[GRASS-SVN] r38820 - grass/branches/releasebranch_6_4/lib/gis
svn_grass at osgeo.org
Fri Aug 21 10:44:23 EDT 2009
Author: hamish
Date: 2009-08-21 10:44:23 -0400 (Fri, 21 Aug 2009)
New Revision: 38820
grass/branches/releasebranch_6_4/lib/gis/datum.table
grass/branches/releasebranch_6_4/lib/gis/datumtransform.table
update NZ ref URLs (merge from trunk)
Modified: grass/branches/releasebranch_6_4/lib/gis/datum.table
--- grass/branches/releasebranch_6_4/lib/gis/datum.table 2009-08-21 14:43:05 UTC (rev 38819)
+++ grass/branches/releasebranch_6_4/lib/gis/datum.table 2009-08-21 14:44:23 UTC (rev 38820)
@@ -77,7 +77,7 @@
hjors55 "Hjorsey_1955" international dx=-73 dy=46 dz=-86
lis37 "Lisbon_1937" international dx=99999 dy=99999 dz=99999
ngo48 "NGO_1948" modif_bessel dx=99999 dy=99999 dz=99999
-# http://www.linz.govt.nz/rcs/linz/pub/web/root/core/SurveySystem/GeodeticInfo/GeodeticDatums/nzgd49tonzgd2000/index.jsp
+# http://www.linz.govt.nz/geodetic/conversion-coordinates/geodetic-datum-conversion/nzgd1949-nzgd2000/three-and-seven-parameter/
nzgd49 "New_Zealand_Geodetic_Datum_1949" international dx=54.4 dy=-20.1 dz=183.1
nzgd2k "New_Zealand_Geodetic_Datum_2000" grs80 dx=0 dy=0 dz=0
# http://earth-info.nga.mil/GandG/coordsys/onlinedatum/CountrySouthAmericanTable.html (accuracy +/-5m), also: EPSG SQL DB V6.4/V6.8
Modified: grass/branches/releasebranch_6_4/lib/gis/datumtransform.table
--- grass/branches/releasebranch_6_4/lib/gis/datumtransform.table 2009-08-21 14:43:05 UTC (rev 38819)
+++ grass/branches/releasebranch_6_4/lib/gis/datumtransform.table 2009-08-21 14:44:23 UTC (rev 38820)
@@ -82,9 +82,10 @@
sam69 "towgs84=-60.0,-2.0,-41.0" "Brazil" " "
sam69 "towgs84=-77.0,3.0,-45.0" "South America?" "Old GRASS sam69 parameters"
nad27 "towgs84=-9.0,151.0,185.0" "Alaska & Canada" "Old GRASS a-can parameters"
-# http://www.linz.govt.nz/rcs/linz/pub/web/root/core/SurveySystem/GeodeticInfo/Software/softwaredownloads/index.jsp
+# http://www.linz.govt.nz/geodetic/conversion-coordinates/geodetic-datum-conversion/nzgd1949-nzgd2000/distortion-grid/
nzgd49 "nadgrids=nzgd2kgrid0005.gsb" "New Zealand" "LINZ NZGD49 NTv2 Distortion Model, accuracy 10-30cm"
-# http://www.linz.govt.nz/rcs/linz/6149/osgpol97_3.pdf
+# note: values in above URL use the Helmert convention for the sign of rotation terms, while PROJ.4 uses the Bursa-Wolf convention.
nzgd49 "towgs84=59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993" "New Zealand" "Accuracy approx. 4m"
tokyo "towgs84=-147.54,507.26,680.47" "Japan" " "
tokyo "towgs84=-147,506,687" "South Korea" " "
