[GRASS-SVN] r38752 - grass/trunk/lib/raster
svn_grass at osgeo.org
Sun Aug 16 04:36:24 EDT 2009
Author: hamish
Date: 2009-08-16 04:36:23 -0400 (Sun, 16 Aug 2009)
New Revision: 38752
grass/trunk/lib/raster/color_write.c
standardize on %.15g for doubles instead of mix of %.10f, %.30f (trac #335)
Modified: grass/trunk/lib/raster/color_write.c
--- grass/trunk/lib/raster/color_write.c 2009-08-16 08:18:37 UTC (rev 38751)
+++ grass/trunk/lib/raster/color_write.c 2009-08-16 08:36:23 UTC (rev 38752)
@@ -15,13 +15,9 @@
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#include <grass/gis.h>
#include <grass/raster.h>
-#define PRECISION 30
-#define THRESHOLD .0000000000000000000000000000005 /* .5 * 10 ^(-30) */
static void write_rules(FILE *, struct _Color_Rule_ *, DCELL, DCELL);
static void write_new_colors(FILE *, struct Colors *);
static void write_old_colors(FILE *, struct Colors *);
@@ -128,7 +124,7 @@
fprintf(fd, "%% %s %s\n", str1, str2);
if (colors->shift) {
- sprintf(str2, "%.10f", (double)colors->shift);
+ sprintf(str2, "%.15g", (double)colors->shift);
G_trim_decimal(str2);
fprintf(fd, "shift:%s\n", str2);
@@ -175,7 +171,7 @@
if (rule->low.value == dmin)
format_min(str, (double)rule->low.value);
else {
- sprintf(str, "%.10f", (double)rule->low.value);
+ sprintf(str, "%.15g", (double)rule->low.value);
G_trim_decimal(str);
fprintf(fd, "%s:%d", str, (int)rule->low.red);
@@ -186,7 +182,7 @@
if (rule->high.value == dmax)
format_max(str, (double)rule->high.value);
else {
- sprintf(str, "%.10f", (double)rule->high.value);
+ sprintf(str, "%.15g", (double)rule->high.value);
fprintf(fd, " %s:%d", str, (int)rule->high.red);
@@ -243,28 +239,28 @@
static void format_min(char *str, double dval)
double dtmp;
- sprintf(str, "%.*f", PRECISION, dval);
+ sprintf(str, "%.15g", dval);
sscanf(str, "%lf", &dtmp);
- if (dtmp != dval) { /* if no zeros after decimal point were trimmed */
- sprintf(str, "%.*f", PRECISION, dval - THRESHOLD);
- /* because precision is probably higher than PRECISION */
+ if (dtmp != dval) { /* if no zeros after decimal point were trimmed */
+ sprintf(str, "%.15g", dval - GRASS_EPSILON);
static void format_max(char *str, double dval)
double dtmp;
- sprintf(str, "%.*f", PRECISION, dval + THRESHOLD);
+ sprintf(str, "%.15g", dval + GRASS_EPSILON);
