[GRASS-SVN] r38889 - in grass/branches/develbranch_6/lib/gpde: . test
Thu Aug 27 16:52:10 EDT 2009
Author: huhabla
Date: 2009-08-27 16:52:10 -0400 (Thu, 27 Aug 2009)
New Revision: 38889
Added:
   grass/branches/develbranch_6/lib/gpde/test/test.gpde.lib.html
Removed:
   grass/branches/develbranch_6/lib/gpde/N_les_pivot.c
   grass/branches/develbranch_6/lib/gpde/N_solvers.c
   grass/branches/develbranch_6/lib/gpde/N_solvers_classic_iter.c
   grass/branches/develbranch_6/lib/gpde/N_solvers_krylov.c
   grass/branches/develbranch_6/lib/gpde/solvers_local_proto.h
   grass/branches/develbranch_6/lib/gpde/test/test_solvers.c
   grass/branches/develbranch_6/lib/gpde/N_geom.c
   grass/branches/develbranch_6/lib/gpde/N_gradient.c
   grass/branches/develbranch_6/lib/gpde/N_gradient_calc.c
   grass/branches/develbranch_6/lib/gpde/N_gwflow.c
   grass/branches/develbranch_6/lib/gpde/N_gwflow.h
   grass/branches/develbranch_6/lib/gpde/N_heatflow.h
   grass/branches/develbranch_6/lib/gpde/N_les.c
   grass/branches/develbranch_6/lib/gpde/N_les_assemble.c
   grass/branches/develbranch_6/lib/gpde/N_pde.h
   grass/branches/develbranch_6/lib/gpde/N_solute_transport.c
   grass/branches/develbranch_6/lib/gpde/N_solute_transport.h
   grass/branches/develbranch_6/lib/gpde/N_tools.c
   grass/branches/develbranch_6/lib/gpde/gpdelib.dox
   grass/branches/develbranch_6/lib/gpde/test/Makefile
   grass/branches/develbranch_6/lib/gpde/test/test_arrays.c
   grass/branches/develbranch_6/lib/gpde/test/test_assemble.c
   grass/branches/develbranch_6/lib/gpde/test/test_geom.c
   grass/branches/develbranch_6/lib/gpde/test/test_gpde_lib.h
   grass/branches/develbranch_6/lib/gpde/test/test_gradient.c
   grass/branches/develbranch_6/lib/gpde/test/test_gwflow.c
   grass/branches/develbranch_6/lib/gpde/test/test_les.c
   grass/branches/develbranch_6/lib/gpde/test/test_main.c
   grass/branches/develbranch_6/lib/gpde/test/test_solute_transport.c
   grass/branches/develbranch_6/lib/gpde/test/test_tools.c
Moving the linear equation solver and tests into the gmath library
Modified: grass/branches/develbranch_6/lib/gpde/N_geom.c
--- grass/branches/develbranch_6/lib/gpde/N_geom.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/N_geom.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -73,6 +73,7 @@
 N_geom_data *N_init_geom_data_3d(G3D_Region * region3d, N_geom_data * geodata)
     N_geom_data *geom = geodata;
     struct Cell_head region2d;
 #pragma omp critical
@@ -115,9 +116,13 @@
     struct Cell_head backup;
     double meters;
     short ll = 0;
     int i;
@@ -158,10 +163,12 @@
 		    "N_init_geom_data_2d: calculating the areas for non parametric projection");
 	    geom->planimetric = 0;
-	    if (geom->area != NULL)
+	    if (geom->area != NULL) {
 		G_free(geom->area);
-	    else
 		geom->area = G_calloc(geom->rows, sizeof(double));
+	    } else {
+		geom->area = G_calloc(geom->rows, sizeof(double));
 	    /*fill the area vector */
 	    for (i = 0; i < geom->rows; i++) {
Modified: grass/branches/develbranch_6/lib/gpde/N_gradient.c
--- grass/branches/develbranch_6/lib/gpde/N_gradient.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/N_gradient.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -116,6 +116,7 @@
 				 N_gradient_2d * gradient, int col, int row)
     double NC = 0, SC = 0, WC = 0, EC = 0;
     N_gradient_2d *grad = gradient;
@@ -250,6 +251,7 @@
 				 int depth)
     double NC, SC, WC, EC, TC, BC;
     N_gradient_3d *grad = gradient;
     NC = N_get_array_3d_d_value(field->y_array, col, row, depth);
@@ -631,6 +633,7 @@
 				      N_gradient_neighbours_y * y)
     N_gradient_neighbours_2d *grad;
     int fail = 0;
     G_debug(5,
@@ -706,9 +709,13 @@
 						       int row)
     double NWN, NEN, WC, EC, SWS, SES;
     double NWW, NEE, NC, SC, SWW, SEE;
     N_gradient_neighbours_2d *grad = NULL;
     N_gradient_neighbours_x *grad_x = NULL;
     N_gradient_neighbours_y *grad_y = NULL;
@@ -832,6 +839,7 @@
 				      N_gradient_neighbours_z * zb)
     N_gradient_neighbours_3d *grad;
     int fail = 0;
     G_debug(5,
Modified: grass/branches/develbranch_6/lib/gpde/N_gradient_calc.c
--- grass/branches/develbranch_6/lib/gpde/N_gradient_calc.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/N_gradient_calc.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -29,8 +29,11 @@
 void N_calc_gradient_field_2d_stats(N_gradient_field_2d * field)
     double minx, miny;
     double maxx, maxy;
     double sumx, sumy;
     int nonullx, nonully;
     G_debug(3,
@@ -110,8 +113,11 @@
 						 gradfield)
     int i, j;
     int rows, cols;
     double dx, dy, p1, p2, r1, r2, mean, grad, res;
     N_gradient_field_2d *field = gradfield;
@@ -245,10 +251,15 @@
 				       N_array_2d * y_comp)
     int i, j;
     int rows, cols;
     double vx, vy;
     N_array_2d *x = x_comp;
     N_array_2d *y = y_comp;
     N_gradient_2d grad;
@@ -300,8 +311,11 @@
 void N_calc_gradient_field_3d_stats(N_gradient_field_3d * field)
     double minx, miny, minz;
     double maxx, maxy, maxz;
     double sumx, sumy, sumz;
     int nonullx, nonully, nonullz;
     G_debug(3,
@@ -392,8 +406,11 @@
 						 gradfield)
     int i, j, k;
     int cols, rows, depths;
     double dx, dy, dz, p1, p2, r1, r2, mean, grad, res;
     N_gradient_field_3d *field = gradfield;
@@ -582,11 +599,17 @@
 				       N_array_3d * z_comp)
     int i, j, k;
     int rows, cols, depths;
     double vx, vy, vz;
     N_array_3d *x = x_comp;
     N_array_3d *y = y_comp;
     N_array_3d *z = z_comp;
     N_gradient_3d grad;
Modified: grass/branches/develbranch_6/lib/gpde/N_gwflow.c
--- grass/branches/develbranch_6/lib/gpde/N_gwflow.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/N_gwflow.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -22,7 +22,7 @@
 /* ***************** N_gwflow_data3d ***************************** */
- * \brief Alllocate memory for the groundwater calculation data structure in 3 dimensions
+ * \brief Allocate memory for the groundwater calculation data structure in 3 dimensions
  * The groundwater calculation data structure will be allocated including
  * all appendant 3d and 2d arrays. The offset for the 3d arrays is one
@@ -264,14 +264,23 @@
 				  int row, int depth)
     double hc_e = 0, hc_w = 0, hc_n = 0, hc_s = 0, hc_t = 0, hc_b = 0;
     double dx, dy, dz, Ax, Ay, Az;
     double hc_x, hc_y, hc_z;
     double hc_xw, hc_yn, hc_zt;
     double hc_xe, hc_ys, hc_zb;
     double hc_start;
     double Ss, r, nf, q;
     double C, W, E, N, S, T, B, V;
     N_data_star *mat_pos;
     N_gwflow_data3d *data;
     /*cast the void pointer to the right data structure */
@@ -371,22 +380,39 @@
 				  int row)
     double T_e = 0, T_w = 0, T_n = 0, T_s = 0;
     double z_e = 0, z_w = 0, z_n = 0, z_s = 0;
     double dx, dy, Az;
     double hc_x, hc_y;
     double z, top;
     double hc_xw, hc_yn;
     double z_xw, z_yn;
     double hc_xe, hc_ys;
     double z_xe, z_ys;
     double hc, hc_start;
     double C, W, E, N, S, V;
     N_gwflow_data2d *data;
     double river_vect = 0;	/*entry in vector */
     double river_mat = 0;	/*entry in matrix */
     double drain_vect = 0;	/*entry in vector */
     double drain_mat = 0;	/*entry in matrix */
Modified: grass/branches/develbranch_6/lib/gpde/N_gwflow.h
--- grass/branches/develbranch_6/lib/gpde/N_gwflow.h	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/N_gwflow.h	2009-08-27 20:52:10 UTC (rev 38889)
@@ -104,5 +104,6 @@
 extern N_gwflow_data2d *N_alloc_gwflow_data2d(int cols, int rows, int river,
 					      int drain);
 extern void N_free_gwflow_data3d(N_gwflow_data3d * data);
 extern void N_free_gwflow_data2d(N_gwflow_data2d * data);
 #endif
Modified: grass/branches/develbranch_6/lib/gpde/N_heatflow.h
--- grass/branches/develbranch_6/lib/gpde/N_heatflow.h	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/N_heatflow.h	2009-08-27 20:52:10 UTC (rev 38889)
@@ -62,6 +62,8 @@
 extern N_heatflow_data3d *N_alloc_heatflow_data3d(int depths, int rows,
 						  int cols);
 extern N_heatflow_data2d *N_alloc_heatflow_data2d(int rows, int cols);
 extern void N_free_heatflow_data3d(N_heatflow_data3d * data);
 extern void N_free_heatflow_data2d(N_heatflow_data2d * data);
 #endif
Modified: grass/branches/develbranch_6/lib/gpde/N_les.c
--- grass/branches/develbranch_6/lib/gpde/N_les.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/N_les.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -17,30 +17,10 @@
 #include "grass/N_pde.h"
+#include "grass/gmath.h"
 #include <stdlib.h>
- * \brief Allocate memory for a sparse vector
- * \param cols int
- * \return N_spvector *
-N_spvector *N_alloc_spvector(int cols)
-    N_spvector *spvector;
-    G_debug(4, "Allocate memory for a sparse vector with %i cols\n", cols);
-    spvector = (N_spvector *) G_calloc(1, sizeof(N_spvector));
-    spvector->cols = cols;
-    spvector->index = (int *)G_calloc(cols, sizeof(int));
-    spvector->values = (double *)G_calloc(cols, sizeof(double));
-    return spvector;
  * \brief Allocate memory for a (not) quadratic linear equation system which includes the Matrix A, vector x and vector b
@@ -198,6 +178,7 @@
 N_les *N_alloc_les_param(int cols, int rows, int type, int parts)
     N_les *les;
     int i;
     if (type == N_SPARSE_LES)
@@ -234,60 +215,19 @@
 	les->quad = 0;
     if (type == N_SPARSE_LES) {
-	les->Asp = (N_spvector **) G_calloc(rows, sizeof(N_spvector *));
+	les->Asp = G_math_alloc_spmatrix(rows);
 	les->type = N_SPARSE_LES;
     else {
-	les->A = (double **)G_calloc(rows, sizeof(double *));
-	for (i = 0; i < rows; i++) {
-	    les->A[i] = (double *)G_calloc(cols, sizeof(double));
+	les->A = G_alloc_matrix(rows, cols);
 	les->type = N_NORMAL_LES;
     return les;
- * \brief Adds a sparse vector to a sparse linear equation system at position row
- * Return 1 for success and -1 for failure
- * \param les N_les *
- * \param spvector N_spvector *
- * \param row int
- * \return int
-int N_add_spvector_to_les(N_les * les, N_spvector * spvector, int row)
-    if (les != NULL) {
-	if (les->type != N_SPARSE_LES)
-	    return -1;
-	if (les->rows > row) {
-	    G_debug(5,
-		    "Add sparse vector %p to the sparse linear equation system at row %i\n",
-		    spvector, row);
-	    les->Asp[row] = spvector;
-	else
-	    return -1;
-    else {
-	return -1;
-    return 1;
  * \brief prints the linear equation system to stdout
  * <p>
@@ -354,29 +294,6 @@
- * \brief Release the memory of the sparse vector
- * \return void
-void N_free_spvector(N_spvector * spvector)
-    if (spvector) {
-	if (spvector->values)
-	    G_free(spvector->values);
-	if (spvector->index)
-	    G_free(spvector->index);
-	G_free(spvector);
-	spvector = NULL;
-    return;
  * \brief Release the memory of the linear equation system
@@ -403,21 +320,13 @@
 	if (les->type == N_SPARSE_LES) {
 	    if (les->Asp) {
-		for (i = 0; i < les->rows; i++)
-		    if (les->Asp[i])
-			N_free_spvector(les->Asp[i]);
-		G_free(les->Asp);
+		G_math_free_spmatrix(les->Asp, les->rows);
 	else {
 	    if (les->A) {
-		    if (les->A[i])
-			G_free(les->A[i]);
-		G_free(les->A);
+		G_free_matrix(les->A);
Modified: grass/branches/develbranch_6/lib/gpde/N_les_assemble.c
--- grass/branches/develbranch_6/lib/gpde/N_les_assemble.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/N_les_assemble.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -23,15 +23,17 @@
 /* local protos */
 static int make_les_entry_2d(int i, int j, int offset_i, int offset_j,
 			     int count, int pos, N_les * les,
-			     N_spvector * spvect, N_array_2d * cell_count,
-			     N_array_2d * status, N_array_2d * start_val,
-			     double entry, int cell_type);
+			     G_math_spvector * spvect,
+			     N_array_2d * cell_count, N_array_2d * status,
+			     N_array_2d * start_val, double entry,
+			     int cell_type);
 static int make_les_entry_3d(int i, int j, int k, int offset_i, int offset_j,
 			     int offset_k, int count, int pos, N_les * les,
-			     N_spvector * spvect, N_array_3d * cell_count,
-			     N_array_3d * status, N_array_3d * start_val,
+			     N_array_3d * cell_count, N_array_3d * status,
+			     N_array_3d * start_val, double entry,
+			     int cell_type);
  * ********************** N_alloc_5star ************************** *
@@ -561,9 +563,13 @@
 			       int cell_type)
     int i, j, count = 0, pos = 0;
     int cell_type_count = 0;
     int **index_ij;
     N_array_2d *cell_count;
     N_les *les = NULL;
     G_debug(2,
@@ -658,11 +664,11 @@
 	N_data_star *items = call->callback(data, geom, i, j);
 	/* we need a sparse vector pointer anytime */
-	N_spvector *spvect = NULL;
+	G_math_spvector *spvect = NULL;
 	/*allocate a sprase vector */
 	if (les_type == N_SPARSE_LES) {
-	    spvect = N_alloc_spvector(items->count);
+	    spvect = G_math_alloc_spvector(items->count);
 	/* initial conditions */
 	les->x[count] = N_get_array_2d_d_value(start_val, i, j);
@@ -737,7 +743,7 @@
 	/*How many entries in the les */
 	    spvect->cols = pos + 1;
-	    N_add_spvector_to_les(les, spvect, count);
+	    G_math_add_spvector(les->Asp, spvect, count);
 	if (items)
@@ -785,9 +791,13 @@
 				 N_array_2d * status, N_array_2d * start_val)
     int rows, cols;
     int count = 0;
     int i, j, x, y, stat;
     double *dvect1;
     double *dvect2;
     G_debug(2,
@@ -818,11 +828,11 @@
 #pragma omp parallel default(shared)
-	/*performe the matrix vector product */
+	/*performe the matrix vector product and */
-	    N_sparse_matrix_vector_product(les, dvect1, dvect2);
+	    G_math_Ax_sparse(les->Asp, dvect1, dvect2, les->rows);
 	else
-	    N_matrix_vector_product(les, dvect1, dvect2);
+	    G_math_d_Ax(les->A, dvect1, dvect2, les->rows, les->cols);
 #pragma omp for schedule (static) private(i)
 	for (i = 0; i < les->cols; i++)
 	    les->b[i] = les->b[i] - dvect2[i];
@@ -876,12 +886,14 @@
 /* **** make an entry in the les (2d) ***************************** */
 int make_les_entry_2d(int i, int j, int offset_i, int offset_j, int count,
-		      int pos, N_les * les, N_spvector * spvect,
+		      int pos, N_les * les, G_math_spvector * spvect,
 		      N_array_2d * start_val, double entry, int cell_type)
     int K;
     int di = offset_i;
     int dj = offset_j;
     K = N_get_array_2d_c_value(cell_count, i + di, j + dj) -
@@ -1013,9 +1025,13 @@
 			       int cell_type)
     int i, j, k, count = 0, pos = 0;
     N_array_3d *cell_count;
     N_les *les = NULL;
     int **index_ij;
     G_debug(2,
@@ -1121,11 +1137,11 @@
 	/*create the entries for the */
 	N_data_star *items = call->callback(data, geom, i, j, k);
 	les->x[count] = N_get_array_3d_d_value(start_val, i, j, k);
@@ -1191,7 +1207,7 @@
 	if (items)
@@ -1238,9 +1254,13 @@
 				 N_array_3d * status, N_array_3d * start_val)
     int count = 0;
     int i, j, x, y, z, stat;
     double *dvect1;
     double *dvect2;
     G_debug(2,
@@ -1277,9 +1297,9 @@
 	else
@@ -1335,17 +1355,20 @@
+		      G_math_spvector * spvect, N_array_3d * cell_count,
     int K;
     int di = offset_i;
     int dj = offset_j;
     int dk = offset_k;
-    K = N_get_array_3d_d_value(cell_count, i + di, j + dj, k + dk) -
-	N_get_array_3d_d_value(cell_count, i, j, k);
+    K = (int)N_get_array_3d_d_value(cell_count, i + di, j + dj, k + dk) -
+	(int)N_get_array_3d_d_value(cell_count, i, j, k);
     if (cell_type == N_CELL_ACTIVE) {
 	if ((int)N_get_array_3d_d_value(status, i + di, j + dj, k + dk) >
Deleted: grass/branches/develbranch_6/lib/gpde/N_les_pivot.c
--- grass/branches/develbranch_6/lib/gpde/N_les_pivot.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/N_les_pivot.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -1,92 +0,0 @@
-* MODULE:       Grass PDE Numerical Library
-* AUTHOR(S):    Soeren Gebbert, Berlin (GER) Dec 2006
-* 		soerengebbert <at> gmx <dot> de
-* PURPOSE:      linear equation system pivoting strategy
-*  		part of the gpde library
-* COPYRIGHT:    (C) 2000 by the GRASS Development Team
-*               This program is free software under the GNU General Public
-*               License (>=v2). Read the file COPYING that comes with GRASS
-*               for details.
