[GRASS-SVN] r39972 -
grass/branches/releasebranch_6_4/vector/v.in.ogr
svn_grass at osgeo.org
Fri Dec 11 04:25:17 EST 2009
Author: mmetz
Date: 2009-12-11 04:25:16 -0500 (Fri, 11 Dec 2009)
New Revision: 39972
grass/branches/releasebranch_6_4/vector/v.in.ogr/description.html
updated manual
Modified: grass/branches/releasebranch_6_4/vector/v.in.ogr/description.html
--- grass/branches/releasebranch_6_4/vector/v.in.ogr/description.html 2009-12-11 00:04:19 UTC (rev 39971)
+++ grass/branches/releasebranch_6_4/vector/v.in.ogr/description.html 2009-12-11 09:25:16 UTC (rev 39972)
@@ -7,7 +7,9 @@
install GDAL to use <em>v.in.ogr</em>.
<P>
If the <b>layer</b> parameter is not given, all available layers
-are imported.
+are imported as separate GRASS layers into one GRASS vector map. If
+several OGR layer names are given, all these layers are imported as
+separate GRASS layers into one GRASS vector map.
<P>
The optional <b>spatial</b> parameter defines spatial query extents.
This parameter allows the user to restrict the region to a spatial subset
