[GRASS-SVN] r40084 - grass/branches/develbranch_6/scripts/v.krige
Sun Dec 20 07:25:03 EST 2009
Author: martinl
Date: 2009-12-20 07:25:02 -0500 (Sun, 20 Dec 2009)
New Revision: 40084
Removed:
   grass/branches/develbranch_6/scripts/v.krige/v.krige.html
   grass/branches/develbranch_6/scripts/v.krige/v.krige.py
clean up dir
Deleted: grass/branches/develbranch_6/scripts/v.krige/v.krige.html
--- grass/branches/develbranch_6/scripts/v.krige/v.krige.html	2009-12-20 06:20:23 UTC (rev 40083)
+++ grass/branches/develbranch_6/scripts/v.krige/v.krige.html	2009-12-20 12:25:02 UTC (rev 40084)
@@ -1,178 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>v.krige</em> allows to perform kriging operations in GRASS
-environment, using R software functions in background.
-<h2>NOTES</h2>
-<em>v.krige</em> is just a front-end to R. The options and parameters
-are the same offered by packages <i>automap</i> and <i>gstat</i>.
-<p>
-Kriging, like other interpolation methods, is fully dependent on input
-data features. Exploratory analysis of data is encouraged to find out
-outliers, trends, anisotropies, uneven distributions and consequently
-choose the kriging algorithm that will give the most acceptable
-result. Good knowledge of the dataset is more valuable than hundreds
-of parameters or powerful hardware. See Isaaks and Srivastava's book,
-exhaustive and clear even if a bit outdated.
-<h3>Dependencies</h3>
-<dl>
-<dt><b>R software >= 2.x</b></dt>
-<dd></dd>
-<dt><b>rpy2</b></dt>
-<dd>Python binding to R. Note! rpy is not supported.</dd>
-<dt><b>R packages automap and gstat. </b></dt>
-<dd>automap is optional (provides automatic variogram fit).</dd>
-</dl>
-<h4>Notes for Debian GNU/Linux</h4>
-Install the dependiencies. <b>Attention! python-rpy IS NOT
-SUITABLE.</b>:
-<div class="code"><pre>
-  aptitude install R python-rpy2
-<pre></div>
-To install R packages, use either R's function (as root):
-  install.packages("gstat", dep=T)
-  install.packages("spgrass6", dep=T)
-<pre></div>
-either the brand new Debian packages [5], add to repositories' list
-for 32bit or 64bit (pick up the suitable line):
-  deb <a href="http://debian.cran.r-project.org/cran2deb/debian-i386">http://debian.cran.r-project.org/cran2deb/debian-i386</a> testing/
-  deb <a href="http://debian.cran.r-project.org/cran2deb/debian-amd64">http://debian.cran.r-project.org/cran2deb/debian-amd64</a> testing/
-<pre></div>
-and get the packages via aptitude:
-  aptitude install r-cran-gstat r-cran-spgrass6
-<pre></div>
-<h4>Notes for Windows</h4>
-Compile GRASS following this
-<a href="http://trac.osgeo.org/grass/wiki/CompileOnWindows">guide</a>.
-You could also use Linux in a virtual machine. Or install Linux in a
-separate partition of the HD. This is not as painful as it appears,
-there are lots of guides over the Internet to help you.
-<h3>Computation time issues</h3>
-Please note that kriging calculation is slown down both by high number
-of input data points and/or high region resolution, even if they both
-contribute to a better output.
-<h2>EXAMPLES</h2>
-Kriging example based on elevation map (Spearfish data set).
-<p>
-<b>Part 1: random sampling</b> of 2000 vector points from known
-elevation map. Each point will receive the elevation value from the
-elevation raster, as if it came from a point survey.
- g.region rast=elevation.10m -p
- v.random output=rand2k_elev n=2000
- v.db.addtable map=rand2k_elev column="elevation double precision"
- v.what.rast vect=rand2k_elev rast=elevation.10m column=elevation
-<pre></div>
-<b>Part 2: remove points lacking elevation attributes</b>. Points
-sampled at the border of the elevation map didn't receive any
-value. v.krige has no preferred action to cope with no data values, so
-the user must check for them and decide what to do (remove points,
-fill with the value of the nearest point, fill with the global/local
-mean...). In the following line of code, points with no data are
-removed from the map.
