[GRASS-SVN] r38917 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Aug 30 13:31:07 EDT 2009
Author: martinl
Date: 2009-08-30 13:31:07 -0400 (Sun, 30 Aug 2009)
New Revision: 38917
grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py
wxGUI: sqlbuilder clean up (part 2)
Modified: grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py
--- grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py 2009-08-29 16:33:39 UTC (rev 38916)
+++ grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py 2009-08-30 17:31:07 UTC (rev 38917)
@@ -79,6 +79,10 @@
self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
+ # statusbar
+ self.statusbar = self.CreateStatusBar(number=1)
+ self.statusbar.SetStatusText(_("SQL statement not verified"), 0)
# buttons
@@ -96,26 +100,27 @@
self.btn_uniquesample = wx.Button(parent = self.panel, id = wx.ID_ANY,
label = _("Get sample"))
self.btn_uniquesample.Enable(False)
- self.btn_is = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "=")
- self.btn_isnot = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "!=")
- self.btn_like = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "LIKE")
- self.btn_gt = wx.Button(parent = self.panel, id = wx.ID_ANY, label = ">")
- self.btn_gtis = wx.Button(parent = self.panel, id = wx.ID_ANY, label = ">=")
- self.btn_lt = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "<")
- self.btn_ltis = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "<=")
- self.btn_or = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "OR")
- self.btn_not = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "NOT")
- self.btn_and = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "AND")
- self.btn_brackets = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "()")
- self.btn_prc = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "%")
- # Text labels
- # self.label_headding = wx.StaticText(self.panel, -1, '')
+ self.btn_lv = { 'is' : ['=', ],
+ 'isnot' : ['!=', ],
+ 'like' : ['LIKE', ],
+ 'gt' : ['>', ],
+ 'ge' : ['>=', ],
+ 'lt' : ['<', ],
+ 'le' : ['<=', ],
+ 'or' : ['OR', ],
+ 'not' : ['NOT', ],
+ 'and' : ['AND', ],
+ 'brac' : ['()', ],
+ 'prc' : ['%', ] }
+ for key, value in self.btn_lv.iteritems():
+ btn = wx.Button(parent = self.panel, id = wx.ID_ANY,
+ label = value[0])
+ self.btn_lv[key].append(btn.GetId())
- # Textareas
+ # text areas
self.text_sql = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY,
value = '', size = (-1, 75),
@@ -124,7 +129,7 @@
self.text_sql.SetValue("SELECT * FROM %s" % self.tablename)
- # List Boxes
+ # list boxes (columns, values)
self.list_columns = wx.ListBox(parent = self.panel, id = wx.ID_ANY,
choices = self.dbInfo.GetColumns(self.tablename),
@@ -133,33 +138,32 @@
choices = self.colvalues,
style = wx.LB_MULTIPLE)
+ self.radio_cv = wx.RadioBox(parent = self.panel, id = wx.ID_ANY,
+ label = " %s " % _("Add on double-click"),
+ choices = [_("columns"), _("values")])
+ self.radio_cv.SetSelection(1) # default 'values'
- # Bindings
+ # bindings
- self.btn_unique.Bind(wx.EVT_BUTTON, self.GetUniqueValues)
- self.btn_uniquesample.Bind(wx.EVT_BUTTON, self.GetSampleValues)
- self.btn_is.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_isnot.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_like.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_gt.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_gtis.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_or.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_lt.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_ltis.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_not.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_brackets.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_prc.Bind(wx.EVT_BUTTON, self.AddMark)
- self.btn_and.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_unique.Bind(wx.EVT_BUTTON, self.OnUniqueValues)
+ self.btn_uniquesample.Bind(wx.EVT_BUTTON, self.OnSampleValues)
+ self.FindWindowById(value[1]).Bind(wx.EVT_BUTTON, self.OnAddMark)
