[GRASS-SVN] r38886 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Aug 27 13:45:38 EDT 2009
Author: martinl
Date: 2009-08-27 13:45:38 -0400 (Thu, 27 Aug 2009)
New Revision: 38886
Added:
grass/trunk/gui/wxpython/gui_modules/dbm_base.py
grass/trunk/gui/wxpython/gui_modules/__init__.py
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/gui_modules/dbm_dialogs.py
grass/trunk/gui/wxpython/gui_modules/gselect.py
grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py
wxGUI: sqlbuilder major clean up (part 1)
Modified: grass/trunk/gui/wxpython/gui_modules/__init__.py
--- grass/trunk/gui/wxpython/gui_modules/__init__.py 2009-08-27 17:43:27 UTC (rev 38885)
+++ grass/trunk/gui/wxpython/gui_modules/__init__.py 2009-08-27 17:45:38 UTC (rev 38886)
@@ -1,6 +1,7 @@
all = [
"colorrules.py",
"dbm.py",
+ "dbm_base.py",
"dbm_dialogs.py",
"debug.py",
"disp_print.py",
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2009-08-27 17:43:27 UTC (rev 38885)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2009-08-27 17:45:38 UTC (rev 38886)
@@ -17,7 +17,6 @@
- Log
- VirtualAttributeList
- AttributeManager
- - VectorDBInfo
(C) 2007-2009 by the GRASS Development Team
@@ -51,7 +50,7 @@
import gcmd
import utils
import gdialogs
-import gselect
+import dbm_base
from debug import Debug
from dbm_dialogs import ModifyTableRecord
from preferences import globalSettings as UserSettings
@@ -477,7 +476,7 @@
self.qlayer = None
# -> layers / tables description
- self.mapDBInfo = VectorDBInfo(self.vectorName)
+ self.mapDBInfo = dbm_base.VectorDBInfo(self.vectorName)
if len(self.mapDBInfo.layers.keys()) == 0:
wx.MessageBox(parent=self.parent,
@@ -725,7 +724,7 @@
dbBox = wx.StaticBox(parent=panel, id=wx.ID_ANY,
label=" %s " % _("Database connection"))
dbSizer = wx.StaticBoxSizer(dbBox, wx.VERTICAL)
- dbSizer.Add(item=self.__createDbInfoDesc(panel, layer),
+ dbSizer.Add(item=dbm_base.createDbInfoDesc(panel, self.mapDBInfo, layer),
proportion=1,
flag=wx.EXPAND | wx.ALL,
border=3)
@@ -1853,34 +1852,10 @@
return (cols, where)
- def __createDbInfoDesc(self, panel, layer):
- """!Create database connection information content"""
- infoFlexSizer = wx.FlexGridSizer (cols=2, hgap=1, vgap=1)
- infoFlexSizer.AddGrowableCol(1)
- infoFlexSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
- label="Driver:"))
- label=self.mapDBInfo.layers[layer]['driver']))
- label="Database:"))
- label=self.mapDBInfo.layers[layer]['database']))
- label="Table:"))
- label=self.mapDBInfo.layers[layer]['table']))
- label="Key:"))
- label=self.mapDBInfo.layers[layer]['key']))
- return infoFlexSizer
def OnCloseWindow(self, event):
"""!Cancel button pressed"""
self.Close()
- if self.parent.GetName() == 'LayerManager':
+ if self.parent and self.parent.GetName() == 'LayerManager':
# deregister ATM
self.parent.dialogs['atm'].remove(self)
@@ -2901,129 +2876,6 @@
event.Skip()
-class VectorDBInfo(gselect.VectorDBInfo):
- """!Class providing information about attribute tables
- linked to the vector map"""
- def __init__(self, map):
- gselect.VectorDBInfo.__init__(self, map)
- def GetColumns(self, table):
- """!Return list of columns names (based on their index)"""
- try:
- names = [''] * len(self.tables[table].keys())
- except KeyError:
- return []
- for name, desc in self.tables[table].iteritems():
- names[desc['index']] = name
- return names
- def SelectByPoint(self, queryCoords, qdist):
- """!Get attributes by coordinates (all available layers)
- Return line id or None if no line is found"""
- line = None
- nselected = 0
- if os.environ.has_key("LC_ALL"):
- locale = os.environ["LC_ALL"]
- os.environ["LC_ALL"] = "C"
- ### FIXME (implement script-style output)
- ret = gcmd.RunCommand('v.what',
- quiet = True,
- read = True,
- flags = 'a',
- map = self.map,
- east_north = '%f,%f' % \
- (float(queryCoords[0]), float(queryCoords[1])),
- distance = float(qdist))
- os.environ["LC_ALL"] = locale
- data = {}
- if ret:
- readAttrb = False
- for item in ret.splitlines():
- try:
- key, value = item.split(':', 1)
- except ValueError:
- continue
- if key == 'Layer' and readAttrb:
- readAttrb = False
- if readAttrb:
- name, value = item.split(':', 1)
- name = name.strip()
- value = value.strip()
- # append value to the column
- if len(value) < 1:
- value = None
- else:
- if self.tables[table][name]['ctype'] != type(''):
- value = self.tables[table][name]['ctype'] (value.strip())
- else:
- value = unicodeValue(value.strip())
- self.tables[table][name]['values'].append(value)
- else:
- if not data.has_key(key):
- data[key] = []
- data[key].append(value.strip())
- if key == 'Table':
- table = value.strip()
- if key == 'Key column': # skip attributes
- readAttrb = True
- return data
- def SelectFromTable(self, layer, cols='*', where=None):
- """!Select records from the table
- Return number of selected records, -1 on error
- if layer <= 0:
- return -1
- nselected = 0
- table = self.layers[layer]["table"] # get table desc
- # select values (only one record)
- if where is None or where is '':
- sql="SELECT %s FROM %s" % (cols, table)
- else:
- sql="SELECT %s FROM %s WHERE %s" % (cols, table, where)
- ret = gcmd.RunCommand('db.select',
- parent = self,
- read = True,
- quiet = True,
- flags = 'v',
- sql= sql,
- database = self.layers[layer]["database"],
- driver = self.layers[layer]["driver"])
- # self.tables[table][key][1] = str(cat)
- if ret:
- for line in ret.splitlines():
- name, value = line.split('|')
- # casting ...
