[GRASS-SVN] r40049 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Fri Dec 18 10:43:43 EST 2009
Author: martinl
Date: 2009-12-18 10:43:43 -0500 (Fri, 18 Dec 2009)
New Revision: 40049
Added:
grass-addons/vector/v.krige/README
Removed:
grass-addons/vector/v.krige/Makefile
grass-addons/vector/v.krige/description.html
grass-addons/vector/v.krige/v.krige.py
v.krige moved to trunk and devbr6.
Deleted: grass-addons/vector/v.krige/Makefile
--- grass-addons/vector/v.krige/Makefile 2009-12-18 15:40:32 UTC (rev 40048)
+++ grass-addons/vector/v.krige/Makefile 2009-12-18 15:43:43 UTC (rev 40049)
@@ -1,7 +0,0 @@
-MODULE_TOPDIR = ../..
-PGM = v.krige.py
-include $(MODULE_TOPDIR)/include/Make/Script.make
-default: script
Added: grass-addons/vector/v.krige/README
--- grass-addons/vector/v.krige/README (rev 0)
+++ grass-addons/vector/v.krige/README 2009-12-18 15:43:43 UTC (rev 40049)
@@ -0,0 +1,4 @@
+v.krige has been moved to trunk (GRASS 7.0) and devbr6 (GRASS
+6.5). Please install GRASS 6.5+ to use v.krige module.
+Martin Landa, 2009-12-18
Deleted: grass-addons/vector/v.krige/description.html
--- grass-addons/vector/v.krige/description.html 2009-12-18 15:40:32 UTC (rev 40048)
+++ grass-addons/vector/v.krige/description.html 2009-12-18 15:43:43 UTC (rev 40049)
@@ -1,224 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>v.krige</em> allows to perform kriging operations in GRASS
-environment, using R software functions in background.
-<h2>NOTES</h2>
-<em>v.krige</em> is just a front-end to R. The options and parameters are the same offered by packages <i>automap</i> and <i>gstat</i>.
-<p>
-Kriging, like other interpolation methods, is fully dependent on input
-data features. Exploratory analysis of data is encouraged to find out
-outliers, trends, anisotropies, uneven distributions and consequently
-choose the kriging algorithm that will give the most acceptable
-result. Good knowledge of the dataset is more valuable than hundreds
-of parameters or powerful hardware. See Isaaks and Srivastava's book,
-exhaustive and clear even if a bit outdated.
-<h3>Dependencies</h3>
-<dl>
-<dt><b>GRASS 6.5 with wxPython support</b></dt>
-<dd></dd>
-<dt><b>R software >= 2.x</b></dt>
-<dd></dd>
-<dt><b>rpy2</b></dt>
-<dd>Python binding to R. Note! rpy is not supported.</dd>
-<dt><b>R packages automap and gstat. </b></dt>
-<dd>automap is optional (provides automatic variogram fit).</dd>
-</dl>
-<h3>Install</h3>
-<h4>Easy way: g.extension</h4>
-Simply run:
-<div class="code"><pre>
- g.extension v.krige
-<pre></div>
-<h4>Less easy way: manual install</h4>
-It is sufficient to copy it into the (GRASS binaries) path
-somewhere. Alternatively, install addons into a separate GRASS addons
-binaries/scripts directory which is easier to maintain. It avoids
-getting clobbered every time you reinstall GRASS. To use these
-separately stored scripts, set and export the GRASS_ADDON_PATH
-environment variable before starting GRASS and it will automatically
-be added to the module search path. To simplify this, do for example:
- # add in $HOME/.bashrc:
- GRASS_ADDON_PATH=/usr/local/grass/addons/
- export GRASS_ADDON_PATH
-<pre></div>
-Make sure that the script is executable, then just call it in GRASS
-typing the filename. Python scripts need to be called writing the
-extension as well, like:
- GRASS 6.5.svn (spearfish60):~ > v.krige.py
-<pre></div>
-<h4>Notes for Debian GNU/Linux</h4>
-Install the dependiencies. <b>Attention! python-rpy IS NOT
-SUITABLE.</b>:
- aptitude install R python-rpy2
-<pre></div>
-To install R packages, use either R's function (as root):
- install.packages("gstat", dep=T)
- install.packages("spgrass6", dep=T)
-<pre></div>
-either the brand new Debian packages [5], add to repositories' list
-for 32bit or 64bit (pick up the suitable line):
- deb <a href="http://debian.cran.r-project.org/cran2deb/debian-i386">http://debian.cran.r-project.org/cran2deb/debian-i386</a> testing/
- deb <a href="http://debian.cran.r-project.org/cran2deb/debian-amd64">http://debian.cran.r-project.org/cran2deb/debian-amd64</a> testing/
-<pre></div>
-and get the packages via aptitude:
- aptitude install r-cran-gstat r-cran-spgrass6
-<pre></div>
-<h4>Notes for Windows</h4>
-At this very moment, v.krige is developed against GRASS 6.5
-(6_develbranch) and no backward compatibility with OSGeo4W's packaged
-GRASS 6.4svn2 is provided, nor with WinGRASS.
-<p>
-If you really need to run v.krige right now on Windows, I suggest to
-compile GRASS following this
-<a href="http://trac.osgeo.org/grass/wiki/CompileOnWindows">guide</a>.
-You could also use Linux in a virtual machine. Or install Linux in a
-separate partition of the HD. This is not as painful as it appears,
-there are lots of guides over the Internet to help you.
-<h3>Computation time issues</h3>
-Please note that kriging calculation is slown down both by high number
-of input data points and/or high region resolution, even if they both
-contribute to a better output.
