[GRASS-SVN] r38818 - grass/trunk/lib/gis
svn_grass at osgeo.org
Fri Aug 21 10:39:25 EDT 2009
Author: hamish
Date: 2009-08-21 10:39:25 -0400 (Fri, 21 Aug 2009)
New Revision: 38818
grass/trunk/lib/gis/datumtransform.table
explain why terms don't match ref URL
Modified: grass/trunk/lib/gis/datumtransform.table
--- grass/trunk/lib/gis/datumtransform.table 2009-08-21 14:24:35 UTC (rev 38817)
+++ grass/trunk/lib/gis/datumtransform.table 2009-08-21 14:39:25 UTC (rev 38818)
@@ -85,6 +85,7 @@
# http://www.linz.govt.nz/geodetic/conversion-coordinates/geodetic-datum-conversion/nzgd1949-nzgd2000/distortion-grid/
nzgd49 "nadgrids=nzgd2kgrid0005.gsb" "New Zealand" "LINZ NZGD49 NTv2 Distortion Model, accuracy 10-30cm"
# http://www.linz.govt.nz/geodetic/conversion-coordinates/geodetic-datum-conversion/nzgd1949-nzgd2000/three-and-seven-parameter/
+# note: values in above URL use the Helmert convention for the sign of rotation terms, while PROJ.4 uses the Bursa-Wolf convention.
nzgd49 "towgs84=59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993" "New Zealand" "Accuracy approx. 4m"
tokyo "towgs84=-147.54,507.26,680.47" "Japan" " "
tokyo "towgs84=-147,506,687" "South Korea" " "
