPoints[n_bpoints - 1]->x[0], BPoints[n_bpoints - 1]->y[0], 0.);
+ /* debug */
+ if (lon - 2 * cutx < -180. || lon - 2 * cutx > 180.)
+ G_fatal_error("coming back, lon %.2f out of bounds", lon - 2 * cutx);
+ if (Points->n_points > 1) {
+ if (fabs(Points->x[Points->n_points - 1] - Points->x[Points->n_points - 2]) > 180.)
+ G_fatal_error("coming back, points too far apart");
+ if (BPoints[n_bpoints - 1]->n_points > 1) {
+ if (fabs(BPoints[n_bpoints - 1]->x[BPoints[n_bpoints - 1]->n_points - 1] - BPoints[n_bpoints - 1]->x[BPoints[n_bpoints - 1]->n_points - 2]) > 180.)
+ G_fatal_error("coming back, bpoints too far apart");
+ use_bpoints = 0;
+ else {
+ Vect_append_point(BPoints[n_bpoints - 1], lon, lat, 0.);
+ /* debug */
+ G_fatal_error("bpoints too far apart");
+ else {
+ if (Points->n_points == 0) {
+ if (lon < -180.)
+ cutx = 360.;
+ else if (lon > 180.)
+ cutx = -360.;
+ else
+ cutx = 0;
+ Vect_append_point(Points, lon + cutx, lat, 0.);
+ /* chop lines along 180E/W */
+ else if (lon < -180. || lon > 180.) {
+ if (lon < -180.)
+ cutx = -180.;
+ else
+ cutx = 180.;
+ G_debug(2, "cross datum border");
+ /* calculate intersection, reset BPoints */
+ if (n_bpoints >= bpoints_alloc) {
+ int j;
+ BPoints = (struct line_pnts **)G_realloc(BPoints, (bpoints_alloc + 10) * sizeof(struct line_pnts *));
+ for (j = bpoints_alloc; j < bpoints_alloc + 10; j++)
+ BPoints[j] = Vect_new_line_struct();
+ bpoints_alloc += 10;
+ Vect_reset_line(BPoints[n_bpoints]);
+ Vect_append_point(BPoints[n_bpoints], -cutx, cuty, 0.);
+ Vect_append_point(BPoints[n_bpoints], lon - 2 * cutx, lat, 0.);
+ /* debug */
+ G_fatal_error("crossing border, lon %.2f out of bounds", lon - 2 * cutx);
+ G_fatal_error("crossing datum border, points too far apart");
+ if (BPoints[n_bpoints]->n_points > 1) {
+ if (fabs(BPoints[n_bpoints]->x[BPoints[n_bpoints]->n_points - 1] - BPoints[n_bpoints]->x[BPoints[n_bpoints]->n_points - 2]) > 180.)
+ G_fatal_error("crossing datum border, bpoints too far apart");
+ use_bpoints = 1;
+ n_bpoints++;
+ else {
+ Vect_append_point(Points, lon, lat, 0.);
+ /* debug */
+ G_fatal_error("points too far apart");
+ } /* done with line */
if (getme && Points->n_points) {
/* change thresh if you want longer line segments */
- write_line_tiled(&VectMap, type, Points, Cats, 2.);
+ write_line_tiled(Map, type, Points, Cats, 2.);
+ for (i = 0; i < n_bpoints; i++)
+ write_line_tiled(Map, type, BPoints[i], Cats, 2.);
else
cnt++;
@@ -403,95 +676,337 @@
/* max_east = 180000000; */ /* Only Eurasiafrica needs 270 */
n_read =
- fread((void *)&h, (size_t) sizeof(struct GSHHS), (size_t) 1, fp);
+ fread((void *)&h, (size_t) sizeof(struct GSHHS1), (size_t) 1, fp);