-#include <math.h>
-#include <unistd.h>
-#include <stdio.h>
-#include <string.h>
-#include "grass/N_pde.h"
-#include "solvers_local_proto.h"
-#define TINY 1.0e-20
- * \brief Optimize the structure of the linear equation system with a common pivoting strategy
- * Create a optimized linear equation system for
- * direct solvers: gauss and lu decomposition.
- * The rows are permuted based on the pivot elements.
- * This algorithm will modify the provided linear equation system
- * and should only be used with the gauss elimination and lu decomposition solver.
- * \param les * N_les -- the linear equation system
- * \return int - the number of swapped rows
-int N_les_pivot_create(N_les * les)
-    int num = 0;		/*number of changed rows */
-    int i, j, k;
-    double max;
-    int number = 0;
-    double tmpval = 0.0, s = 0.0;
-    double *link = NULL;
-    G_debug(2, "N_les_pivot_create: swap rows if needed");
-    for (i = 0; i < les->rows; i++) {
-	max = fabs(les->A[i][i]);
-	number = i;
-	for (j = i; j < les->rows; j++) {
-	    s = 0.0;
-	    for (k = i; k < les->rows; k++) {
-		s += fabs(les->A[j][i]);
-	    /*search for the pivot element */
-	    if (max < fabs(les->A[j][i]) / s) {
-		max = fabs(les->A[j][i]);
-		number = j;
-	if (max == 0) {
-	    max = TINY;
-	    G_warning("Matrix is singular");
-	/*if an pivot element was found, swap the les entries */
-	if (number != i) {
-	    G_debug(4, "swap row %i with row %i", i, number);
-	    tmpval = les->b[number];
-	    les->b[number] = les->b[i];
-	    les->b[i] = tmpval;
-	    link = les->A[number];
-	    les->A[number] = les->A[i];
-	    les->A[i] = link;
-	    num++;
-    return num;
Modified: grass/branches/develbranch_6/lib/gpde/N_pde.h
--- grass/branches/develbranch_6/lib/gpde/N_pde.h	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/N_pde.h	2009-08-27 20:52:10 UTC (rev 38889)
@@ -18,6 +18,7 @@
 #include <grass/gis.h>
 #include <grass/G3d.h>
 #include <grass/glocale.h>
+#include <grass/gmath.h>
 #ifndef _N_PDE_H_
 #define _N_PDE_H_
@@ -74,17 +75,6 @@
- * \brief The row vector of the sparse matrix
-typedef struct
-    int cols;			/*Number of entries */
-    double *values;		/*The non null values of the row */
-    int *index;			/*the index number */
-} N_spvector;
  * \brief The linear equation system (les) structure
  * This structure manages the Ax = b system.
@@ -98,26 +88,33 @@
     double *x;			/*the value vector */
     double *b;			/*the right side of Ax = b */
     double **A;			/*the normal quadratic matrix */
-    N_spvector **Asp;		/*the sparse matrix */
+    G_math_spvector **Asp;	/*the sparse matrix */
     int rows;			/*number of rows */
     int cols;			/*number of cols */
     int quad;			/*is the matrix quadratic (1-quadratic, 0 not) */
     int type;			/*the type of the les, normal == 0, sparse == 1 */
 } N_les;
-extern N_spvector *N_alloc_spvector(int cols);
 extern N_les *N_alloc_les_param(int cols, int rows, int type, int param);
 extern N_les *N_alloc_les(int rows, int type);
 extern N_les *N_alloc_les_A(int rows, int type);
 extern N_les *N_alloc_les_Ax(int rows, int type);
 extern N_les *N_alloc_les_Ax_b(int rows, int type);
 extern N_les *N_alloc_nquad_les(int cols, int rows, int type);
 extern N_les *N_alloc_nquad_les_A(int cols, int rows, int type);
 extern N_les *N_alloc_nquad_les_Ax(int cols, int rows, int type);
 extern N_les *N_alloc_nquad_les_Ax_b(int cols, int rows, int type);
 extern void N_print_les(N_les * les);
-extern int N_add_spvector_to_les(N_les * les, N_spvector * vector, int row);
-extern void N_free_spvector(N_spvector * vector);
 extern void N_free_les(N_les * les);
@@ -146,32 +143,16 @@
 } N_geom_data;
 extern N_geom_data *N_alloc_geom_data(void);
 extern void N_free_geom_data(N_geom_data * geodata);
 extern N_geom_data *N_init_geom_data_3d(G3D_Region * region3d,
 extern N_geom_data *N_init_geom_data_2d(struct Cell_head *region,
 extern double N_get_geom_data_area_of_cell(N_geom_data * geom, int row);
-/* *************** LINEARE EQUATION SOLVER PART ****************** */
-extern int N_solver_gauss(N_les * les);
-extern int N_solver_lu(N_les * les);
-extern int N_solver_cholesky(N_les * les);
-extern int N_solver_jacobi(N_les * L, int maxit, double sor, double error);
-extern int N_solver_SOR(N_les * L, int maxit, double sor, double error);
-extern int N_solver_cg(N_les * les, int maxit, double error);
-extern int N_solver_pcg(N_les * les, int maxit, double error, int prec);
-extern int N_solver_bicgstab(N_les * les, int maxit, double error);
-extern void N_matrix_vector_product(N_les * les, double *source,
-				    double *result);
-extern void N_sparse_matrix_vector_product(N_les * les, double *source,
-					   double *result);
-extern N_les *N_create_diag_precond_matrix(N_les * les, int prec);
 /* *************** READING RASTER AND VOLUME DATA **************** */
@@ -187,13 +168,19 @@
 } N_array_2d;
 extern N_array_2d *N_alloc_array_2d(int cols, int rows, int offset, int type);
 extern void N_free_array_2d(N_array_2d * data_array);
 extern int N_get_array_2d_type(N_array_2d * array2d);
 extern void N_get_array_2d_value(N_array_2d * array2d, int col, int row,
 				 void *value);
 extern CELL N_get_array_2d_c_value(N_array_2d * array2d, int col, int row);
 extern FCELL N_get_array_2d_f_value(N_array_2d * array2d, int col, int row);
 extern DCELL N_get_array_2d_d_value(N_array_2d * array2d, int col, int row);
 extern void N_put_array_2d_value(N_array_2d * array2d, int col, int row,
 				 char *value);
 extern void N_put_array_2d_c_value(N_array_2d * array2d, int col, int row,
@@ -203,17 +190,25 @@
 extern void N_put_array_2d_d_value(N_array_2d * array2d, int col, int row,
 				   DCELL value);
 extern int N_is_array_2d_value_null(N_array_2d * array2d, int col, int row);
 extern void N_put_array_2d_value_null(N_array_2d * array2d, int col, int row);
 extern void N_print_array_2d(N_array_2d * data);
 extern void N_print_array_2d_info(N_array_2d * data);
 extern void N_copy_array_2d(N_array_2d * source, N_array_2d * target);
 extern double N_norm_array_2d(N_array_2d * array1, N_array_2d * array2,
 			      int type);
 extern N_array_2d *N_math_array_2d(N_array_2d * array1, N_array_2d * array2,
 				   N_array_2d * result, int type);
 extern int N_convert_array_2d_null_to_zero(N_array_2d * a);
 extern N_array_2d *N_read_rast_to_array_2d(char *name, N_array_2d * array);
 extern void N_write_array_2d_to_rast(N_array_2d * array, char *name);
 extern void N_calc_array_2d_stats(N_array_2d * a, double *min, double *max,
 				  double *sum, int *nonzero, int withoffset);
@@ -230,7 +225,9 @@
 extern N_array_3d *N_alloc_array_3d(int cols, int rows, int depths,
 extern void N_free_array_3d(N_array_3d * data_array);
 extern int N_get_array_3d_type(N_array_3d * array3d);
 extern void N_get_array_3d_value(N_array_3d * array3d, int col, int row,
 				 int depth, void *value);
 extern float N_get_array_3d_f_value(N_array_3d * array3d, int col, int row,
@@ -248,13 +245,17 @@
 extern void N_put_array_3d_value_null(N_array_3d * array3d, int col, int row,
 				      int depth);
 extern void N_print_array_3d(N_array_3d * data);
 extern void N_print_array_3d_info(N_array_3d * data);
 extern void N_copy_array_3d(N_array_3d * source, N_array_3d * target);
 extern double N_norm_array_3d(N_array_3d * array1, N_array_3d * array2,
 			      int type);
 extern N_array_3d *N_math_array_3d(N_array_3d * array1, N_array_3d * array2,
 				   N_array_3d * result, int type);
 extern int N_convert_array_3d_null_to_zero(N_array_3d * a);
 extern N_array_3d *N_read_rast3d_to_array_3d(char *name, N_array_3d * array,
 					     int mask);
 extern void N_write_array_3d_to_rast3d(N_array_3d * array, char *name,
@@ -371,11 +372,17 @@
 extern void N_set_les_callback_2d_func(N_les_callback_2d * data,
 				       N_data_star * (*callback_func_2d) ());
 extern N_les_callback_3d *N_alloc_les_callback_3d(void);
 extern N_les_callback_2d *N_alloc_les_callback_2d(void);
 extern N_data_star *N_alloc_5star(void);
 extern N_data_star *N_alloc_7star(void);
 extern N_data_star *N_alloc_9star(void);
 extern N_data_star *N_alloc_27star(void);
 extern N_data_star *N_create_5star(double C, double W, double E, double N,
 				   double S, double V);
 extern N_data_star *N_create_7star(double C, double W, double E, double N,
@@ -431,6 +438,7 @@
 				      int cell_Type);
 extern int N_les_pivot_create(N_les * les);
 int N_les_integrate_dirichlet_2d(N_les * les, N_geom_data * geom,
 				 N_array_2d * status, N_array_2d * start_val);
 int N_les_integrate_dirichlet_3d(N_les * les, N_geom_data * geom,
@@ -459,12 +467,19 @@
 extern double N_calc_arith_mean(double a, double b);
 extern double N_calc_arith_mean_n(double *a, int size);
 extern double N_calc_geom_mean(double a, double b);
 extern double N_calc_geom_mean_n(double *a, int size);
 extern double N_calc_harmonic_mean(double a, double b);
 extern double N_calc_harmonic_mean_n(double *a, int size);
 extern double N_calc_quad_mean(double a, double b);
 extern double N_calc_quad_mean_n(double *a, int size);
@@ -472,6 +487,7 @@
 extern double N_full_upwinding(double sprod, double distance, double D);
 extern double N_exp_upwinding(double sprod, double distance, double D);
@@ -644,25 +660,33 @@
 extern N_gradient_2d *N_alloc_gradient_2d(void);
 extern void N_free_gradient_2d(N_gradient_2d * grad);
 extern N_gradient_2d *N_create_gradient_2d(double NC, double SC, double WC,
 					   double EC);
 extern int N_copy_gradient_2d(N_gradient_2d * source, N_gradient_2d * target);
 extern N_gradient_2d *N_get_gradient_2d(N_gradient_field_2d * field,
 					int row);
 extern N_gradient_3d *N_alloc_gradient_3d(void);
 extern void N_free_gradient_3d(N_gradient_3d * grad);
 extern N_gradient_3d *N_create_gradient_3d(double NC, double SC, double WC,
 					   double EC, double TC, double BC);
 extern int N_copy_gradient_3d(N_gradient_3d * source, N_gradient_3d * target);
 extern N_gradient_3d *N_get_gradient_3d(N_gradient_field_3d * field,
 					N_gradient_3d * gradient, int col,
 					int row, int depth);
 extern N_gradient_neighbours_x *N_alloc_gradient_neighbours_x(void);
 extern void N_free_gradient_neighbours_x(N_gradient_neighbours_x * grad);
 extern N_gradient_neighbours_x *N_create_gradient_neighbours_x(double NWN,
 							       double NEN,
 							       double WC,
@@ -673,7 +697,9 @@
 					N_gradient_neighbours_x * target);
 extern N_gradient_neighbours_y *N_alloc_gradient_neighbours_y(void);
 extern void N_free_gradient_neighbours_y(N_gradient_neighbours_y * grad);
 extern N_gradient_neighbours_y *N_create_gradient_neighbours_y(double NWW,
 							       double NEE,
 							       double NC,
@@ -684,7 +710,9 @@
 					N_gradient_neighbours_y * target);
 extern N_gradient_neighbours_z *N_alloc_gradient_neighbours_z(void);
 extern void N_free_gradient_neighbours_z(N_gradient_neighbours_z * grad);
 extern N_gradient_neighbours_z *N_create_gradient_neighbours_z(double NWZ,
 							       double NZ,
 							       double NEZ,
@@ -698,7 +726,9 @@
 					N_gradient_neighbours_z * target);
 extern N_gradient_neighbours_2d *N_alloc_gradient_neighbours_2d(void);
 extern void N_free_gradient_neighbours_2d(N_gradient_neighbours_2d * grad);
     * N_create_gradient_neighbours_2d(N_gradient_neighbours_x * x,
 				      N_gradient_neighbours_y * y);
@@ -711,7 +741,9 @@
 extern N_gradient_neighbours_3d *N_alloc_gradient_neighbours_3d(void);
