[GRASS-SVN] r38882 - grass/branches/releasebranch_6_4/lib/external/bwidget
Thu Aug 27 05:08:09 EDT 2009
Author: hamish
Date: 2009-08-27 05:08:08 -0400 (Thu, 27 Aug 2009)
New Revision: 38882
Added:
   grass/branches/releasebranch_6_4/lib/external/bwidget/LGPL-2.1.txt
Removed:
   grass/branches/releasebranch_6_4/lib/external/bwidget/LGPL.txt
update LGPL 2.0 to 2.1; "at our option a newer version of the license"
Added: grass/branches/releasebranch_6_4/lib/external/bwidget/LGPL-2.1.txt
--- grass/branches/releasebranch_6_4/lib/external/bwidget/LGPL-2.1.txt	                        (rev 0)
+++ grass/branches/releasebranch_6_4/lib/external/bwidget/LGPL-2.1.txt	2009-08-27 09:08:08 UTC (rev 38882)
@@ -0,0 +1,504 @@
+		  GNU LESSER GENERAL PUBLIC LICENSE
+		       Version 2.1, February 1999
+ Copyright (C) 1991, 1999 Free Software Foundation, Inc.
+ 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+ Everyone is permitted to copy and distribute verbatim copies
+ of this license document, but changing it is not allowed.
+[This is the first released version of the Lesser GPL.  It also counts
+ as the successor of the GNU Library Public License, version 2, hence
+ the version number 2.1.]
+			    Preamble
+  The licenses for most software are designed to take away your
+freedom to share and change it.  By contrast, the GNU General Public
+Licenses are intended to guarantee your freedom to share and change
+free software--to make sure the software is free for all its users.
+  This license, the Lesser General Public License, applies to some
+specially designated software packages--typically libraries--of the
+Free Software Foundation and other authors who decide to use it.  You
+can use it too, but we suggest you first think carefully about whether
+this license or the ordinary General Public License is the better
+strategy to use in any particular case, based on the explanations below.
+  When we speak of free software, we are referring to freedom of use,
+not price.  Our General Public Licenses are designed to make sure that
+you have the freedom to distribute copies of free software (and charge
+for this service if you wish); that you receive source code or can get
+it if you want it; that you can change the software and use pieces of
+it in new free programs; and that you are informed that you can do
+these things.
+  To protect your rights, we need to make restrictions that forbid
+distributors to deny you these rights or to ask you to surrender these
+rights.  These restrictions translate to certain responsibilities for
+you if you distribute copies of the library or if you modify it.
+  For example, if you distribute copies of the library, whether gratis
+or for a fee, you must give the recipients all the rights that we gave
+you.  You must make sure that they, too, receive or can get the source
+code.  If you link other code with the library, you must provide
+complete object files to the recipients, so that they can relink them
+with the library after making changes to the library and recompiling
+it.  And you must show them these terms so they know their rights.
+  We protect your rights with a two-step method: (1) we copyright the
+library, and (2) we offer you this license, which gives you legal
+permission to copy, distribute and/or modify the library.
+  To protect each distributor, we want to make it very clear that
+there is no warranty for the free library.  Also, if the library is
+modified by someone else and passed on, the recipients should know
+that what they have is not the original version, so that the original
+author's reputation will not be affected by problems that might be
+introduced by others.
+  Finally, software patents pose a constant threat to the existence of
+any free program.  We wish to make sure that a company cannot
+effectively restrict the users of a free program by obtaining a
+restrictive license from a patent holder.  Therefore, we insist that
+any patent license obtained for a version of the library must be
+consistent with the full freedom of use specified in this license.
+  Most GNU software, including some libraries, is covered by the
+ordinary GNU General Public License.  This license, the GNU Lesser
+General Public License, applies to certain designated libraries, and
+is quite different from the ordinary General Public License.  We use
+this license for certain libraries in order to permit linking those
+libraries into non-free programs.
+  When a program is linked with a library, whether statically or using
+a shared library, the combination of the two is legally speaking a
+combined work, a derivative of the original library.  The ordinary
+General Public License therefore permits such linking only if the
+entire combination fits its criteria of freedom.  The Lesser General
+Public License permits more lax criteria for linking other code with
+the library.
+  We call this license the "Lesser" General Public License because it
+does Less to protect the user's freedom than the ordinary General
+Public License.  It also provides other free software developers Less
+of an advantage over competing non-free programs.  These disadvantages
+are the reason we use the ordinary General Public License for many
+libraries.  However, the Lesser license provides advantages in certain
+special circumstances.
+  For example, on rare occasions, there may be a special need to
+encourage the widest possible use of a certain library, so that it becomes
+a de-facto standard.  To achieve this, non-free programs must be
+allowed to use the library.  A more frequent case is that a free
+library does the same job as widely used non-free libraries.  In this
+case, there is little to gain by limiting the free library to free
+software only, so we use the Lesser General Public License.
+  In other cases, permission to use a particular library in non-free
+programs enables a greater number of people to use a large body of
+free software.  For example, permission to use the GNU C Library in
+non-free programs enables many more people to use the whole GNU
+operating system, as well as its variant, the GNU/Linux operating
+system.