- /* done with gshhs file */
- fclose(fp);
Vect_destroy_line_struct(Points);
+ Vect_destroy_line_struct(BPoints[i]);
Vect_destroy_cats_struct(Cats);
- /* write out vect header info */
- Vect_set_scale(&VectMap, 100000);
- sprintf(buf, "GSHHS shorelines version %d imported by v.in.gshhs",
- version);
- Vect_set_comment(&VectMap, buf);
+ return 1;
- /* create table for layer 1 and link new vector to table, code taken from v.in.ogr */
- db_init_string(&sql);
- db_init_string(&strval);
+/* GSHHS version 2.x import, works with data release 7 */
+/* the only difference between gshhs_import1 and gshhs_import2 is
+ * the use of struct GSHHS1 or struct GSHHS2, respectively */
+int gshhs_import2(struct Map_info *Map, FILE *fp, int limit_to_region,
+ char source;
+ struct GSHHS2 h;
+ int type;
- Fi = Vect_default_field_info(&VectMap, 1, NULL, GV_1TABLE);
+ n_read = fread((void *)&h, (size_t) sizeof(struct GSHHS2), (size_t) 1, fp);
- Vect_map_add_dblink(&VectMap, 1, NULL, Fi->table,
- cat_col_name, Fi->database, Fi->driver);
+ if (flip) {
- sprintf(buf, "create table %s (%s integer, type varchar(25))",
- Fi->table, cat_col_name);
- db_set_string(&sql, buf);
+ type = GV_LINE;
- driver =
- db_start_driver_open_database(Fi->driver,
- Vect_subst_var(Fi->database, &VectMap));
- if (driver == NULL) {
- G_fatal_error(_("Cannot open database <%s> by driver <%s>"),
- Vect_subst_var(Fi->database, &VectMap), Fi->driver);
- G_debug(1, "table: %s", Fi->table);
- G_debug(1, "driver: %s", Fi->driver);
- G_debug(1, "database: %s", Fi->database);
+ /* read lines from GSHHS database */
+ while (n_read == 1) {
+ if (flip) {
+ h.id = swabi4((unsigned int)h.id);
+ h.n = swabi4((unsigned int)h.n);
+ h.west = swabi4((unsigned int)h.west);
+ h.east = swabi4((unsigned int)h.east);
+ h.south = swabi4((unsigned int)h.south);
+ h.north = swabi4((unsigned int)h.north);
+ h.area = swabi4((unsigned int)h.area);
+ h.flag = swabi4((unsigned int)h.flag);
+ level = h.flag & 255;
+ /* version = (h.flag >> 8) & 255; */
+ greenwich = (h.flag >> 16) & 255;
+ src = (h.flag >> 24) & 255;
+ w = h.west * GSHHS_SCL; /* Convert from microdegrees to degrees */
+ e = h.east * GSHHS_SCL;
+ s = h.south * GSHHS_SCL;
+ n = h.north * GSHHS_SCL;
+ /* skip WDBII data because they are too inacurate? */
+ source = (src == 1) ? 'W' : 'C'; /* Either WVS or CIA (WDBII) pedigree */
+ area = 0.1 * h.area; /* Now im km^2 */
- if (db_execute_immediate(driver, &sql) != DB_OK) {
- db_close_database(driver);
- db_shutdown_driver(driver);
- G_fatal_error(_("Cannot create table: <%s>"), db_get_string(&sql));
+ /* GRASS specific, max_east must always be 180 */
+ while (w > 180.)
+ w -= 360.0;
+ while (e > 180.)