 extern void N_free_gradient_neighbours_3d(N_gradient_neighbours_3d * grad);
     * N_create_gradient_neighbours_3d(N_gradient_neighbours_x * xt,
 				      N_gradient_neighbours_x * xc,
@@ -725,11 +757,14 @@
 					 N_gradient_neighbours_3d * target);
 extern void N_print_gradient_field_2d_info(N_gradient_field_2d * field);
 extern void N_calc_gradient_field_2d_stats(N_gradient_field_2d * field);
 extern N_gradient_field_2d *N_alloc_gradient_field_2d(int cols, int rows);
 extern void N_free_gradient_field_2d(N_gradient_field_2d * field);
 extern int N_copy_gradient_field_2d(N_gradient_field_2d * source,
 				    N_gradient_field_2d * target);
 extern N_gradient_field_2d *N_compute_gradient_field_2d(N_array_2d * pot,
@@ -743,11 +778,13 @@
 						   N_array_2d * y_comp);
 extern void N_print_gradient_field_3d_info(N_gradient_field_3d * field);
 extern void N_calc_gradient_field_3d_stats(N_gradient_field_3d * field);
 extern N_gradient_field_3d *N_alloc_gradient_field_3d(int cols, int rows,
 						      int depths);
 extern void N_free_gradient_field_3d(N_gradient_field_3d * field);
 extern int N_copy_gradient_field_3d(N_gradient_field_3d * source,
 				    N_gradient_field_3d * target);
 extern N_gradient_field_3d *N_compute_gradient_field_3d(N_array_3d * pot,
Modified: grass/branches/develbranch_6/lib/gpde/N_solute_transport.c
--- grass/branches/develbranch_6/lib/gpde/N_solute_transport.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/N_solute_transport.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -30,21 +30,35 @@
 					    int row, int depth)
     double Df_e = 0, Df_w = 0, Df_n = 0, Df_s = 0, Df_t = 0, Df_b = 0;
     double dx, dy, dz, Az;
     double diff_x, diff_y, diff_z;
     double diff_xw, diff_yn;
     double diff_xe, diff_ys;
     double diff_zt, diff_zb;
     double cin = 0, cg, cg_start;
     double R, nf, cs, q;
     double vw = 0, ve = 0, vn = 0, vs = 0, vt = 0, vb = 0;
     double Ds_w = 0, Ds_e = 0, Ds_n = 0, Ds_s = 0, Ds_t = 0, Ds_b = 0;
     double Dw = 0, De = 0, Dn = 0, Ds = 0, Dt = 0, Db = 0;
     double rw = 0.5, re = 0.5, rn = 0.5, rs = 0.5, rt = 0.5, rb = 0.5;
     N_solute_transport_data3d *data = NULL;
     N_gradient_3d grad;
@@ -186,27 +200,47 @@
 					    int row)
     double Df_e = 0, Df_w = 0, Df_n = 0, Df_s = 0;
     double dx, dy, Az;
     double diff_x, diff_y;
     double disp_x, disp_y;
     double z;
     double disp_xw, disp_yn;
     double z_xw, z_yn;
     double disp_xe, disp_ys;
     double z_xe, z_ys;
     double C, W, E, N, S, V, NE, NW, SW, SE;
     double vw = 0, ve = 0, vn = 0, vs = 0;
     double Ds_w = 0, Ds_e = 0, Ds_n = 0, Ds_s = 0;
     double Dw = 0, De = 0, Dn = 0, Ds = 0;
     double rw = 0.5, re = 0.5, rn = 0.5, rs = 0.5;
     N_solute_transport_data2d *data = NULL;
     N_gradient_2d grad;
@@ -578,8 +612,11 @@
 void N_calc_solute_transport_transmission_2d(N_solute_transport_data2d * data)
     int i, j, count = 1;
     int cols, rows;
     double c;
     N_gradient_2d grad;
     cols = data->grad->cols;
@@ -651,9 +688,13 @@
 void N_calc_solute_transport_disptensor_2d(N_solute_transport_data2d * data)
     int i, j;
     int cols, rows;
     double vx, vy, vv;
     double disp_xx, disp_yy, disp_xy;
     N_gradient_2d grad;
@@ -710,9 +751,13 @@
 void N_calc_solute_transport_disptensor_3d(N_solute_transport_data3d * data)
     int i, j, k;
     double vx, vy, vz, vv;
     double disp_xx, disp_yy, disp_zz, disp_xy, disp_xz, disp_yz;
     N_gradient_3d grad;
Modified: grass/branches/develbranch_6/lib/gpde/N_solute_transport.h
--- grass/branches/develbranch_6/lib/gpde/N_solute_transport.h	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/N_solute_transport.h	2009-08-27 20:52:10 UTC (rev 38889)
@@ -95,6 +95,7 @@
 extern N_solute_transport_data2d *N_alloc_solute_transport_data2d(int cols,
 								  int rows);
 extern void N_free_solute_transport_data3d(N_solute_transport_data3d * data);
 extern void N_free_solute_transport_data2d(N_solute_transport_data2d * data);
 /*compute the dispersivity tensor */
Deleted: grass/branches/develbranch_6/lib/gpde/N_solvers.c
--- grass/branches/develbranch_6/lib/gpde/N_solvers.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/N_solvers.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -1,429 +0,0 @@
-* PURPOSE:      direkt linear equation system solvers
-*               for details.
-#include <math.h>
-#include <stdio.h>
-/*prototypes */
-static void gauss_elimination(double **A, double *b, int rows);
-static void lu_decomposition(double **A, int rows);
-static int cholesky_decomposition(double **A, int rows);
-static void backward_solving(double **A, double *x, double *b, int rows);
-static void forward_solving(double **A, double *x, double *b, int rows);
- * GAUSS elimination solver for Ax = b *********************
- * \brief The gauss elimination solver for quardatic matrices
- * This solver does not support sparse matrices
- * The matrix A will be overwritten.
- * The result is written to the vector x in the N_les structure
- * \return int -- 1 success, 0 solver does not work with sprase matrices, -1 matrix is not quadratic, -2 unable to solve the les
-int N_solver_gauss(N_les * les)
-    if (les->type != N_NORMAL_LES) {
-	G_warning(_("The gauss elimination solver does not work with sparse matrices"));
-	return 0;
-    if (les->quad != 1) {
-	G_fatal_error(_("The linear equation system is not quadratic"));
-	return 0;
-    G_message(_("Starting direct gauss elimination solver"));
-    N_les_pivot_create(les);
-    gauss_elimination(les->A, les->b, les->rows);
-    backward_solving(les->A, les->x, les->b, les->rows);
-    return 1;
- * LU solver for Ax = b ************************************
- * \brief The LU solver for quardatic matrices
-int N_solver_lu(N_les * les)
-    int i;
-    double *c, *tmpv;
-	G_warning(_("The lu solver does not work with sparse matrices"));
-	return 0;
-	G_warning(_("The linear equation system is not quadratic"));
-	return -1;
-    G_message(_("Starting direct lu decomposition solver"));
-    tmpv = vectmem(les->rows);
-    c = vectmem(les->rows);
-    lu_decomposition(les->A, les->rows);
-#pragma omp parallel
-#pragma omp for  schedule (static) private(i)
-	    tmpv[i] = les->A[i][i];
-	    les->A[i][i] = 1;
-#pragma omp single
-	    forward_solving(les->A, les->b, les->b, les->rows);
-	    les->A[i][i] = tmpv[i];
-#pragma omp single
-    G_free(c);
-    G_free(tmpv);
-    return 1;
- * cholesky solver for Ax = b ******************************
- * \brief The choleksy decomposition solver for quardatic, symmetric
- * positiv definite matrices
- * \return int -- 1 success, 0 solver does not work with sprase matrices, -1 matrix is not quadratic, -2 unable to solve the les, -3 matrix is not symmetric
-int N_solver_cholesky(N_les * les)
-	G_warning(_("The cholesky solver does not work with sparse matrices"));
-	return 0;
-	return -1;
-    /* check for symmetry */
-    if (check_symmetry(les) != 1) {
-	G_warning(_("Matrix is not symmetric!"));
-	return -3;
-    G_message(_("Starting cholesky decomposition solver"));
-    if (cholesky_decomposition(les->A, les->rows) != 1) {
-	G_warning(_("Unable to solve the linear equation system"));
-	return -2;
-    return 1;
- * gauss elimination ***************************************
- * \brief Gauss elimination
- * The matrix will be overwritten with the decomposite form
- * \param A double **
- * \param b double *
- * \param rows int
- * \return void
-void gauss_elimination(double **A, double *b, int rows)
-    int i, j, k;
-    double tmpval = 0.0;
-    for (k = 0; k < rows - 1; k++) {
-#pragma omp parallel for schedule (static) private(i, j, tmpval) shared(k, A, b, rows)
-	for (i = k + 1; i < rows; i++) {
-	    tmpval = A[i][k] / A[k][k];
-	    b[i] = b[i] - tmpval * b[k];
-	    for (j = k + 1; j < rows; j++) {
-		A[i][j] = A[i][j] - tmpval * A[k][j];
-    return;
- * lu decomposition ****************************************
- * \brief lu decomposition
- * \param rows int
- * \return void
-void lu_decomposition(double **A, int rows)
-    int i, j, k;
-#pragma omp parallel for schedule (static) private(i, j) shared(k, A, rows)
-	    A[i][k] = A[i][k] / A[k][k];
-		A[i][j] = A[i][j] - A[i][k] * A[k][j];
-    return;
- * cholesky decomposition **********************************
- * \brief cholesky decomposition for symmetric, positiv definite matrices
- * The provided matrix will be overwritten with the lower and
- * upper triangle matrix A = LL^T
- * \param rows int
- * \return void
-int cholesky_decomposition(double **A, int rows)
-    int i, j, k;
-    double sum_1 = 0.0;
-    double sum_2 = 0.0;
-    int error = 0;
-    for (k = 0; k < rows; k++) {
-#pragma omp parallel private(i, j, sum_2) shared(A, rows, sum_1)
-#pragma omp for schedule (static) private(j) reduction(+:sum_1)
-	    for (j = 0; j < k; j++) {
-		sum_1 += A[k][j] * A[k][j];
-#pragma omp single
-		if ((A[k][k] - sum_1) < 0) {
-		    error++;	/*not allowed to exit the OpenMP region */
-		A[k][k] = sqrt(A[k][k] - sum_1);
-		sum_1 = 0.0;
-#pragma omp for schedule (static) private(i, j, sum_2)
-		sum_2 = 0.0;
-		    sum_2 += A[i][j] * A[k][j];
-		A[i][k] = (A[i][k] - sum_2) / A[k][k];
-    /*we need to copy the lower triangle matrix to the upper trianle */
-#pragma omp parallel for schedule (static) private(i, k) shared(A, rows)
-	    A[k][i] = A[i][k];
-    if (error > 0) {
-	G_warning("Matrix is not positive definite");
-	return -1;
-    return 1;
- * backward solving ****************************************
- * \brief backward solving
- * \param x double *
- * \param rows int
- * \return void
-void backward_solving(double **A, double *x, double *b, int rows)
-    int i, j;
-    for (i = rows - 1; i >= 0; i--) {
-	tmpval = 0;
-	for (j = i + 1; j < rows; j++) {
-	    /*tmpval += A[i][j] * x[j]; */
-	    b[i] = b[i] - A[i][j] * x[j];
-	/*x[i] = (b[i] - tmpval) / A[i][i]; */
-	x[i] = (b[i]) / A[i][i];
-    return;
- * forward solving *****************************************
- * \brief forward solving
- * \param rows int
- * \return void
-void forward_solving(double **A, double *x, double *b, int rows)
-    int i, j;
-	tmpval = 0;
-	for (j = 0; j < i; j++) {
-	    tmpval += A[i][j] * x[j];
-	x[i] = (b[i] - tmpval) / A[i][i];
-    return;
- * ***** solving a tridiagonal eq system ***************** *
-void thomalg(double **M, double *V, int rows)
-    double *Vtmp;
-    double *g;
-    double b;
-    int i;
-    Vtmp = vectmem(rows);
-    g = vectmem(rows);
-	if (i == 0) {
-	    b = M[i][i];
-	    Vtmp[i] = V[i] / b;
-	else {
-	    b = M[i][i] - M[i][i - 1] * g[i - 1];
-	    Vtmp[i] = (V[i] - Vtmp[i - 1] * M[i][i - 1]) / b;
-	if (i < rows - 1) {
-	    g[i] = M[i][i + 1] / b;
-    V[rows - 1] = Vtmp[rows - 1];
-    for (i = rows - 2; i >= 0; i--) {
-	V[i] = Vtmp[i] - g[i] * V[i + 1];
-    G_free(Vtmp);
-    G_free(g);
- * vectmem *************************************************
- * \brief Allocate vector memory
- * \param rows int
- * \return double *
-double *vectmem(int rows)
-    double *vector;
-    vector = (double *)(G_calloc(rows, (sizeof(double))));
-    return vector;
Deleted: grass/branches/develbranch_6/lib/gpde/N_solvers_classic_iter.c
--- grass/branches/develbranch_6/lib/gpde/N_solvers_classic_iter.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/N_solvers_classic_iter.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -1,241 +0,0 @@
-* PURPOSE:      linear equation system solvers
-*               for details.