-<h2>EXAMPLES</h2>
-Kriging example based on elevation map (Spearfish data set).
-<p>
-<b>Part 1: random sampling</b> of 2000 vector points from known
-elevation map. Each point will receive the elevation value from the
-elevation raster, as if it came from a point survey.
- g.region rast=elevation.10m -p
- v.random output=rand2k_elev n=2000
- v.db.addtable map=rand2k_elev column="elevation double precision"
- v.what.rast vect=rand2k_elev rast=elevation.10m column=elevation
-<pre></div>
-<p>
-<b>Part 2: remove points lacking elevation attributes</b>. Points
-sampled at the border of the elevation map didn't receive any
-value. v.krige has no preferred action to cope with no data values, so
-the user must check for them and decide what to do (remove points,
-fill with the value of the nearest point, fill with the global/local
-mean...). In the following line of code, points with no data are
-removed from the map.
- v.extract rand2k_elev output=rand2k_elev_filt where="elevation not NULL"
-<pre></div>
-Check the result of previous line ("number of NULL attributes" must be
-0):
- v.univar rand2k_elev_filt type=point column=elevation
-<pre></div>
-<p>
-<b>Part 3: reconstruct DEM through kriging</b>. Using automatic
-variogram fit is the simplest way to run v.krige from CLI (note:
-requires R's automap package). Output map name is optional, the
-modules creates it automatically appending "_kriging" the the input
-map name and also checks for overwrite. If output_var is specified,
-the variance map is also created. Automatic variogram fit is provided
-by R package automap, the variogram models tested by the fitting
-functions are: exponential, spherical, Gaussian, Matern, M.Stein's
-parametrisation. A wider range of models is available from gstat
-package and can be tested on the GUI via the variogram plotting. If
-model is specified in the CLI, also sill, nugget and range values are
-to be provided, otherwise an error is raised (see second example of
-v.krige command).
- v.krige.py input=rand2k_elev_filt column=elevation output=rand2k_elev_kriging \
- output_var=rand2k_elev_kriging_var
- output_var=rand2k_elev_kriging_var model=Lin sill=2500 nugget=0 range=1000 \
- --overwrite
-<pre></div>
-Or run wxGUI, to interactively fit the variogram and explore options:
- v.krige.py
-</pre></div>
-<b>Calculate prediction error</b>:
- r.mapcalc "rand2k_elev_kriging_pe = sqrt(rand2k_elev_kriging_var)"
- r.univar elevation.10m
- r.univar rand2k_elev_kriging
- r.univar rand2k_elev_kriging_pe
-<pre></div>
-The results show high errors, as the kriging techniques (ordinary and
-block kriging) are unable to handle a dataset with a trend, like the
-one used in this example: elevation is higher in the southwest corner
-and lower on northeast corner. Universal kriging can give far better
-results in these cases as it can handle the trend. It is available in
-R package gstat and will be part of a future v.krige release.
-<h2>SEE ALSO</h2>
-R package <a href="http://cran.r-project.org/web/packages/gstat/index.html">gstat</a>,
-mantained by Edzer J. Pebesma and others
-<br>
-R
-package <a href="http://cran.r-project.org/web/packages/spgrass6/index.html">spgrass6</a>,
-mantained by Roger Bivand
-<br><br>
-v.krige's <a href="http://grass.osgeo.org/wiki/V.krige_GSoC_2009">wiki page</a>
-<h2>REFERENCES</h2>
-Isaaks and Srivastava, 1989: "An Introduction to Applied Geostatistics" (ISBN 0-19-505013-4)
-<h2>AUTHOR</h2>
-Anne Ghisla, Google Summer of Code 2009
-<p>
-<i>Last changed: $Date$</i>
Deleted: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-12-18 15:40:32 UTC (rev 40048)
+++ grass-addons/vector/v.krige/v.krige.py 2009-12-18 15:43:43 UTC (rev 40049)
@@ -1,860 +0,0 @@
-#!/usr/bin/env python
-MODULE: v.krige
-AUTHOR(S): Anne Ghisla <a.ghisla AT gmail.com>
-PURPOSE: Performs ordinary or block kriging
-DEPENDS: R 2.x, packages gstat and spgrass6, optional: automap
-COPYRIGHT: (C) 2009 by the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
-## g.parser informations
-#%module
-#% description: Performs ordinary or block kriging.
-#% keywords: vector, kriging
-#%end
-#%option
-#% key: input
-#% type: string
-#% gisprompt: old,vector,vector
-#% description: Name of point vector map containing sample data
-#% required: yes
-#%end
-#%option
-#% key: column
-#% type: string
-#% description: Column with numerical value to be interpolated
-#% required : yes
-#%end
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new,cell,raster
-#% label: Name for output raster map
-#% description: If omitted, will be <input name>_kriging
-#% required : no
-#%end
-#%option
-#% key: package
-#% type: string
-#% options: gstat
-#% answer: gstat
-#% description: R package to use
-#% required: no
-#%end
-#%option
-#% key: model
-#% type: string
-#% options: Exp,Sph,Gau,Mat,Lin
-#% multiple: yes
-#% label: Variogram model(s)
-#% description: Leave empty to test all models (requires automap)
-#% required: no
-#%end
-#%option
-#% key: block
-#% type: integer
-#% multiple: no
-#% label: Block size (square block)
-#% description: Block size. Used by block kriging.
