[GRASS-SVN] r38898 - in grass/branches/develbranch_6: lib/form vector/v.digit
Fri Aug 28 05:00:23 EDT 2009
Author: marisn
Date: 2009-08-28 05:00:23 -0400 (Fri, 28 Aug 2009)
New Revision: 38898
   grass/branches/develbranch_6/lib/form/form.tcl
   grass/branches/develbranch_6/lib/form/open.c
   grass/branches/develbranch_6/vector/v.digit/generate.c
Fix v.digit attribute entry if db path contains spaces
Modified: grass/branches/develbranch_6/lib/form/form.tcl
--- grass/branches/develbranch_6/lib/form/form.tcl	2009-08-28 07:16:52 UTC (rev 38897)
+++ grass/branches/develbranch_6/lib/form/form.tcl	2009-08-28 09:00:23 UTC (rev 38898)
@@ -1,9 +1,9 @@
-lappend auto_path $env(GISBASE)/bwidget
+lappend auto_path "$env(GISBASE)/bwidget"
 package require -exact BWidget 1.2.1
 #package require http
-set formpath $env(GISBASE)/etc/form
-source $formpath/html_library.tcl
+set formpath [file normalize "$env(GISBASE)/etc/form"]
+source "$formpath/html_library.tcl"
 proc create_submit_msg { formid  }  {
     global submit_result submit_msg formf
Modified: grass/branches/develbranch_6/lib/form/open.c
--- grass/branches/develbranch_6/lib/form/open.c	2009-08-28 07:16:52 UTC (rev 38897)
+++ grass/branches/develbranch_6/lib/form/open.c	2009-08-28 09:00:23 UTC (rev 38898)
@@ -107,9 +107,9 @@
-	sprintf(command, "%s/etc/form/form", G_gisbase());
-	sprintf(script, "%s/etc/form/form.tcl", G_gisbase());
+	sprintf(command, "\"%s/etc/form/form\"", G_gisbase());
+	sprintf(script, "\"%s/etc/form/form.tcl\"", G_gisbase());
+G_message("FC: %s form -f %s", command, script);
 	execl(command, "form", "-f", script, NULL);
 	G_debug(2, "CHILD END\n");
Modified: grass/branches/develbranch_6/vector/v.digit/generate.c
--- grass/branches/develbranch_6/vector/v.digit/generate.c	2009-08-28 07:16:52 UTC (rev 38897)
+++ grass/branches/develbranch_6/vector/v.digit/generate.c	2009-08-28 09:00:23 UTC (rev 38898)
@@ -4,6 +4,34 @@
 #include <grass/dbmi.h>
 #include <grass/form.h>
+/* I was unable to find standard strrep function. */
+char *strrep(char *from, char *to, char symbol) {
+	int i = 0, j = 0, size;
+	size = sizeof(from)*strlen(from)+1;
+	to = (char *)malloc(size);
+	if (!to) {
+		return NULL;
+	while (from[i]) {
+		if (from[i]==symbol) {
+			size++;
+			to = realloc(to, size);
+			if (!to)
+				return NULL;
+			to[j] = '\\';
+			j++;
+		to[j] = from[i];
+		i++;
+		j++;
+	to[j]='\0';
+	return to;
 /* Generate form in HTML/TXT format.
  *  Pointer to resulting string is stored to 'form'. This string must be freed by application.
@@ -17,6 +45,7 @@
     int col, ncols, ctype, sqltype, more;
     char buf[5000], buf1[100];
+    char *escstr;
     const char *colname;
     dbString sql, html, str;
     dbDriver *driver;
@@ -133,8 +162,14 @@
 		/* Note: because html_library.tcl failes to parse
 		 *  <INPUT name=abc value='dbname=xxx'> and returnes
 		 *  name="xxx" value="dbname=xxx" order of value and name parameters is changed */
+		/* Note: TCL will process \$[] chars in dbname (path) and thus we need to escape them.
+		 *  As {} chars are converted by html_library.tcl to HTML entities, it's no use to escape them.*/
+		escstr = strrep(dbname,escstr,'\\');
+		escstr = strrep(escstr,escstr,'$');
+		escstr = strrep(escstr,escstr,'[');
+		escstr = strrep(escstr,escstr,']');
 		sprintf(buf, "<INPUT type=hidden value=\"%s\" name=%s>",
-			dbname, F_DATABASE_FNAME);
+			escstr, F_DATABASE_FNAME);
 		db_append_string(&html, buf);
 		sprintf(buf, "<INPUT type=hidden name=%s value=\"%s\">",
 			F_TABLE_FNAME, tblname);
@@ -238,7 +273,6 @@
     G_debug(2, "FORM STRING:\n%s\n", db_get_string(&html));
     db_close_cursor(&cursor);
     db_close_database(driver);
     db_shutdown_driver(driver);