- v.extract rand2k_elev output=rand2k_elev_filt where="elevation not NULL"
-<pre></div>
-Check the result of previous line ("number of NULL attributes" must be
-0):
- v.univar rand2k_elev_filt type=point column=elevation
-<pre></div>
-<b>Part 3: reconstruct DEM through kriging</b>. Using automatic
-variogram fit is the simplest way to run v.krige from CLI (note:
-requires R's automap package). Output map name is optional, the
-modules creates it automatically appending "_kriging" the the input
-map name and also checks for overwrite. If output_var is specified,
-the variance map is also created. Automatic variogram fit is provided
-by R package automap, the variogram models tested by the fitting
-functions are: exponential, spherical, Gaussian, Matern, M.Stein's
-parametrisation. A wider range of models is available from gstat
-package and can be tested on the GUI via the variogram plotting. If
-model is specified in the CLI, also sill, nugget and range values are
-to be provided, otherwise an error is raised (see second example of
-v.krige command).
- v.krige input=rand2k_elev_filt column=elevation output=rand2k_elev_kriging \
-         output_var=rand2k_elev_kriging_var
-         output_var=rand2k_elev_kriging_var model=Lin sill=2500 nugget=0 range=1000 \
-         --overwrite
-<pre></div>
-Or run wxGUI, to interactively fit the variogram and explore options:
-  v.krige
-</pre></div>
-<b>Calculate prediction error</b>:
- r.mapcalc "rand2k_elev_kriging_pe = sqrt(rand2k_elev_kriging_var)"
- r.univar elevation.10m
- r.univar rand2k_elev_kriging
- r.univar rand2k_elev_kriging_pe
-<pre></div>
-The results show high errors, as the kriging techniques (ordinary and
-block kriging) are unable to handle a dataset with a trend, like the
-one used in this example: elevation is higher in the southwest corner
-and lower on northeast corner. Universal kriging can give far better
-results in these cases as it can handle the trend. It is available in
-R package gstat and will be part of a future v.krige release.
-<h2>SEE ALSO</h2>
-R package <a href="http://cran.r-project.org/web/packages/gstat/index.html">gstat</a>,
-mantained by Edzer J. Pebesma and others
-<br>
-R
-package <a href="http://cran.r-project.org/web/packages/spgrass6/index.html">spgrass6</a>,
-mantained by Roger Bivand
-<br><br>
-v.krige's <a href="http://grass.osgeo.org/wiki/V.krige_GSoC_2009">wiki page</a>
-<h2>REFERENCES</h2>
-Isaaks and Srivastava, 1989: "An Introduction to Applied Geostatistics" (ISBN 0-19-505013-4)
-<h2>AUTHOR</h2>
-Anne Ghisla, Google Summer of Code 2009
-<p>
-<i>Last changed: $Date$</i>
Deleted: grass/branches/develbranch_6/scripts/v.krige/v.krige.py
--- grass/branches/develbranch_6/scripts/v.krige/v.krige.py	2009-12-20 06:20:23 UTC (rev 40083)
+++ grass/branches/develbranch_6/scripts/v.krige/v.krige.py	2009-12-20 12:25:02 UTC (rev 40084)
@@ -1,862 +0,0 @@
-#!/usr/bin/env python
-MODULE:    v.krige
-AUTHOR(S): Anne Ghisla <a.ghisla AT gmail.com>
-PURPOSE:   Performs ordinary or block kriging
-DEPENDS:   R 2.x, packages gstat and spgrass6, optional: automap
-COPYRIGHT: (C) 2009 by the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
-## g.parser informations
-#%module
-#% description: Performs ordinary or block kriging.
-#% keywords: vector, interpolation, kriging
-#%end
-#%option
-#% key: input
-#% type: string
-#% gisprompt: old,vector,vector
-#% description: Name of point vector map containing sample data
-#% required: yes
-#%end
-#%option
-#% key: column
-#% type: string
-#% gisprompt: old,dbcolumn,dbcolumn
-#% description: Name of attribute column with numerical value to be interpolated
-#% required : yes
-#%end
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new,cell,raster
-#% label: Name for output raster map
-#% description: If omitted, will be <input name>_kriging
-#% required : no
-#%end
-#%option
-#% key: package
-#% type: string
-#% options: gstat
-#% answer: gstat
-#% description: R package to use
-#% required: no
-#%end
-#%option
-#% key: model
-#% type: string
-#% options: Exp,Sph,Gau,Mat,Lin
-#% multiple: yes
-#% label: Variogram model(s)
-#% description: Leave empty to test all models (requires automap)
-#% required: no
-#%end
-#%option
-#% key: block
-#% type: integer
-#% multiple: no
-#% label: Block size (square block)
-#% description: Block size. Used by block kriging.