- if value:
- value = self.tables[table][name]['ctype'] (value)
- else:
- value = unicodeValue(value)
- else:
- value = None
- nselected = 1
- return nselected
def main(argv=None):
if argv is None:
argv = sys.argv
Added: grass/trunk/gui/wxpython/gui_modules/dbm_base.py
--- grass/trunk/gui/wxpython/gui_modules/dbm_base.py (rev 0)
+++ grass/trunk/gui/wxpython/gui_modules/dbm_base.py 2009-08-27 17:45:38 UTC (rev 38886)
@@ -0,0 +1,170 @@
+ at package dbm_base.py
+ at brief Support classes for dbm.py
+List of classes:
+ - VectorDBInfo
+(C) 2007-2009 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Martin Landa <landa.martin gmail.com>
+import os
+import wx
+import gselect
+import gcmd
+def createDbInfoDesc(panel, mapDBInfo, layer):
+ """!Create database connection information content"""
+ infoFlexSizer = wx.FlexGridSizer (cols=2, hgap=1, vgap=1)
+ infoFlexSizer.AddGrowableCol(1)
+ infoFlexSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
+ label="Driver:"))
+ label=mapDBInfo.layers[layer]['driver']))
+ label="Database:"))
+ label=mapDBInfo.layers[layer]['database']))
+ label="Table:"))
+ label=mapDBInfo.layers[layer]['table']))
+ label="Key:"))
+ label=mapDBInfo.layers[layer]['key']))
+ return infoFlexSizer
+class VectorDBInfo(gselect.VectorDBInfo):
+ """!Class providing information about attribute tables
+ linked to the vector map"""
+ def __init__(self, map):
+ gselect.VectorDBInfo.__init__(self, map)
+ def GetColumns(self, table):
+ """!Return list of columns names (based on their index)"""
+ try:
+ names = [''] * len(self.tables[table].keys())
+ except KeyError:
+ return []
+ for name, desc in self.tables[table].iteritems():
+ names[desc['index']] = name
+ return names
+ def SelectByPoint(self, queryCoords, qdist):
+ """!Get attributes by coordinates (all available layers)
+ Return line id or None if no line is found"""
+ line = None
+ nselected = 0
+ if os.environ.has_key("LC_ALL"):
+ locale = os.environ["LC_ALL"]
+ os.environ["LC_ALL"] = "C"
+ ### FIXME (implement script-style output)
+ ret = gcmd.RunCommand('v.what',
+ quiet = True,
+ read = True,
+ flags = 'a',
+ map = self.map,
+ east_north = '%f,%f' % \
+ (float(queryCoords[0]), float(queryCoords[1])),
+ distance = float(qdist))
+ os.environ["LC_ALL"] = locale
+ data = {}
+ if ret:
+ readAttrb = False
+ for item in ret.splitlines():
+ try:
+ key, value = item.split(':', 1)
+ except ValueError:
+ continue
+ if key == 'Layer' and readAttrb:
+ readAttrb = False
+ if readAttrb:
+ name, value = item.split(':', 1)
+ name = name.strip()
+ value = value.strip()
+ # append value to the column
+ if len(value) < 1:
+ value = None
+ else:
+ if self.tables[table][name]['ctype'] != type(''):
+ value = self.tables[table][name]['ctype'] (value.strip())
+ else:
+ value = unicodeValue(value.strip())
+ self.tables[table][name]['values'].append(value)
+ else:
+ if not data.has_key(key):
+ data[key] = []
+ data[key].append(value.strip())
+ if key == 'Table':
+ table = value.strip()
+ if key == 'Key column': # skip attributes
+ readAttrb = True
+ return data
+ def SelectFromTable(self, layer, cols='*', where=None):
+ """!Select records from the table
+ Return number of selected records, -1 on error
+ if layer <= 0:
+ return -1
+ nselected = 0
+ table = self.layers[layer]["table"] # get table desc
+ # select values (only one record)
+ if where is None or where is '':
+ sql="SELECT %s FROM %s" % (cols, table)
+ else:
+ sql="SELECT %s FROM %s WHERE %s" % (cols, table, where)
+ ret = gcmd.RunCommand('db.select',
+ parent = self,
+ read = True,
+ quiet = True,
+ flags = 'v',
+ sql= sql,
+ database = self.layers[layer]["database"],
+ driver = self.layers[layer]["driver"])
+ # self.tables[table][key][1] = str(cat)
+ if ret:
+ for line in ret.splitlines():
+ name, value = line.split('|')
+ # casting ...