+ e -= 360.0;
- if (db_create_index2(driver, Fi->table, cat_col_name) != DB_OK)
- G_warning(_("Cannot create index"));
+ if (maxx > 180. && w < 0)
+ w += 360.;
+ if (maxx > 180. && e < 0)
+ e += 360.;
- if (db_grant_on_table
- (driver, Fi->table, DB_PRIV_SELECT, DB_GROUP | DB_PUBLIC) != DB_OK)
- G_fatal_error(_("Cannot grant privileges on table <%s>"), Fi->table);
+ getme = 1;
+ getme = 0;
+ /* check gshhs bbox */
+ if (w >= minx && w < maxx && e <= maxx && e > minx &&
+ s >= miny && s < maxy && n <= maxy && n > miny) {
+ getme = 1; /* inside current region */
+ else if (w < maxx && e > minx && s < maxy && n > miny) {
+ getme = 2; /* overlap */
+ if (getme) {
+ /* abusing getme flag a bit */
+ if (getme == 2)
+ getme = 0;
+ Vect_reset_line(Points);
+ Vect_reset_cats(Cats);
+ /* simple table and cats for layer 1: not unique, just per slevel */
+ Vect_cat_set(Cats, 1, level);
+ /* cats for layer 2 are unique ID, same like GSHHS ID */
+ Vect_cat_set(Cats, 2, h.id);
- db_begin_transaction(driver);
+ use_bpoints = 0;
+ n_bpoints = 0;
- for (i = 0; i < shore_levels; i++) {
- sprintf(buf, "insert into %s values ( %d, \'%s\')", Fi->table, i + 1,
- slevel[i]);
+ if (fread
+ ((void *)&p, (size_t) sizeof(struct GSHHS_POINT),
+ (size_t) 1, fp) != 1)
+ G_fatal_error(_("Error reading data"));
- G_fatal_error(_("Cannot insert new row: <%s>"),
- db_get_string(&sql));
+ if (flip) {
+ p.x = swabi4((unsigned int)p.x);
+ p.y = swabi4((unsigned int)p.y);
+ lon = p.x * GSHHS_SCL;
+ lon -= 360.0;
- db_commit_transaction(driver);
- db_close_database_shutdown_driver(driver);
+ lat = p.y * GSHHS_SCL;
- /* table for layer 1 created */
+ if (getme == 0) { /* overlap */
+ /* datum border wrap around work around, clumsy code but works */
+ if (maxx > 180. && lon < 0) {
+ if (lat >= miny && lat <= maxy && (lon + 360.) >= minx && (lon + 360.) <= maxx) {
+ /* vertex inside current region, import line */
+ getme = 1;
+ else {
+ if (lat >= miny && lat <= maxy && lon >= minx && lon <= maxx) {
+ getme = 1;
+ /* needed for accurate bboxes */
+ lon += 360.;
+ lon -= 360.;
+ else {
+ lon += 360.;
+ lon -= 360.;
- if (flag.topo->answer) {
- G_message(_("Run \"v.build map=%s option=build\" to build topology"),
- outname);
+ /* The GSHHS Antarctica problem: convert from 0 - 360 to -180 - 180 */
+ cutx = -180.;
+ /* ...and close polygon */
+ lon += 360.;
+ cutx = -180.;
+ else {
+ cutx = 180.;
+ /* debug */
+ use_bpoints = 0;
+ else {
+ /* debug */
+ else {
+ if (lon < -180.)
+ cutx = 360.;
+ cutx = -360.;
+ else
+ cutx = 0;
+ if (lon < -180.)
+ cutx = -180.;
+ else
+ cutx = 180.;
+ int j;
+ /* debug */
+ use_bpoints = 1;
+ n_bpoints++;
+ else {
+ /* debug */
+ if (getme && Points->n_points) {
+ /* change thresh if you want longer line segments */
+ else
+ cnt++;
+ else {
+ G_debug(1, "skipped line box west: %f, east: %f, north: %f, south: %f",
+ w, e, n, s);
+ fseek(fp, (long)(h.n * sizeof(struct GSHHS_POINT)), SEEK_CUR);
+ cnt++;
+ /* 270 needed for more than Eurasiafrica only, solved above */
+ /* max_east = 180000000; */ /* Only Eurasiafrica needs 270 */
+ n_read =
+ fread((void *)&h, (size_t) sizeof(struct GSHHS2), (size_t) 1, fp);
- else {
- Vect_build(&VectMap);
- Vect_hist_command(&VectMap);
- Vect_close(&VectMap);
+ Vect_destroy_line_struct(Points);
+ Vect_destroy_cats_struct(Cats);
- G_message("--------------------------------------");
- G_message(_("Skipped GSHHS lines: %d"), cnt);
- G_message(_("GSHHS shoreline version %d import complete"), version);
- exit(EXIT_SUCCESS);
+ return 1;
