[GRASS-SVN] r38863 - grass/trunk/vector/v.out.ascii
Tue Aug 25 12:10:27 EDT 2009
Author: martinl
Date: 2009-08-25 12:10:26 -0400 (Tue, 25 Aug 2009)
New Revision: 38863
   grass/trunk/vector/v.out.ascii/main.c
v.out.ascii - output/format options required - '-' for standard output
Modified: grass/trunk/vector/v.out.ascii/main.c
--- grass/trunk/vector/v.out.ascii/main.c	2009-08-25 16:08:38 UTC (rev 38862)
+++ grass/trunk/vector/v.out.ascii/main.c	2009-08-25 16:10:26 UTC (rev 38863)
@@ -8,7 +8,7 @@
  *             Martin Landa, CTU in Prague, Czech Republic (v.out.ascii.db merged)
  * PURPOSE:    v.out.ascii: writes GRASS vector data as ASCII files
- * COPYRIGHT:  (C) 2000-2008 by the GRASS Development Team
+ * COPYRIGHT:  (C) 2000-2009 by the GRASS Development Team
  *             This program is free software under the GNU General Public
  *              License (>=v2). Read the file COPYING that comes with GRASS
@@ -16,7 +16,6 @@
-/*  @(#)b_a_dig.c       2.1  6/26/87  */
 #include <stdio.h>
 #include <stdlib.h>
@@ -44,20 +43,21 @@
     module = G_define_module();
     G_add_keyword(_("vector"));
     G_add_keyword(_("export"));
+    G_add_keyword(_("ascii"));
     module->description =
 	_("Converts a GRASS binary vector map to a GRASS ASCII vector map.");
     input = G_define_standard_option(G_OPT_V_INPUT);
     output = G_define_standard_option(G_OPT_F_OUTPUT);
-    output->required = NO;
     output->description =
-	_("Path to resulting ASCII file or ASCII vector name if '-o' is defined");
+	_("Path to resulting ASCII file ('-' for standard output) "
+	  "or ASCII vector name if '-o' is defined");
     format_opt = G_define_option();
     format_opt->key = "format";
     format_opt->type = TYPE_STRING;
-    format_opt->required = NO;
+    format_opt->required = YES;
     format_opt->multiple = NO;
     format_opt->options = "point,standard";
     format_opt->answer = "point";
@@ -120,7 +120,7 @@
 	G_fatal_error(_("Format 'point' is not supported for old version"));
-    if (ver == 4 && output->answer == NULL) {
+    if (ver == 4 && strcmp(output->answer, "-") == 0) {
 	G_fatal_error(_("'output' must be given for old version"));
@@ -147,7 +147,7 @@
 	G_fatal_error(_("Unable to open vector map <%s>"),
 		      input->answer);
-    if (output->answer) {
+    if (strcmp(output->answer, "-") != 0) {
 	if (ver == 4) {
 	    ascii = G_fopen_new("dig_ascii", output->answer);