+  Although the Lesser General Public License is Less protective of the
+users' freedom, it does ensure that the user of a program that is
+linked with the Library has the freedom and the wherewithal to run
+that program using a modified version of the Library.
+  The precise terms and conditions for copying, distribution and
+modification follow.  Pay close attention to the difference between a
+"work based on the library" and a "work that uses the library".  The
+former contains code derived from the library, whereas the latter must
+be combined with the library in order to run.
+   TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
+  0. This License Agreement applies to any software library or other
+program which contains a notice placed by the copyright holder or
+other authorized party saying it may be distributed under the terms of
+this Lesser General Public License (also called "this License").
+Each licensee is addressed as "you".
+  A "library" means a collection of software functions and/or data
+prepared so as to be conveniently linked with application programs
+(which use some of those functions and data) to form executables.
+  The "Library", below, refers to any such software library or work
+which has been distributed under these terms.  A "work based on the
+Library" means either the Library or any derivative work under
+copyright law: that is to say, a work containing the Library or a
+portion of it, either verbatim or with modifications and/or translated
+straightforwardly into another language.  (Hereinafter, translation is
+included without limitation in the term "modification".)
+  "Source code" for a work means the preferred form of the work for
+making modifications to it.  For a library, complete source code means
+all the source code for all modules it contains, plus any associated
+interface definition files, plus the scripts used to control compilation
+and installation of the library.
+  Activities other than copying, distribution and modification are not
+covered by this License; they are outside its scope.  The act of
+running a program using the Library is not restricted, and output from
+such a program is covered only if its contents constitute a work based
+on the Library (independent of the use of the Library in a tool for
+writing it).  Whether that is true depends on what the Library does
+and what the program that uses the Library does.
+  1. You may copy and distribute verbatim copies of the Library's
+complete source code as you receive it, in any medium, provided that
+you conspicuously and appropriately publish on each copy an
+appropriate copyright notice and disclaimer of warranty; keep intact
+all the notices that refer to this License and to the absence of any
+warranty; and distribute a copy of this License along with the
+Library.
+  You may charge a fee for the physical act of transferring a copy,
+and you may at your option offer warranty protection in exchange for a
+fee.
+  2. You may modify your copy or copies of the Library or any portion
+of it, thus forming a work based on the Library, and copy and
+distribute such modifications or work under the terms of Section 1
+above, provided that you also meet all of these conditions:
+    a) The modified work must itself be a software library.
+    b) You must cause the files modified to carry prominent notices
+    stating that you changed the files and the date of any change.
+    c) You must cause the whole of the work to be licensed at no
+    charge to all third parties under the terms of this License.
+    d) If a facility in the modified Library refers to a function or a
+    table of data to be supplied by an application program that uses
+    the facility, other than as an argument passed when the facility
+    is invoked, then you must make a good faith effort to ensure that,
+    in the event an application does not supply such function or
+    table, the facility still operates, and performs whatever part of
+    its purpose remains meaningful.
+    (For example, a function in a library to compute square roots has
+    a purpose that is entirely well-defined independent of the
+    application.  Therefore, Subsection 2d requires that any
+    application-supplied function or table used by this function must
+    be optional: if the application does not supply it, the square
+    root function must still compute square roots.)
+These requirements apply to the modified work as a whole.  If
+identifiable sections of that work are not derived from the Library,
+and can be reasonably considered independent and separate works in
+themselves, then this License, and its terms, do not apply to those
+sections when you distribute them as separate works.  But when you
+distribute the same sections as part of a whole which is a work based
+on the Library, the distribution of the whole must be on the terms of
+this License, whose permissions for other licensees extend to the
+entire whole, and thus to each and every part regardless of who wrote
+it.
+Thus, it is not the intent of this section to claim rights or contest
+your rights to work written entirely by you; rather, the intent is to
+exercise the right to control the distribution of derivative or
+collective works based on the Library.
+In addition, mere aggregation of another work not based on the Library
+with the Library (or with a work based on the Library) on a volume of
+a storage or distribution medium does not bring the other work under
+the scope of this License.
+  3. You may opt to apply the terms of the ordinary GNU General Public
+License instead of this License to a given copy of the Library.  To do
+this, you must alter all the notices that refer to this License, so
+that they refer to the ordinary GNU General Public License, version 2,
+instead of to this License.  (If a newer version than version 2 of the
+ordinary GNU General Public License has appeared, then you can specify
+that version instead if you wish.)  Do not make any other change in
+these notices.
+  Once this change is made in a given copy, it is irreversible for
+that copy, so the ordinary GNU General Public License applies to all
+subsequent copies and derivative works made from that copy.
+  This option is useful when you wish to copy part of the code of
+the Library into a program that is not a library.
+  4. You may copy and distribute the Library (or a portion or
+derivative of it, under Section 2) in object code or executable form
+under the terms of Sections 1 and 2 above provided that you accompany
+it with the complete corresponding machine-readable source code, which
+must be distributed under the terms of Sections 1 and 2 above on a
+medium customarily used for software interchange.
+  If distribution of object code is made by offering access to copy
+from a designated place, then offering equivalent access to copy the
+source code from the same place satisfies the requirement to
+distribute the source code, even though third parties are not
+compelled to copy the source along with the object code.