-#include <math.h>
-#include <stdio.h>
-static int sparse_jacobi_gauss(N_les * L, int maxit, double sor, double error,
-			       const char *type);
-static int jacobi(double **M, double *b, double *x, int rows, int maxit,
-		  double sor, double error);
-static int gauss_seidel(double **M, double *b, double *x, int rows, int maxit,
- * ******** overrelaxed jacobian ************************* *
- * \brief The iterative jacobian solver for regular matrices
- * The result is written to the vector L->x of the les.
- * This iterative solver works with sparse matrices and regular quadratic matrices.
- * The parameter <i>maxit</i> specifies the maximum number of iterations. If the maximum is reached, the
- * solver will abort the calculation and writes the current result into the vector L->x.
- * The parameter <i>err</i> defines the error break criteria for the solver.
- * \param L N_les *  -- the linear equatuin system
- * \param maxit int -- the maximum number of iterations
- * \param sor double -- defines the successive overrelaxion parameter [0:1]
- * \param error double -- defines the error break criteria
- * \return int -- 1=success, -1=could not solve the les
-int N_solver_jacobi(N_les * L, int maxit, double sor, double error)
-    if (L->quad != 1) {
-	return -1;
-    if (L->type == N_NORMAL_LES)
-	return jacobi(L->A, L->b, L->x, L->rows, maxit, sor, error);
-    else
-	return sparse_jacobi_gauss(L, maxit, sor, error,
-				   N_SOLVER_ITERATIVE_JACOBI);
- * ********* overrelaxed gauss seidel ******************** *
- * \brief The iterative overrelaxed gauss seidel solver for regular matrices
-int N_solver_SOR(N_les * L, int maxit, double sor, double error)
-	return -1;
-	return gauss_seidel(L->A, L->b, L->x, L->rows, maxit, sor, error);
-    else
-				   N_SOLVER_ITERATIVE_SOR);
- * ****** sparse jacobi and SOR algorithm **************** *
-int
-sparse_jacobi_gauss(N_les * L, int maxit, double sor, double error,
-		    const char *type)
-    int i, j, k, rows, finished = 0;
-    double *Enew, *x, *b;
-    double E, err = 0;
-    x = L->x;
-    b = L->b;
-    rows = L->rows;
-    Enew = vectmem(rows);
-    for (k = 0; k < maxit; k++) {
-	err = 0;
-	    if (k == 0) {
-		for (j = 0; j < rows; j++) {
-		    Enew[j] = x[j];
-		E = 0;
-		if (strcmp(type, N_SOLVER_ITERATIVE_JACOBI) == 0) {
-		    for (j = 0; j < L->Asp[i]->cols; j++) {
-			E += L->Asp[i]->values[j] * x[L->Asp[i]->index[j]];
-		else {
-			E += L->Asp[i]->values[j] * Enew[L->Asp[i]->index[j]];
-		Enew[i] = x[i] - sor * (E - b[i]) / L->Asp[i]->values[0];
-		err += (x[j] - Enew[j]) * (x[j] - Enew[j]);
-		x[j] = Enew[j];
-	    G_message(_("sparse Jacobi -- iteration %5i error %g\n"), k, err);
-	else if (strcmp(type, N_SOLVER_ITERATIVE_SOR) == 0)
-	    G_message(_("sparse SOR -- iteration %5i error %g\n"), k, err);
-	if (err < error) {
-	    finished = 1;
-	    break;
-    G_free(Enew);
-    return finished;
- * ******* direct jacobi ********************************* *
-int jacobi(double **M, double *b, double *x, int rows, int maxit, double sor,
-	   double error)
-    int i, j, k;
-    double *Enew;
-	Enew[j] = x[j];
-	    E = 0;
-		E += M[i][j] * x[j];
-	    Enew[i] = x[i] - sor * (E - b[i]) / M[i][i];
-	err = 0;
-	    x[j] = Enew[j];
-	G_message(_("Jacobi -- iteration %5i error %g\n"), k, err);
-	if (err < error)
-	    break;
-    return 1;
- * ******* direct gauss seidel *************************** *
-int gauss_seidel(double **M, double *b, double *x, int rows, int maxit,
-    int i, j, k;
-    double *Enew;
-	Enew[j] = x[j];
-	    E = 0;
-		E += M[i][j] * Enew[j];
-	err = 0;
-	    x[j] = Enew[j];
-	G_message(_("SOR -- iteration %5i error %g\n"), k, err);
-	if (err < error)
-	    break;
-    return 1;
Deleted: grass/branches/develbranch_6/lib/gpde/N_solvers_krylov.c
--- grass/branches/develbranch_6/lib/gpde/N_solvers_krylov.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/N_solvers_krylov.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -1,982 +0,0 @@
-*               for details.
-#include <math.h>
-#include <stdio.h>
-/*local protos */
-static void scalar_product(double *a, double *b, double *scalar, int rows);
-static void sub_vectors(double *source_a, double *source_b, double *result,
-			int row);
-static void sub_vectors_scalar(double *source_a, double *source_b,
-			       double *result, double scalar_b, int rows);
-static void add_vectors(double *source_a, double *source_b, double *result,
-			int rows);
-static void add_vectors_scalar(double *source_a, double *source_b,
-static void add_vectors_scalar2(double *source_a, double *source_b,
-				double *result, double scalar_a,
-				double scalar_b, int rows);
-static void scalar_vector_product(double *a, double *result, double scalar,
-				  int rows);
-static void sync_vectors(double *source, double *target, int rows);
- * *** preconditioned conjugate gradients **************** *
- * \brief The iterative preconditioned conjugate gradients solver for symmetric positive definite matrices
- * This iterative solver works with symmetric positive definite sparse matrices and
- * symmetric positive definite regular quadratic matrices.
- * \param err double -- defines the error break criteria
- * \param prec int -- the preconditioner which shoudl be used N_DIAGONAL_PRECONDITION, N_ROWSUM_PRECONDITION
- * \return int -- 1 - success, 2 - not finisehd but success, 0 - matrix singular, -1 - could not solve the les
-int N_solver_pcg(N_les * L, int maxit, double err, int prec)
-    double *r, *z;
-    double *p;
-    double *v;
-    double *x, *b;
-    double s = 0.0;
-    double a0 = 0, a1 = 0, mygamma, tmp = 0;
-    int m, rows, i;
-    int finished = 2;
-    int error_break;
-    N_les *M;
-	return -1;
-    if (check_symmetry(L) != 1) {
-    x = L->x;
-    b = L->b;
-    rows = L->rows;
-    r = vectmem(rows);
-    p = vectmem(rows);
-    v = vectmem(rows);
-    z = vectmem(rows);
-    error_break = 0;
-    /*compute the preconditioning matrix */
-    M = N_create_diag_precond_matrix(L, prec);
-     * residual calculation
-	/* matrix vector multiplication */
-	if (L->type == N_SPARSE_LES)
-	    N_sparse_matrix_vector_product(L, x, v);
-	else
-	    N_matrix_vector_product(L, x, v);
-	sub_vectors(b, v, r, rows);
-	/*performe the preconditioning */
-	N_sparse_matrix_vector_product(M, r, p);
-	/* scalar product */
-#pragma omp for schedule (static) private(i) reduction(+:s)
-	    s += p[i] * r[i];
-    a0 = s;
-    s = 0.0;
-    /* start the iteration */
-    for (m = 0; m < maxit; m++) {
-#pragma omp parallel default(shared)
-		N_sparse_matrix_vector_product(L, p, v);
-	    else
-		N_matrix_vector_product(L, p, v);
-		s += v[i] * p[i];
-	    /* barrier */
-#pragma omp single
-		tmp = s;
-		mygamma = a0 / tmp;
-		s = 0.0;
-	    add_vectors_scalar(x, p, x, mygamma, rows);
-	    if (m % 50 == 1) {
-		else
-	    else {
-		sub_vectors_scalar(r, v, r, mygamma, rows);
-	    N_sparse_matrix_vector_product(M, r, z);
-		s += z[i] * r[i];
-	    /* barrier */
-#pragma omp single
-		a1 = s;
-		tmp = a1 / a0;
-		a0 = a1;
-		s = 0.0;
-		if (a1 < 0 || a1 == 0 || a1 > 0) {
-		else {
-		    error_break = 1;
-	    add_vectors_scalar(z, p, p, tmp, rows);
-	    G_message(_("Sparse PCG -- iteration %i error  %g\n"), m, a0);
-	else
-	    G_message(_("PCG -- iteration %i error  %g\n"), m, a0);
-	if (error_break == 1) {
-	    finished = -1;
-	    break;
-	if (a0 < err) {
-	    finished = 1;
-	    break;
-    G_free(r);
-    G_free(p);
-    G_free(v);
-    G_free(z);
-    return finished;
- * ****************** conjugate gradients **************** *
- * \brief The iterative conjugate gradients solver for symmetric positive definite matrices
-int N_solver_cg(N_les * L, int maxit, double err)
-    double *r;
-    double *p;
-    double *v;
-    double *x, *b;
-    double s = 0.0;
-    int m, rows, i;
-    int finished = 2;
-    int error_break;
-	return -1;
-    x = L->x;
-    b = L->b;
-    rows = L->rows;
-    error_break = 0;
-	else
-	sync_vectors(r, p, rows);
-	    s += r[i] * r[i];
-    a0 = s;
-    s = 0.0;
-	    else
-		s += v[i] * p[i];
-	    /* barrier */
-#pragma omp single
-		tmp = s;
-		s = 0.0;
-		else
-	    else {
-		s += r[i] * r[i];
-	    /* barrier */
-#pragma omp single
-		a1 = s;
-		tmp = a1 / a0;
-		a0 = a1;
-		s = 0.0;
-		else {
-		    error_break = 1;
-	    add_vectors_scalar(r, p, p, tmp, rows);
-	    G_message(_("Sparse CG -- iteration %i error  %g\n"), m, a0);
-	else
-	    G_message(_("CG -- iteration %i error  %g\n"), m, a0);
-	    finished = -1;
-	    break;
-	if (a0 < err) {
-	    finished = 1;
-	    break;
-    G_free(r);
-    G_free(p);
-    G_free(v);
-    return finished;
- * ************ biconjugate gradients ******************** *
- * \brief The iterative biconjugate gradients solver with stabilization for unsymmetric non-definite matrices
-int N_solver_bicgstab(N_les * L, int maxit, double err)
-    double *r;
-    double *r0;
-    double *p;
-    double *v;
-    double *s;
-    double *t;
-    double *x, *b;
-    double s1 = 0.0, s2 = 0.0, s3 = 0.0;
-    double alpha = 0, beta = 0, omega, rr0 = 0, error;
-    int m, rows, i;
-    int finished = 2;
-    int error_break;
-	return -1;
-    x = L->x;
-    b = L->b;
-    rows = L->rows;
-    r0 = vectmem(rows);
-    s = vectmem(rows);
-    t = vectmem(rows);
-    error_break = 0;
-	else
-	sync_vectors(r, r0, rows);
-    s1 = s2 = s3 = 0.0;
-	    else
-#pragma omp for schedule (static) private(i) reduction(+:s1, s2, s3)
-		s1 += r[i] * r[i];
-		s2 += r[i] * r0[i];
-		s3 += v[i] * r0[i];
-#pragma omp single
-		error = s1;
-		if (error < 0 || error == 0 || error > 0) {
-		else {
-		    error_break = 1;
-		rr0 = s2;
-		alpha = rr0 / s3;
-	    sub_vectors_scalar(r, v, s, alpha, rows);
-		N_sparse_matrix_vector_product(L, s, t);
-	    else
-		N_matrix_vector_product(L, s, t);
-#pragma omp for schedule (static) private(i) reduction(+:s1, s2)
-		s1 += t[i] * s[i];
-		s2 += t[i] * t[i];
-#pragma omp single
-		omega = s1 / s2;
-		s1 = s2 = 0.0;
-	    add_vectors_scalar2(p, s, r, alpha, omega, rows);
-	    add_vectors(x, r, x, rows);
-	    sub_vectors_scalar(s, t, r, omega, rows);
-#pragma omp for schedule (static) private(i) reduction(+:s1)
-		s1 += r[i] * r0[i];
-#pragma omp single
-		beta = alpha / omega * s1 / rr0;
-	    sub_vectors_scalar(p, v, p, omega, rows);
-	    add_vectors_scalar(r, p, p, beta, rows);
-	    G_message(_("Sparse BiCGStab -- iteration %i error  %g\n"), m,
-		      error);
-	else
-	    G_message(_("BiCGStab -- iteration %i error  %g\n"), m, error);
-	    finished = -1;
-	    break;
-	if (error < err) {
-	    finished = 1;
-	    break;
-    G_free(r);
-    G_free(r0);
-    G_free(p);
-    G_free(v);
-    G_free(s);
-    G_free(t);
-    return finished;
- * \brief Calculates the scalar product of vector a and b
- * The result is written to variable scalar
- * \param a       double *
- * \param scalar  double *
- * \param rows int
- * \return void
-void scalar_product(double *a, double *b, double *scalar, int rows)
-    int i;
-    double s = 0.0;
-#pragma omp parallel for schedule (static) reduction(+:s)
-	s += a[i] * b[i];
-    *scalar = s;
-    return;
- * \brief Calculates the matrix - vector product of matrix L->A and vector x
- * The result is written to vector named result. This function only works with
- * regular quadratic matrices.
- * \param result double *
- * \return void
-void N_matrix_vector_product(N_les * L, double *x, double *result)
-    int i, j;
-    double tmp;
-#pragma omp for schedule (static) private(i, j, tmp)
-    for (i = 0; i < L->rows; i++) {
-	tmp = 0;
-	for (j = 0; j < L->cols; j++) {
-	    tmp += L->A[i][j] * x[j];
-	result[i] = tmp;
-    return;
- * \brief Calculates the matrix - vector product of sparse matrix L->Asp and vector x
- * sparse matrices matrices.
- * \return void
-void N_sparse_matrix_vector_product(N_les * L, double *x, double *result)
-    int i, j;
-    double tmp;
-	tmp = 0;
-	    tmp += L->Asp[i]->values[j] * x[L->Asp[i]->index[j]];
-	result[i] = tmp;
-    return;
- * \brief Multipiles the vector a and b with the scalars scalar_a and scalar_b and adds them
- * The result is written to the vector named result.
