[GRASS-SVN] r38921 - grass/trunk/gui/wxpython/gui_modules
Sun Aug 30 14:49:45 EDT 2009
Author: martinl
Date: 2009-08-30 14:49:45 -0400 (Sun, 30 Aug 2009)
New Revision: 38921
   grass/trunk/gui/wxpython/gui_modules/dbm.py
   grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py
wxGUI: sqlbuilder clean up (part 3)
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py	2009-08-30 18:48:51 UTC (rev 38920)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py	2009-08-30 18:49:45 UTC (rev 38921)
@@ -478,6 +478,9 @@
         # -> layers / tables description
         self.mapDBInfo = dbm_base.VectorDBInfo(self.vectorName)
+        # sqlbuilder
+        self.builder = None
         if len(self.mapDBInfo.layers.keys()) == 0:
             wx.MessageBox(parent=self.parent,
                           message=_("Database connection for vector map <%s> "
@@ -1862,16 +1865,28 @@
         event.Skip()
     def OnBuilder(self,event):
-        """!SQL Builder button pressed"""
-        self.builder = sqlbuilder.SQLFrame(parent=self, id=wx.ID_ANY,
-                                           title=_("SQL Builder"),
-                                           vectmap=self.vectorName)
+        """!SQL Builder button pressed -> show the SQLBuilder dialog"""
+        if not self.builder:
+            self.builder = sqlbuilder.SQLFrame(parent = self, id = wx.ID_ANY,
+                                               title = _("SQL Builder"),
+                                               vectmap = self.vectorName,
+                                               evtheader = self.OnBuilderEvt)
+            self.builder.Show()
+        else:
+            self.builder.Raise()
+    def OnBuilderEvt(self, event):
+        if event == 'apply':
+            sqlstr = self.builder.GetSQLStatement()
+            self.FindWindowById(self.layerPage[self.layer]['statement']).SetValue(sqlstr)
+            if self.builder.CloseOnApply():
+        elif event == 'close':
     def OnTextEnter(self, event):
         pass
-    def OnSQLBuilder(self, event):
-        pass
     def OnDataItemActivated(self, event):
         """!Item activated, highlight selected item"""
         self.OnDataDrawSelected(event)
Modified: grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py
--- grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py	2009-08-30 18:48:51 UTC (rev 38920)
+++ grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py	2009-08-30 18:49:45 UTC (rev 38921)
@@ -47,7 +47,7 @@
 class SQLFrame(wx.Frame):
     """!SQL Frame class"""
     def __init__(self, parent, title, vectmap, id = wx.ID_ANY,
-                 layer = 1, qtype = "select"):
+                 layer = 1, qtype = "select", evtheader = None):
         wx.Frame.__init__(self, parent, id, title)
@@ -55,6 +55,7 @@
                              wx.BITMAP_TYPE_ICO))
         self.parent = parent
+        self.evtHeader = evtheader
         # variables
@@ -70,7 +71,7 @@
         self.tablename = self.dbInfo.GetTable(self.layer)
         self.driver, self.database = self.dbInfo.GetDbSettings(self.layer)
-        self.qtype = qtype      # type of the uqery: SELECT, UPDATE, DELETE, ...
+        self.qtype = qtype      # type of query: SELECT, UPDATE, DELETE, ...
         self.colvalues = []     # array with unique values in selected column
         # set dialog title
@@ -87,13 +88,17 @@
         # buttons
         self.btn_clear  = wx.Button(parent = self.panel, id = wx.ID_CLEAR)
+        self.btn_clear.SetToolTipString(_("Set SQL statement to default"))
         self.btn_verify = wx.Button(parent = self.panel, id = wx.ID_ANY,
                                     label = _("Verify"))
+        self.btn_verify.SetToolTipString(_("Verify SQL statement"))
         # self.btn_help = wx.Button(self.panel, -1, "Help")
         # self.btn_load = wx.Button(self.panel, -1, "Load")
         # self.btn_save = wx.Button(self.panel, -1, "Save")
         self.btn_apply  = wx.Button(parent = self.panel, id = wx.ID_APPLY)
+        self.btn_apply.SetToolTipString(_("Apply SQL statement and close the dialog"))
         self.btn_close  = wx.Button(parent = self.panel, id = wx.ID_CLOSE)
+        self.btn_close.SetToolTipString(_("Close the dialog"))
         self.btn_unique = wx.Button(parent = self.panel, id = wx.ID_ANY,
                                     label = _("Get all values"))
         self.btn_unique.Enable(False)
@@ -127,7 +132,9 @@
                                     style=wx.TE_MULTILINE)
         if self.qtype.lower() == "select":
             self.text_sql.SetValue("SELECT * FROM %s" % self.tablename)
+        self.text_sql.SetInsertionPointEnd()
+        wx.CallAfter(self.text_sql.SetFocus)
         # list boxes (columns, values)
@@ -142,6 +149,10 @@
                                     label = " %s " % _("Add on double-click"),
                                     choices = [_("columns"), _("values")])
         self.radio_cv.SetSelection(1) # default 'values'
+        self.close_onapply = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
+                                         label = _("Close dialog on apply"))
+        self.close_onapply.SetValue(True)
         # bindings
@@ -259,6 +270,8 @@
                       flag = wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border = 5)
         pagesizer.Add(item = buttonsizer, proportion = 0,
                       flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
+        pagesizer.Add(item = self.close_onapply, proportion = 0,
+                      flag = wx.LEFT | wx.RIGHT | wx.BOTTOM, border = 5)
         self.panel.SetAutoLayout(True)
         self.panel.SetSizer(pagesizer)
@@ -372,7 +385,15 @@
         if newsqlstr:
             self.text_sql.SetValue(newsqlstr)
+    def GetSQLStatement(self):
+        """!Return SQL statement"""
+        return self.text_sql.GetValue().strip().replace("\n"," ")
+    def CloseOnApply(self):
+        """!Return True if the dialog will be close on apply"""
+        return self.close_onapply.IsChecked()
     def OnText(self, event):
         """Query string changed"""
         if len(self.text_sql.GetValue()) > 0:
@@ -382,12 +403,14 @@
     def OnApply(self, event):
         """Apply button pressed"""
-        if self.parent:
-            try:
-                self.parent.text_query.SetValue= self.text_sql.GetValue().strip().replace("\n"," ")
-            except:
-                pass
+        if self.evtHeader:
+            self.evtHeader(event = 'apply')
+        if self.close_onapply.IsChecked():
+            self.Destroy()
+        event.Skip()
     def OnVerify(self, event):
         """!Verify button pressed"""
         ret, msg = gcmd.RunCommand('db.select',
@@ -415,6 +438,8 @@
     def OnClose(self, event):
         """!Close button pressed"""
+            self.evtHeader(event = 'close')
         self.Destroy()
         event.Skip()