+  5. A program that contains no derivative of any portion of the
+Library, but is designed to work with the Library by being compiled or
+linked with it, is called a "work that uses the Library".  Such a
+work, in isolation, is not a derivative work of the Library, and
+therefore falls outside the scope of this License.
+  However, linking a "work that uses the Library" with the Library
+creates an executable that is a derivative of the Library (because it
+contains portions of the Library), rather than a "work that uses the
+library".  The executable is therefore covered by this License.
+Section 6 states terms for distribution of such executables.
+  When a "work that uses the Library" uses material from a header file
+that is part of the Library, the object code for the work may be a
+derivative work of the Library even though the source code is not.
+Whether this is true is especially significant if the work can be
+linked without the Library, or if the work is itself a library.  The
+threshold for this to be true is not precisely defined by law.
+  If such an object file uses only numerical parameters, data
+structure layouts and accessors, and small macros and small inline
+functions (ten lines or less in length), then the use of the object
+file is unrestricted, regardless of whether it is legally a derivative
+work.  (Executables containing this object code plus portions of the
+Library will still fall under Section 6.)
+  Otherwise, if the work is a derivative of the Library, you may
+distribute the object code for the work under the terms of Section 6.
+Any executables containing that work also fall under Section 6,
+whether or not they are linked directly with the Library itself.
+  6. As an exception to the Sections above, you may also combine or
+link a "work that uses the Library" with the Library to produce a
+work containing portions of the Library, and distribute that work
+under terms of your choice, provided that the terms permit
+modification of the work for the customer's own use and reverse
+engineering for debugging such modifications.
+  You must give prominent notice with each copy of the work that the
+Library is used in it and that the Library and its use are covered by
+this License.  You must supply a copy of this License.  If the work
+during execution displays copyright notices, you must include the
+copyright notice for the Library among them, as well as a reference
+directing the user to the copy of this License.  Also, you must do one
+of these things:
+    a) Accompany the work with the complete corresponding
+    machine-readable source code for the Library including whatever
+    changes were used in the work (which must be distributed under
+    Sections 1 and 2 above); and, if the work is an executable linked
+    with the Library, with the complete machine-readable "work that
+    uses the Library", as object code and/or source code, so that the
+    user can modify the Library and then relink to produce a modified
+    executable containing the modified Library.  (It is understood
+    that the user who changes the contents of definitions files in the
+    Library will not necessarily be able to recompile the application
+    to use the modified definitions.)
+    b) Use a suitable shared library mechanism for linking with the
+    Library.  A suitable mechanism is one that (1) uses at run time a
+    copy of the library already present on the user's computer system,
+    rather than copying library functions into the executable, and (2)
+    will operate properly with a modified version of the library, if
+    the user installs one, as long as the modified version is
+    interface-compatible with the version that the work was made with.
+    c) Accompany the work with a written offer, valid for at
+    least three years, to give the same user the materials
+    specified in Subsection 6a, above, for a charge no more
+    than the cost of performing this distribution.
+    d) If distribution of the work is made by offering access to copy
+    from a designated place, offer equivalent access to copy the above
+    specified materials from the same place.
+    e) Verify that the user has already received a copy of these
+    materials or that you have already sent this user a copy.
+  For an executable, the required form of the "work that uses the
+Library" must include any data and utility programs needed for
+reproducing the executable from it.  However, as a special exception,
+the materials to be distributed need not include anything that is
+normally distributed (in either source or binary form) with the major
+components (compiler, kernel, and so on) of the operating system on
+which the executable runs, unless that component itself accompanies
+the executable.
+  It may happen that this requirement contradicts the license
+restrictions of other proprietary libraries that do not normally
+accompany the operating system.  Such a contradiction means you cannot
+use both them and the Library together in an executable that you
+distribute.
+  7. You may place library facilities that are a work based on the
+Library side-by-side in a single library together with other library
+facilities not covered by this License, and distribute such a combined
+library, provided that the separate distribution of the work based on
+the Library and of the other library facilities is otherwise
+permitted, and provided that you do these two things:
+    a) Accompany the combined library with a copy of the same work
+    based on the Library, uncombined with any other library
+    facilities.  This must be distributed under the terms of the
+    Sections above.
+    b) Give prominent notice with the combined library of the fact
+    that part of it is a work based on the Library, and explaining
+    where to find the accompanying uncombined form of the same work.
+  8. You may not copy, modify, sublicense, link with, or distribute
+the Library except as expressly provided under this License.  Any
+attempt otherwise to copy, modify, sublicense, link with, or
+distribute the Library is void, and will automatically terminate your
+rights under this License.  However, parties who have received copies,
+or rights, from you under this License will not have their licenses
+terminated so long as such parties remain in full compliance.
+  9. You are not required to accept this License, since you have not
+signed it.  However, nothing else grants you permission to modify or
+distribute the Library or its derivative works.  These actions are
+prohibited by law if you do not accept this License.  Therefore, by
+modifying or distributing the Library (or any work based on the
+Library), you indicate your acceptance of this License to do so, and
+all its terms and conditions for copying, distributing or modifying
+the Library or works based on it.
+  10. Each time you redistribute the Library (or any work based on the
+Library), the recipient automatically receives a license from the
+original licensor to copy, distribute, link with or modify the Library
+subject to these terms and conditions.  You may not impose any further
+restrictions on the recipients' exercise of the rights granted herein.