-#% required: no
-#%end
-#%option
-#% key: range
-#% type: integer
-#% label: Range value
-#% description: Automatically fixed if not set
-#% required : no
-#%end
-#%option
-#% key: nugget
-#% type: integer
-#% label: Nugget value
-#% required : no
-#%end
-#%option
-#% key: sill
-#% type: integer
-#% label: Sill value
-#% required : no
-#%end
-#%option
-#% key: output_var
-#% type: string
-#% label: Name for output variance raster map
-#% description: If omitted, will be <input name>_kriging_var
-#% required : no
-#%end
-import os, sys
-from tempfile import gettempdir
-import time
-import thread
-GUIModulesPath = os.path.join(os.getenv("GISBASE"), "etc", "wxpython", "gui_modules")
-sys.path.append(GUIModulesPath)
-GUIPath = os.path.join(os.getenv("GISBASE"), "etc", "wxpython")
-sys.path.append(GUIPath)
-import globalvar
-if not os.getenv("GRASS_WXBUNDLED"):
-    globalvar.CheckForWx()
-import gselect
-import goutput
-import menuform
-#import help
-import wx
-import wx.lib.flatnotebook as FN
-import wx.lib.plot as plot # for plotting the variogram.
-### i18N
-import gettext
-gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
-### dependencies to be checked once, as they are quite time-consuming. cfr. grass.parser.
-# GRASS binding
-try:
-    import grass.script as grass
-except ImportError:
-    sys.exit(_("No GRASS-python library found."))
-# move other checks in functions, as R?
-# globals
-maxint = 1e6 # instead of sys.maxint, not working with SpinCtrl on 64bit [reported by Bob Moskovitz]
-Region = grass.region()
-Command = None
-InputData = None
-Variogram = None
-VariogramFunction = None
-robjects = None
-rinterface = None
-#classes in alphabetical order. methods in logical order :)
-class Controller():
-    """ Executes analysis. For the moment, only with gstat functions."""
-    def ImportMap(self, map, column):
-        """ Adds x,y columns to the GRASS map and then imports it in R.
-        Checks for NULL values in the provided column and exits if they are present."""
-        #@NOTE: it alters original data. Is it correct? Shall I remove those columns
-        # if they were absent from original data?
-        cols = grass.vector_columns(map = map, layer = 1)
-        if not cols.has_key('x') and not cols.has_key('y'):
-            grass.run_command('v.db.addcolumn', map = map,
-                              columns = 'x double precision, y double precision')
-            grass.run_command('v.to.db', map = map, option = 'coor', col = 'x,y')
-        nulls = int(grass.parse_command('v.univar', map = map, column = column, type = 'point', \
-                                            parse = (grass.parse_key_val, \
-                                     {'sep':': '}))['number of NULL attributes'])
-        if nulls > 0:
-            grass.fatal(_("%d NULL value(s) in the selected column - unable to perform kriging.") % nulls)
-        return robjects.r.readVECT6(map, type =  'point')
-    def CreateGrid(self, inputdata):
-        Grid = robjects.r.gmeta2grd()
-        # addition of coordinates columns into dataframe.
-        coordinatesDF = robjects.r['as.data.frame'](robjects.r.coordinates(Grid))
-        data = robjects.r['data.frame'](x = coordinatesDF.r['s1'][0],
-                                        y = coordinatesDF.r['s2'][0],
-                                        k = robjects.r.rep(1, Region['cols']*Region['rows']))
-        GridPredicted = robjects.r.SpatialGridDataFrame(Grid,
-                                                        data,
-                                                        proj4string =  robjects.r.CRS(robjects.r.proj4string(inputdata)))
-        return GridPredicted
-    def ComposeFormula(self, column, isblock, inputdata):
-        if isblock is True:
-            predictor = 'x+y'
-        else:
-            predictor = 1
-        Formula = robjects.r['as.formula'](robjects.r.paste(column, "~", predictor))
-        #print Formula
-        return Formula
-    def FitVariogram(self, formula, inputdata, sill, nugget, range, model = ''):
-        """ Fits variogram either automagically either specifying all parameters.
