[GRASS-SVN] r38832 - in grass/trunk: include lib/gis vector/v.in.ogr
svn_grass at osgeo.org
Sat Aug 22 03:48:04 EDT 2009
Author: neteler
Date: 2009-08-22 03:48:03 -0400 (Sat, 22 Aug 2009)
New Revision: 38832
grass/trunk/include/gisdefs.h
grass/trunk/lib/gis/strings.c
grass/trunk/vector/v.in.ogr/main.c
G_strdup() back for Windows (merge from devel_branch6, r38567)
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h 2009-08-21 21:17:33 UTC (rev 38831)
+++ grass/trunk/include/gisdefs.h 2009-08-22 07:48:03 UTC (rev 38832)
@@ -565,6 +565,7 @@
void G_str_to_lower(char *);
int G_str_to_sql(char *);
char *G_squeeze(char *);
+char *G_strdup(const char *);
/* system.c */
int G_system(const char *);
Modified: grass/trunk/lib/gis/strings.c
--- grass/trunk/lib/gis/strings.c 2009-08-21 21:17:33 UTC (rev 38831)
+++ grass/trunk/lib/gis/strings.c 2009-08-22 07:48:03 UTC (rev 38832)
@@ -108,6 +108,29 @@
+ * \brief Copies the null-terminated string into a newly
+ * allocated string. The string is allocated using G_malloc().
+ * \param[in] string the string to duplicate
+ * \return pointer to a string that is a duplicate of the string
+ * given to G_strdup().
+ * \return NULL if unable to allocate the required space
+char *G_strdup(const char *string)
+ char *p;
+ p = G_malloc(strlen(string) + 1);
+ if (p != NULL) {
+ strcpy(p, string);
+ return p;
* \brief Replace all occurencies of old_str in buffer with new_str
* Code example:
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2009-08-21 21:17:33 UTC (rev 38831)
+++ grass/trunk/vector/v.in.ogr/main.c 2009-08-22 07:48:03 UTC (rev 38832)
@@ -663,7 +663,7 @@
G_debug(3, "Ogr_ftype: %i", Ogr_ftype); /* look up below */
if (i < ncnames - 1) {
- Ogr_fieldname = strdup(cnames_opt->answers[i + 1]);
+ Ogr_fieldname = G_strdup(cnames_opt->answers[i + 1]);
else {
/* Change column names to [A-Za-z][A-Za-z0-9_]* */
@@ -679,7 +679,7 @@
/* avoid that we get the 'cat' column twice */
if (strcmp(Ogr_fieldname, "cat") == 0) {
sprintf(namebuf, "%s_", Ogr_fieldname);
- Ogr_fieldname = strdup(namebuf);
+ Ogr_fieldname = G_strdup(namebuf);
/* captial column names are a pain in SQL */
