[GRASS-SVN] r39891 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Dec 4 04:04:50 EST 2009
Author: hcho
Date: 2009-12-04 04:04:45 -0500 (Fri, 04 Dec 2009)
New Revision: 39891
grass/trunk/gui/wxpython/gui_modules/mapdisp_command.py
grass/trunk/gui/wxpython/gui_modules/render.py
Imported debug as Debug.
Removed item= parameters (not valid anymore) from AddLayer.
Fixed a bug in command file reading.
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_command.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_command.py 2009-12-04 07:30:47 UTC (rev 39890)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_command.py 2009-12-04 09:04:45 UTC (rev 39891)
@@ -17,6 +17,7 @@
import sys
import time
+from debug import Debug
from threading import Thread
class Command(Thread):
@@ -48,10 +49,21 @@
try:
Debug.msg (3, "Command.run(): cmd=%s" % (line))
- self.map.AddLayer(item=None, type="raster",
+ cmd = line.split(" ")
+ opacity = 1
+ if " opacity=" in line:
+ cmd2 = cmd
+ cmd = []
+ for c in cmd2:
+ if c.find("opacity=") == 0:
+ opacity = float(c.split("=")[1]) / 100
+ else:
+ cmd.append(c)
+ self.map.AddLayer(type="raster",
name='',
- command=line,
- l_opacity=1)
+ command=cmd,
+ l_opacity=opacity)
self.parent.redraw =True
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2009-12-04 07:30:47 UTC (rev 39890)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2009-12-04 09:04:45 UTC (rev 39891)
@@ -1335,14 +1335,12 @@
map.width = 640
map.height = 480
- map.AddLayer(item=None,
- type="raster",
+ map.AddLayer(type="raster",
name="elevation.dem",
command = ["d.rast", "elevation.dem at PERMANENT", "catlist=1000-1500", "-i"],
l_opacity=.7)
- type="vector",
+ map.AddLayer(type="vector",
name="streams",
command = ["d.vect", "streams at PERMANENT", "color=red", "width=3", "type=line"])