+ if value:
+ value = self.tables[table][name]['ctype'] (value)
+ else:
+ value = unicodeValue(value)
+ else:
+ value = None
+ nselected = 1
+ return nselected
Property changes on: grass/trunk/gui/wxpython/gui_modules/dbm_base.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:keywords
+ Author Date Id
Added: svn:eol-style
+ native
Modified: grass/trunk/gui/wxpython/gui_modules/dbm_dialogs.py
--- grass/trunk/gui/wxpython/gui_modules/dbm_dialogs.py 2009-08-27 17:43:27 UTC (rev 38885)
+++ grass/trunk/gui/wxpython/gui_modules/dbm_dialogs.py 2009-08-27 17:45:38 UTC (rev 38886)
@@ -25,10 +25,10 @@
import wx
import wx.lib.scrolledpanel as scrolled
-import dbm
import gcmd
+from dbm_base import VectorDBInfo
class DisplayAttributesDialog(wx.Dialog):
@@ -62,7 +62,7 @@
self.fid = -1 # feature id
# get layer/table/column information
- self.mapDBInfo = dbm.VectorDBInfo(self.map)
+ self.mapDBInfo = VectorDBInfo(self.map)
layers = self.mapDBInfo.layers.keys() # get available layers
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py 2009-08-27 17:43:27 UTC (rev 38885)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py 2009-08-27 17:45:38 UTC (rev 38886)
@@ -480,6 +480,15 @@
return self.layers[layer]['table']
+ def GetDbSettings(self, layer):
+ """!Get database settins
+ @param layer layer number
+ @return (driver, database)
+ return self.layers[layer]['driver'], self.layers[layer]['database']
def GetTableDesc(self, table):
"""!Get table columns
Modified: grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py
--- grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py 2009-08-27 17:43:27 UTC (rev 38885)
+++ grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py 2009-08-27 17:45:38 UTC (rev 38886)
@@ -1,384 +1,421 @@
-MODULE: sqlbuilder.py
+ at package sqlbuilder.py
-CLASSES:
- * SQLFrame
+ at brief GRASS SQL Builder
-PURPOSE: GRASS SQL Builder
+Classes:
+ - SQLFrame
- Usage:
- sqlbuilder.py table_name
+ at todo Various updates are required...
-AUTHOR(S): GRASS Development Team
- Original author: Jachym Cepicky <jachym.cepicky gmail.com>
- Various updates: Martin Landa <landa.martin gmail.com>,
- Hamish Bowman <hamish_b yahoo com>
+Usage:
+ at code
+python sqlbuilder.py vector_map
+ at endcode
-COPYRIGHT: (C) 2007-2009 by the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
+for details.
+ at author Jachym Cepicky <jachym.cepicky gmail.com> (original author)
+ at author Martin Landa <landa.martin gmail.com>,
+ at author Hamish Bowman <hamish_b yahoo com>
-import wx
-import os,sys
+import os
+import sys
import time
-from grass.script import core as grass
+### i18N
+import gettext
+gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
-import gcmd
import globalvar
+if not os.getenv("GRASS_WXBUNDLED"):
+ globalvar.CheckForWx()
-imagePath = os.path.join(globalvar.ETCWXDIR)
-sys.path.append(imagePath)
-import images
-imagepath = images.__path__[0]
-sys.path.append(imagepath)
+import wx
+import grass.script as grass
+grass.set_fatal_exit(False)
+import gcmd
+import dbm_base
class SQLFrame(wx.Frame):
"""!SQL Frame class"""
- def __init__(self, parent, id, title, vectmap, qtype="select"):
+ def __init__(self, parent, title, vectmap, id = wx.ID_ANY,
+ layer = 1, qtype = "select"):
wx.Frame.__init__(self, parent, id, title)
+ self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_sql.ico'),
+ wx.BITMAP_TYPE_ICO))
+ self.parent = parent
- self.SetTitle(_("GRASS SQL Builder: %s") % (qtype.upper()))
- self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_sql.ico'), wx.BITMAP_TYPE_ICO))
# variables
- self.vectmap = vectmap
+ self.vectmap = vectmap # fullname
if not "@" in self.vectmap:
self.vectmap = self.vectmap + "@" + grass.gisenv()['MAPSET']
self.mapname, self.mapset = self.vectmap.split("@")
- #FIXME: pass layer number to v.db.connect ???