-#% required: no
-#%end
-#%option
-#% key: range
-#% type: integer
-#% label: Range value
-#% description: Automatically fixed if not set
-#% required : no
-#%end
-#%option
-#% key: nugget
-#% type: integer
-#% label: Nugget value
-#% required : no
-#%end
-#%option
-#% key: sill
-#% type: integer
-#% label: Sill value
-#% required : no
-#%end
-#%option
-#% key: output_var
-#% type: string
-#% label: Name for output variance raster map
-#% description: If omitted, will be <input name>_kriging_var
-#% required : no
-#%end
-import os, sys
-from tempfile import gettempdir
-import time
-import thread
-GUIModulesPath = os.path.join(os.getenv("GISBASE"), "etc", "wxpython", "gui_modules")
-sys.path.append(GUIModulesPath)
-GUIPath = os.path.join(os.getenv("GISBASE"), "etc", "wxpython")
-sys.path.append(GUIPath)
-import globalvar
-if not os.getenv("GRASS_WXBUNDLED"):
- globalvar.CheckForWx()
-import gselect
-import goutput
-import menuform
-#import help
-import wx
-import wx.lib.flatnotebook as FN
-import wx.lib.plot as plot # for plotting the variogram.
-### i18N
-import gettext
-gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
-### dependencies to be checked once, as they are quite time-consuming. cfr. grass.parser.
-# GRASS binding
-try:
- import grass.script as grass
-except ImportError:
- sys.exit(_("No GRASS-python library found."))
-# move other checks in functions, as R?
-# globals
-maxint = 1e6 # instead of sys.maxint, not working with SpinCtrl on 64bit [reported by Bob Moskovitz]
-Region = grass.region()
-Command = None
-InputData = None
-Variogram = None
-VariogramFunction = None
-robjects = None
-rinterface = None
-#classes in alphabetical order. methods in logical order :)
-class Controller():
- """ Executes analysis. For the moment, only with gstat functions."""
- def ImportMap(self, map, column):
- """ Adds x,y columns to the GRASS map and then imports it in R.
- Checks for NULL values in the provided column and exits if they are present."""
- #@NOTE: it alters original data. Is it correct? Shall I remove those columns
- # if they were absent from original data?
- cols = grass.vector_columns(map=map, layer=1)
- if not cols.has_key('x') and not cols.has_key('y'):
- grass.run_command('v.db.addcol', map = map,
- columns = 'x double precision, y double precision')
- grass.run_command('v.to.db', map = map, option = 'coor', col = 'x,y')
- nulls = int(grass.parse_command('v.univar', map=map, column=column, type='point', \
- parse = (grass.parse_key_val, \
- {'sep':': '}))['number of NULL attributes'])
- if nulls > 0:
- grass.fatal(_("%d NULL value(s) in the selected column - unable to perform kriging.") % nulls)
- return robjects.r.readVECT6(map, type= 'point')
- def CreateGrid(self, inputdata):
- Grid = robjects.r.gmeta2grd()
- # addition of coordinates columns into dataframe.
- coordinatesDF = robjects.r['as.data.frame'](robjects.r.coordinates(Grid))
- data=robjects.r['data.frame'](x=coordinatesDF.r['s1'][0],
- y=coordinatesDF.r['s2'][0],
- k=robjects.r.rep(1, Region['cols']*Region['rows']))
- GridPredicted = robjects.r.SpatialGridDataFrame(Grid,
- data,
- proj4string= robjects.r.CRS(robjects.r.proj4string(inputdata)))
- return GridPredicted
- def ComposeFormula(self, column, isblock, inputdata):
- if isblock is True:
- predictor = 'x+y'
- else:
- predictor = 1
- Formula = robjects.r['as.formula'](robjects.r.paste(column, "~", predictor))
- #print Formula
- return Formula
- def FitVariogram(self, formula, inputdata, sill, nugget, range, model = ''):
- """ Fits variogram either automagically either specifying all parameters.
- Returns a list containing data and model variograms. """
- Variograms = {}
- if model is '':
- robjects.r.require('automap')
- DottedParams = {}
- #print (nugget.r_repr(), sill, range)
- DottedParams['fix.values'] = robjects.r.c(nugget, range, sill)
- VariogramModel = robjects.r.autofitVariogram(formula, inputdata, **DottedParams)
- #print robjects.r.warnings()
- Variograms['datavariogram'] = VariogramModel.r['exp_var'][0]
- Variograms['variogrammodel'] = VariogramModel.r['var_model'][0]
- # obtain the model name. *Too* complicated to get the string instead of level, unlike R does.
- VariogramAsDF = robjects.r['as.data.frame'](VariogramModel.r['var_model'][0]) # force conversion
- ModelDF = VariogramAsDF.r['model'][0]
- Variograms['model'] = robjects.r.levels(ModelDF).subset(ModelDF[1])[0]
- else:
- DataVariogram = robjects.r['variogram'](formula, inputdata)
- VariogramModel = robjects.r['fit.variogram'](DataVariogram,
- model = robjects.r.vgm(psill = sill,
- model = model,
- nugget = nugget,
- range = range))
- Variograms['datavariogram'] = DataVariogram
- Variograms['model'] = model
- return Variograms
- def DoKriging(self, formula, inputdata, grid, model, block):
- DottedParams = {'debug.level': -1} # let krige() print percentage status
- if block is not '': #@FIXME(anne): but it's a string!! and krige accepts it!!
