[GRASS-SVN] r39918 - grass/trunk/gui/wxpython/support
svn_grass at osgeo.org
Sun Dec 6 06:24:34 EST 2009
Author: martinl
Date: 2009-12-06 06:24:34 -0500 (Sun, 06 Dec 2009)
New Revision: 39918
grass/trunk/gui/wxpython/support/update_menudata.py
print error message when menudata.xml is not found
Modified: grass/trunk/gui/wxpython/support/update_menudata.py
--- grass/trunk/gui/wxpython/support/update_menudata.py 2009-12-06 11:18:58 UTC (rev 39917)
+++ grass/trunk/gui/wxpython/support/update_menudata.py 2009-12-06 11:24:34 UTC (rev 39918)
@@ -103,11 +103,13 @@
def writeData(data):
"""!Write updated menudata.xml"""
- file = os.path.join('..', 'xml', 'menudata.xml')
+ file = os.path.join('xml', 'menudata.xml')
try:
+ if not os.path.exists(file):
+ raise IOError
data.tree.write(file)
except IOError:
- print >> sys.stderr, "'menudata.xml' not found. Please run the script from 'gui/wxpython/support'."
+ print >> sys.stderr, "'%s' not found. Please run the script from 'gui/wxpython'." % file
def main(argv = None):