- ret = gcmd.RunCommand('v.db.connect',
- quiet = True,
- read = True,
- flags = 'g',
- fs = '|',
- map = self.vectmap)
- self.layer,self.tablename, self.column, self.database, self.driver =\
- line.strip().split("|")
+ # db info
+ self.layer = layer
+ self.dbInfo = dbm_base.VectorDBInfo(self.vectmap)
+ self.tablename = self.dbInfo.GetTable(self.layer)
+ self.driver, self.database = self.dbInfo.GetDbSettings(self.layer)
self.qtype = qtype # type of the uqery: SELECT, UPDATE, DELETE, ...
- self.column_names = [] # array with column names
- self.columns = {} # array with colum properties
- self.colvalues = [] # array with uniqe values in selected column
- self.heading = ""
- self.parent = parent
+ self.colvalues = [] # array with unique values in selected column
- if self.qtype.lower()=="select":
- self.heading = "SELECT * FROM %s WHERE" % self.tablename
+ # set dialog title
+ self.SetTitle(_("GRASS SQL Builder (%s): vector map <%s>") % \
+ (qtype.upper(), self.vectmap))
+ self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
- # Init
- self.GetColumns()
- # Buttons
+ # buttons
- self.btn_clear = wx.Button(self, -1, "Clear")
- self.btn_verify = wx.Button(self, -1, "Verify")
- #self.btn_help = wx.Button(self, -1, "Help")
- # self.btn_load = wx.Button(self, -1, "Load")
- # self.btn_save = wx.Button(self, -1, "Save")
- self.btn_apply = wx.Button(self, -1, "Apply")
- self.btn_close = wx.Button(self, -1, "Close")
- self.btn_uniqe = wx.Button(self, -1, "Get all values")
- self.btn_uniqesample = wx.Button(self, -1, "Get sample")
- self.btn_is = wx.Button(self, -1, "=")
- self.btn_isnot = wx.Button(self, -1, "!=")
- self.btn_like = wx.Button(self, -1, "LIKE")
- self.btn_gt = wx.Button(self, -1, ">")
- self.btn_gtis = wx.Button(self, -1, ">=")
- self.btn_lt = wx.Button(self, -1, "<")
- self.btn_ltis = wx.Button(self, -1, "<=")
- self.btn_or = wx.Button(self, -1, "OR")
- self.btn_not = wx.Button(self, -1, "NOT")
- self.btn_and = wx.Button(self, -1, "AND")
- self.btn_brackets = wx.Button(self, -1, "()")
- self.btn_prc = wx.Button(self, -1, "%")
+ self.btn_clear = wx.Button(parent = self.panel, id = wx.ID_CLEAR)
+ self.btn_verify = wx.Button(parent = self.panel, id = wx.ID_ANY,
+ label = _("Verify"))
+ # self.btn_help = wx.Button(self.panel, -1, "Help")
+ # self.btn_load = wx.Button(self.panel, -1, "Load")
+ # self.btn_save = wx.Button(self.panel, -1, "Save")
+ self.btn_apply = wx.Button(parent = self.panel, id = wx.ID_APPLY)
+ self.btn_close = wx.Button(parent = self.panel, id = wx.ID_CLOSE)
+ self.btn_unique = wx.Button(parent = self.panel, id = wx.ID_ANY,
+ label = _("Get all values"))
+ self.btn_unique.Enable(False)
+ self.btn_uniquesample = wx.Button(parent = self.panel, id = wx.ID_ANY,
+ label = _("Get sample"))
+ self.btn_uniquesample.Enable(False)
+ self.btn_is = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "=")
+ self.btn_isnot = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "!=")
+ self.btn_like = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "LIKE")
+ self.btn_gt = wx.Button(parent = self.panel, id = wx.ID_ANY, label = ">")
+ self.btn_gtis = wx.Button(parent = self.panel, id = wx.ID_ANY, label = ">=")
+ self.btn_lt = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "<")
+ self.btn_ltis = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "<=")
+ self.btn_or = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "OR")
+ self.btn_not = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "NOT")
+ self.btn_and = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "AND")
+ self.btn_brackets = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "()")
+ self.btn_prc = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "%")
# Text labels
- #self.label_headding = wx.StaticText(self, -1, '')
+ # self.label_headding = wx.StaticText(self.panel, -1, '')
# Textareas
- self.text_sql = wx.TextCtrl(self, -1, '', size=(-1,75),style=wx.TE_MULTILINE)
+ self.text_sql = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY,
+ value = '', size = (-1, 75),