- * \param scalar_a double
- * \param scalar_b double
- * \param rows int
-void
-add_vectors_scalar2(double *a, double *b, double *result, double scalar_a,
-    int i;
-	result[i] = scalar_a * a[i] + scalar_b * b[i];
-    return;
- * \brief Multipiles the vector b with the scalar scalar_b and adds  a to b
- * \param rows int
-void
-add_vectors_scalar(double *a, double *b, double *result, double scalar_b,
-		   int rows)
-    int i;
-	result[i] = a[i] + scalar_b * b[i];
-    return;
- * \brief Multipiles the vector b with the scalar scalar_b and substracts b from a
- * \param rows int
-void
-sub_vectors_scalar(double *a, double *b, double *result, double scalar_b,
-		   int rows)
-    int i;
-	result[i] = a[i] - scalar_b * b[i];
-    return;
- * \brief Adds a to b
- * \param rows int
-void add_vectors(double *a, double *b, double *result, int rows)
-    int i;
-	result[i] = a[i] + b[i];
-    return;
- * \brief Substracts b from a
- * \param rows int
-void sub_vectors(double *a, double *b, double *result, int rows)
-    int i;
-	result[i] = a[i] - b[i];
-    return;
- * \brief Multipiles the vector a with the scalar named scalar
- * \param rows int
-void scalar_vector_product(double *a, double *result, double scalar, int rows)
-    int i;
-	result[i] = scalar * a[i];
-    return;
- * \brief Copies the source vector to the target vector
- * \param source double *
- * \param target double *
- * \param rows int
-void sync_vectors(double *source, double *target, int rows)
-    int i;
-	target[i] = source[i];
-    return;
- * ***** Check if matrix is symmetric ******************** *
- * \brief Check if the matrix in les is symmetric
- * \param L N_les* -- the linear equation system
- * \return int -- 1 = symmetric, 0 = unsymmetric
-int check_symmetry(N_les * L)
-    int i, j, k;
-    double value1 = 0;
-    double value2 = 0;
-    int index;
-    int symm = 0;
-	return 0;
-    G_debug(2, "check_symmetry: Check if matrix is symmetric");
-    if (L->type == N_SPARSE_LES) {
-#pragma omp parallel for schedule (static) private(i, j, k, value1, value2, index) reduction(+:symm) shared(L)
-	for (j = 0; j < L->rows; j++) {
-	    for (i = 1; i < L->Asp[j]->cols; i++) {
-		value1 = 0;
-		value2 = 0;
-		index = 0;
-		index = L->Asp[j]->index[i];
-		value1 = L->Asp[j]->values[i];
-		for (k = 1; k < L->Asp[index]->cols; k++) {
-		    if (L->Asp[index]->index[k] == j) {
-			value2 = L->Asp[index]->values[k];
-			if ((value1 != value2)) {
-			    if ((fabs((fabs(value1) - fabs(value2))) <
-				 SYMM_TOLERANCE)) {
-				G_debug(5,
-					"check_symmetry: sparse matrix is unsymmetric, but within tolerance");
-			    else {
-				G_warning
-				    ("Matrix unsymmetric: Position [%i][%i] : [%i][%i] \nError: %12.18lf != %12.18lf \ndifference = %12.18lf\nStop symmetry calculation.\n",
-				     j, index, index, L->Asp[index]->index[k],
-				     value1, value2,
-				     fabs(fabs(value1) - fabs(value2)));
-				symm++;
-    else {
-	    for (j = i + 1; j < L->rows; j++) {
-		if (L->A[i][j] != L->A[j][i]) {
-		    if ((fabs(fabs(L->A[i][j]) - fabs(L->A[j][i])) <
-			G_debug(5,
-				"check_symmetry: matrix is unsymmetric, but within tolerance");
-		    else {
-			G_warning
-			    ("Matrix unsymmetric: Position [%i][%i] : [%i][%i] \nError: %12.18lf != %12.18lf\ndifference = %12.18lf\nStop symmetry calculation.\n",
-			     i, j, j, i, L->A[i][j], L->A[j][i],
-			     fabs(fabs(L->A[i][j]) - fabs(L->A[j][i])));
-			symm++;
-    if (symm > 0)
-	return 0;
-    return 1;
- * \brief Compute a diagonal preconditioning matrix for krylov space solver
- * \param L N_les*
- * \pram prec int -- the preconditioner which should be choosen N_DIAGONAL_PRECONDITION, N_ROWSUM_PRECONDITION
- * \return M N_les* -- the preconditioning matrix
-N_les *N_create_diag_precond_matrix(N_les * L, int prec)
-    N_les *L_new;
-    int rows = L->rows;
-    int cols = L->cols;
-    int i, j;
-    double sum;
-    L_new = N_alloc_les_A(rows, N_SPARSE_LES);
-    if (L->type == N_NORMAL_LES) {
-#pragma omp parallel for schedule (static) private(i, sum) shared(L_new, L, rows, prec)
-	    N_spvector *spvect = N_alloc_spvector(1);
-	    switch (prec) {
-	    case N_ROWSCALE_EUKLIDNORM_PRECONDITION:
-		sum = 0;
-		for (j = 0; j < cols; j++)
-		    sum += L->A[i][j] * L->A[i][j];
-		spvect->values[0] = 1.0 / sqrt(sum);
-		break;
-	    case N_ROWSCALE_ABSSUMNORM_PRECONDITION:
-		sum = 0;
-		    sum += fabs(L->A[i][j]);
-		spvect->values[0] = 1.0 / (sum);
-		break;
-	    case N_DIAGONAL_PRECONDITION:
-		spvect->values[0] = 1.0 / L->A[i][i];
-		break;
-	    default:
-	    spvect->index[0] = i;
-	    spvect->cols = 1;;
-	    N_add_spvector_to_les(L_new, spvect, i);
-    else {
-	    switch (prec) {
-		sum = 0;
-		    sum += L->Asp[i]->values[j] * L->Asp[i]->values[j];
-		break;
-		sum = 0;
-		    sum += fabs(L->Asp[i]->values[j]);
-		break;
-		spvect->values[0] = 1.0 / L->Asp[i]->values[0];
-		break;
-	    default:
-    return L_new;
Modified: grass/branches/develbranch_6/lib/gpde/N_tools.c
--- grass/branches/develbranch_6/lib/gpde/N_tools.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/N_tools.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -53,6 +53,7 @@
     double val = 0.0;
     int i;
     for (i = 0; i < size; i++)
@@ -96,6 +97,7 @@
     double val = 1;
     int i;
@@ -140,6 +142,7 @@
     double val = 0;
     int i;
@@ -189,6 +192,7 @@
     double val = 0;
     int i;
Modified: grass/branches/develbranch_6/lib/gpde/gpdelib.dox
--- grass/branches/develbranch_6/lib/gpde/gpdelib.dox	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/gpdelib.dox	2009-08-27 20:52:10 UTC (rev 38889)
@@ -11,10 +11,9 @@
 solution of PDE's within GRASS.
 Therefore it provides functions to create and solve linear equation systems.
 The library design is thread safe and supports threaded parallelism with OpenMP.
-Most of the available solvers (expect the gauss seidel and jacobi solver)
-and the assembling of the linear equation systems are parallelized with OpenMP.
+The assembling of the linear equation systems is parallelized with OpenMP.
 The creation of a linear equation system can be done by using quadratic or sparse matrices.
-Sparse and quadratic matrices are supported by the iterative equation solvers,
+Sparse and quadratic matrices are supported by the iterative equation solvers of the gmath library,
 the direct equation solvers only support regular quadratic matrices.
 <p>
 To enable parallel computing, you will need a compiler with OpenMP capabilities
@@ -31,9 +30,6 @@
 The basis for the discretisation is the geometrical structure of raster and volume maps.
 <br>
 <br>
-There are plans to implement heat flow in two and three dimensions.
-<br>
-<br>
 Currently only planimetric projections are supported for numerical calculations.
 <br>
 <br>
@@ -52,99 +48,14 @@
       to manage the data
 2.) Assemble the linear equation system
     - use the sparse matrix structure to save lots of memory and cpu time
-3.) Solve the linear equation system with the gauss, lu, jacobi, sor, cg or bicgstab method
-    - always prefer the iterative krylov-space methods for solving
-    - if the linear equation systems are in a bad condition try the jacobian solver
+3.) Solve the linear equation system with the gauss, lu, cg, pcg or bicgstab method
+    - always prefer the iterative krylov-space (cg, pcg and bicgstab) methods for solving
     - the available direct solvers don't support sparse matrices
 4.) Write the result back as raster/volume map
 \endverbatim
-The following code shows how to implement this principle with the GRASS PDE lib:
+The modules r.gwflow and r3.gwflow are examples how to use the gpde library.
-\verbatim
-/* ****** calculate 2d dimensional groundwater flow ************** */
-int main()
-    int i, j;
-    N_gwflow_data2d *data = NULL; 	/* data structure with the groundwater data		*/
-    N_geom_data *geom = NULL; 		/* geometry of the calculation area (region)		*/
-    N_les *les = NULL; 		/* the linear equation system structure			*/
-    N_les_callback_2d *call = NULL;	/* the callback for the groundwater flow calulation	*/
-    /* allocate the callback structure */
-    call = N_alloc_les_callback_2d();
-    /* set the callback to groundwater flow calculation */
-    N_set_les_callback_2d_func(call, (*N_callback_gwflow_2d));
-   /* allocate the groundwater data structure with one million cells */
-    data = N_alloc_gwflow_data2d(1000, 1000);
-    /* get the current region */
-    G_get_set_window(&region);
-    /* allocate and initiate the geometry structure  for geometry and area calculation
-       needed by the groundwater calculation callback */
-    geom = N_init_geom_data_2d(&region, geom);
-    /*fill the data arrays with raster maps*/
-    N_read_rast_to_array_2d("phead_map_name", data->phead);
-    N_read_rast_to_array_2d("phead_map_name", data->phead_start);
-    N_read_rast_to_array_2d("status_map_name", data->status);
-    N_read_rast_to_array_2d("hc_x_map_name", data->hc_x);
-    N_read_rast_to_array_2d("hc_y_map_name", data->hc_y);
-    N_read_rast_to_array_2d("q_map_name", data->q);
-    N_read_rast_to_array_2d("s_map_name", data->s);
-    N_read_rast_to_array_2d("top_map_name", data->top);
-    N_read_rast_to_array_2d("bottom_map_name", data->bottom);
-    N_read_rast_to_array_2d("r_map_name", data->r);
-    /* Set the inactive cells to zero, to assure a no flow boundary */
-    /* notice: the data arrays are of type DCELL, so the put_*_d_value functions are used */
-    for (y = 0; y < geom->rows; y++) {
-	for (x = 0; x < geom->cols; x++) {
-	    stat = (int)N_get_array_2d_d_value(data->status, x, y);
-	    if (stat == N_CELL_INACTIVE) {	/*only inactive cells */
-		N_put_array_2d_d_value(data->hc_x, x, y, 0);
-		N_put_array_2d_d_value(data->hc_y, x, y, 0);
-		N_put_array_2d_d_value(data->s, x, y, 0);
-		N_put_array_2d_d_value(data->q, x, y, 0);
-    /*Assemble the sparse matrix */
-    les = N_assemble_les_2d(N_SPARSE_LES, geom, data->status, data->phead_start, (void *)data, call);
-    /*Solve the linear equation system with the cg method*/
-    N_solver_cg(les, 100000, 0.1e-8);
-    /* now copy the result from the x vector of the linear equation system
-       into a data array, this function is not provided by the gpde lib,
-       you have to write your own: take a look at r.gwflow
-    copy_x_vect_to_data_array(les->x, data->phead, geom);
-    /*write the x vector of the les back into a raster map*/
-    N_write_array_2d_to_rast(data->phead, "output_map_name");
-    /*free the memory*/
-    N_free_les(les);
-    N_free_gwflow_data2d(data);
-    N_free_geom_data(geom);
-    G_free(call);
-    return 0;
-\endverbatim
-The assembling of lineare equation systems is based on a 5 point star for raster maps and a
-7 point star for volume maps, implemented as finite volume/differences discretization.
 <p>
 All raster and volume maps which are used to create a linear equation system
 must be loaded completely into the memory.<br>
@@ -397,45 +308,6 @@
 <p>
 N_data_star *#N_callback_template_2d(void *data, N_geom_data * geom, int row, int col);
-\section solvers Available solvers
-\subsection direct_solvers Direct solvers
-Two direct solvers are implemented, the gauss elimination solver and the lu decomposition solver.
-The direct solvers only work with regular quadratic matrices, not with sparse matrices.
-<p>
-int #N_solver_gauss (N_les * les);
-<p>
-int #N_solver_lu (N_les * les);
-\subsection iterative_solvers Iterative solvers
-The iterative solvers work with regular quadartic and sparse matrices.
-<p>
-To solve symmetric and positive definite linear equation systems the iterative
-conjugated gradient method with additional diagonal preconditioning are implemented.
-int #N_solver_cg(N_les * les, int maxit, double error);
-<p>
-int #N_solver_pcg(N_les * les, int maxit, double error);
-<p>
-To solve unsymmetric non definite linear equation system the iterative BiCGSatb method is implemented
-<p>
-int #N_solver_bicgstab(N_les * les, int maxit, double error);
-<p>
-Additionally jacobi and Gauss-Seidel iterative solvers with relaxation are implemented
-<p>
-int #N_solver_jacobi (N_les * L, int maxit, double sor, double error);
-<p>
-int #N_solver_SOR (N_les * L, int maxit, double sor, double error);
 \section available_pdes Implemented PDE's
 Groundwater flow in 2 and 3 dimensions are implemented.
Deleted: grass/branches/develbranch_6/lib/gpde/solvers_local_proto.h
--- grass/branches/develbranch_6/lib/gpde/solvers_local_proto.h	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/solvers_local_proto.h	2009-08-27 20:52:10 UTC (rev 38889)
@@ -1,22 +0,0 @@
-* PURPOSE:      local prototypes for linear equation system solvers
-*               for details.
-#define SYMM_TOLERANCE 1.0e-18
-double *vectmem(int size);
-int check_symmetry(N_les * les);
Modified: grass/branches/develbranch_6/lib/gpde/test/Makefile
--- grass/branches/develbranch_6/lib/gpde/test/Makefile	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/test/Makefile	2009-08-27 20:52:10 UTC (rev 38889)
@@ -2,8 +2,8 @@
 PGM=test.gpde.lib
-LIBES = $(GISLIB) $(G3DLIB) $(GPDELIB)
-DEPENDENCIES = $(GISDEP) $(G3DDEP) $(GPDEDEP)
+LIBES = $(GISLIB) $(G3DLIB) $(GPDELIB) $(GMATHLIB)
+DEPENDENCIES = $(GISDEP) $(G3DDEP) $(GPDEDEP) $(GMATDEP)
 include $(MODULE_TOPDIR)/include/Make/Module.make
Added: grass/branches/develbranch_6/lib/gpde/test/test.gpde.lib.html
--- grass/branches/develbranch_6/lib/gpde/test/test.gpde.lib.html	                        (rev 0)
+++ grass/branches/develbranch_6/lib/gpde/test/test.gpde.lib.html	2009-08-27 20:52:10 UTC (rev 38889)
@@ -0,0 +1,3 @@
+Take a look at the module command line help for more information.
