[GRASS-SVN] r40077 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Dec 19 16:20:53 EST 2009
Author: martinl
Date: 2009-12-19 16:20:53 -0500 (Sat, 19 Dec 2009)
New Revision: 40077
grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
wxGUI: split log/prompt area
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py 2009-12-19 21:17:21 UTC (rev 40076)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py 2009-12-19 21:20:53 UTC (rev 40077)
@@ -128,15 +128,17 @@
def abort(self):
self.requestCmd.abort()
-class GMConsole(wx.Panel):
+class GMConsole(wx.SplitterWindow):
"""!Create and manage output console for commands run by GUI.
def __init__(self, parent, id=wx.ID_ANY, margin=False, pageid=0,
notebook = None,
style=wx.TAB_TRAVERSAL | wx.FULL_REPAINT_ON_RESIZE,
**kwargs):
- wx.Panel.__init__(self, parent, id, style = style, *kwargs)
+ wx.SplitterWindow.__init__(self, parent, id, style = style, *kwargs)
self.SetName("GMConsole")
+ self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
# initialize variables
self.Map = None
@@ -160,16 +162,10 @@
# progress bar
- self.console_progressbar = wx.Gauge(parent=self, id=wx.ID_ANY,
+ self.console_progressbar = wx.Gauge(parent=self.panel, id=wx.ID_ANY,
range=100, pos=(110, 50), size=(-1, 25),
style=wx.GA_HORIZONTAL)
self.console_progressbar.Bind(EVT_CMD_PROGRESS, self.OnCmdProgress)
- # abort
- self.btn_abort = wx.Button(parent = self, id = wx.ID_ANY, label = _("&Abort command"),
- size=(125,-1))
- self.btn_abort.SetToolTipString(_("Abort the running command"))
- self.btn_abort.Bind(wx.EVT_BUTTON, self.OnCmdAbort)
- self.btn_abort.Enable(False)
# text control for command output
@@ -181,13 +177,15 @@
self.cmd_output.Bind(wx.EVT_TIMER, self.OnProcessPendingOutputWindowEvents)
self.Bind(EVT_CMD_RUN, self.OnCmdRun)
self.Bind(EVT_CMD_DONE, self.OnCmdDone)
+ # command prompt
+ self.cmd_prompt = prompt.GPromptSTC(parent = self.panel, id=wx.ID_ANY,
+ onRun = self.RunCmd)
+ if self.parent.GetName() != 'LayerManager':
+ self.cmd_prompt.Hide()
- if self.parent.GetName() == 'LayerManager':
- # command prompt
- self.cmd_prompt = prompt.GPromptSTC(self, id=wx.ID_ANY)
# stream redirection
@@ -202,21 +200,25 @@
# buttons
- self.console_clear = wx.Button(parent = self, id = wx.ID_ANY,
- label = _("C&lear output"), size=(125,-1))
- self.cmd_clear = wx.Button(parent = self, id = wx.ID_ANY,
+ self.btn_console_clear = wx.Button(parent = self.panel, id = wx.ID_ANY,
+ label = _("C&lear output"), size=(125,-1))
+ self.btn_cmd_clear = wx.Button(parent = self.panel, id = wx.ID_ANY,
label = _("Cl&ear command"), size=(125,-1))
- self.Bind(wx.EVT_BUTTON, self.cmd_prompt.OnCmdErase, self.cmd_clear)
- self.console_save = wx.Button(parent = self, id = wx.ID_ANY,
- label = _("&Save output"), size=(125,-1))
- self.Bind(wx.EVT_BUTTON, self.ClearHistory, self.console_clear)
- self.Bind(wx.EVT_BUTTON, self.SaveHistory, self.console_save)
+ self.btn_cmd_clear.Hide()
+ self.btn_console_save = wx.Button(parent = self.panel, id = wx.ID_ANY,
+ label = _("&Save output"), size=(125,-1))
+ # abort
+ self.btn_abort = wx.Button(parent = self.panel, id = wx.ID_ANY, label = _("&Abort command"),
+ size=(125,-1))
+ self.btn_abort.SetToolTipString(_("Abort the running command"))
+ self.btn_abort.Enable(False)
- self.Bind(EVT_CMD_ABORT, self.OnCmdAbort)
+ self.btn_cmd_clear.Bind(wx.EVT_BUTTON, self.cmd_prompt.OnCmdErase)