+ style=wx.TE_MULTILINE)
+ if self.qtype.lower() == "select":
+ self.text_sql.SetValue("SELECT * FROM %s" % self.tablename)
# List Boxes
- self.list_columns = wx.ListBox(self, -1, wx.DefaultPosition, (-1, -1), self.columns.keys(), wx.LB_MULTIPLE|wx.LB_SORT)
- self.list_values = wx.ListBox(self, -1, wx.DefaultPosition, (-1, -1), self.colvalues, wx.LB_MULTIPLE|wx.LB_SORT)
+ self.list_columns = wx.ListBox(parent = self.panel, id = wx.ID_ANY,
+ choices = self.dbInfo.GetColumns(self.tablename),
+ style = wx.LB_MULTIPLE)
+ self.list_values = wx.ListBox(parent = self.panel, id = wx.ID_ANY,
+ choices = self.colvalues,
# Bindings
- self.btn_uniqe.Bind(wx.EVT_BUTTON, self.GetUniqueValues)
- self.btn_uniqesample.Bind(wx.EVT_BUTTON, self.GetSampleValues)
- self.btn_is.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_isnot.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_like.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_gt.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_gtis.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_or.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_lt.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_ltis.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_not.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_brackets.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_prc.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_and.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
- self.btn_clear.Bind(wx.EVT_BUTTON, self.OnClear)
- self.btn_verify.Bind(wx.EVT_BUTTON, self.OnVerify)
- self.btn_apply.Bind(wx.EVT_BUTTON, self.OnApply)
+ self.btn_unique.Bind(wx.EVT_BUTTON, self.GetUniqueValues)
+ self.btn_uniquesample.Bind(wx.EVT_BUTTON, self.GetSampleValues)
+ self.btn_is.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_isnot.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_like.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_gt.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_gtis.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_or.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_lt.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_ltis.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_not.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_brackets.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_prc.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_and.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
+ self.btn_clear.Bind(wx.EVT_BUTTON, self.OnClear)
+ self.btn_verify.Bind(wx.EVT_BUTTON, self.OnVerify)
+ self.btn_apply.Bind(wx.EVT_BUTTON, self.OnApply)
- self.list_columns.Bind(wx.EVT_LISTBOX, self.AddColumnName)
- self.list_values.Bind(wx.EVT_LISTBOX, self.AddValue)
+ self.list_columns.Bind(wx.EVT_LISTBOX, self.AddColumnName)
+ self.list_values.Bind(wx.EVT_LISTBOX, self.AddValue)
+ self.text_sql.Bind(wx.EVT_TEXT, self.OnText)
self.__doLayout()
def __doLayout(self):
- databasebox = wx.StaticBox(self, -1, "Database connection")
- databaseboxsizer = wx.StaticBoxSizer(databasebox,wx.VERTICAL)
- dbstr = "Database: %s\n" % (self.database)
- dbstr += "Driver: %s\n" % (self.driver)
- dbstr += "Table: %s" % (self.tablename)
- databaseboxsizer.Add(wx.StaticText(self,-1,dbstr), flag=wx.EXPAND)
+ """!Do dialog layout"""
+ # dbInfo
+ databasebox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+ label = " %s " % _("Database connection"))
+ databaseboxsizer = wx.StaticBoxSizer(databasebox, wx.VERTICAL)
+ databaseboxsizer.Add(item=dbm_base.createDbInfoDesc(self.panel, self.dbInfo, layer = self.layer),
+ proportion=1,
+ flag=wx.EXPAND | wx.ALL,
+ border=3)
- sqlbox = wx.StaticBox(self, -1, "%s" % self.heading)
- sqlboxsizer = wx.StaticBoxSizer(sqlbox,wx.VERTICAL)
- sqlboxsizer.Add(self.text_sql, flag=wx.EXPAND)
+ # sql box
+ sqlbox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+ label = " %s " % _("Query"))
+ sqlboxsizer = wx.StaticBoxSizer(sqlbox, wx.VERTICAL)
+ sqlboxsizer.Add(item = self.text_sql, flag = wx.EXPAND)
pagesizer = wx.BoxSizer(wx.VERTICAL)