Modified: grass/branches/develbranch_6/lib/gpde/test/test_arrays.c
--- grass/branches/develbranch_6/lib/gpde/test/test_arrays.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/test/test_arrays.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -332,12 +332,10 @@
     data11 = N_alloc_array_2d(TEST_N_NUM_COLS, TEST_N_NUM_ROWS, 1, CELL_TYPE);
     data2 = N_alloc_array_2d(TEST_N_NUM_COLS, TEST_N_NUM_ROWS, 1, FCELL_TYPE);
     N_print_array_2d_info(data2);
-    data22 =
-	N_alloc_array_2d(TEST_N_NUM_COLS, TEST_N_NUM_ROWS, 1, FCELL_TYPE);
+    data22 = N_alloc_array_2d(TEST_N_NUM_COLS, TEST_N_NUM_ROWS, 1, FCELL_TYPE);
     data3 = N_alloc_array_2d(TEST_N_NUM_COLS, TEST_N_NUM_ROWS, 1, DCELL_TYPE);
     N_print_array_2d_info(data3);
-    data33 =
-	N_alloc_array_2d(TEST_N_NUM_COLS, TEST_N_NUM_ROWS, 1, DCELL_TYPE);
+    data33 = N_alloc_array_2d(TEST_N_NUM_COLS, TEST_N_NUM_ROWS, 1, DCELL_TYPE);
     /*Fill the first arrays with data */
@@ -529,8 +527,7 @@
     N_math_array_2d(data2, data22, tmp, N_ARRAY_SUM);
     res = N_convert_array_2d_null_to_zero(tmp);
     if (res == 0) {
-	G_warning
-	    ("test_array_2d: error in  N_convert_array_2d_null_to_zero ");
+	G_warning("test_array_2d: error in  N_convert_array_2d_null_to_zero ");
 	sum++;
     N_free_array_2d(tmp);
@@ -627,19 +624,19 @@
     /*Alloacte memory for all arrays */
     data1 =
-	N_alloc_array_3d(TEST_N_NUM_COLS, TEST_N_NUM_ROWS, TEST_N_NUM_DEPTHS,
-			 2, FCELL_TYPE);
+	N_alloc_array_3d(TEST_N_NUM_COLS, TEST_N_NUM_ROWS, TEST_N_NUM_DEPTHS, 2,
+			 FCELL_TYPE);
     N_print_array_3d_info(data1);
     data11 =
-			 2, FCELL_TYPE);
+			 FCELL_TYPE);
     data2 =
-			 2, DCELL_TYPE);
+			 DCELL_TYPE);
     N_print_array_3d_info(data2);
     data22 =
-			 2, DCELL_TYPE);
+			 DCELL_TYPE);
Modified: grass/branches/develbranch_6/lib/gpde/test/test_assemble.c
--- grass/branches/develbranch_6/lib/gpde/test/test_assemble.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/test/test_assemble.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -73,7 +73,7 @@
 		N_put_array_2d_c_value(data, i, j, 2);
 	    else {
-		N_put_array_2d_c_value(data, i, j, 1);
+      	N_put_array_2d_c_value(data, i, j, 1);
@@ -98,7 +98,7 @@
 		N_put_array_2d_d_value(data, i, j, 50);
 	    else {
-		N_put_array_2d_d_value(data, i, j, 1);
+      	N_put_array_2d_d_value(data, i, j, 1);
@@ -114,8 +114,8 @@
     int i, j, k;
     data =
-			 1, FCELL_TYPE);
+	N_alloc_array_3d(TEST_N_NUM_COLS, TEST_N_NUM_ROWS, TEST_N_NUM_DEPTHS, 1,
+			 FCELL_TYPE);
 #pragma omp parallel for private (i, j, k) shared (data)
     for (k = 0; k < TEST_N_NUM_DEPTHS; k++)
@@ -127,7 +127,7 @@
 		else {
-		    N_put_array_3d_f_value(data, i, j, k, 1.0);
+      	    N_put_array_3d_f_value(data, i, j, k, 1.0);
@@ -145,8 +145,8 @@
     int i, j, k;
     data =
-			 1, DCELL_TYPE);
+			 DCELL_TYPE);
@@ -159,7 +159,7 @@
 		else {
-		    N_put_array_3d_f_value(data, i, j, k, 1);
+      	    N_put_array_3d_f_value(data, i, j, k, 1);
@@ -199,29 +199,19 @@
     geom->cols = TEST_N_NUM_COLS;
     /*Assemble the matrix */
-    les =
-	N_assemble_les_3d(N_SPARSE_LES, geom, status, start_val, NULL, call);
+    les = N_assemble_les_3d(N_SPARSE_LES, geom, status, start_val, NULL, call);
     N_free_les(les);
-    les =
-	N_assemble_les_3d_active(N_SPARSE_LES, geom, status, start_val, NULL,
-				 call);
+    les = N_assemble_les_3d_active(N_SPARSE_LES, geom, status, start_val, NULL, call);
     N_free_les(les);
-    les =
-	N_assemble_les_3d_dirichlet(N_SPARSE_LES, geom, status, start_val,
-				    NULL, call);
+    les = N_assemble_les_3d_dirichlet(N_SPARSE_LES, geom, status, start_val, NULL, call);
     N_les_integrate_dirichlet_3d(les, geom, status, start_val);
     N_free_les(les);
-    les =
-	N_assemble_les_3d(N_NORMAL_LES, geom, status, start_val, NULL, call);
+    les = N_assemble_les_3d(N_NORMAL_LES, geom, status, start_val, NULL, call);
     N_free_les(les);
-    les =
-	N_assemble_les_3d_active(N_NORMAL_LES, geom, status, start_val, NULL,
-				 call);
+    les = N_assemble_les_3d_active(N_NORMAL_LES, geom, status, start_val, NULL, call);
     N_free_les(les);
-    les =
-	N_assemble_les_3d_dirichlet(N_NORMAL_LES, geom, status, start_val,
-				    NULL, call);
+    les = N_assemble_les_3d_dirichlet(N_NORMAL_LES, geom, status, start_val, NULL, call);
     N_free_les(les);
@@ -261,29 +251,19 @@
-    les =
-	N_assemble_les_2d(N_SPARSE_LES, geom, status, start_val, NULL, call);
+    les = N_assemble_les_2d(N_SPARSE_LES, geom, status, start_val, NULL, call);
     N_free_les(les);
-    les =
-	N_assemble_les_2d_active(N_SPARSE_LES, geom, status, start_val, NULL,
-				 call);
+    les = N_assemble_les_2d_active(N_SPARSE_LES, geom, status, start_val, NULL, call);
     N_free_les(les);
-    les =
-	N_assemble_les_2d_dirichlet(N_SPARSE_LES, geom, status, start_val,
-				    NULL, call);
+    les = N_assemble_les_2d_dirichlet(N_SPARSE_LES, geom, status, start_val, NULL, call);
     N_les_integrate_dirichlet_2d(les, geom, status, start_val);
     N_free_les(les);
-    les =
-	N_assemble_les_2d(N_NORMAL_LES, geom, status, start_val, NULL, call);
+    les = N_assemble_les_2d(N_NORMAL_LES, geom, status, start_val, NULL, call);
     N_free_les(les);
-    les =
-	N_assemble_les_2d_active(N_NORMAL_LES, geom, status, start_val, NULL,
-				 call);
+    les = N_assemble_les_2d_active(N_NORMAL_LES, geom, status, start_val, NULL, call);
     N_free_les(les);
-    les =
-	N_assemble_les_2d_dirichlet(N_NORMAL_LES, geom, status, start_val,
-				    NULL, call);
+    les = N_assemble_les_2d_dirichlet(N_NORMAL_LES, geom, status, start_val, NULL, call);
     N_free_les(les);
Modified: grass/branches/develbranch_6/lib/gpde/test/test_geom.c
--- grass/branches/develbranch_6/lib/gpde/test/test_geom.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/test/test_geom.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -111,8 +111,7 @@
 	    area += N_get_geom_data_area_of_cell(geom, i);
 	if (area == 0) {
-	    G_warning
-		("Wrong area calculation in N_get_geom_data_area_of_cell");
+	    G_warning("Wrong area calculation in N_get_geom_data_area_of_cell");
 	    sum++;
@@ -149,8 +148,7 @@
 	if (area == 0) {
-	    G_warning
 	    sum++;
@@ -161,8 +159,7 @@
 	if (area == 0) {
-	    G_warning
 	    sum++;
Modified: grass/branches/develbranch_6/lib/gpde/test/test_gpde_lib.h
--- grass/branches/develbranch_6/lib/gpde/test/test_gpde_lib.h	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/test/test_gpde_lib.h	2009-08-27 20:52:10 UTC (rev 38889)
@@ -24,7 +24,7 @@
 #define TEST_N_NUM_DEPTHS 10
 /* Array test functions */
-extern int unit_test_arrays(void);
+extern int unit_test_arrays (void);
 /* matrix assembling */
 extern int unit_test_assemble(void);
@@ -32,9 +32,6 @@
 /* gradient creation and handling tests */
 extern int unit_test_gradient(void);
-/* direct and iterative solvers */
-extern int unit_test_solvers(void);
 /* test the meth tools of gpde */
 extern int unit_test_tools(void);
@@ -42,10 +39,10 @@
 extern int unit_test_geom_data(void);
 /* les creation */
-extern int unit_test_les_creation(void);
+extern int unit_test_les_creation (void);
-/*gwflow */
-extern int integration_test_gwflow(void);
+/*gwflow*/
+extern int integration_test_gwflow (void);
 /* solute transport */
 extern int integration_test_solute_transport(void);
Modified: grass/branches/develbranch_6/lib/gpde/test/test_gradient.c
--- grass/branches/develbranch_6/lib/gpde/test/test_gradient.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/test/test_gradient.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -68,7 +68,7 @@
 #pragma omp parallel for private (i, j) shared (data)
     for (j = 0; j < TEST_N_NUM_ROWS; j++) {
 	for (i = 0; i < TEST_N_NUM_COLS; i++) {
     return data;
@@ -87,7 +87,7 @@
-	    N_put_array_2d_d_value(data, i, j, (double)i * j);
+		N_put_array_2d_d_value(data, i, j, (double)i*j);
     return data;
@@ -102,17 +102,17 @@
     int i, j, k;
     data =
-			 1, FCELL_TYPE);
+			 FCELL_TYPE);
     for (k = 0; k < TEST_N_NUM_DEPTHS; k++) {
     return data;
@@ -127,16 +127,16 @@
     int i, j, k;
     data =
-			 1, DCELL_TYPE);
+			 DCELL_TYPE);
-		N_put_array_3d_f_value(data, i, j, k, (double)i * j * k);
+		    N_put_array_3d_f_value(data, i, j, k, (float)i*j*k);
     return data;
@@ -174,10 +174,9 @@
     pot = create_potential_array_3d();
     field = N_compute_gradient_field_3d(pot, relax, relax, relax, geom, NULL);
-    field =
-	N_compute_gradient_field_3d(pot, relax, relax, relax, geom, field);
+    field = N_compute_gradient_field_3d(pot, relax, relax, relax, geom, field);
-    /*compute stats */
+    /*compute stats*/
     N_calc_gradient_field_3d_stats(field);
     N_print_gradient_field_3d_info(field);
@@ -187,7 +186,7 @@
     N_free_array_3d(pot);
     relax = N_alloc_array_3d(3, 3, 3, 0, DCELL_TYPE);
-    pot = N_alloc_array_3d(3, 3, 3, 0, DCELL_TYPE);
+    pot =   N_alloc_array_3d(3, 3, 3, 0, DCELL_TYPE);
     xcomp = N_alloc_array_3d(3, 3, 3, 0, DCELL_TYPE);
     ycomp = N_alloc_array_3d(3, 3, 3, 0, DCELL_TYPE);
     zcomp = N_alloc_array_3d(3, 3, 3, 0, DCELL_TYPE);
@@ -267,8 +266,7 @@
     geom->cols = 3;
-    field =
     grad = N_get_gradient_3d(field, NULL, 0, 0, 0);
@@ -302,10 +300,10 @@
     N_compute_gradient_field_components_3d(field, xcomp, ycomp, zcomp);
-       N_print_array_3d(xcomp);
-       N_print_array_3d(ycomp);
-       N_print_array_3d(zcomp);
+    N_print_array_3d(xcomp);
+    N_print_array_3d(ycomp);
+    N_print_array_3d(zcomp);
     N_free_gradient_field_3d(field);
     G_free(geom);
@@ -354,7 +352,7 @@
     field = N_compute_gradient_field_2d(pot, relax, relax, geom, field);
+    /*compute stats*/
     N_calc_gradient_field_2d_stats(field);
     N_print_gradient_field_2d_info(field);
@@ -364,7 +362,7 @@
     N_free_array_2d(pot);
     relax = N_alloc_array_2d(3, 3, 0, DCELL_TYPE);
-    pot = N_alloc_array_2d(3, 3, 0, DCELL_TYPE);
+    pot =   N_alloc_array_2d(3, 3, 0, DCELL_TYPE);
     xcomp = N_alloc_array_2d(3, 3, 0, DCELL_TYPE);
     ycomp = N_alloc_array_2d(3, 3, 0, DCELL_TYPE);
@@ -401,55 +399,46 @@
-    /*common gradient calculation */
+    /*common gradient calculation*/
     grad = N_get_gradient_2d(field, NULL, 0, 0);
-    G_message
-	("Gradient 2d: pos 0,0 NC %g == 0 ; SC %g == 2 ; WC %g == 0 ; EC %g == -1\n",
-	 grad->NC, grad->SC, grad->WC, grad->EC);
+    G_message("Gradient 2d: pos 0,0 NC %g == 0 ; SC %g == 2 ; WC %g == 0 ; EC %g == -1\n",
+	   grad->NC, grad->SC, grad->WC, grad->EC);
     grad = N_get_gradient_2d(field, grad, 1, 0);
-    G_message
-	("Gradient 2d: pos 1,0 NC %g == 0 ; SC %g == 5 ; WC %g == -1 ; EC %g == -4\n",
+    G_message("Gradient 2d: pos 1,0 NC %g == 0 ; SC %g == 5 ; WC %g == -1 ; EC %g == -4\n",
     N_free_gradient_2d(grad);
     grad = N_get_gradient_2d(field, NULL, 1, 1);
-    G_message
-	("Gradient 2d: pos 1,1 NC %g == 5 ; SC %g == 8 ; WC %g == -4 ; EC %g == -3\n",
+    G_message("Gradient 2d: pos 1,1 NC %g == 5 ; SC %g == 8 ; WC %g == -4 ; EC %g == -3\n",
     grad = N_get_gradient_2d(field, grad, 1, 2);
-    G_message
-	("Gradient 2d: pos 1,2 NC %g == 8 ; SC %g ==  0 ; WC %g == -7 ; EC %g == -10\n",
+    G_message("Gradient 2d: pos 1,2 NC %g == 8 ; SC %g ==  0 ; WC %g == -7 ; EC %g == -10\n",
     grad = N_get_gradient_2d(field, NULL, 2, 2);
-    G_message
-	("Gradient 2d: pos 2,2 NC %g ==15 ; SC %g ==  0 ; WC %g == -10 ; EC %g ==  0\n",
+    G_message("Gradient 2d: pos 2,2 NC %g ==15 ; SC %g ==  0 ; WC %g == -10 ; EC %g ==  0\n",
     N_compute_gradient_field_components_2d(field, xcomp, ycomp);
-    /*gradient neighbour calculation */
+    /*gradient neighbour calculation*/
     grad_2d = N_get_gradient_neighbours_2d(field, NULL, 1, 1);
     grad_2d = N_get_gradient_neighbours_2d(field, grad_2d, 1, 1);
-    G_message
-	("N_gradient_neighbours_x; pos 1,1 NWN %g NEN %g WC %g EC %g SWS %g SES %g\n",
-	 grad_2d->x->NWN, grad_2d->x->NEN, grad_2d->x->WC, grad_2d->x->EC,
-	 grad_2d->x->SWS, grad_2d->x->SES);
-    G_message
-	("N_gradient_neighbours_y: pos 1,1 NWW %g NEE %g NC %g SC %g SWW %g SEE %g\n",
-	 grad_2d->y->NWW, grad_2d->y->NEE, grad_2d->y->NC, grad_2d->y->SC,
-	 grad_2d->y->SWW, grad_2d->y->SEE);
+    G_message("N_gradient_neighbours_x; pos 1,1 NWN %g NEN %g WC %g EC %g SWS %g SES %g\n",
+	   grad_2d->x->NWN, grad_2d->x->NEN, grad_2d->x->WC, grad_2d->x->EC, grad_2d->x->SWS, grad_2d->x->SES);
+    G_message("N_gradient_neighbours_y: pos 1,1 NWW %g NEE %g NC %g SC %g SWW %g SEE %g\n",
+	   grad_2d->y->NWW, grad_2d->y->NEE, grad_2d->y->NC, grad_2d->y->SC, grad_2d->y->SWW, grad_2d->y->SEE);
     N_free_gradient_neighbours_2d(grad_2d);
-       N_print_array_2d(xcomp);
-       N_print_array_2d(ycomp);
+    N_print_array_2d(xcomp);
+    N_print_array_2d(ycomp);
     N_free_gradient_field_2d(field);
     G_free(geom);
Modified: grass/branches/develbranch_6/lib/gpde/test/test_gwflow.c
--- grass/branches/develbranch_6/lib/gpde/test/test_gwflow.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/test/test_gwflow.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -15,6 +15,9 @@
 #include <grass/N_pde.h>
@@ -108,9 +111,7 @@
     int i, j;
     N_gwflow_data2d *data;
-    data =