+You are not responsible for enforcing compliance by third parties with
+this License.
+  11. If, as a consequence of a court judgment or allegation of patent
+infringement or for any other reason (not limited to patent issues),
+conditions are imposed on you (whether by court order, agreement or
+otherwise) that contradict the conditions of this License, they do not
+excuse you from the conditions of this License.  If you cannot
+distribute so as to satisfy simultaneously your obligations under this
+License and any other pertinent obligations, then as a consequence you
+may not distribute the Library at all.  For example, if a patent
+license would not permit royalty-free redistribution of the Library by
+all those who receive copies directly or indirectly through you, then
+the only way you could satisfy both it and this License would be to
+refrain entirely from distribution of the Library.
+If any portion of this section is held invalid or unenforceable under any
+particular circumstance, the balance of the section is intended to apply,
+and the section as a whole is intended to apply in other circumstances.
+It is not the purpose of this section to induce you to infringe any
+patents or other property right claims or to contest validity of any
+such claims; this section has the sole purpose of protecting the
+integrity of the free software distribution system which is
+implemented by public license practices.  Many people have made
+generous contributions to the wide range of software distributed
+through that system in reliance on consistent application of that
+system; it is up to the author/donor to decide if he or she is willing
+to distribute software through any other system and a licensee cannot
+impose that choice.
+This section is intended to make thoroughly clear what is believed to
+be a consequence of the rest of this License.
+  12. If the distribution and/or use of the Library is restricted in
+certain countries either by patents or by copyrighted interfaces, the
+original copyright holder who places the Library under this License may add
+an explicit geographical distribution limitation excluding those countries,
+so that distribution is permitted only in or among countries not thus
+excluded.  In such case, this License incorporates the limitation as if
+written in the body of this License.
+  13. The Free Software Foundation may publish revised and/or new
+versions of the Lesser General Public License from time to time.
+Such new versions will be similar in spirit to the present version,
+but may differ in detail to address new problems or concerns.
+Each version is given a distinguishing version number.  If the Library
+specifies a version number of this License which applies to it and
+"any later version", you have the option of following the terms and
+conditions either of that version or of any later version published by
+the Free Software Foundation.  If the Library does not specify a
+license version number, you may choose any version ever published by
+  14. If you wish to incorporate parts of the Library into other free
+programs whose distribution conditions are incompatible with these,
+write to the author to ask for permission.  For software which is
+copyrighted by the Free Software Foundation, write to the Free
+Software Foundation; we sometimes make exceptions for this.  Our
+decision will be guided by the two goals of preserving the free status
+of all derivatives of our free software and of promoting the sharing
+and reuse of software generally.
+			    NO WARRANTY
+  15. BECAUSE THE LIBRARY IS LICENSED FREE OF CHARGE, THERE IS NO
+WARRANTY FOR THE LIBRARY, TO THE EXTENT PERMITTED BY APPLICABLE LAW.
+EXCEPT WHEN OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR
+OTHER PARTIES PROVIDE THE LIBRARY "AS IS" WITHOUT WARRANTY OF ANY
+KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE
+IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
+PURPOSE.  THE ENTIRE RISK AS TO THE QUALITY AND PERFORMANCE OF THE
+LIBRARY IS WITH YOU.  SHOULD THE LIBRARY PROVE DEFECTIVE, YOU ASSUME
+THE COST OF ALL NECESSARY SERVICING, REPAIR OR CORRECTION.
+  16. IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN
+WRITING WILL ANY COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MAY MODIFY
+AND/OR REDISTRIBUTE THE LIBRARY AS PERMITTED ABOVE, BE LIABLE TO YOU
+FOR DAMAGES, INCLUDING ANY GENERAL, SPECIAL, INCIDENTAL OR
+CONSEQUENTIAL DAMAGES ARISING OUT OF THE USE OR INABILITY TO USE THE
+LIBRARY (INCLUDING BUT NOT LIMITED TO LOSS OF DATA OR DATA BEING
+RENDERED INACCURATE OR LOSSES SUSTAINED BY YOU OR THIRD PARTIES OR A
+FAILURE OF THE LIBRARY TO OPERATE WITH ANY OTHER SOFTWARE), EVEN IF
+SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH
+DAMAGES.
+		     END OF TERMS AND CONDITIONS
+           How to Apply These Terms to Your New Libraries
+  If you develop a new library, and you want it to be of the greatest
+possible use to the public, we recommend making it free software that
+everyone can redistribute and change.  You can do so by permitting
+redistribution under these terms (or, alternatively, under the terms of the
+ordinary General Public License).
+  To apply these terms, attach the following notices to the library.  It is
+safest to attach them to the start of each source file to most effectively
+convey the exclusion of warranty; and each file should have at least the
+"copyright" line and a pointer to where the full notice is found.
+    <one line to give the library's name and a brief idea of what it does.>
+    Copyright (C) <year>  <name of author>
+    This library is free software; you can redistribute it and/or
+    modify it under the terms of the GNU Lesser General Public
+    License as published by the Free Software Foundation; either
+    version 2.1 of the License, or (at your option) any later version.
+    This library is distributed in the hope that it will be useful,
+    but WITHOUT ANY WARRANTY; without even the implied warranty of
+    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+    Lesser General Public License for more details.