+ self.btn_console_clear.Bind(wx.EVT_BUTTON, self.ClearHistory)
+ self.btn_console_save.Bind(wx.EVT_BUTTON, self.SaveHistory)
+ self.btn_abort.Bind(wx.EVT_BUTTON, self.OnCmdAbort)
+ self.btn_abort.Bind(EVT_CMD_ABORT, self.OnCmdAbort)
self.__layout()
@@ -225,33 +227,39 @@
boxsizer = wx.BoxSizer(wx.VERTICAL)
buttonsizer = wx.BoxSizer(wx.HORIZONTAL)
- boxsizer.Add(item=self.cmd_output, proportion=1,
- flag=wx.EXPAND | wx.ALIGN_BOTTOM, border=0)
- boxsizer.Add(item=self.cmd_prompt, proportion=0,
- flag=wx.EXPAND | wx.FIXED_MINSIZE | wx.ALIGN_BOTTOM, border=0)
- buttonsizer.Add(item=self.console_clear, proportion=0,
+ boxsizer.Add(item=self.cmd_prompt, proportion=1,
+ flag=wx.EXPAND | wx.ALL, border=1)
+ buttonsizer.Add(item=self.btn_console_clear, proportion=0,
flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE | wx.ALL, border=5)
- buttonsizer.Add(item=self.console_save, proportion=0,
+ buttonsizer.Add(item=self.btn_console_save, proportion=0,
- buttonsizer.Add(item=self.cmd_clear, proportion=0,
- flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE | wx.ALL, border=5)
+ buttonsizer.Add(item=self.btn_cmd_clear, proportion=0,
+ flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE | wx.ALL, border=5)
buttonsizer.Add(item=self.btn_abort, proportion=0,
boxsizer.Add(item=buttonsizer, proportion=0,
flag=wx.ALIGN_CENTER)
- boxsizer.Add(item=self.console_progressbar, proportion=0,
- flag=wx.EXPAND | wx.ALIGN_CENTRE_VERTICAL | wx.LEFT | wx.RIGHT, border=5)
+ boxsizer.Add(item=self.console_progressbar, proportion=1,
+ flag=wx.EXPAND | wx.ALIGN_CENTRE_VERTICAL | wx.LEFT | wx.RIGHT | wx.BOTTOM, border=3)
boxsizer.Fit(self)
boxsizer.SetSizeHints(self)
+ self.panel.SetSizer(boxsizer)
+ # split window
+ if self.parent.GetName() == 'LayerManager':
+ self.SplitHorizontally(self.cmd_output, self.panel, -75)
+ self.SetMinimumPaneSize(100)
+ else:
+ self.SplitHorizontally(self.cmd_output, self.panel, -10)
+ self.SetMinimumPaneSize(65)
+ self.Fit()
# layout
self.SetAutoLayout(True)
- self.SetSizer(boxsizer)
self.Layout()
def Redirect(self):
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py 2009-12-19 21:17:21 UTC (rev 40076)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py 2009-12-19 21:20:53 UTC (rev 40077)
@@ -668,11 +668,12 @@
class GPromptSTC(wx.stc.StyledTextCtrl):
"""!Styled GRASS prompt with autocomplete and calltips"""
- def __init__(self, parent, id, size=wx.DefaultSize, margin=False, wrap=None):
+ def __init__(self, parent, id, onRun, margin=False, wrap=None):
wx.stc.StyledTextCtrl.__init__(self, parent, id)
self.parent = parent
self.SetUndoCollection(True)
+ self.RunCmd = onRun
# styles
@@ -898,7 +899,7 @@
maplist = []
self.maptype = ''
- #what kind of map/data type is desired?
+ # what kind of map/data type is desired?
if (((cmdtype in ['r', 'i'] or cmd in self.drastcmd) and arg in self.rastargs) or
((cmd=='nviz' or cmdtype=='r3') and arg in ['elevation','color']) or
arg in ['rast', 'raster']):
@@ -920,9 +921,7 @@
self.maptype ='group'
elif arg=='3dview':
self.maptype ='3dview'
- print 'maptype at end of = ' + str(self.maptype)
elif event.GetKeyCode() == 44:
# autocompletion after ','
# if comma is pressed, use the same maptype as previous for multiple map entries
@@ -996,7 +995,7 @@
cmd = shlex.split(str(line))
#send the command list to the processor
- self.parent.RunCmd(cmd)
+ self.RunCmd(cmd)
#add command to history
self.cmdbuffer.append(line)
