[GRASS-SVN] r38930 - in grass/branches/develbranch_6/gui/wxpython:
	gui_modules vdigit
    svn_grass at osgeo.org
    Mon Aug 31 03:58:06 EDT 2009
Author: martinl
Date: 2009-08-31 03:58:06 -0400 (Mon, 31 Aug 2009)
New Revision: 38930
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
   grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp
   grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h
wxGUI: ZBulk-labeling fixed (trac #737)
       (merge from relbr64, r38929)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py	2009-08-31 07:37:05 UTC (rev 38929)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py	2009-08-31 07:58:06 UTC (rev 38930)
@@ -1428,7 +1428,7 @@
             end   = self.Pixel2Cell(self.polycoords[-1])
             begin = self.Pixel2Cell(self.mouse['begin'])
-            self.DrawLines(self.pdcTmp, begin, end)
+            self.DrawLines(self.pdcTmp, polycoords = (begin, end))
     def OnLeftDown(self, event):
@@ -2143,8 +2143,8 @@
                 dlg = VDigitZBulkDialog(parent=self, title=_("Z bulk-labeling dialog"),
                                         nselected=len(selected))
                 if dlg.ShowModal() == wx.ID_OK:
-                    if digitClass.ZBulkLine(pos1, pos2, dlg.value.GetValue(),
-                                            dlg.step.GetValue()) < 0:
+                    if digitClass.ZBulkLines(pos1, pos2, dlg.value.GetValue(),
+                                             dlg.step.GetValue()) < 0:
                         return
                 self.UpdateMap(render=False, renderVector=True)
             elif digitToolbar.GetAction() == "typeConv":
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2009-08-31 07:37:05 UTC (rev 38929)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2009-08-31 07:58:06 UTC (rev 38930)
@@ -1008,6 +1008,12 @@
     def OnZBulk(self, event):
         """!Z bulk-labeling selected lines/boundaries"""
+        if not self.parent.digit.driver.Is3D():
+            wx.MessageBox(parent=self.parent,
+                          message=_("Vector map is not 3D. Operation canceled."),
+                          caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+            return
         if self.action['desc'] == 'zbulkLine': # select previous action
             self.toolbar[0].ToggleTool(self.addPoint, True)
             self.toolbar[0].ToggleTool(self.additionalTools, False)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py	2009-08-31 07:37:05 UTC (rev 38929)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py	2009-08-31 07:58:06 UTC (rev 38930)
@@ -711,6 +711,25 @@
                                   UserSettings.Get(group='vdigit', key='catBoundary',
                                                    subkey='enabled'))
+    def ZBulkLines(self, pos1, pos2, start, step):
+        """!Z-bulk labeling
+        @param pos1 reference line (start point)
+        @param pos1 reference line (end point)
+        @param start starting value
+        @param step step value
+        @return number of modified lines
+        @return -1 on error
+        ret = self.digit.ZBulkLabeling(pos1[0], pos1[1], pos2[0], pos2[1],
+                                       start, step)
+        if ret > 0:
+            self.toolbar.EnableUndo()
+        return ret
     def __getSnapThreshold(self):
         """!Get snap mode and threshold value
@@ -1018,6 +1037,13 @@
         return self.__display.GetMapBoundingBox()
+    def Is3D(self):
+        """!Check if open vector map is 3D
+        @return True if 3D
+        @return False if not 3D"""
+        return self.__display.Is3D()
     def DrawSelected(self, draw=True):
         """!Show/hide selected features"""
         self.__display.DrawSelected(draw)
@@ -2463,7 +2489,7 @@
         flexSizer.Add(self.step, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
         sizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=1)
-        border.Add(item=sizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
+        border.Add(item=sizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=0)
         # buttons
         btnCancel = wx.Button(self, wx.ID_CANCEL)
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp	2009-08-31 07:37:05 UTC (rev 38929)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp	2009-08-31 07:58:06 UTC (rev 38930)
@@ -617,3 +617,13 @@
     return 0;
+   \brief Check if vector map is 3D
+   \return True for 3D otherwise False
+bool DisplayDriver::Is3D()
+    return (bool) Vect_is_3d(mapInfo);
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h	2009-08-31 07:37:05 UTC (rev 38929)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h	2009-08-31 07:58:06 UTC (rev 38930)
@@ -206,6 +206,7 @@
     /* misc */
     std::vector<double> GetMapBoundingBox();
+    bool Is3D();
     /* set */
     void SetRegion(double, double, double, double,