- DottedParams['block'] = block
- #print DottedParams
- KrigingResult = robjects.r.krige(formula, inputdata, grid, model, **DottedParams)
- return KrigingResult
- def ExportMap(self, map, column, name, overwrite, command, variograms):
- # add kriging parameters to raster map history
- robjects.r.writeRAST6(map, vname = name, zcol = column, overwrite = overwrite)
- grass.run_command('r.support',
- map = name,
- title = 'Kriging output',
- history = 'Issued from command v.krige ' + command)
- if command.find('model') is -1: # if the command has no model option, add automap chosen model
- map = name,
- history = 'Model chosen by automatic fitting: ' + variograms['model'])
- def Run(self, input, column, output, package, sill, nugget, range, logger, \
- overwrite, model, block, output_var, command, **kwargs):
- """ Wrapper for all functions above. """
- logger.message(_("Processing %d cells. Computing time raises exponentially with resolution." % Region['cells']))
- logger.message(_("Importing data..."))
- if globals()["InputData"] is None:
- globals()["InputData"] = self.ImportMap(input, column)
- # and from here over, InputData refers to the global variable
- #print(robjects.r.slot(InputData, 'data').names)
- logger.message(_("Data successfully imported."))
- GridPredicted = self.CreateGrid(InputData)
- logger.message(_("Fitting variogram..."))
- isblock = block is not ''
- Formula = self.ComposeFormula(column, isblock, InputData)
- if globals()["Variogram"] is None:
- globals()["Variogram"] = self.FitVariogram(Formula,
- InputData,
- model = model,
- sill = sill,
- nugget = nugget,
- range = range)
- logger.message(_("Variogram fitted."))
- logger.message(_("Kriging..."))
- KrigingResult = self.DoKriging(Formula, InputData, GridPredicted, Variogram['variogrammodel'], block) # using global ones
- logger.message(_("Kriging performed."))
- self.ExportMap(map = KrigingResult,
- column='var1.pred',
- name = output,
- overwrite = overwrite,
- command = command,
- variograms = Variogram)
- if output_var is not '':
- column='var1.var',
- name = output_var,
-class KrigingPanel(wx.Panel):
- """ Main panel. Contains all widgets except Menus and Statusbar. """
- def __init__(self, parent, *args, **kwargs):
- wx.Panel.__init__(self, parent, *args, **kwargs)
- self.parent = parent
- self.border = 4
- # 1. Input data
- InputBoxSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label=_("Input Data")),
- orient=wx.HORIZONTAL)
- flexSizer = wx.FlexGridSizer(cols=3, hgap=5, vgap=5)
- flexSizer.AddGrowableCol(1)
- flexSizer.Add(item = wx.StaticText(self, id=wx.ID_ANY, label=_("Point dataset:")),
- flag = wx.ALIGN_CENTER_VERTICAL)
- self.InputDataMap = gselect.VectorSelect(parent = self,
- ftype = 'points',
- updateOnPopup = False)
- self.InputDataMap.SetFocus()
- flexSizer.Add(item = self.InputDataMap, flag = wx.ALIGN_CENTER_VERTICAL)
- RefreshButton = wx.Button(self, id=wx.ID_REFRESH)
- RefreshButton.Bind(wx.EVT_BUTTON, self.OnButtonRefresh)
- flexSizer.Add(item = RefreshButton, flag = wx.ALIGN_CENTER_VERTICAL)
- flexSizer.Add(item = wx.StaticText(self, id=wx.ID_ANY, label=_("Numeric column:")),
- flag=wx.ALIGN_CENTER_VERTICAL)
- self.InputDataColumn = gselect.ColumnSelect(self, id=wx.ID_ANY)
- self.InputDataColumn.SetSelection(0)
- flexSizer.Add(item = self.InputDataColumn)
- self.InputDataMap.GetChildren()[0].Bind(wx.EVT_TEXT, self.OnInputDataChanged)
- InputBoxSizer.Add(item = flexSizer)
- # 2. Kriging. In book pages one for each R package. Includes variogram fit.
- KrigingSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label=_("Kriging")), wx.HORIZONTAL)
- self.RPackagesBook = FN.FlatNotebook(parent=self, id=wx.ID_ANY,
- style=FN.FNB_BOTTOM |
- FN.FNB_NO_NAV_BUTTONS |
- FN.FNB_FANCY_TABS | FN.FNB_NO_X_BUTTON)
- for Rpackage in ["gstat"]: # , "geoR"]: #@TODO: enable it if/when it'll be implemented.
- self.CreatePage(package = Rpackage)
- ## Command output. From menuform module, cmdPanel class
- self.goutput = goutput.GMConsole(parent=self, margin=False,
- pageid=self.RPackagesBook.GetPageCount(),
- notebook = self.RPackagesBook)
- self.goutputId = self.RPackagesBook.GetPageCount()
- self.outpage = self.RPackagesBook.AddPage(self.goutput, text=_("Command output"))
- self.RPackagesBook.SetSelection(0)
- KrigingSizer.Add(self.RPackagesBook, proportion=1, flag=wx.EXPAND)
- # 3. Output Parameters.
- OutputSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label=_("Output")), wx.HORIZONTAL)
- OutputParameters = wx.GridBagSizer(hgap=5, vgap=5)
- OutputParameters.AddGrowableCol(1)
- OutputParameters.Add(item = wx.StaticText(self, id=wx.ID_ANY, label=_("Name for the output raster map:")),
- flag = wx.ALIGN_CENTER_VERTICAL,
- pos = (0, 0))
- self.OutputMapName = gselect.Select(parent = self, id = wx.ID_ANY,
- type = 'raster',
- mapsets = [grass.gisenv()['MAPSET']])
- OutputParameters.Add(item=self.OutputMapName, flag=wx.EXPAND | wx.ALL,
- pos = (0, 1))
- self.VarianceRasterCheckbox = wx.CheckBox(self, id=wx.ID_ANY, label=_("Export variance map as well: "))
- self.VarianceRasterCheckbox.SetValue(state = True)
- OutputParameters.Add(item = self.VarianceRasterCheckbox,
- pos = (1, 0))
- self.OutputVarianceMapName = gselect.Select(parent = self, id = wx.ID_ANY,
- type = 'raster',
- self.VarianceRasterCheckbox.Bind(wx.EVT_CHECKBOX, self.OnVarianceCBChecked)
- OutputParameters.Add(item=self.OutputVarianceMapName, flag=wx.EXPAND | wx.ALL,
- pos = (1, 1))
- self.OverwriteCheckBox = wx.CheckBox(self, id=wx.ID_ANY,
- label=_("Allow output files to overwrite existing files"))
- self.OverwriteCheckBox.SetValue(state = False)
- OutputParameters.Add(item = self.OverwriteCheckBox,
- pos = (2, 0), span = (1, 2))
- OutputSizer.Add(OutputParameters, proportion=0, flag=wx.EXPAND | wx.ALL, border=self.border)
- # 4. Run Button and Quit Button
- ButtonSizer = wx.BoxSizer(wx.HORIZONTAL)
- HelpButton = wx.Button(self, id=wx.ID_HELP)
- HelpButton.Bind(wx.EVT_BUTTON, self.OnHelpButton)
- QuitButton = wx.Button(self, id=wx.ID_EXIT)
- QuitButton.Bind(wx.EVT_BUTTON, self.OnCloseWindow)
- self.RunButton = wx.Button(self, id=wx.ID_ANY, label=_("Run")) # no stock ID for Run button..
- self.RunButton.Bind(wx.EVT_BUTTON, self.OnRunButton)
- self.RunButton.Enable(False) # disable it on loading the interface, as input map is not set
- ButtonSizer.Add(HelpButton, proportion=0, flag=wx.ALIGN_LEFT | wx.ALL, border=self.border)
- ButtonSizer.Add(QuitButton, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=self.border)
- ButtonSizer.Add(self.RunButton, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=self.border)
- # Main Sizer. Add each child sizer as soon as it is ready.
- Sizer = wx.BoxSizer(wx.VERTICAL)
- Sizer.Add(InputBoxSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=self.border)
- Sizer.Add(KrigingSizer, proportion=1, flag=wx.EXPAND | wx.ALL, border=self.border)
- Sizer.Add(OutputSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=self.border)
- Sizer.Add(ButtonSizer, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=self.border)
- self.SetSizerAndFit(Sizer)
- # last action of __init__: update imput data list.
- # it's performed in the few seconds gap while user examines interface before clicking anything.
- #@TODO: implement a splashcreen IF the maps cause a noticeable lag [markus' suggestion]
- self.InputDataMap.GetElementList()
- def CreatePage(self, package):
- """ Creates the three notebook pages, one for each R package """
- for package in ["gstat"]:
- classobj = eval("RBook"+package+"Panel")
- setattr(self, "RBook"+package+"Panel", (classobj(self, id=wx.ID_ANY)))
- self.RPackagesBook.AddPage(page=getattr(self, "RBook"+package+"Panel"), text=package)
- def OnButtonRefresh(self, event):
- """ Forces refresh of list of available layers. """
- def OnCloseWindow(self, event):
- """ Cancel button pressed"""
- self.parent.Close()
- event.Skip()
- def OnHelpButton(self, event):
- # file = os.path.join(os.getenv("GISBASE"), "docs", "html", "v.krige.py.html")
- # file = os.path.join(os.path.curdir, "description.html")
- # @TODO fix HelpWindow
- # helpFrame = help.HelpWindow(parent=self, id=wx.ID_ANY,
- # title=_("GRASS - Help page for v.krige.py"),
- # size=(640, 480),
- # file=file)
- # helpFrame.Show(True)
- grass.run_command('g.manual', entry = 'v.krige.py')
- event.Skip()
- def OnInputDataChanged(self, event):
- """ Refreshes list of columns and fills output map name TextCtrl """
- MapName = event.GetString()
- self.InputDataColumn.InsertColumns(vector = MapName,
- layer = 1, excludeKey = True,
- type = ['integer', 'double precision'])
- self.RunButton.Enable(self.InputDataColumn.GetSelection() is not -1)
- self.RBookgstatPanel.PlotButton.Enable(self.InputDataColumn.GetSelection() is not -1)
- if self.InputDataColumn.GetSelection() is not -1:
- self.OutputMapName.SetValue(MapName.split("@")[0]+"_kriging")
- self.OutputVarianceMapName.SetValue(MapName.split("@")[0]+"_kriging_var")
- else:
- self.OutputMapName.SetValue('')
- self.OutputVarianceMapName.SetValue('')
- def OnRunButton(self,event):
- """ Execute R analysis. """
- #@FIXME: send data to main method instead of running it here.
- #-1: get the selected notebook page. The user shall know that [s]he can modify settings in all
- # pages, but only the selected one will be executed when Run is pressed.
- SelectedPanel = self.RPackagesBook.GetCurrentPage()
- if self.RPackagesBook.GetPageText(self.RPackagesBook.GetSelection()) == 'Command output':
- self.goutput.WriteError("No parameters for running. Please select \"gstat\" tab, check parameters and re-run.")