+    You should have received a copy of the GNU Lesser General Public
+    License along with this library; if not, write to the Free Software
+    Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+Also add information on how to contact you by electronic and paper mail.
+You should also get your employer (if you work as a programmer) or your
+school, if any, to sign a "copyright disclaimer" for the library, if
+necessary.  Here is a sample; alter the names:
+  Yoyodyne, Inc., hereby disclaims all copyright interest in the
+  library `Frob' (a library for tweaking knobs) written by James Random Hacker.
+  <signature of Ty Coon>, 1 April 1990
+  Ty Coon, President of Vice
+That's all there is to it!
Property changes on: grass/branches/releasebranch_6_4/lib/external/bwidget/LGPL-2.1.txt
___________________________________________________________________
Added: svn:mime-type
   + text/plain
Added: svn:eol-style
   + native
Deleted: grass/branches/releasebranch_6_4/lib/external/bwidget/LGPL.txt
--- grass/branches/releasebranch_6_4/lib/external/bwidget/LGPL.txt	2009-08-27 08:59:35 UTC (rev 38881)
+++ grass/branches/releasebranch_6_4/lib/external/bwidget/LGPL.txt	2009-08-27 09:08:08 UTC (rev 38882)
@@ -1,481 +0,0 @@
-		  GNU LIBRARY GENERAL PUBLIC LICENSE
-		       Version 2, June 1991
- Copyright (C) 1991 Free Software Foundation, Inc.
-    		    59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
- Everyone is permitted to copy and distribute verbatim copies
- of this license document, but changing it is not allowed.
-[This is the first released version of the library GPL.  It is
- numbered 2 because it goes with version 2 of the ordinary GPL.]
-			    Preamble
-  The licenses for most software are designed to take away your
-freedom to share and change it.  By contrast, the GNU General Public
-Licenses are intended to guarantee your freedom to share and change
-free software--to make sure the software is free for all its users.
-  This license, the Library General Public License, applies to some
-specially designated Free Software Foundation software, and to any
-other libraries whose authors decide to use it.  You can use it for
-your libraries, too.
-  When we speak of free software, we are referring to freedom, not
-price.  Our General Public Licenses are designed to make sure that you
-have the freedom to distribute copies of free software (and charge for
-this service if you wish), that you receive source code or can get it
-if you want it, that you can change the software or use pieces of it
-in new free programs; and that you know you can do these things.
-  To protect your rights, we need to make restrictions that forbid
-anyone to deny you these rights or to ask you to surrender the rights.
-These restrictions translate to certain responsibilities for you if
-you distribute copies of the library, or if you modify it.
-  For example, if you distribute copies of the library, whether gratis
-or for a fee, you must give the recipients all the rights that we gave
-you.  You must make sure that they, too, receive or can get the source
-code.  If you link a program with the library, you must provide
-complete object files to the recipients so that they can relink them
-with the library, after making changes to the library and recompiling
-it.  And you must show them these terms so they know their rights.
-  Our method of protecting your rights has two steps: (1) copyright
-the library, and (2) offer you this license which gives you legal
-permission to copy, distribute and/or modify the library.
-  Also, for each distributor's protection, we want to make certain
-that everyone understands that there is no warranty for this free
-library.  If the library is modified by someone else and passed on, we
-want its recipients to know that what they have is not the original
-version, so that any problems introduced by others will not reflect on
-the original authors' reputations.
-  Finally, any free program is threatened constantly by software
-patents.  We wish to avoid the danger that companies distributing free
-software will individually obtain patent licenses, thus in effect
-transforming the program into proprietary software.  To prevent this,
-we have made it clear that any patent must be licensed for everyone's
-free use or not licensed at all.
-  Most GNU software, including some libraries, is covered by the ordinary
-GNU General Public License, which was designed for utility programs.  This
-license, the GNU Library General Public License, applies to certain
-designated libraries.  This license is quite different from the ordinary
-one; be sure to read it in full, and don't assume that anything in it is
-the same as in the ordinary license.
-  The reason we have a separate public license for some libraries is that
-they blur the distinction we usually make between modifying or adding to a
-program and simply using it.  Linking a program with a library, without
-changing the library, is in some sense simply using the library, and is
-analogous to running a utility program or application program.  However, in
-a textual and legal sense, the linked executable is a combined work, a
-derivative of the original library, and the ordinary General Public License
-treats it as such.
-  Because of this blurred distinction, using the ordinary General
-Public License for libraries did not effectively promote software
-sharing, because most developers did not use the libraries.  We
-concluded that weaker conditions might promote sharing better.
-  However, unrestricted linking of non-free programs would deprive the
-users of those programs of all benefit from the free status of the
-libraries themselves.  This Library General Public License is intended to
-permit developers of non-free programs to use free libraries, while
-preserving your freedom as a user of such programs to change the free
-libraries that are incorporated in them.  (We have not seen how to achieve
-this as regards changes in header files, but we have achieved it as regards
-changes in the actual functions of the Library.)  The hope is that this
-will lead to faster development of free libraries.
-  The precise terms and conditions for copying, distribution and
-modification follow.  Pay close attention to the difference between a
-"work based on the library" and a "work that uses the library".  The
-former contains code derived from the library, while the latter only
-works together with the library.