- buttonsizer1 = wx.GridBagSizer(2,2)
- buttonsizer1.Add(self.btn_clear, (0,0))
- buttonsizer1.Add(self.btn_verify, (0,1))
- #buttonsizer1.Add(self.btn_help, (0,2))
- #buttonsizer1.Add(self.btn_load, (0,2))
+ # buttons
+ buttonsizer = wx.FlexGridSizer(cols = 4, hgap = 5, vgap = 5)
+ buttonsizer.Add(item = self.btn_clear)
+ buttonsizer.Add(item = self.btn_verify)
+ # buttonsizer1.Add(self.btn_help, (0,2))
+ # buttonsizer1.Add(self.btn_load, (0,2))
# buttonsizer1.Add(self.btn_save, (0,3))
- buttonsizer1.Add(self.btn_apply, (0,2))
+ buttonsizer.Add(item = self.btn_apply)
+ buttonsizer.Add(item = self.btn_close)
+ buttonsizer2 = wx.GridBagSizer(5, 5)
+ buttonsizer2.Add(item = self.btn_is, pos = (0,0))
+ buttonsizer2.Add(item = self.btn_isnot, pos = (1,0))
+ buttonsizer2.Add(item = self.btn_like, pos = (2, 0))
- buttonsizer2 = wx.GridBagSizer(2, 2)
- buttonsizer2.Add(self.btn_is, (0,0))
- buttonsizer2.Add(self.btn_isnot, (1,0))
- buttonsizer2.Add(self.btn_like, (2, 0))
+ buttonsizer2.Add(item = self.btn_gt, pos = (0, 1))
+ buttonsizer2.Add(item = self.btn_gtis, pos = (1, 1))
+ buttonsizer2.Add(item = self.btn_or, pos = (2, 1))
- buttonsizer2.Add(self.btn_gt, (0, 1))
- buttonsizer2.Add(self.btn_gtis, (1, 1))
- buttonsizer2.Add(self.btn_or, (2, 1))
+ buttonsizer2.Add(item = self.btn_lt, pos = (0, 2))
+ buttonsizer2.Add(item = self.btn_ltis, pos = (1, 2))
+ buttonsizer2.Add(item = self.btn_not, pos = (2, 2))
- buttonsizer2.Add(self.btn_lt, (0, 2))
- buttonsizer2.Add(self.btn_ltis, (1, 2))
- buttonsizer2.Add(self.btn_not, (2, 2))
+ buttonsizer2.Add(item = self.btn_brackets, pos = (0, 3))
+ buttonsizer2.Add(item = self.btn_prc, pos = (1, 3))
+ buttonsizer2.Add(item = self.btn_and, pos = (2, 3))
- buttonsizer2.Add(self.btn_brackets, (0, 3))
- buttonsizer2.Add(self.btn_prc, (1, 3))
- buttonsizer2.Add(self.btn_and, (2, 3))
- buttonsizer3 = wx.GridSizer(4, 3, 3, 3)
- buttonsizer3.Add(self.btn_apply,0,wx.RIGHT,5)
- buttonsizer3.Add(self.btn_close,0,wx.RIGHT,5)
buttonsizer4 = wx.BoxSizer(wx.HORIZONTAL)
- buttonsizer4.Add(self.btn_uniqesample,0,flag=wx.ALIGN_CENTER_HORIZONTAL,border=5)
- buttonsizer4.Add(self.btn_uniqe,0,flag=wx.ALIGN_CENTER_HORIZONTAL,border=5)
- hsizer1 = wx.BoxSizer(wx.HORIZONTAL)
- #hsizer2 = wx.BoxSizer(wx.HORIZONTAL)
- columnsbox = wx.StaticBox(self,-1,"Columns: ")
- valuesbox = wx.StaticBox(self,-1,"Values: ")
- #hsizer1.Add(wx.StaticText(self,-1, "Unique values: "), border=0, proportion=1)
- columnsizer = wx.StaticBoxSizer(columnsbox,wx.VERTICAL)
- valuesizer = wx.StaticBoxSizer(valuesbox,wx.VERTICAL)
- columnsizer.Add(self.list_columns, flag=wx.EXPAND,)
- valuesizer.Add(self.list_values, flag=wx.EXPAND)
- self.list_columns.SetMinSize((-1,130))
- self.list_values.SetMinSize((-1,100))
- valuesizer.Add(buttonsizer4)
- hsizer1.Add(columnsizer,border=0, proportion=1)
- hsizer1.Add(valuesizer,border=0, proportion=1)
- pagesizer.Add(databaseboxsizer,flag=wx.EXPAND,border=5)
- pagesizer.Add(hsizer1, 1,flag=wx.EXPAND,border=5)
- #pagesizer.Add(self.btn_uniqe,0,wx.ALIGN_LEFT|wx.TOP,border=5)
- #pagesizer.Add(self.btn_uniqesample,0,wx.ALIGN_LEFT|wx.TOP,border=5)
- pagesizer.Add(buttonsizer2, 0, wx.ALIGN_CENTER_HORIZONTAL|wx.TOP, border=5)
- pagesizer.Add(sqlboxsizer, flag=wx.EXPAND,border=5)
- pagesizer.Add(buttonsizer1, 0, wx.ALIGN_CENTER_HORIZONTAL|wx.TOP, border=5)
- pagesizer.Add(buttonsizer3, proportion=0, flag=wx.TOP, border=5)
- self.SetAutoLayout(True)
- self.SetSizer(pagesizer)
- pagesizer.Fit(self)
- #pagesizer.SetSizeHints(self)
+ buttonsizer4.Add(item = self.btn_uniquesample, proportion = 0,
+ flag = wx.ALIGN_CENTER_HORIZONTAL | wx.RIGHT, border = 5)
+ buttonsizer4.Add(item = self.btn_unique, proportion = 0,
+ flag = wx.ALIGN_CENTER_HORIZONTAL)
+ hsizer = wx.BoxSizer(wx.HORIZONTAL)
+ columnsbox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+ label = " %s " % _("Columns"))
+ valuesbox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+ label = " %s " % _("Values"))
+ # hsizer1.Add(wx.StaticText(self.panel,-1, "Unique values: "), border=0, proportion=1)
