[GRASS-SVN] r38903 - grass/trunk/tools
svn_grass at osgeo.org
Fri Aug 28 12:11:29 EDT 2009
Author: glynn
Date: 2009-08-28 12:11:29 -0400 (Fri, 28 Aug 2009)
New Revision: 38903
grass/trunk/tools/sql.sh
Enlarge symbol fields
Modified: grass/trunk/tools/sql.sh
--- grass/trunk/tools/sql.sh 2009-08-28 13:46:51 UTC (rev 38902)
+++ grass/trunk/tools/sql.sh 2009-08-28 16:11:29 UTC (rev 38903)
@@ -287,21 +287,21 @@
CREATE TABLE stlib_exp (
library VARCHAR(80) NOT NULL,
object VARCHAR(40) NOT NULL,
- symbol VARCHAR(150) NOT NULL
+ symbol VARCHAR(256) NOT NULL
\copy stlib_exp FROM '$tmpdir/stlib_exp.lst'
CREATE TABLE shlib_exp (
\copy shlib_exp FROM '$tmpdir/shlib_exp.lst'
CREATE TABLE obj_exp (
object VARCHAR(100) NOT NULL,
- symbol VARCHAR(200) NOT NULL
\copy obj_exp FROM '$tmpdir/obj_exp.lst'
@@ -309,42 +309,42 @@
CREATE TABLE stlib_imp (
\copy stlib_imp FROM '$tmpdir/stlib_imp.lst'
CREATE TABLE shlib_imp (
\copy shlib_imp FROM '$tmpdir/shlib_imp.lst'
CREATE TABLE obj_imp (
\copy obj_imp FROM '$tmpdir/obj_imp.lst'
CREATE TABLE prog_imp (
program VARCHAR(80) NOT NULL,
\copy prog_imp FROM '$tmpdir/prog_imp.lst'
CREATE TABLE prog_exp (
- symbol VARCHAR(180) NOT NULL
\copy prog_exp FROM '$tmpdir/prog_exp.lst'
CREATE TABLE libs (
- symbol VARCHAR(160) NOT NULL
\copy libs FROM '$tmpdir/libs.lst'
@@ -358,7 +358,7 @@
\copy ldd FROM '$tmpdir/ldd.lst'
CREATE TABLE ansi (
\copy ansi FROM '$tmpdir/ansi.lst'