-  Note that it is possible for a library to be covered by the ordinary
-General Public License rather than by this special one.
-   TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
-  0. This License Agreement applies to any software library which
-contains a notice placed by the copyright holder or other authorized
-party saying it may be distributed under the terms of this Library
-General Public License (also called "this License").  Each licensee is
-addressed as "you".
-  A "library" means a collection of software functions and/or data
-prepared so as to be conveniently linked with application programs
-(which use some of those functions and data) to form executables.
-  The "Library", below, refers to any such software library or work
-which has been distributed under these terms.  A "work based on the
-Library" means either the Library or any derivative work under
-copyright law: that is to say, a work containing the Library or a
-portion of it, either verbatim or with modifications and/or translated
-straightforwardly into another language.  (Hereinafter, translation is
-included without limitation in the term "modification".)
-  "Source code" for a work means the preferred form of the work for
-making modifications to it.  For a library, complete source code means
-all the source code for all modules it contains, plus any associated
-interface definition files, plus the scripts used to control compilation
-and installation of the library.
-  Activities other than copying, distribution and modification are not
-covered by this License; they are outside its scope.  The act of
-running a program using the Library is not restricted, and output from
-such a program is covered only if its contents constitute a work based
-on the Library (independent of the use of the Library in a tool for
-writing it).  Whether that is true depends on what the Library does
-and what the program that uses the Library does.
-  1. You may copy and distribute verbatim copies of the Library's
-complete source code as you receive it, in any medium, provided that
-you conspicuously and appropriately publish on each copy an
-appropriate copyright notice and disclaimer of warranty; keep intact
-all the notices that refer to this License and to the absence of any
-warranty; and distribute a copy of this License along with the
-Library.
-  You may charge a fee for the physical act of transferring a copy,
-and you may at your option offer warranty protection in exchange for a
-fee.
-  2. You may modify your copy or copies of the Library or any portion
-of it, thus forming a work based on the Library, and copy and
-distribute such modifications or work under the terms of Section 1
-above, provided that you also meet all of these conditions:
-    a) The modified work must itself be a software library.
-    b) You must cause the files modified to carry prominent notices
-    stating that you changed the files and the date of any change.
-    c) You must cause the whole of the work to be licensed at no
-    charge to all third parties under the terms of this License.
-    d) If a facility in the modified Library refers to a function or a
-    table of data to be supplied by an application program that uses
-    the facility, other than as an argument passed when the facility
-    is invoked, then you must make a good faith effort to ensure that,
-    in the event an application does not supply such function or
-    table, the facility still operates, and performs whatever part of
-    its purpose remains meaningful.
-    (For example, a function in a library to compute square roots has
-    a purpose that is entirely well-defined independent of the
-    application.  Therefore, Subsection 2d requires that any
-    application-supplied function or table used by this function must
-    be optional: if the application does not supply it, the square
-    root function must still compute square roots.)
-These requirements apply to the modified work as a whole.  If
-identifiable sections of that work are not derived from the Library,
-and can be reasonably considered independent and separate works in
-themselves, then this License, and its terms, do not apply to those
-sections when you distribute them as separate works.  But when you
-distribute the same sections as part of a whole which is a work based
-on the Library, the distribution of the whole must be on the terms of
-this License, whose permissions for other licensees extend to the
-entire whole, and thus to each and every part regardless of who wrote
-it.
-Thus, it is not the intent of this section to claim rights or contest
-your rights to work written entirely by you; rather, the intent is to
-exercise the right to control the distribution of derivative or
-collective works based on the Library.
-In addition, mere aggregation of another work not based on the Library
-with the Library (or with a work based on the Library) on a volume of
-a storage or distribution medium does not bring the other work under
-the scope of this License.
-  3. You may opt to apply the terms of the ordinary GNU General Public
-License instead of this License to a given copy of the Library.  To do
-this, you must alter all the notices that refer to this License, so
-that they refer to the ordinary GNU General Public License, version 2,
-instead of to this License.  (If a newer version than version 2 of the
-ordinary GNU General Public License has appeared, then you can specify
-that version instead if you wish.)  Do not make any other change in
-these notices.
-  Once this change is made in a given copy, it is irreversible for
-that copy, so the ordinary GNU General Public License applies to all
-subsequent copies and derivative works made from that copy.
-  This option is useful when you wish to copy part of the code of
-the Library into a program that is not a library.
-  4. You may copy and distribute the Library (or a portion or
-derivative of it, under Section 2) in object code or executable form
-under the terms of Sections 1 and 2 above provided that you accompany
-it with the complete corresponding machine-readable source code, which
-must be distributed under the terms of Sections 1 and 2 above on a
-medium customarily used for software interchange.
-  If distribution of object code is made by offering access to copy
-from a designated place, then offering equivalent access to copy the
-source code from the same place satisfies the requirement to
-distribute the source code, even though third parties are not
-compelled to copy the source along with the object code.
-  5. A program that contains no derivative of any portion of the
-Library, but is designed to work with the Library by being compiled or
-linked with it, is called a "work that uses the Library".  Such a
-work, in isolation, is not a derivative work of the Library, and
-therefore falls outside the scope of this License.