+ columnsizer = wx.StaticBoxSizer(columnsbox, wx.VERTICAL)
+ valuesizer = wx.StaticBoxSizer(valuesbox, wx.VERTICAL)
+ columnsizer.Add(item = self.list_columns, proportion = 1,
+ flag = wx.EXPAND)
+ valuesizer.Add(item = self.list_values, proportion = 1,
+ flag = wx.EXPAND)
+ # self.list_columns.SetMinSize((-1,130))
+ # self.list_values.SetMinSize((-1,100))
+ valuesizer.Add(item = buttonsizer4, proportion = 0,
+ flag = wx.TOP, border = 5)
+ hsizer.Add(item = columnsizer, proportion = 1,
+ flag = wx.EXPAND)
+ hsizer.Add(item = valuesizer, proportion = 1,
+ flag = wx.EXPAND)
+ pagesizer.Add(item = databaseboxsizer,
+ flag = wx.ALL | wx.EXPAND, border = 5)
+ pagesizer.Add(item = hsizer, proportion = 1,
+ flag = wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border = 5)
+ # pagesizer.Add(self.btn_uniqe,0,wx.ALIGN_LEFT|wx.TOP,border=5)
+ # pagesizer.Add(self.btn_uniqesample,0,wx.ALIGN_LEFT|wx.TOP,border=5)
+ pagesizer.Add(item = buttonsizer2, proportion = 0,
+ flag = wx.ALIGN_CENTER_HORIZONTAL | wx.BOTTOM, border = 5)
+ pagesizer.Add(item = sqlboxsizer, proportion = 0,
+ flag = wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border = 5)
+ pagesizer.Add(item = buttonsizer, proportion = 0,
+ flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
+ self.panel.SetAutoLayout(True)
+ self.panel.SetSizer(pagesizer)
+ pagesizer.Fit(self.panel)
self.Layout()
- self.Show(True)
- def GetColumns(self):
- """!Get columns"""
- ret = gcmd.RunCommand('db.describe',
- quiet = True,
- read = True,
- flags = 'c',
- table = self.tablename,
- database = self.database,
- driver = self.driver)
+ self.SetMinSize((660, 480))
- # skip ncols and nrows lines
- linetype = line.strip().split(":")[0]
- if linetype == "ncols" or linetype == "nrows":
- continue
- num, name, ctype, length = line.strip().split(":")
- name.strip()
- #self.columns_names.append(name)
- self.columns[name] = {'type' : ctype}
- def GetUniqueValues(self,event,justsample=False):
+ def GetUniqueValues(self, event, justsample = False):
+ """!Get unique values"""
vals = []
try:
idx = self.list_columns.GetSelections()[0]
+ column = self.list_columns.GetString(idx)
except:
+ self.list_values.Clear()
return
- column = self.list_columns.GetString(idx)
i = 0
querystring = "SELECT %s FROM %s" % (column, self.tablename)
- read = True,
- quiet = True,
- flags = 'c',
- driver = self.driver,
- sql = querystring)
+ data = grass.db_select(table = self.tablename,
+ sql = querystring,
+ database = self.database,
+ driver = self.driver)
+ for line in data:
if justsample and i < 256 or \
not justsample:
- self.list_values.Insert(line.strip(),0)
+ self.list_values.Append(line.strip())
else:
break
i += 1
+ def GetSampleValues(self, event):
+ """!Get sample values"""
+ self.GetUniqueValues(None, True)
- def GetSampleValues(self,event):
- self.GetUniqueValues(None,True)
- def AddColumnName(self,event):
- idx = self.list_columns.GetSelections()[0]
- self.__addSomething(column)
+ def AddColumnName(self, event):
+ """!Add column name to the query"""
+ idx = self.list_columns.GetSelections()
+ for i in idx:
+ column = self.list_columns.GetString(i)
+ self.__Add(element = 'column', value = column)
+ if not self.btn_uniquesample.IsEnabled():
+ self.btn_uniquesample.Enable()
+ self.btn_unique.Enable()
def AddValue(self,event):
+ """!Add value"""
idx = self.list_values.GetSelections()[0]
value = self.list_values.GetString(idx)
if self.columns[column]['type'].lower().find("chara") > -1:
value = "'%s'" % value
- self.__addSomething(value)
+ self.__Add(value)
def AddMark(self,event):
- if event.GetId() == self.btn_is.GetId(): mark = "="
- elif event.GetId() == self.btn_isnot.GetId(): mark = "!="
- elif event.GetId() == self.btn_like.GetId(): mark = "LIKE"
- elif event.GetId() == self.btn_gt.GetId(): mark = ">"
- elif event.GetId() == self.btn_gtis.GetId(): mark = ">="
- elif event.GetId() == self.btn_lt.GetId(): mark = "<"
- elif event.GetId() == self.btn_ltis.GetId(): mark = "<="
- elif event.GetId() == self.btn_or.GetId(): mark = "OR"
