[GRASS-SVN] r39980 - grass/trunk/raster/r.watershed/ram
Fri Dec 11 13:36:10 EST 2009
Author: mmetz
Date: 2009-12-11 13:36:10 -0500 (Fri, 11 Dec 2009)
New Revision: 39980
   grass/trunk/raster/r.watershed/ram/Gwater.h
   grass/trunk/raster/r.watershed/ram/close_maps2.c
   grass/trunk/raster/r.watershed/ram/do_astar.c
   grass/trunk/raster/r.watershed/ram/find_pour.c
   grass/trunk/raster/r.watershed/ram/main.c
   grass/trunk/raster/r.watershed/ram/no_stream.c
   grass/trunk/raster/r.watershed/ram/over_cells.c
speed up A* Search, fix half basin bug
Modified: grass/trunk/raster/r.watershed/ram/Gwater.h
--- grass/trunk/raster/r.watershed/ram/Gwater.h	2009-12-11 12:27:30 UTC (rev 39979)
+++ grass/trunk/raster/r.watershed/ram/Gwater.h	2009-12-11 18:36:10 UTC (rev 39980)
@@ -39,6 +39,11 @@
     /* int nxt; */
+#define OC_STACK struct overland_cells_stack
+OC_STACK {
+    int row, col;
 extern struct Cell_head window;
 extern int mfd, c_fac, abs_acc, ele_scale;
@@ -47,6 +52,9 @@
 extern SHORT nrows, ncols;
 extern double half_res, diag, max_length, dep_slope;
 extern int bas_thres, tot_parts;
+extern CELL n_basins;
+extern OC_STACK *ocs;
+extern int ocs_alloced;
 extern FLAG *worked, *in_list, *s_b, *swale;
 extern RAMSEG dis_seg, alt_seg, wat_seg, asp_seg, bas_seg, haf_seg;
 extern RAMSEG r_h_seg, dep_seg;
Modified: grass/trunk/raster/r.watershed/ram/close_maps2.c
--- grass/trunk/raster/r.watershed/ram/close_maps2.c	2009-12-11 12:27:30 UTC (rev 39979)
+++ grass/trunk/raster/r.watershed/ram/close_maps2.c	2009-12-11 18:36:10 UTC (rev 39980)
@@ -24,13 +24,7 @@
 	    theseg = haf;
 	    thesegseg = haf_seg;
-	max = -9;
-	for (r = 0; r < nrows; r++) {
-	    for (c = 0; c < ncols; c++) {
-		if (max < theseg[SEG_INDEX(thesegseg, r, c)])
-		    max = theseg[SEG_INDEX(thesegseg, r, c)];
+	max = n_basins;
 	G_debug(1, "%d basins created", max);
 	Rast_init_colors(&colors);
 	Rast_make_random_colors(&colors, 1, max);
Modified: grass/trunk/raster/r.watershed/ram/do_astar.c
--- grass/trunk/raster/r.watershed/ram/do_astar.c	2009-12-11 12:27:30 UTC (rev 39979)
+++ grass/trunk/raster/r.watershed/ram/do_astar.c	2009-12-11 18:36:10 UTC (rev 39980)
@@ -84,6 +84,8 @@
 		    slope[ct_dir] =
 			get_slope2(alt_val, alt_nbr[ct_dir],
 				   dist_to_nbr[ct_dir]);
+		if (!is_in_list) {
 		    if (ct_dir > 3 && slope[ct_dir] > 0) {
 			if (slope[nbr_ew[ct_dir]] > 0) {
 			    /* slope to ew nbr > slope to center */
Modified: grass/trunk/raster/r.watershed/ram/find_pour.c
--- grass/trunk/raster/r.watershed/ram/find_pour.c	2009-12-11 12:27:30 UTC (rev 39979)
+++ grass/trunk/raster/r.watershed/ram/find_pour.c	2009-12-11 18:36:10 UTC (rev 39980)
@@ -6,6 +6,9 @@
     double easting, northing, stream_length;
     CELL old_elev, basin_num;
+    ocs_alloced = 2 * bas_thres;
+    ocs = (OC_STACK *)G_malloc(ocs_alloced * sizeof(OC_STACK));
     basin_num = 0;
     stream_length = old_elev = 0;
     for (row = 0; row < nrows; row++) {
@@ -36,6 +39,8 @@
     G_percent(nrows, nrows, 1);	/* finish it */
+    n_basins = basin_num;
+    G_free(ocs);
     return 0;
Modified: grass/trunk/raster/r.watershed/ram/main.c
--- grass/trunk/raster/r.watershed/ram/main.c	2009-12-11 12:27:30 UTC (rev 39979)
+++ grass/trunk/raster/r.watershed/ram/main.c	2009-12-11 18:36:10 UTC (rev 39980)
@@ -30,6 +30,9 @@
 SHORT nrows, ncols;
+CELL n_basins;
+OC_STACK *ocs;
+int ocs_alloced;
Modified: grass/trunk/raster/r.watershed/ram/no_stream.c
--- grass/trunk/raster/r.watershed/ram/no_stream.c	2009-12-11 12:27:30 UTC (rev 39979)
+++ grass/trunk/raster/r.watershed/ram/no_stream.c	2009-12-11 18:36:10 UTC (rev 39980)
@@ -10,6 +10,7 @@
     SHORT updir, riteflag, leftflag, thisdir;
     while (1) {
+	bas[SEG_INDEX(bas_seg, row, col)] = basin_num;
 	max_drain = -1;
 	for (r = row - 1, rr = 0; r <= row + 1; r++, rr++) {