-  However, linking a "work that uses the Library" with the Library
-creates an executable that is a derivative of the Library (because it
-contains portions of the Library), rather than a "work that uses the
-library".  The executable is therefore covered by this License.
-Section 6 states terms for distribution of such executables.
-  When a "work that uses the Library" uses material from a header file
-that is part of the Library, the object code for the work may be a
-derivative work of the Library even though the source code is not.
-Whether this is true is especially significant if the work can be
-linked without the Library, or if the work is itself a library.  The
-threshold for this to be true is not precisely defined by law.
-  If such an object file uses only numerical parameters, data
-structure layouts and accessors, and small macros and small inline
-functions (ten lines or less in length), then the use of the object
-file is unrestricted, regardless of whether it is legally a derivative
-work.  (Executables containing this object code plus portions of the
-Library will still fall under Section 6.)
-  Otherwise, if the work is a derivative of the Library, you may
-distribute the object code for the work under the terms of Section 6.
-Any executables containing that work also fall under Section 6,
-whether or not they are linked directly with the Library itself.
-  6. As an exception to the Sections above, you may also compile or
-link a "work that uses the Library" with the Library to produce a
-work containing portions of the Library, and distribute that work
-under terms of your choice, provided that the terms permit
-modification of the work for the customer's own use and reverse
-engineering for debugging such modifications.
-  You must give prominent notice with each copy of the work that the
-Library is used in it and that the Library and its use are covered by
-this License.  You must supply a copy of this License.  If the work
-during execution displays copyright notices, you must include the
-copyright notice for the Library among them, as well as a reference
-directing the user to the copy of this License.  Also, you must do one
-of these things:
-    a) Accompany the work with the complete corresponding
-    machine-readable source code for the Library including whatever
-    changes were used in the work (which must be distributed under
-    Sections 1 and 2 above); and, if the work is an executable linked
-    with the Library, with the complete machine-readable "work that
-    uses the Library", as object code and/or source code, so that the
-    user can modify the Library and then relink to produce a modified
-    executable containing the modified Library.  (It is understood
-    that the user who changes the contents of definitions files in the
-    Library will not necessarily be able to recompile the application
-    to use the modified definitions.)
-    b) Accompany the work with a written offer, valid for at
-    least three years, to give the same user the materials
-    specified in Subsection 6a, above, for a charge no more
-    than the cost of performing this distribution.
-    c) If distribution of the work is made by offering access to copy
-    from a designated place, offer equivalent access to copy the above
-    specified materials from the same place.
-    d) Verify that the user has already received a copy of these
-    materials or that you have already sent this user a copy.
-  For an executable, the required form of the "work that uses the
-Library" must include any data and utility programs needed for
-reproducing the executable from it.  However, as a special exception,
-the source code distributed need not include anything that is normally
-distributed (in either source or binary form) with the major
-components (compiler, kernel, and so on) of the operating system on
-which the executable runs, unless that component itself accompanies
-the executable.
-  It may happen that this requirement contradicts the license
-restrictions of other proprietary libraries that do not normally
-accompany the operating system.  Such a contradiction means you cannot
-use both them and the Library together in an executable that you
-distribute.
-  7. You may place library facilities that are a work based on the
-Library side-by-side in a single library together with other library
-facilities not covered by this License, and distribute such a combined
-library, provided that the separate distribution of the work based on
-the Library and of the other library facilities is otherwise
-permitted, and provided that you do these two things:
-    a) Accompany the combined library with a copy of the same work
-    based on the Library, uncombined with any other library
-    facilities.  This must be distributed under the terms of the
-    Sections above.
-    b) Give prominent notice with the combined library of the fact
-    that part of it is a work based on the Library, and explaining
-    where to find the accompanying uncombined form of the same work.
-  8. You may not copy, modify, sublicense, link with, or distribute
-the Library except as expressly provided under this License.  Any
-attempt otherwise to copy, modify, sublicense, link with, or
-distribute the Library is void, and will automatically terminate your
-rights under this License.  However, parties who have received copies,
-or rights, from you under this License will not have their licenses
-terminated so long as such parties remain in full compliance.
-  9. You are not required to accept this License, since you have not
-signed it.  However, nothing else grants you permission to modify or
-distribute the Library or its derivative works.  These actions are
-prohibited by law if you do not accept this License.  Therefore, by
-modifying or distributing the Library (or any work based on the
-Library), you indicate your acceptance of this License to do so, and
-all its terms and conditions for copying, distributing or modifying
-the Library or works based on it.
-  10. Each time you redistribute the Library (or any work based on the
-Library), the recipient automatically receives a license from the
-original licensor to copy, distribute, link with or modify the Library
-subject to these terms and conditions.  You may not impose any further
-restrictions on the recipients' exercise of the rights granted herein.
-You are not responsible for enforcing compliance by third parties to
-this License.
-  11. If, as a consequence of a court judgment or allegation of patent
-infringement or for any other reason (not limited to patent issues),
-conditions are imposed on you (whether by court order, agreement or
-otherwise) that contradict the conditions of this License, they do not
-excuse you from the conditions of this License.  If you cannot
-distribute so as to satisfy simultaneously your obligations under this
-License and any other pertinent obligations, then as a consequence you
-may not distribute the Library at all.  For example, if a patent
-license would not permit royalty-free redistribution of the Library by
-all those who receive copies directly or indirectly through you, then
-the only way you could satisfy both it and this License would be to
-refrain entirely from distribution of the Library.