- elif event.GetId() == self.btn_not.GetId(): mark = "NOT"
- elif event.GetId() == self.btn_and.GetId(): mark = "AND"
- elif event.GetId() == self.btn_brackets.GetId(): mark = "()"
- elif event.GetId() == self.btn_prc.GetId(): mark = "%"
- self.__addSomething(mark)
+ """!Add mark"""
+ if event.GetId() == self.btn_is.GetId():
+ mark = "="
+ elif event.GetId() == self.btn_isnot.GetId():
+ mark = "!="
+ elif event.GetId() == self.btn_like.GetId():
+ mark = "LIKE"
+ elif event.GetId() == self.btn_gt.GetId():
+ mark = ">"
+ elif event.GetId() == self.btn_gtis.GetId():
+ mark = ">="
+ elif event.GetId() == self.btn_lt.GetId():
+ mark = "<"
+ elif event.GetId() == self.btn_ltis.GetId():
+ mark = "<="
+ elif event.GetId() == self.btn_or.GetId():
+ mark = "OR"
+ elif event.GetId() == self.btn_not.GetId():
+ mark = "NOT"
+ elif event.GetId() == self.btn_and.GetId():
+ mark = "AND"
+ elif event.GetId() == self.btn_brackets.GetId():
+ mark = "()"
+ elif event.GetId() == self.btn_prc.GetId():
+ mark = "%"
+ self.__Add(mark)
- def __addSomething(self,what):
+ def __Add(self, element, value):
+ """!Add element to the query
+ @param what what to add
sqlstr = self.text_sql.GetValue()
newsqlstr = ''
- position = self.text_sql.GetPosition()[0]
- selection = self.text_sql.GetSelection()
- newsqlstr = sqlstr[:position]
- try:
- if newsqlstr[-1] != " ":
- newsqlstr += " "
- except:
- pass
- newsqlstr += what
- newsqlstr += " "+sqlstr[position:]
- self.text_sql.SetValue(newsqlstr)
- # FIXME: cursor position is messed up
- # see also http://trac.wxwidgets.org/ticket/10051
- #DEBUG: print "before: %d" % (position)
- self.text_sql.SetInsertionPoint(position)
- #? self.text_sql.SetInsertionPoint(position+len(what))
- #? self.text_sql.SetInsertionPointEnd()
- #DEBUG: print "len(what)=%d" % (len(what))
- #DEBUG: print "after: %d" % (self.text_sql.GetPosition()[0])
- #DEBUG: print " "
- def OnApply(self,event):
+ if element == 'column':
+ idx1 = len('select')
+ idx2 = sqlstr.lower().find('from')
+ colstr = sqlstr[idx1:idx2].strip()
+ if colstr == '*':
+ cols = []
+ else:
+ cols = colstr.split(',')
+ if value in cols:
+ cols.remove(value)
+ else:
+ cols.append(value)
+ if len(cols) < 1:
+ cols = ['*',]
+ newsqlstr = 'SELECT ' + ','.join(cols) + ' ' + sqlstr[idx2:]
+ if newsqlstr:
+ self.text_sql.SetValue(newsqlstr)
+ def OnText(self, event):
+ """Query string changed"""
+ if len(self.text_sql.GetValue()) > 0:
+ self.btn_verify.Enable(True)
+ else:
+ self.btn_verify.Enable(False)
+ def OnApply(self, event):
+ """Apply button pressed"""
if self.parent:
try:
self.parent.text_query.SetValue= self.text_sql.GetValue().strip().replace("\n"," ")
except:
pass
+ def OnVerify(self, event):
+ """!Verify button pressed"""
+ ret, msg = gcmd.RunCommand('db.select',
+ getErrorMsg = True,
+ table = self.tablename,
+ sql = self.text_sql.GetValue(),
+ flags = 't',
+ driver = self.driver,
+ database = self.database)
- def OnVerify(self,event):
- if self.text_sql.GetValue():
- querystring = "SELECT * FROM %s WHERE %s" % \
- (self.tablename,
- self.text_sql.GetValue().strip().replace("\n"," "))
- # FIXME: LOG
- # print self.text_sql.GetValue().strip().replace("\n"," "), "not correct!"
- print "Testing [%s] ..." % (querystring)
- ret, msg = gcmd.RunCommand('db.select',
- getErrorMsg = True,
- verbose = True,
- flags = 't',
- print msg, " "
- if ret == 0:
- pass
+ if ret != 0 and msg:
+ wx.MessageBox(parent=self,
+ message=_("SQL statement is not valid.\n\n%s") % msg,
+ caption=_("Warning"), style=wx.OK | wx.ICON_WARNING | wx.CENTRE)
def OnClear(self, event):
- self.text_sql.SetValue("")
- def OnClose(self,event):
+ """!Clear button pressed"""
+ else:
+ self.text_sql.SetValue("")
+ def OnClose(self, event):
+ """!Close button pressed"""
self.Destroy()
if __name__ == "__main__":
if len(sys.argv) != 2:
print >>sys.stderr, __doc__
sys.exit()
app = wx.App(0)
- sqlb = SQLFrame(None, -1, 'SQL Builder',sys.argv[1])
+ sqlb = SQLFrame(parent = None, title = _('SQL Builder'), vectmap = sys.argv[1])
+ sqlb.Show()
app.MainLoop()