-	N_alloc_gwflow_data2d(TEST_N_NUM_COLS_LOCAL, TEST_N_NUM_ROWS_LOCAL, 1,
-			      1);
+    data = N_alloc_gwflow_data2d(TEST_N_NUM_COLS_LOCAL, TEST_N_NUM_ROWS_LOCAL, 1, 1);
     for (j = 0; j < TEST_N_NUM_ROWS_LOCAL; j++) {
@@ -179,37 +180,37 @@
      /*CG*/ les =
 	N_assemble_les_3d(N_SPARSE_LES, geom, data->status, data->phead_start,
-    N_solver_cg(les, 100, 0.1e-8);
+    G_math_solver_sparse_cg(les->Asp, les->x, les->b, les->rows, 100, 0.1e-8);
     N_print_les(les);
     N_free_les(les);
-    /*PCG N_DIAGONAL_PRECONDITION */ les =
+     /*PCG N_DIAGONAL_PRECONDITION*/ les =
-    N_solver_pcg(les, 100, 0.1e-8, N_DIAGONAL_PRECONDITION);
+    G_math_solver_sparse_pcg(les->Asp, les->x, les->b, les->rows, 100, 0.1e-8, N_DIAGONAL_PRECONDITION);
     N_print_les(les);
     N_free_les(les);
-    /*PCG N_ROWSCALE_EUKLIDNORM_PRECONDITION */ les =
+     /*PCG N_ROWSCALE_EUKLIDNORM_PRECONDITION*/ les =
-    N_solver_pcg(les, 100, 0.1e-8, N_ROWSCALE_EUKLIDNORM_PRECONDITION);
+    G_math_solver_sparse_pcg(les->Asp, les->x, les->b, les->rows, 100, 0.1e-8, N_ROWSCALE_EUKLIDNORM_PRECONDITION);
     N_print_les(les);
     N_free_les(les);
-    /*PCG N_ROWSCALE_ABSSUMNORM_PRECONDITION */ les =
+     /*PCG N_ROWSCALE_ABSSUMNORM_PRECONDITION*/ les =
-    N_solver_pcg(les, 100, 0.1e-8, N_ROWSCALE_ABSSUMNORM_PRECONDITION);
+    G_math_solver_sparse_pcg(les->Asp, les->x, les->b, les->rows, 100, 0.1e-8, N_ROWSCALE_ABSSUMNORM_PRECONDITION);
     N_print_les(les);
     N_free_les(les);
      /*CG*/ les =
-	N_assemble_les_3d_dirichlet(N_SPARSE_LES, geom, data->status,
-				    data->phead_start, (void *)data, call);
+	N_assemble_les_3d_dirichlet(N_SPARSE_LES, geom, data->status, data->phead_start,
+			  (void *)data, call);
     N_les_integrate_dirichlet_3d(les, geom, data->status, data->phead_start);
     N_print_les(les);
     N_free_les(les);
@@ -217,41 +218,41 @@
      /*CG*/ les =
 	N_assemble_les_3d(N_NORMAL_LES, geom, data->status, data->phead_start,
+    G_math_solver_cg(les->A, les->x, les->b, les->rows,  100, 0.1e-8);
     N_print_les(les);
     N_free_les(les);
+    G_math_solver_pcg(les->A, les->x, les->b, les->rows,  100, 0.1e-8, N_DIAGONAL_PRECONDITION);
     N_print_les(les);
     N_free_les(les);
+    G_math_solver_pcg(les->A, les->x, les->b, les->rows,  100, 0.1e-8, N_ROWSCALE_EUKLIDNORM_PRECONDITION);
     N_print_les(les);
     N_free_les(les);
+    G_math_solver_pcg(les->A, les->x, les->b, les->rows, 100, 0.1e-8, N_ROWSCALE_ABSSUMNORM_PRECONDITION);
     N_print_les(les);
     N_free_les(les);
      /*CG*/ les =
-	N_assemble_les_3d_dirichlet(N_NORMAL_LES, geom, data->status,
+	N_assemble_les_3d_dirichlet(N_NORMAL_LES, geom, data->status, data->phead_start,
     N_print_les(les);
     N_free_les(les);
@@ -259,30 +260,30 @@
      /*BICG*/ les =
-    N_solver_bicgstab(les, 100, 0.1e-8);
+    G_math_solver_sparse_bicgstab(les->Asp, les->x, les->b, les->rows,  100, 0.1e-8);
     N_print_les(les);
     N_free_les(les);
      /*BICG*/ les =
+    G_math_solver_bicgstab(les->A, les->x, les->b, les->rows, 100, 0.1e-8);
     N_print_les(les);
     N_free_les(les);
      /*BICG*/ les =
     N_print_les(les);
     N_free_les(les);
      /*BICG*/ les =
     N_print_les(les);
     N_free_les(les);
@@ -290,45 +291,45 @@
      /*GUASS*/ les =
-    N_solver_gauss(les);
+    G_math_solver_gauss(les->A, les->x, les->b, les->rows);
     N_print_les(les);
     N_free_les(les);
      /*LU*/ les =
-    N_solver_lu(les);
+    G_math_solver_lu(les->A, les->x, les->b, les->rows);
     N_print_les(les);
     N_free_les(les);
      /*GUASS*/ les =
     N_print_les(les);
     N_free_les(les);
      /*LU*/ les =
-    N_solver_lu(les);
     N_print_les(les);
     N_free_les(les);
-    /*Cholesky */ les =
+     /*Cholesky*/ les =
-    N_solver_cholesky(les);
+    G_math_solver_cholesky(les->A, les->x, les->b, les->rows, les->rows);
     N_print_les(les);
     N_free_les(les);
     N_print_les(les);
     N_free_les(les);
@@ -365,53 +366,85 @@
     geom->cols = TEST_N_NUM_COLS_LOCAL;
-    /*Assemble the matrix */
+     /*Assemble the matrix */
      /*CG*/ les =
     N_print_les(les);
     N_free_les(les);
+	N_assemble_les_2d(N_SPARSE_LES, geom, data->status, data->phead_start,
+    N_print_les(les);
+    N_free_les(les);
+    N_print_les(les);
+    N_free_les(les);
+    N_print_les(les);
+    N_free_les(les);
      /*CG*/ les =
-	N_assemble_les_2d_dirichlet(N_SPARSE_LES, geom, data->status,
+	N_assemble_les_2d_dirichlet(N_SPARSE_LES, geom, data->status, data->phead_start,
     N_les_integrate_dirichlet_2d(les, geom, data->status, data->phead_start);
     N_print_les(les);
     N_free_les(les);
      /*CG*/ les =
 	N_assemble_les_2d(N_NORMAL_LES, geom, data->status, data->phead_start,
     N_print_les(les);
     N_free_les(les);
+	N_assemble_les_2d(N_NORMAL_LES, geom, data->status, data->phead_start,
+    N_print_les(les);
+    N_free_les(les);
-     /*CG*/ les =
-	N_assemble_les_2d_dirichlet(N_NORMAL_LES, geom, data->status,
-    N_les_integrate_dirichlet_2d(les, geom, data->status, data->phead_start);
     N_print_les(les);
     N_free_les(les);
-     /*PCG*/ les =
     N_print_les(les);
     N_free_les(les);
-     /*PCG*/ les =
+     /*CG*/ les =
+	N_assemble_les_2d_dirichlet(N_NORMAL_LES, geom, data->status, data->phead_start,
     N_print_les(les);
     N_free_les(les);
@@ -419,83 +452,79 @@
      /*BICG*/ les =
     N_print_les(les);
     N_free_les(les);
      /*BICG*/ les =
     N_print_les(les);
     N_free_les(les);
      /*BICG*/ les =
-	N_assemble_les_2d(N_NORMAL_LES, geom, data->status, data->phead_start,
+    N_les_integrate_dirichlet_2d(les, geom, data->status, data->phead_start);
     N_print_les(les);
     N_free_les(les);
      /*BICG*/ les =
     N_print_les(les);
     N_free_les(les);
-     /*GAUSS*/ les =
+     /*GUASS*/ les =
     N_print_les(les);
     N_free_les(les);
-     /*GAUSS*/ les =
+     /*LU*/ les =
     N_print_les(les);
     N_free_les(les);
-     /*LU*/ les =
+     /*GUASS*/ les =
-    N_solver_lu(les);
     N_print_les(les);
     N_free_les(les);
      /*LU*/ les =
-    N_solver_lu(les);
     N_print_les(les);
     N_free_les(les);
     N_print_les(les);
     N_free_les(les);
     N_print_les(les);
     N_free_les(les);
     G_free(geom);
     G_free(call);
Modified: grass/branches/develbranch_6/lib/gpde/test/test_les.c
--- grass/branches/develbranch_6/lib/gpde/test/test_les.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/test/test_les.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -17,6 +17,7 @@
 #include <grass/gis.h>
 #include <grass/glocale.h>
+#include <grass/gmath.h>
 #include "test_gpde_lib.h"
@@ -49,7 +50,7 @@
 int test_les(void)
-    N_spvector *spvector = NULL;
+    G_math_spvector *spvector = NULL;
     N_les *les = NULL;
     N_les *sples = NULL;
     int i, j;
@@ -106,7 +107,7 @@
 #pragma omp parallel for private(i, j) shared(sples, spvector)
     for (i = 0; i < TEST_N_NUM_ROWS; i++) {
-	spvector = N_alloc_spvector(TEST_N_NUM_ROWS);
+	spvector = G_math_alloc_spvector(TEST_N_NUM_ROWS);
 	    if (i != j)
@@ -115,7 +116,7 @@
 	spvector->index[0] = i;
 	spvector->values[0] = -1e2 - i;
-	N_add_spvector_to_les(sples, spvector, i);
+	G_math_add_spvector(sples->Asp, spvector, i);
 	sples->x[i] = 273.15 + i;
 	sples->b[i] = 1e2 - i;
@@ -139,7 +140,7 @@
 	    if (i != j)
@@ -148,7 +149,7 @@
Modified: grass/branches/develbranch_6/lib/gpde/test/test_main.c
--- grass/branches/develbranch_6/lib/gpde/test/test_main.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/test/test_main.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -34,7 +34,7 @@
 paramType param;		/*Parameters */
 /*- prototypes --------------------------------------------------------------*/
-static void set_params(void);	/*Fill the paramType structure */
+static void set_params(void);		/*Fill the paramType structure */
 /* Set up the arguments we are expecting ********************************** */
@@ -45,7 +45,7 @@
     param.unit->key = "unit";
     param.unit->type = TYPE_STRING;
     param.unit->required = NO;
-    param.unit->options = "array,assemble,geom,gradient,les,solver,tools";
+    param.unit->options = "array,assemble,geom,gradient,les,tools";
     param.unit->description = _("Choose the unit tests to run");
     param.integration = G_define_option();
@@ -100,7 +100,6 @@
 	returnstat += unit_test_gradient();
 	returnstat += unit_test_geom_data();
 	returnstat += unit_test_les_creation();
-	returnstat += unit_test_solvers();
 	returnstat += unit_test_tools();
@@ -133,9 +132,6 @@
 		    if (strcmp(param.unit->answers[i], "les") == 0)
-		    if (strcmp(param.unit->answers[i], "solver") == 0)
 		    if (strcmp(param.unit->answers[i], "tools") == 0)
@@ -150,11 +146,10 @@
 		    if (strcmp(param.integration->answers[i], "gwflow") == 0)
 			returnstat += integration_test_gwflow();
-		    if (strcmp(param.integration->answers[i], "heatflow") == 0) ;	/*nothing to do for now */
+		    if (strcmp(param.integration->answers[i], "heatflow") == 0);	/*nothing to do for now */
-		    if (strcmp(param.integration->answers[i], "transport") ==
-			0)
-			returnstat += integration_test_solute_transport();
+		    if (strcmp(param.integration->answers[i], "transport") == 0)
+		        returnstat += integration_test_solute_transport();
 		    i++;
@@ -162,10 +157,10 @@
-    if (returnstat != 0)
-	G_warning("Errors detected while testing the gpde lib");
+    if(returnstat != 0)
+    	G_warning("Errors detected while testing the gpde lib");
     else
-	G_message("\n-- gpde lib tests finished successfully --");
+    	G_message("\n-- gpde lib tests finished successfully --");
     return (returnstat);
Modified: grass/branches/develbranch_6/lib/gpde/test/test_solute_transport.c
--- grass/branches/develbranch_6/lib/gpde/test/test_solute_transport.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/test/test_solute_transport.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -51,7 +51,8 @@
     if (sum > 0)
 	G_warning(_("\n-- solute_transport integration tests failure --"));
     else
-	G_message(_("\n-- solute_transport integration tests finished successfully --"));
+	G_message(_
+		  ("\n-- solute_transport integration tests finished successfully --"));
     return sum;
@@ -143,9 +144,9 @@
 		N_put_array_2d_d_value(data->cs, i, j, 1.0);
-    /*dispersivity length */
-    data->al = 0.2;
-    data->at = 0.02;
+   /*dispersivity length*/
+   data->al = 0.2;
+   data->at = 0.02;
@@ -168,7 +169,7 @@
     N_set_les_callback_3d_func(call, (*N_callback_solute_transport_3d));	/*solute_transport 3d */
     data = create_solute_transport_data_3d();
     N_calc_solute_transport_disptensor_3d(data);
     data->dt = 86400;
@@ -187,59 +188,32 @@
-    /*Jacobi */ les =
-	N_assemble_les_3d(N_SPARSE_LES, geom, data->status, data->c_start,
-			  (void *)data, call);
-    N_solver_jacobi(les, 100, 1, 0.1e-8);
-    N_print_les(les);
-    N_free_les(les);
-    /*jacobi */ les =
-	N_assemble_les_3d(N_NORMAL_LES, geom, data->status, data->c_start,
-    N_print_les(les);
-    N_free_les(les);
-     /*SOR*/ les =
-    N_solver_SOR(les, 100, 1, 0.1e-8);
-    N_print_les(les);
-    N_free_les(les);
-     /*SOR*/ les =
-    N_print_les(les);
-    N_free_les(les);
      /*BICG*/ les =
     N_print_les(les);
     N_free_les(les);
      /*BICG*/ les =
     N_print_les(les);
     N_free_les(les);
      /*GUASS*/ les =
     N_print_les(les);
     N_free_les(les);
      /*LU*/ les =
-    N_solver_lu(les);
     N_print_les(les);
     N_free_les(les);
@@ -302,65 +276,37 @@
     N_compute_gradient_field_2d(pot, relax, relax, geom, data->grad);
-    /*The dispersivity tensor */
+    /*The dispersivity tensor*/
     N_calc_solute_transport_disptensor_2d(data);
-    /*Jacobi */ les =
+   /*BICG*/ les =
 	N_assemble_les_2d(N_SPARSE_LES, geom, data->status, data->c_start,
     N_print_les(les);
     N_free_les(les);
-    /*jacobi */ les =
-	N_assemble_les_2d(N_NORMAL_LES, geom, data->status, data->c_start,
-    N_print_les(les);
-    N_free_les(les);
-     /*SOR*/ les =
-	N_assemble_les_2d(N_SPARSE_LES, geom, data->status, data->c_start,
-    N_print_les(les);
-    N_free_les(les);
-     /*SOR*/ les =
-    N_print_les(les);
-    N_free_les(les);
      /*BICG*/ les =
-    N_print_les(les);
-    N_free_les(les);
-     /*BICG*/ les =
     N_print_les(les);
     N_free_les(les);
-     /*GAUSS*/ les =
+     /*GUASS*/ les =
     N_print_les(les);
     N_free_les(les);
      /*LU*/ les =
-    N_solver_lu(les);
     N_print_les(les);
     N_free_les(les);
Deleted: grass/branches/develbranch_6/lib/gpde/test/test_solvers.c
--- grass/branches/develbranch_6/lib/gpde/test/test_solvers.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/test/test_solvers.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -1,235 +0,0 @@
-* MODULE:       Grass PDE Numerical Library
-* AUTHOR(S):    Soeren Gebbert, Berlin (GER) Dec 2006
-* 		soerengebbert <at> gmx <dot> de
-* PURPOSE:      Unit tests for les solving
-* COPYRIGHT:    (C) 2000 by the GRASS Development Team
-*               This program is free software under the GNU General Public
-*               License (>=v2). Read the file COPYING that comes with GRASS
-*               for details.