self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
self.btn_clear.Bind(wx.EVT_BUTTON, self.OnClear)
self.btn_verify.Bind(wx.EVT_BUTTON, self.OnVerify)
self.btn_apply.Bind(wx.EVT_BUTTON, self.OnApply)
- self.list_columns.Bind(wx.EVT_LISTBOX, self.AddColumnName)
- self.list_values.Bind(wx.EVT_LISTBOX, self.AddValue)
+ self.list_columns.Bind(wx.EVT_LISTBOX, self.OnAddColumn)
+ self.list_values.Bind(wx.EVT_LISTBOX, self.OnAddValue)
self.text_sql.Bind(wx.EVT_TEXT, self.OnText)
+ self.Bind(wx.EVT_CLOSE, self.OnClose)
self.__doLayout()
def __doLayout(self):
@@ -193,27 +197,31 @@
buttonsizer.Add(item = self.btn_close)
buttonsizer2 = wx.GridBagSizer(5, 5)
- buttonsizer2.Add(item = self.btn_is, pos = (0,0))
- buttonsizer2.Add(item = self.btn_isnot, pos = (1,0))
- buttonsizer2.Add(item = self.btn_like, pos = (2, 0))
+ buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['is'][1]), pos = (0,0))
+ buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['isnot'][1]), pos = (1,0))
+ buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['like'][1]), pos = (2, 0))
- buttonsizer2.Add(item = self.btn_gt, pos = (0, 1))
- buttonsizer2.Add(item = self.btn_gtis, pos = (1, 1))
- buttonsizer2.Add(item = self.btn_or, pos = (2, 1))
+ buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['gt'][1]), pos = (0, 1))
+ buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['ge'][1]), pos = (1, 1))
+ buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['or'][1]), pos = (2, 1))
- buttonsizer2.Add(item = self.btn_lt, pos = (0, 2))
- buttonsizer2.Add(item = self.btn_ltis, pos = (1, 2))
- buttonsizer2.Add(item = self.btn_not, pos = (2, 2))
+ buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['lt'][1]), pos = (0, 2))
+ buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['le'][1]), pos = (1, 2))
+ buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['not'][1]), pos = (2, 2))
- buttonsizer2.Add(item = self.btn_brackets, pos = (0, 3))
- buttonsizer2.Add(item = self.btn_prc, pos = (1, 3))
- buttonsizer2.Add(item = self.btn_and, pos = (2, 3))
+ buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['brac'][1]), pos = (0, 3))
+ buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['prc'][1]), pos = (1, 3))
+ buttonsizer2.Add(item = self.FindWindowById(self.btn_lv['and'][1]), pos = (2, 3))
- buttonsizer4 = wx.BoxSizer(wx.HORIZONTAL)
- buttonsizer4.Add(item = self.btn_uniquesample, proportion = 0,
+ buttonsizer3 = wx.BoxSizer(wx.HORIZONTAL)
+ buttonsizer3.Add(item = self.btn_uniquesample, proportion = 0,
flag = wx.ALIGN_CENTER_HORIZONTAL | wx.RIGHT, border = 5)
- buttonsizer4.Add(item = self.btn_unique, proportion = 0,
+ buttonsizer3.Add(item = self.btn_unique, proportion = 0,
flag = wx.ALIGN_CENTER_HORIZONTAL)
+ radiosizer = wx.BoxSizer(wx.HORIZONTAL)
+ radiosizer.Add(item = self.radio_cv, proportion = 1,
+ flag = wx.ALIGN_CENTER_HORIZONTAL | wx.EXPAND, border = 5)
hsizer = wx.BoxSizer(wx.HORIZONTAL)
@@ -226,11 +234,13 @@
valuesizer = wx.StaticBoxSizer(valuesbox, wx.VERTICAL)
columnsizer.Add(item = self.list_columns, proportion = 1,
flag = wx.EXPAND)
+ columnsizer.Add(item = radiosizer, proportion = 0,
+ flag = wx.TOP | wx.EXPAND, border = 5)
valuesizer.Add(item = self.list_values, proportion = 1,
flag = wx.EXPAND)
# self.list_columns.SetMinSize((-1,130))
# self.list_values.SetMinSize((-1,100))
- valuesizer.Add(item = buttonsizer4, proportion = 0,
+ valuesizer.Add(item = buttonsizer3, proportion = 0,
flag = wx.TOP, border = 5)
hsizer.Add(item = columnsizer, proportion = 1,
flag = wx.EXPAND)
@@ -255,9 +265,9 @@
pagesizer.Fit(self.panel)
self.Layout()
- self.SetMinSize((660, 480))
+ self.SetMinSize((660, 525))
- def GetUniqueValues(self, event, justsample = False):
+ def OnUniqueValues(self, event, justsample = False):
"""!Get unique values"""
vals = []
try:
@@ -269,27 +279,26 @@
self.list_values.Clear()
- i = 0
querystring = "SELECT %s FROM %s" % (column, self.tablename)
data = grass.db_select(table = self.tablename,