- return False # no break invoked by above function
- # mount command string as it would have been written on CLI
- command = ["v.krige.py", "input=" + self.InputDataMap.GetValue(),
- "column=" + self.InputDataColumn.GetValue(),
- "output=" + self.OutputMapName.GetValue(),
- "package=" + '%s' % self.RPackagesBook.GetPageText(self.RPackagesBook.GetSelection())]
- if not hasattr(SelectedPanel, 'VariogramCheckBox') or not SelectedPanel.VariogramCheckBox.IsChecked():
- command.append("model=" + '%s' % SelectedPanel.ModelChoicebox.GetStringSelection().split(" ")[0])
- for i in ['Sill', 'Nugget', 'Range']:
- if getattr(SelectedPanel, i+"ChextBox").IsChecked():
- command.append(i.lower() + "=" + '%s' % getattr(SelectedPanel, i+'Ctrl').GetValue())
- if SelectedPanel.KrigingRadioBox.GetStringSelection() == "Block kriging":
- command.append("block=" + '%s' % SelectedPanel.BlockSpinBox.GetValue())
- if self.OverwriteCheckBox.IsChecked():
- command.append("--overwrite")
- if self.VarianceRasterCheckbox.IsChecked():
- command.append("output_var=" + self.OutputVarianceMapName.GetValue())
- # give it to the output console
- #@FIXME: it runs the command as a NEW instance. Reimports data, recalculates variogram fit..
- #otherwise I can use Controller() and mimic RunCmd behaviour.
- self.goutput.RunCmd(command, switchPage = True)
- def OnVarianceCBChecked(self, event):
- self.OutputVarianceMapName.Enable(event.IsChecked())
-class KrigingModule(wx.Frame):
- """ Kriging module for GRASS GIS. Depends on R and its packages gstat and geoR. """
- wx.Frame.__init__(self, parent, *args, **kwargs)
- # setting properties and all widgettery
- self.SetTitle(_("Kriging Module"))
- self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_dialog.ico'), wx.BITMAP_TYPE_ICO))
- self.log = Log(self)
- self.CreateStatusBar()
- self.log.message(_("Ready."))
- self.Panel = KrigingPanel(self)
- self.SetMinSize(self.GetBestSize())
- self.SetSize(self.GetBestSize())
-class Log:
- """ The log output is redirected to the status bar of the containing frame. """
- def __init__(self, parent):
- def message(self, text_string):
- """ Updates status bar """
- self.parent.SetStatusText(text_string.strip())
-class RBookPanel(wx.Panel):
- """ Generic notebook page with shared widgets and empty kriging functions. """
- self.VariogramSizer = wx.StaticBoxSizer(wx.StaticBox(self,
- id=wx.ID_ANY,
- label=_("Variogram fitting")),
- wx.HORIZONTAL)
- self.LeftSizer = wx.BoxSizer(wx.VERTICAL)
- self.RightSizer = wx.BoxSizer(wx.VERTICAL)
- self.ParametersSizer = wx.GridBagSizer(vgap=5, hgap=5)
- self.VariogramSizer.Add(self.LeftSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=parent.border)
- self.VariogramSizer.Add(self.RightSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=parent.border)
- # left side of Variogram fitting. The checkboxes and spinctrls.
- self.PlotButton = wx.Button(self, id=wx.ID_ANY, label=_("Plot/refresh variogram")) # no stock ID for Run button..
- self.PlotButton.Bind(wx.EVT_BUTTON, self.OnPlotButton)
- self.PlotButton.Enable(False) # grey it out until a suitable layer is available
- self.LeftSizer.Add(self.PlotButton, proportion=0, flag= wx.ALL, border=parent.border)
- self.LeftSizer.Add(self.ParametersSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=parent.border)
- self.ParametersList = ["Sill", "Nugget", "Range"]
- MinValues = [0,0,1]
- for n in self.ParametersList:
- setattr(self, n+"ChextBox", wx.CheckBox(self,
- id=self.ParametersList.index(n),
- label=_(n + ":")))
- setattr(self, n+"Ctrl", (wx.SpinCtrl(self,
- id = wx.ID_ANY,
- min = MinValues[self.ParametersList.index(n)],
- max=maxint)))
- getattr(self, n+"ChextBox").Bind(wx.EVT_CHECKBOX,
- self.UseValue,
- id=self.ParametersList.index(n))
- setattr(self, n+"Sizer", (wx.BoxSizer(wx.HORIZONTAL)))
- self.ParametersSizer.Add(getattr(self, n+"ChextBox"),
- pos = (self.ParametersList.index(n),0))
- self.ParametersSizer.Add(getattr(self, n+"Ctrl"),
- flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL,
- pos = (self.ParametersList.index(n),1))
- # right side of the Variogram fitting. The plot area.
- #Plot = wx.StaticText(self, id= wx.ID_ANY, label = "Check Plot Variogram to interactively fit model.")
- #PlotPanel = wx.Panel(self)
- #self.PlotArea = plot.PlotCanvas(PlotPanel)
- #self.PlotArea.SetInitialSize(size = (250,250))
- #self.RightSizer.Add(PlotPanel, proportion=0, flag= wx.EXPAND|wx.ALL, border=parent.border)
- self.KrigingSizer = wx.StaticBoxSizer(wx.StaticBox(self,
- id=wx.ID_ANY,
- label=_("Kriging techniques")),
- wx.VERTICAL)
- KrigingList = ["Ordinary kriging", "Block kriging"]#, "Universal kriging"] #@FIXME: i18n on the list?
- self.KrigingRadioBox = wx.RadioBox(self,
- id=wx.ID_ANY,
- choices=KrigingList,
- majorDimension=1,
- style=wx.RA_SPECIFY_COLS)
- self.KrigingRadioBox.Bind(wx.EVT_RADIOBOX, self.HideBlockOptions)
- self.KrigingSizer.Add(self.KrigingRadioBox, proportion=0, flag=wx.EXPAND | wx.ALL, border=parent.border)
- # block kriging parameters. Size.
