[GRASS-SVN] r38823 - grass-addons/raster/r.viewshed
svn_grass at osgeo.org
Fri Aug 21 12:06:16 EDT 2009
Author: neteler
Date: 2009-08-21 12:06:16 -0400 (Fri, 21 Aug 2009)
New Revision: 38823
grass-addons/raster/r.viewshed/main.cc
grass-addons/raster/r.viewshed/r.viewshed.html
grass-addons/raster/r.viewshed/visibility.h
use streamdir mechanism from r.terraflow for tmp files; longer names; gettext fixes
Modified: grass-addons/raster/r.viewshed/main.cc
--- grass-addons/raster/r.viewshed/main.cc 2009-08-21 15:14:02 UTC (rev 38822)
+++ grass-addons/raster/r.viewshed/main.cc 2009-08-21 16:06:16 UTC (rev 38823)
@@ -138,6 +138,7 @@
module->description = _("IO-efficient viewshed algorithm");
struct Cell_head region;
+ char *optstreamdir;
if (G_get_set_window(®ion) == -1)
G_fatal_error("Error getting current region");
@@ -326,7 +327,7 @@
else {
/*set it */
- sprintf(buf, "%s=%s", STREAM_TMPDIR, "/var/tmp/");
+ sprintf(buf, "%s=%s", STREAM_TMPDIR, viewOptions.streamdir);
fprintf(stderr, "setting %s ", buf);
putenv(buf);
if (getenv(STREAM_TMPDIR) == NULL) {
@@ -336,7 +337,7 @@
else {
fprintf(stderr, ", ok.\n");
- printf("Intermediate stream location: %s\n", "/var/tmp/");
+ printf("Intermediate stream location: %s\n", viewOptions.streamdir);
fprintf(stderr, "Intermediate files will not be deleted "
"in case of abnormal termination.\n");
@@ -540,7 +541,7 @@
elevationFlag = G_define_flag();
elevationFlag->key = 'e';
elevationFlag->description =
- ("Output format is {NODATA, -1 (invisible), elev-viewpoint_elev (visible)}");
+ _("Output format is {NODATA, -1 (invisible), elev-viewpoint_elev (visible)}");
/* viewpoint coordinates */
struct Option *viewLocOpt;
@@ -551,7 +552,7 @@
viewLocOpt->required = YES;
viewLocOpt->key_desc = "lat,long";
viewLocOpt->description =
- ("Coordinates of viewing position in latitude-longitude (if -r flag is present, then coordinates are row-column)");
+ _("Coordinates of viewing position in latitude-longitude (if -r flag is present, then coordinates are row-column)");
viewLocOpt->guisection = _("Input_options");
/* observer elevation */
@@ -575,7 +576,7 @@
maxDistOpt->required = NO;
maxDistOpt->key_desc = "value";
maxDistOpt->description =
- ("Maximum visibility radius. By default infinity (-1).");
+ _("Maximum visibility radius. By default infinity (-1).");
char infdist[10];
sprintf(infdist, "%d", INFINITY_DISTANCE);
@@ -594,6 +595,21 @@
_("The amount of main memory in MB to be used");
memAmountOpt->answer = "500";
+ /* temporary STREAM path */
+ struct Option *streamdirOpt;
+ streamdirOpt = G_define_option() ;
+ streamdirOpt->key = "stream_dir";
+ streamdirOpt->type = TYPE_STRING;
+ streamdirOpt->required = NO;
+#ifdef __MINGW32__
+ streamdirOpt->answer = G_convert_dirseps_from_host(G_store(getenv("TEMP")));
+#else
+ streamdirOpt->answer = G_store("/var/tmp/");
+#endif
+ streamdirOpt->description=
+ _("Directory to hold temporary files (they can be large)");
/*fill the options and flags with G_parser */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -602,6 +618,7 @@
/* store the parameters into a structure to be used along the way */
strcpy(viewOptions->inputfname, inputOpt->answer);
strcpy(viewOptions->outputfname, outputOpt->answer);
+ strcpy(viewOptions->streamdir,streamdirOpt->answer);
viewOptions->obsElev = atof(obsElevOpt->answer);
@@ -847,6 +864,7 @@
G_message(_("---max memory = %d MB\n"), (int)(memSizeBytes >> 20));
G_message(_("---------------------------------\n"));
+ G_message(_("---temporary files streamdir: %s\n"), viewOptions.streamdir);
#else
printf("---------------------------------\nOptions set as:\n");
@@ -880,6 +898,7 @@
printf("max memory = %d MB\n", (int)(memSizeBytes >> 20));
printf("---------------------------------\n");
+ printf("---temporary files streamdir: %s\n", viewOptions.streamdir);
#endif
Modified: grass-addons/raster/r.viewshed/r.viewshed.html
--- grass-addons/raster/r.viewshed/r.viewshed.html 2009-08-21 15:14:02 UTC (rev 38822)
+++ grass-addons/raster/r.viewshed/r.viewshed.html 2009-08-21 16:06:16 UTC (rev 38823)
@@ -180,7 +180,8 @@
of a mountain:
<div class="code"><pre>
-r.viewshed input=elevation.dem output=viewshed coordinate=598869,4916642 mem=800
+g.region rast=elevation.10m
+r.viewshed input=elevation.10m output=viewshed coordinate=598869,4916642 mem=800
</pre></div>
<h3>REFERENCES</h3>
Modified: grass-addons/raster/r.viewshed/visibility.h
--- grass-addons/raster/r.viewshed/visibility.h 2009-08-21 15:14:02 UTC (rev 38822)
+++ grass-addons/raster/r.viewshed/visibility.h 2009-08-21 16:06:16 UTC (rev 38823)
@@ -54,6 +54,9 @@
/* default max distance */
#define INFINITY_DISTANCE -1
+/* File/directory name lengths for GRASS compatibility */
+#define GNAME_MAX 256
+#define GPATH_MAX 4096
typedef struct viewpoint_
@@ -96,10 +99,10 @@
/* the name of the input raster */
- char inputfname[100];
+ char inputfname[GNAME_MAX];
/* the name of the output raster */
- char outputfname[100];
+ char outputfname[GNAME_MAX];
float obsElev;
/* observer elevation above the terrain */
@@ -124,6 +127,7 @@
double ellps_a; /* the parameter of the ellipsoid */
float cellsize; /* the cell resolution */
+ char streamdir[GPATH_MAX]; /* directory for tmp files */
} ViewOptions;