 	    for (c = col - 1, cc = 0; c <= col + 1; c++, cc++) {
@@ -33,30 +34,30 @@
 	    downdir = asp[SEG_INDEX(asp_seg, row, col)];
 	    if (downdir < 0)
 		downdir = -downdir;
-	    if (sides == 8) {
-		if (uprow != row && upcol != col)
-		    stream_length += diag;
-		else if (uprow != row)
-		    stream_length += window.ns_res;
-		else
-		    stream_length += window.ew_res;
-	    else {		/* sides == 4 */
-		asp_value = asp[SEG_INDEX(asp_seg, uprow, upcol)];
-		if (downdir == 2 || downdir == 6) {
-		    if (asp_value == 2 || asp_value == 6)
+	    if (arm_flag) {
+		if (sides == 8) {
+		    if (uprow != row && upcol != col)
+			stream_length += diag;
+		    else if (uprow != row)
 		    else
-		else {		/* downdir == 4,8 */
-		    if (asp_value == 4 || asp_value == 8)
-		    else
+		else {		/* sides == 4 */
+		    asp_value = asp[SEG_INDEX(asp_seg, uprow, upcol)];
+		    if (downdir == 2 || downdir == 6) {
+			if (asp_value == 2 || asp_value == 6)
+			    stream_length += window.ns_res;
+			else
+		    else {		/* downdir == 4,8 */
+			if (asp_value == 4 || asp_value == 8)
+			    stream_length += window.ew_res;
+			else
 	    riteflag = leftflag = 0;
 	    for (r = row - 1, rr = 0; rr < 3; r++, rr++) {
@@ -65,23 +66,24 @@
 			aspect = asp[SEG_INDEX(asp_seg, r, c)];
 			if (aspect == drain[rr][cc]) {
 			    thisdir = updrain[rr][cc];
-			    if (haf_basin_side(updir,
-					       (SHORT) downdir,
-					       thisdir) == RITE) {
+			    switch (haf_basin_side
+			            (updir, (SHORT) downdir, thisdir)) {
+			    case LEFT:
+				overland_cells(r, c, basin_num, basin_num - 1,
+					       &new_ele);
+				leftflag++;
+				break;
+			    case RITE:
 				overland_cells(r, c, basin_num, basin_num,
 					       &new_ele);
 				riteflag++;
+				break;
-			    else {
-				overland_cells(r, c, basin_num, basin_num - 1,
-					       &new_ele);
-				leftflag++;
-	    if (leftflag >= riteflag)
+	    if (leftflag > riteflag)
 		haf[SEG_INDEX(haf_seg, row, col)] = basin_num - 1;
 	    else
 		haf[SEG_INDEX(haf_seg, row, col)] = basin_num;
@@ -96,6 +98,7 @@
 		    slope = MIN_SLOPE;
 		fprintf(fp, " %f %f\n", slope, stream_length);
+	    haf[SEG_INDEX(haf_seg, row, col)] = basin_num;
 	    return 0;
Modified: grass/trunk/raster/r.watershed/ram/over_cells.c
--- grass/trunk/raster/r.watershed/ram/over_cells.c	2009-12-11 12:27:30 UTC (rev 39979)
+++ grass/trunk/raster/r.watershed/ram/over_cells.c	2009-12-11 18:36:10 UTC (rev 39980)
@@ -2,7 +2,7 @@
 #define BIGNEG	-9999999
 int
-overland_cells(int row, int col, CELL basin_num, CELL haf_num, CELL * hih_ele)
+overland_cells_recursive(int row, int col, CELL basin_num, CELL haf_num, CELL * hih_ele)
     int r, rr, c, cc;
     CELL new_ele, new_max_ele, value;
@@ -33,3 +33,59 @@
     return 0;
+/* non-recursive version */
+int
+overland_cells(int row, int col, CELL basin_num, CELL haf_num, CELL * hih_ele)
+    int r, c, rr, cc, next_r, next_c;
+    int top = 0, idx;
+    /* put root on stack */
+    ocs[top].row = row;
+    ocs[top].col = col;
+    idx = SEG_INDEX(bas_seg, row, col);
+    bas[idx] = basin_num;
+    haf[idx] = haf_num;
+    top++;
+    while (top) {
+	top--;
+	next_r = ocs[top].row;
+	next_c = ocs[top].col;
+	for (r = next_r - 1, rr = 0; r <= next_r + 1; r++, rr++) {
+	    for (c = next_c - 1, cc = 0; c <= next_c + 1; c++, cc++) {
+		if (r >= 0 && c >= 0 && r < nrows && c < ncols) {
+		    idx = SEG_INDEX(bas_seg, r, c);
+		    if (asp[idx] == drain[rr][cc]) {
+			if (top >= ocs_alloced) {
+			    ocs_alloced += bas_thres;
+			    ocs = (OC_STACK *)G_realloc(ocs, ocs_alloced * sizeof(OC_STACK));
+			ocs[top].row = r;
+			ocs[top].col = c;
+			top++;
+    if (arm_flag) {
+	if (new_max_ele == BIGNEG) {
+	    cseg_get(&alt, hih_ele, row, col);
+	else {
+	    *hih_ele = new_max_ele;
+    return 0;