- BlockSizer = wx.BoxSizer(wx.HORIZONTAL)
- BlockLabel = wx.StaticText(self, id= wx.ID_ANY, label = _("Block size:"))
- self.BlockSpinBox = wx.SpinCtrl(self, id = wx.ID_ANY, min=1, max=maxint)
- self.BlockSpinBox.Enable(False) # default choice is Ordinary kriging so block param is disabled
- BlockSizer.Add(BlockLabel, flag= wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=parent.border)
- BlockSizer.Add(self.BlockSpinBox, flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=parent.border)
- self.KrigingSizer.Add(BlockSizer, flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=parent.border)
- self.Sizer = wx.BoxSizer(wx.VERTICAL)
- self.Sizer.Add(self.VariogramSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=parent.border)
- self.Sizer.Add(self.KrigingSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=parent.border)
- def HideBlockOptions(self, event):
- self.BlockSpinBox.Enable(event.GetInt() == 1)
- def OnPlotButton(self,event):
- """ Plots variogram with current options. """
- pass
- def UseValue(self, event):
- """ Enables/Disables the SpinCtrl in respect of the checkbox. """
- n = self.ParametersList[event.GetId()]
- getattr(self, n+"Ctrl").Enable(event.IsChecked())
-class RBookgstatPanel(RBookPanel):
- """ Subclass of RBookPanel, with specific gstat options and kriging functions. """
- RBookPanel.__init__(self, parent, *args, **kwargs)
- if robjects.r.require('automap')[0]:
- self.VariogramCheckBox = wx.CheckBox(self, id=wx.ID_ANY, label=_("Auto-fit variogram"))
- self.LeftSizer.Insert(0,
- self.VariogramCheckBox,
- proportion=0,
- flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL,
- border=4)
- self.SetSizerAndFit(self.Sizer)
- self.VariogramCheckBox.Bind(wx.EVT_CHECKBOX, self.HideOptions)
- self.VariogramCheckBox.SetValue(state = True) # check it by default
- ModelFactor = robjects.r.vgm().r['long']
- ModelList = robjects.r.levels(ModelFactor[0])
- #@FIXME: no other way to let the Python pick it up..
- # and this is te wrong place where to load this list. should be at the very beginning.
- self.ModelChoicebox = wx.Choice(self, id=wx.ID_ANY, choices=ModelList)
- # disable model parameters' widgets by default
- for n in ["Sill", "Nugget", "Range"]:
- getattr(self, n+"Ctrl").Enable(False)
- self.ModelChoicebox.Enable(False)
- VariogramSubSizer = wx.BoxSizer(wx.HORIZONTAL)
- VariogramSubSizer.Add(item=wx.StaticText(self,
- id= wx.ID_ANY,
- label = _("Model: ")),
- flag=wx.ALIGN_CENTER_VERTICAL | wx.ALL,
- border=4)
- VariogramSubSizer.Add(item=self.ModelChoicebox,
- border=4)
- self.LeftSizer.Insert(2, item= VariogramSubSizer)
- def HideOptions(self, event):
- self.ModelChoicebox.Enable(not event.IsChecked())
- if not event.IsChecked():
- getattr(self, n+"Ctrl").Enable(True)
- getattr(self, n+ "ChextBox").SetValue(True)
- getattr(self, n+ "ChextBox").Enable(False) # grey it out keeping it checked.. improvable
- else:
- getattr(self, n+ "ChextBox").SetValue(False)
- getattr(self, n+ "ChextBox").Enable(True)
- #@FIXME: was for n in self.ParametersSizer.GetChildren(): n.Enable(False) but doesn't work
- ## BIG WARNING: smell of code duplication. Fix this asap.
- controller = Controller()
- map = self.parent.InputDataMap.GetValue()
- column = self.parent.InputDataColumn.GetValue()
- # import data or pick them up
- globals()["InputData"] = controller.ImportMap(map = map,
- column = column)
- # fit the variogram or pick it up
- Formula = controller.ComposeFormula(column = column,
- isblock = self.KrigingRadioBox.GetStringSelection() == "Block kriging",
- inputdata = globals()['InputData'])
- #if globals()["Variogram"] is None:
- if hasattr(self, 'VariogramCheckBox') and self.VariogramCheckBox.IsChecked():
- self.model = ''
- for each in ("Sill","Nugget","Range"):
- if getattr(self, each+'ChextBox').IsChecked():
- setattr(self, each.lower(), getattr(self, each+"Ctrl").GetValue())
- else:
- setattr(self, each.lower(), robjects.r('''NA'''))
- else:
- self.model = self.ModelChoicebox.GetStringSelection().split(" ")[0]
- if getattr(self, each+'ChextBox').IsChecked(): #@FIXME will be removed when chextboxes will be frozen
- globals()["Variogram"] = controller.FitVariogram(Formula,
- InputData,
- model = self.model,
- sill = self.sill,
- nugget = self.nugget,
- range = self.range)
- ## A: use wx.plot library. Does not draw lines from f(x), damn.
- ## convert R dataframe (data variogram) - points
- ##print Variogram['datavariogram']
- #PointList = []
- #for n in range(len(Variogram['datavariogram'].r['dist'][0])): #@FIXME: so less Pythonic!!
- # dist = Variogram['datavariogram'].r['dist'][0][n]
- # gamma = Variogram['datavariogram'].r['gamma'][0][n]
- # PointList.append((dist,gamma))
- #DataPoints = plot.PolyMarker(PointList, legend='points', colour='black', marker='circle',size=1)
- ## convert R dataframe (model variogram) - line
- #LineList = []
- #textplot = robjects.r.plot(Variogram['datavariogram'], Variogram['variogrammodel'])
- #print textplot
- ##for n in range(len(Variogram['variogrammodel'].r['dist'][0])): #@FIXME: so less Pythonic!!