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <grass/glocale.h>
-#include <grass/N_pde.h>
-#include "test_gpde_lib.h"
-/* prototypes */
-static int test_solvers(void);
-static N_les *create_normal_les(int rows);
-static N_les *create_sparse_les(int rows);
-/* Performe the solver unit tests ****************************************** */
-int unit_test_solvers(void)
-    int sum = 0;
-    G_message(_("\n++ Running solver unit tests ++"));
-    sum += test_solvers();
-    if (sum > 0)
-	G_warning(_("\n-- Solver unit tests failure --"));
-    else
-	G_message(_("\n-- Solver unit tests finished successfully --"));
-    return sum;
-/* create a normal matrix with values ** Hilbert matrix ********** */
-N_les *create_normal_les(int rows)
-    N_les *les;
-    int i, j;
-    int size = rows;
-    double val;
-    les = N_alloc_les(rows, N_NORMAL_LES);
-    for (i = 0; i < size; i++) {
-	val = 0.0;
-	for (j = 0; j < size; j++) {
-	    les->A[i][j] = (double)(1.0 / (((double)i + 1.0) +
-					   ((double)j + 1.0) - 1.0));
-	    val += les->A[i][j];
-	les->b[i] = val;
-    return les;
-/* create a sparse matrix with values ** Hilbert matrix ********** */
-N_les *create_sparse_les(int rows)
-    N_les *les;
-    N_spvector *spvector;
-    int i, j;
-    double val;
-    les = N_alloc_les(rows, N_SPARSE_LES);
-    for (i = 0; i < rows; i++) {
-	spvector = N_alloc_spvector(rows);
-	val = 0;
-	    spvector->values[j] =
-		(double)(1.0 / (((double)i + 1.0) + ((double)j + 1.0) - 1.0));
-	    spvector->index[j] = j;
-	    val += spvector->values[j];
-	N_add_spvector_to_les(les, spvector, i);
-	les->b[i] = val;
-    return les;
-/* Test all implemented solvers for sparse and normal matrices *** */
-int test_solvers(void)
-    N_les *les;
-    N_les *sples;
-    G_message("\t * testing jacobi solver\n");
-    les = create_normal_les(TEST_N_NUM_ROWS);
-    sples = create_sparse_les(TEST_N_NUM_ROWS);
-    N_solver_jacobi(les, 100, 1, 0.1e-4);
-    /*N_print_les(les); */
-    N_solver_jacobi(sples, 100, 1, 0.1e-4);
-    /*N_print_les(sples); */
-    N_free_les(les);
-    N_free_les(sples);
-    G_message("\t * testing SOR solver\n");
-    N_solver_SOR(les, 100, 1, 0.1e-4);
-    N_solver_SOR(sples, 100, 1, 0.1e-4);
-    N_free_les(les);
-    G_message("\t * testing cg solver\n");
-    N_solver_cg(sples, 100, 0.1e-8);
-    N_free_les(les);
-    G_message("\t * testing pcg solver with N_DIAGONAL_PRECONDITION\n");
-    N_print_les(les);
-    N_solver_pcg(sples, 100, 0.1e-8, N_DIAGONAL_PRECONDITION);
-    N_print_les(sples);
-    N_free_les(les);
-    G_message
-	("\t * testing pcg solver with N_ROWSCALE_EUKLIDNORM_PRECONDITION\n");
-    N_print_les(les);
-    N_solver_pcg(sples, 100, 0.1e-8, N_ROWSCALE_EUKLIDNORM_PRECONDITION);
-    N_free_les(les);
-    G_message
-	("\t * testing pcg solver with N_ROWSCALE_ABSSUMNORM_PRECONDITION\n");
-    N_print_les(les);
-    N_solver_pcg(sples, 100, 0.1e-8, N_ROWSCALE_ABSSUMNORM_PRECONDITION);
-    N_free_les(les);
-    G_message("\t * testing bicgstab solver\n");
-    N_solver_bicgstab(sples, 100, 0.1e-8);
-    N_free_les(les);
-    G_message("\t * testing gauss elimination solver\n");
-     /*GAUSS*/ N_solver_gauss(les);
-    N_print_les(les);
-    N_free_les(les);
-    G_message("\t * testing lu decomposition solver\n");
-     /*LU*/ N_solver_lu(les);
-    N_print_les(les);
-    N_free_les(les);
-    /*cholesky */ N_solver_cholesky(les);
-    N_print_les(les);
-    N_free_les(les);
-    return 0;
Modified: grass/branches/develbranch_6/lib/gpde/test/test_tools.c
--- grass/branches/develbranch_6/lib/gpde/test/test_tools.c	2009-08-27 20:50:27 UTC (rev 38888)
+++ grass/branches/develbranch_6/lib/gpde/test/test_tools.c	2009-08-27 20:52:10 UTC (rev 38889)
@@ -48,149 +48,139 @@
 int test_mean_calc(void)
-    double a, b, mean_n, mean, vector, distance, D, weight;
-    double v[2];
-    double array[10] = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
-    int i;
-    int sum = 0;
-    char buff1[10];
+  double a, b, mean_n, mean, vector, distance, D, weight;
+  double v[2];
+  double array[10] = {0,0,0,0,0,0,0,0,0,0};
+  int i;
+  int sum = 0;
+  char buff1[10];
-    for (i = 0; i < 10; i++)
-	array[i] += i;
+  for(i = 0; i < 10; i++)
+  array[i] += i;
-    a = 1.0 / 3.0;
-    b = 3.0;
-    v[0] = a;
-    v[1] = b;
+  a = 1.0/3.0;
+  b = 3.0;
+  v[0] = a; v[1] = b;
-    /*arith mean */
-    mean = N_calc_arith_mean(a, b);
-    G_message("N_calc_arith_mean: calc a %g and b %g = %12.18lf", a, b, mean);
-    mean_n = N_calc_arith_mean_n(v, 2);
-    G_message("N_calc_arith_mean_n: calc a %g and b %g = %12.18lf", v[0],
-	      v[1], mean_n);
-    if (mean != mean_n)
-	sum++;
+  /*arith mean*/
+  mean = N_calc_arith_mean(a, b);
+  G_message("N_calc_arith_mean: calc a %g and b %g = %12.18lf", a, b, mean);
+  mean_n = N_calc_arith_mean_n(v, 2);
+  G_message("N_calc_arith_mean_n: calc a %g and b %g = %12.18lf", v[0], v[1], mean_n);
+  if(mean != mean_n)
+  	sum++;
-    /*geom mean */
-    mean = N_calc_geom_mean(a, b);
-    G_message("N_calc_geom_mean: calc a %g and b %g = %12.18lf", a, b, mean);
-    mean_n = N_calc_geom_mean_n(v, 2);
-    G_message("N_calc_geom_mean_n: calc a %g and b %g = %12.18lf", v[0], v[1],
-	      mean_n);
-	sum++;
+  /*geom mean*/
+  mean = N_calc_geom_mean(a, b);
+  G_message("N_calc_geom_mean: calc a %g and b %g = %12.18lf", a, b, mean);
+  mean_n = N_calc_geom_mean_n(v, 2);
+  G_message("N_calc_geom_mean_n: calc a %g and b %g = %12.18lf", v[0], v[1], mean_n);
+  	sum++;
-    /*harmonic mean */
-    mean = N_calc_harmonic_mean(a, b);
-    G_message("N_calc_harmonic_mean: calc a %g and b %g = %12.18lf", a, b,
-	      mean);
-    mean_n = N_calc_harmonic_mean_n(v, 2);
-    G_message("N_calc_harmonic_mean_n: calc a %g and b %g = %12.18lf", v[0],
-	      v[1], mean_n);
-	sum++;
-    /*null test */
-    a = 2;
-    b = 0;
-    v[0] = a;
-    v[1] = b;
-	      mean);
-	      v[1], mean_n);
-	sum++;
+  /*harmonic mean*/
+  mean = N_calc_harmonic_mean(a, b);
+  G_message("N_calc_harmonic_mean: calc a %g and b %g = %12.18lf", a, b, mean);
+  mean_n = N_calc_harmonic_mean_n(v, 2);
+  G_message("N_calc_harmonic_mean_n: calc a %g and b %g = %12.18lf", v[0], v[1], mean_n);
+  	sum++;
+  /*null test*/
+  a = 2;
+  b = 0;
+  	sum++;
+  /*quadratic mean*/
+  a = 1.0/3.0;
+  b = 3.0;
-    /*quadratic mean */
-    a = 1.0 / 3.0;
-    b = 3.0;
-    v[0] = a;
-    v[1] = b;
+  mean = N_calc_quad_mean(a, b);
+  G_message("N_calc_quad_mean: calc a %g and b %g = %12.18lf", a, b, mean);
+  mean_n = N_calc_quad_mean_n(v, 2);
+  G_message("N_calc_quad_mean_n: calc a %g and b %g = %12.18lf", v[0], v[1], mean_n);
+  	sum++;
-    mean = N_calc_quad_mean(a, b);
-    G_message("N_calc_quad_mean: calc a %g and b %g = %12.18lf", a, b, mean);
-    mean_n = N_calc_quad_mean_n(v, 2);
-    G_message("N_calc_quad_mean_n: calc a %g and b %g = %12.18lf", v[0], v[1],
-	      mean_n);
-	sum++;
+  /*Test the full upwind stabailization*/
+  vector= -0.000001;
+  distance = 20;
+  D = 0.000001;
-    /*Test the full upwind stabailization */
-    vector = -0.000001;
-    distance = 20;
-    D = 0.000001;
+  weight = N_full_upwinding(vector, distance, D);
+  G_message("N_full_upwinding: vector %g distance %g D %g weight %g\n", vector, distance, D, weight);
-    weight = N_full_upwinding(vector, distance, D);
-    G_message("N_full_upwinding: vector %g distance %g D %g weight %g\n",
-	      vector, distance, D, weight);
-    if (weight != 0) {
+  if(weight != 0)
 	G_warning("Error detected in N_full_upwinding");
 	sum++;
-    vector = 0.000001;
+  vector= 0.000001;
-    if (weight != 1) {
+  if(weight != 1)
 	sum++;
-    D = 0.0;
+  D = 0.0;
-    if (weight != 0.5) {
+  if(weight != 0.5)
 	sum++;
-    /*Test the exponential upwind stabailization */
-    distance = 20;
-    D = 0.000001;
+  /*Test the exponential upwind stabailization*/
+  distance = 20;
+  D = 0.000001;
-    weight = N_exp_upwinding(vector, distance, D);
-    G_message("N_exp_upwinding: vector %g distance %g D %g weight %g\n",
-    sprintf(buff1, "%1.2lf", weight);
-    sscanf(buff1, "%lf", &weight);
+  weight = N_exp_upwinding(vector, distance, D);
+  G_message("N_exp_upwinding: vector %g distance %g D %g weight %g\n", vector, distance, D, weight);
+  sprintf(buff1, "%1.2lf", weight);
+  sscanf(buff1, "%lf", &weight);
-    if (weight != 0.05) {
+  if(weight != 0.05)
 	G_warning("Error detected in N_exp_upwinding");
 	sum++;
+  vector= 0.000001;
-    if (weight != 0.95) {
+  if(weight != 0.95)
 	sum++;
-    D = 0.0;
+  D = 0.0;
+  if(weight != 0.5)
 	sum++;
-    return sum;
+  return sum;
