[GRASS-SVN] r40033 - grass/trunk/scripts/v.dissolve
Thu Dec 17 07:36:32 EST 2009
Author: mmetz
Date: 2009-12-17 07:36:31 -0500 (Thu, 17 Dec 2009)
New Revision: 40033
   grass/trunk/scripts/v.dissolve/v.dissolve.py
coltype check fixed
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.py
--- grass/trunk/scripts/v.dissolve/v.dissolve.py	2009-12-16 21:21:10 UTC (rev 40032)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.py	2009-12-17 12:36:31 UTC (rev 40033)
@@ -88,7 +88,7 @@
         except KeyError:
             grass.fatal(_('Column <%s> not found') % column)
-	if coltype not in ('INTEGER', 'CHARACTER'):
+	if coltype['type'] not in ('INTEGER', 'CHARACTER'):
 	    grass.fatal(_("Key column must be of type integer or string"))
         f = grass.vector_layer_db(input, layer)