- ## dist = Variogram['datavariogram'].r['dist'][0][n]
- ## gamma = Variogram['datavariogram'].r['gamma'][0][n]
- ## LineList.append((dist,gamma))
- ### give them to plot.PolyPoints and plot.PolyLine
- ## plot it
- #VariogramPlot = plot.PlotGraphics([DataPoints])#,
- # #title = "Wa",
- # #xlabel = "Distance",
- # #ylabel = "Gamma") #([DataPoints, line], title, xlabel, ylabel)
- #self.PlotArea.Draw(VariogramPlot)
- # B: use R plot function, in a separate window.
- thread.start_new_thread(self.plot, ())
- #self.plot()
- def plot(self):
- #robjects.r.X11()
- #robjects.r.png("variogram.png")
- textplot = robjects.r.plot(Variogram['datavariogram'], Variogram['variogrammodel'])
- print textplot
- self.refresh()
- #robjects.r['dev.off']()
- def refresh(self):
- while True:
- rinterface.process_revents()
- time.sleep(0.1)
-class RBookgeoRPanel(RBookPanel):
- """ Subclass of RBookPanel, with specific geoR options and kriging functions. """
- #@TODO: change these two lines as soon as geoR f(x)s are integrated.
- for n in self.GetChildren():
- n.Hide()
- self.Sizer.Add(wx.StaticText(self, id= wx.ID_ANY, label = _("Work in progress! No functionality provided.")))
-def main(argv=None):
- #@FIXME: solve this double ifelse. the control should not be done twice.
- if argv is None:
- importR()
- argv = sys.argv[1:] #stripping first item, the full name of this script
- # wxGUI call.
- app = wx.App()
- KrigingFrame = KrigingModule(parent=None)
- KrigingFrame.Centre()
- KrigingFrame.Show()
- app.MainLoop()
- else:
- #CLI
- options, flags = argv
- #@TODO: Work on verbosity. Sometimes it's too verbose (R), sometimes not enough.
- if grass.find_file(options['input'], element = 'vector')['fullname'] is '':
- grass.fatal(_("option: <input>: Vector map not found."))
- #@TODO: elaborate input string, if contains mapset or not.. thanks again to Bob for testing on 64bit.
- # create output map name, if not specified
- if options['output'] is '':
- try: # to strip mapset name from fullname. Ugh.
- options['input'] = options['input'].split("@")[0]
- except:
- pass
- options['output'] = options['input'] + '_kriging'
- # check for output map with same name. g.parser can't handle this, afaik.
- if grass.find_file(options['output'], element = 'cell')['fullname'] and os.getenv("GRASS_OVERWRITE") == None:
- grass.fatal(_("option: <output>: Raster map already exists."))
- if options['output_var'] is not '' and (grass.find_file(options['output_var'], element = 'cell')['fullname'] and os.getenv("GRASS_OVERWRITE") == None):
- grass.fatal(_("option: <output>: Variance raster map already exists."))
- importR()
- if options['model'] is '':
- try:
- robjects.r.require("automap")
- except ImportError, e:
- grass.fatal(_("R package automap is missing, no variogram autofit available."))
- else:
- if options['sill'] is '' or options['nugget'] is '' or options['range'] is '':
- grass.fatal(_("You have specified model, but forgot at least one of sill, nugget and range."))
- #@TODO: let GRASS remount its commandstring. Until then, keep that 4 lines below.
- #print grass.write_command(argv)
- command = ""
- notnulloptions = {}
- for k, v in options.items():
- if v is not '':
- notnulloptions[k] = v
- command = command.join("%s=%s " % (k, v) for k, v in notnulloptions.items())
- #print command
- # re-cast integers from strings, as parser() cast everything to string.
- for each in ("sill","nugget","range"):
- if options[each] is not '':
- options[each] = int(options[each])
- else:
- options[each] = robjects.r('''NA''')
- controller.Run(input = options['input'],
- column = options['column'],
- output = options['output'],
- overwrite = os.getenv("GRASS_OVERWRITE") == 1,
- package = options['package'],
- model = options['model'],
- block = options['block'],
- sill = options['sill'],
- nugget = options['nugget'],
- range = options['range'],
- output_var = options['output_var'],
- logger = grass)
-def importR():
- # R
- # unuseful since rpy2 will complain adequately.
- # try:
- # #@FIXME: in Windows, it launches R terminal
- # grass.find_program('R')
- # except:
- # sys.exit(_("R is not installed. Install it and re-run, or modify environment variables."))
- # rpy2
- global robjects
- global rinterface
- try:
- import rpy2.robjects as robjects
- import rpy2.rinterface as rinterface #to speed up kriging? for plots.
- haveRpy2 = True
- except ImportError:
- print >> sys.stderr, "Rpy2 not found. Please install it and re-run." # ok for other OSes?
- haveRpy2 = False
- if not haveRpy2:
- sys.exit(1)
- # R packages check.
- # @FIXME: it leaves a Rtmpxxxx folder into the make tempfolder and causes make complain. [markus]
- for each in ["gstat", "spgrass6"]:
- if not robjects.r.require(each, quietly=True)[0]:
- sys.exit(_("R package " + each + " is missing. Install it and re-run v.krige."))
-if __name__ == '__main__':
- if len(sys.argv) > 1:
- sys.exit(main(argv=grass.parser()))
- else:
- main()