-        Returns a list containing data and model variograms. """
-        Variograms = {}
-        if model is '':
-            robjects.r.require('automap')
-            DottedParams = {}
-            #print (nugget.r_repr(), sill, range)
-            DottedParams['fix.values'] = robjects.r.c(nugget, range, sill)
-            VariogramModel = robjects.r.autofitVariogram(formula, inputdata, **DottedParams)
-            #print robjects.r.warnings()
-            Variograms['datavariogram'] = VariogramModel.r['exp_var'][0]
-            Variograms['variogrammodel'] = VariogramModel.r['var_model'][0]
-            # obtain the model name. *Too* complicated to get the string instead of level, unlike R does.
-            VariogramAsDF = robjects.r['as.data.frame'](VariogramModel.r['var_model'][0]) # force conversion
-            ModelDF = VariogramAsDF.r['model'][0]
-            Variograms['model'] = robjects.r.levels(ModelDF).subset(ModelDF[1])[0]
-        else:
-            DataVariogram = robjects.r['variogram'](formula, inputdata)
-            VariogramModel = robjects.r['fit.variogram'](DataVariogram,
-                                                         model = robjects.r.vgm(psill = sill,
-        model = model,
-        nugget = nugget,
-        range = range))
-            Variograms['datavariogram'] = DataVariogram
-            Variograms['model'] = model
-        return Variograms
-    def DoKriging(self, formula, inputdata, grid, model, block):
-        DottedParams = {'debug.level': -1} # let krige() print percentage status
-        if block is not '': #@FIXME(anne): but it's a string!! and krige accepts it!!
-            DottedParams['block'] = block
-        #print DottedParams
-        KrigingResult = robjects.r.krige(formula, inputdata, grid, model, **DottedParams)
-        return KrigingResult
-    def ExportMap(self, map, column, name, overwrite, command, variograms):
-        # add kriging parameters to raster map history
-        robjects.r.writeRAST6(map, vname = name, zcol = column, overwrite = overwrite)
-        grass.run_command('r.support',
-                          map = name,
-                          title = 'Kriging output',
-                          history = 'Issued from command v.krige ' + command)
-        if command.find('model') is -1: # if the command has no model option, add automap chosen model
-                                      map = name,
-                                      history = 'Model chosen by automatic fitting: ' + variograms['model'])
-    def Run(self, input, column, output, package, sill, nugget, range, logger, \
-            overwrite, model, block, output_var, command, **kwargs):
-        """ Wrapper for all functions above. """
-        logger.message(_("Processing %d cells. Computing time raises exponentially with resolution." % Region['cells']))
-        logger.message(_("Importing data..."))
-        if globals()["InputData"] is None:
-            globals()["InputData"] = self.ImportMap(input, column)
-        # and from here over, InputData refers to the global variable
-        #print(robjects.r.slot(InputData, 'data').names)
-        logger.message(_("Data successfully imported."))
-        GridPredicted = self.CreateGrid(InputData)
-        logger.message(_("Fitting variogram..."))
-        isblock = block is not ''
-        Formula = self.ComposeFormula(column, isblock, InputData)
-        if globals()["Variogram"] is None:
-            globals()["Variogram"] = self.FitVariogram(Formula,
-                                          InputData,
-                                          model = model,
-                                          sill = sill,
-                                          nugget = nugget,
-                                          range = range)
-        logger.message(_("Variogram fitted."))
-        logger.message(_("Kriging..."))
-        KrigingResult = self.DoKriging(Formula, InputData, GridPredicted, Variogram['variogrammodel'], block) # using global ones
-        logger.message(_("Kriging performed."))