-If any portion of this section is held invalid or unenforceable under any
-particular circumstance, the balance of the section is intended to apply,
-and the section as a whole is intended to apply in other circumstances.
-It is not the purpose of this section to induce you to infringe any
-patents or other property right claims or to contest validity of any
-such claims; this section has the sole purpose of protecting the
-integrity of the free software distribution system which is
-implemented by public license practices.  Many people have made
-generous contributions to the wide range of software distributed
-through that system in reliance on consistent application of that
-system; it is up to the author/donor to decide if he or she is willing
-to distribute software through any other system and a licensee cannot
-impose that choice.
-This section is intended to make thoroughly clear what is believed to
-be a consequence of the rest of this License.
-  12. If the distribution and/or use of the Library is restricted in
-certain countries either by patents or by copyrighted interfaces, the
-original copyright holder who places the Library under this License may add
-an explicit geographical distribution limitation excluding those countries,
-so that distribution is permitted only in or among countries not thus
-excluded.  In such case, this License incorporates the limitation as if
-written in the body of this License.
-  13. The Free Software Foundation may publish revised and/or new
-versions of the Library General Public License from time to time.
-Such new versions will be similar in spirit to the present version,
-but may differ in detail to address new problems or concerns.
-Each version is given a distinguishing version number.  If the Library
-specifies a version number of this License which applies to it and
-"any later version", you have the option of following the terms and
-conditions either of that version or of any later version published by
-the Free Software Foundation.  If the Library does not specify a
-license version number, you may choose any version ever published by
-  14. If you wish to incorporate parts of the Library into other free
-programs whose distribution conditions are incompatible with these,
-write to the author to ask for permission.  For software which is
-copyrighted by the Free Software Foundation, write to the Free
-Software Foundation; we sometimes make exceptions for this.  Our
-decision will be guided by the two goals of preserving the free status
-of all derivatives of our free software and of promoting the sharing
-and reuse of software generally.
-			    NO WARRANTY
-  15. BECAUSE THE LIBRARY IS LICENSED FREE OF CHARGE, THERE IS NO
-WARRANTY FOR THE LIBRARY, TO THE EXTENT PERMITTED BY APPLICABLE LAW.
-EXCEPT WHEN OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR
-OTHER PARTIES PROVIDE THE LIBRARY "AS IS" WITHOUT WARRANTY OF ANY
-KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE
-IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
-PURPOSE.  THE ENTIRE RISK AS TO THE QUALITY AND PERFORMANCE OF THE
-LIBRARY IS WITH YOU.  SHOULD THE LIBRARY PROVE DEFECTIVE, YOU ASSUME
-THE COST OF ALL NECESSARY SERVICING, REPAIR OR CORRECTION.
-  16. IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN
-WRITING WILL ANY COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MAY MODIFY
-AND/OR REDISTRIBUTE THE LIBRARY AS PERMITTED ABOVE, BE LIABLE TO YOU
-FOR DAMAGES, INCLUDING ANY GENERAL, SPECIAL, INCIDENTAL OR
-CONSEQUENTIAL DAMAGES ARISING OUT OF THE USE OR INABILITY TO USE THE
-LIBRARY (INCLUDING BUT NOT LIMITED TO LOSS OF DATA OR DATA BEING
-RENDERED INACCURATE OR LOSSES SUSTAINED BY YOU OR THIRD PARTIES OR A
-FAILURE OF THE LIBRARY TO OPERATE WITH ANY OTHER SOFTWARE), EVEN IF
-SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH
-DAMAGES.
-		     END OF TERMS AND CONDITIONS
-           How to Apply These Terms to Your New Libraries
-  If you develop a new library, and you want it to be of the greatest
-possible use to the public, we recommend making it free software that
-everyone can redistribute and change.  You can do so by permitting
-redistribution under these terms (or, alternatively, under the terms of the
-ordinary General Public License).
-  To apply these terms, attach the following notices to the library.  It is
-safest to attach them to the start of each source file to most effectively
-convey the exclusion of warranty; and each file should have at least the
-"copyright" line and a pointer to where the full notice is found.
-    <one line to give the library's name and a brief idea of what it does.>
-    Copyright (C) <year>  <name of author>
-    This library is free software; you can redistribute it and/or
-    modify it under the terms of the GNU Library General Public
-    License as published by the Free Software Foundation; either
-    version 2 of the License, or (at your option) any later version.
-    This library is distributed in the hope that it will be useful,
-    but WITHOUT ANY WARRANTY; without even the implied warranty of
-    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
-    Library General Public License for more details.
-    You should have received a copy of the GNU Library General Public
-    License along with this library; if not, write to the Free
-    Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
-Also add information on how to contact you by electronic and paper mail.
-You should also get your employer (if you work as a programmer) or your
-school, if any, to sign a "copyright disclaimer" for the library, if
-necessary.  Here is a sample; alter the names:
-  Yoyodyne, Inc., hereby disclaims all copyright interest in the
-  library `Frob' (a library for tweaking knobs) written by James Random Hacker.
-  <signature of Ty Coon>, 1 April 1990
-  Ty Coon, President of Vice
-That's all there is to it!