sql = querystring,
database = self.database,
driver = self.driver)
+ i = 0
for line in data:
if justsample and i < 256 or \
not justsample:
self.list_values.Append(line.strip())
else:
break
- i += 1
- def GetSampleValues(self, event):
+ i += 0
+ def OnSampleValues(self, event):
"""!Get sample values"""
- self.GetUniqueValues(None, True)
+ self.OnUniqueValues(None, True)
- def AddColumnName(self, event):
+ def OnAddColumn(self, event):
"""!Add column name to the query"""
idx = self.list_columns.GetSelections()
for i in idx:
@@ -297,74 +306,70 @@
self.__Add(element = 'column', value = column)
if not self.btn_uniquesample.IsEnabled():
- self.btn_uniquesample.Enable()
- self.btn_unique.Enable()
+ self.btn_uniquesample.Enable(True)
+ self.btn_unique.Enable(True)
- def AddValue(self,event):
+ def OnAddValue(self, event):
"""!Add value"""
idx = self.list_values.GetSelections()[0]
value = self.list_values.GetString(idx)
idx = self.list_columns.GetSelections()[0]
column = self.list_columns.GetString(idx)
- if self.columns[column]['type'].lower().find("chara") > -1:
+ ctype = self.dbInfo.GetTableDesc(self.dbInfo.GetTable(self.layer))[column]['type']
+ if ctype == 'character':
value = "'%s'" % value
- self.__Add(value)
+ self.__Add(element = 'value', value = value)
- def AddMark(self,event):
+ def OnAddMark(self, event):
"""!Add mark"""
- if event.GetId() == self.btn_is.GetId():
- mark = "="
- elif event.GetId() == self.btn_isnot.GetId():
- mark = "!="
- elif event.GetId() == self.btn_like.GetId():
- mark = "LIKE"
- elif event.GetId() == self.btn_gt.GetId():
- mark = ">"
- elif event.GetId() == self.btn_gtis.GetId():
- mark = ">="
- elif event.GetId() == self.btn_lt.GetId():
- mark = "<"
- elif event.GetId() == self.btn_ltis.GetId():
- mark = "<="
- elif event.GetId() == self.btn_or.GetId():
- mark = "OR"
- elif event.GetId() == self.btn_not.GetId():
- mark = "NOT"
- elif event.GetId() == self.btn_and.GetId():
- mark = "AND"
- elif event.GetId() == self.btn_brackets.GetId():
- mark = "()"
- elif event.GetId() == self.btn_prc.GetId():
- mark = "%"
- self.__Add(mark)
+ mark = None
+ if event.GetId() == value[1]:
+ mark = value[0]
+ break
+ self.__Add(element = 'mark', value = mark)
def __Add(self, element, value):
"""!Add element to the query
- @param what what to add
+ @param element element to add (column, value)
sqlstr = self.text_sql.GetValue()
newsqlstr = ''
if element == 'column':
- idx1 = len('select')
- idx2 = sqlstr.lower().find('from')
- colstr = sqlstr[idx1:idx2].strip()
- if colstr == '*':
- cols = []
- else:
- cols = colstr.split(',')
- if value in cols:
- cols.remove(value)
- else:
- cols.append(value)
- if len(cols) < 1:
- cols = ['*',]
- newsqlstr = 'SELECT ' + ','.join(cols) + ' ' + sqlstr[idx2:]
+ if self.radio_cv.GetSelection() == 0: # -> column
+ idx1 = len('select')
+ idx2 = sqlstr.lower().find('from')
+ colstr = sqlstr[idx1:idx2].strip()
+ if colstr == '*':
+ cols = []
+ else:
+ cols = colstr.split(',')
+ if value in cols:
+ cols.remove(value)
+ else:
+ cols.append(value)
+ if len(cols) < 1:
+ cols = ['*',]
+ newsqlstr = 'SELECT ' + ','.join(cols) + ' ' + sqlstr[idx2:]
+ else: # -> where
+ newsqlstr = sqlstr
+ if sqlstr.lower().find('where') < 0:
+ newsqlstr += ' WHERE'
+ newsqlstr += ' ' + value
+ elif element == 'value':
+ newsqlstr = sqlstr + ' ' + value
+ elif element == 'mark':
if newsqlstr:
self.text_sql.SetValue(newsqlstr)
@@ -394,10 +399,13 @@
database = self.database)
if ret != 0 and msg:
+ self.statusbar.SetStatusText(_("SQL statement is not valid"), 0)
wx.MessageBox(parent=self,
message=_("SQL statement is not valid.\n\n%s") % msg,
caption=_("Warning"), style=wx.OK | wx.ICON_WARNING | wx.CENTRE)
+ else:
+ self.statusbar.SetStatusText(_("SQL statement is valid"), 0)
def OnClear(self, event):
"""!Clear button pressed"""
if self.qtype.lower() == "select":
@@ -409,6 +417,8 @@
"""!Close button pressed"""
self.Destroy()
+ event.Skip()
if __name__ == "__main__":
if len(sys.argv) != 2:
print >>sys.stderr, __doc__
