[GRASS-SVN] r40028 - in grass/branches/develbranch_6/gui/wxpython:
docs xml
svn_grass at osgeo.org
Wed Dec 16 15:13:32 EST 2009
Author: martinl
Date: 2009-12-16 15:13:31 -0500 (Wed, 16 Dec 2009)
New Revision: 40028
grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
wxGUI: more shortcuts
(merge r40024 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html 2009-12-16 20:10:08 UTC (rev 40027)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html 2009-12-16 20:13:31 UTC (rev 40028)
@@ -8,7 +8,7 @@
typing at GRASS command line prompt
<div class="code"><pre>
- g.gui -u wxpython&
+ g.gui -u wxpython
</pre></div>
or define in your <tt>.grassrc6</tt> file 'GRASS_GUI' variable
@@ -21,7 +21,7 @@
can be restarted from the GRASS command line prompt by typing
- g.gui wxpython&
+ g.gui wxpython
</pre></div>
or to restart with previously saved workspace type:
@@ -266,8 +266,12 @@
<dd>Save workspace</dd>
<dt>Ctrl+C</dt>
<dd>Close workspace</dd>
+ <dt>Ctrl+L</dt>
+ <dd>Load map layers</dd>
+ <dt>Ctrl+E</dt>
+ <dd>Exit GUI</dd>
<dt>Ctrl+Q</dt>
- <dd>Quit GUI</dd>
+ <dd>Quit GRASS</dd>
</dl>
<b>Global</b>
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2009-12-16 20:10:08 UTC (rev 40027)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2009-12-16 20:13:31 UTC (rev 40028)
@@ -33,12 +33,14 @@
<label>Close</label>
<help>Close workspace file</help>
<handler>self.OnWorkspaceClose</handler>
+ <shortcut>Ctrl+C</shortcut>
</menuitem>
<separator />
<menuitem>
<label>Load map layers</label>
<help>Load map layers into layer tree</help>
<handler>self.OnWorkspaceLoad</handler>
+ <shortcut>Ctrl+L</shortcut>
</menuitem>
<separator />
<menuitem>
@@ -649,9 +651,10 @@
</menuitem>
<separator />
<menuitem>
- <label>Quit GUI</label>
+ <label>Exit GUI</label>
<help>Quit wxGUI session</help>
<handler>self.OnCloseWindow</handler>
+ <shortcut>Ctrl+E</shortcut>
</menuitem>
<menuitem>
<label>Quit GRASS GIS</label>