-        self.ExportMap(map = KrigingResult,
-                       column='var1.pred',
-                       name = output,
-                       overwrite = overwrite,
-                       command = command,
-                       variograms = Variogram)
-        if output_var is not '':
-                           column='var1.var',
-                           name = output_var,
-class KrigingPanel(wx.Panel):
-    """ Main panel. Contains all widgets except Menus and Statusbar. """
-    def __init__(self, parent, *args, **kwargs):
-        wx.Panel.__init__(self, parent, *args, **kwargs)
-        self.parent = parent
-        self.border = 4
-        #    1. Input data
-        InputBoxSizer = wx.StaticBoxSizer(wx.StaticBox(self, id = wx.ID_ANY, label = _("Input Data")),
-                                          orient = wx.HORIZONTAL)
-        flexSizer = wx.FlexGridSizer(cols = 3, hgap = 5, vgap = 5)
-        flexSizer.AddGrowableCol(1)
-        flexSizer.Add(item = wx.StaticText(self, id = wx.ID_ANY, label = _("Point dataset:")),
-                      flag = wx.ALIGN_CENTER_VERTICAL)
-        self.InputDataMap = gselect.VectorSelect(parent = self,
-                                                 ftype = 'points',
-                                                 updateOnPopup = False)
-        self.InputDataMap.SetFocus()
-        flexSizer.Add(item = self.InputDataMap, flag = wx.ALIGN_CENTER_VERTICAL)
-        RefreshButton = wx.Button(self, id = wx.ID_REFRESH)
-        RefreshButton.Bind(wx.EVT_BUTTON, self.OnButtonRefresh)
-        flexSizer.Add(item = RefreshButton, flag = wx.ALIGN_CENTER_VERTICAL)
-        flexSizer.Add(item = wx.StaticText(self, id = wx.ID_ANY, label = _("Numeric column:")),
-        self.InputDataColumn = gselect.ColumnSelect(self, id = wx.ID_ANY)
-        self.InputDataColumn.SetSelection(0)
-        flexSizer.Add(item = self.InputDataColumn)
-        self.InputDataMap.GetChildren()[0].Bind(wx.EVT_TEXT, self.OnInputDataChanged)
-        InputBoxSizer.Add(item = flexSizer)
-        #    2. Kriging. In book pages one for each R package. Includes variogram fit.
-        KrigingSizer = wx.StaticBoxSizer(wx.StaticBox(self, id = wx.ID_ANY, label = _("Kriging")), wx.HORIZONTAL)
-        self.RPackagesBook = FN.FlatNotebook(parent = self, id = wx.ID_ANY,
-                                        style = FN.FNB_BOTTOM |
-                                        FN.FNB_NO_NAV_BUTTONS |
-                                        FN.FNB_FANCY_TABS | FN.FNB_NO_X_BUTTON)
-        for Rpackage in ["gstat"]: # , "geoR"]: #@TODO: enable it if/when it'll be implemented.
-            self.CreatePage(package = Rpackage)
-        ## Command output. From menuform module, cmdPanel class
-        self.goutput = goutput.GMConsole(parent = self, margin = False,
-                                         pageid = self.RPackagesBook.GetPageCount(),
-                                         notebook = self.RPackagesBook)
-        self.goutputId = self.RPackagesBook.GetPageCount()
-        self.outpage = self.RPackagesBook.AddPage(self.goutput, text = _("Command output"))
-        self.RPackagesBook.SetSelection(0)
-        KrigingSizer.Add(self.RPackagesBook, proportion = 1, flag = wx.EXPAND)
-        #    3. Output Parameters.
-        OutputSizer = wx.StaticBoxSizer(wx.StaticBox(self, id = wx.ID_ANY, label = _("Output")), wx.HORIZONTAL)
-        OutputParameters = wx.GridBagSizer(hgap = 5, vgap = 5)
-        OutputParameters.AddGrowableCol(1)
-        OutputParameters.Add(item = wx.StaticText(self, id = wx.ID_ANY, label = _("Name for the output raster map:")),
-                             flag = wx.ALIGN_CENTER_VERTICAL,
-                             pos = (0, 0))
-        self.OutputMapName = gselect.Select(parent = self, id = wx.ID_ANY,
-                                            type = 'raster',
-                                            mapsets = [grass.gisenv()['MAPSET']])
-        OutputParameters.Add(item = self.OutputMapName, flag = wx.EXPAND | wx.ALL,
-                             pos = (0, 1))
-        self.VarianceRasterCheckbox = wx.CheckBox(self, id = wx.ID_ANY, label = _("Export variance map as well: "))
-        self.VarianceRasterCheckbox.SetValue(state = True)
-        OutputParameters.Add(item = self.VarianceRasterCheckbox,
-                             pos = (1, 0))
-        self.OutputVarianceMapName = gselect.Select(parent = self, id = wx.ID_ANY,
-                                            type = 'raster',
-        self.VarianceRasterCheckbox.Bind(wx.EVT_CHECKBOX, self.OnVarianceCBChecked)
-        OutputParameters.Add(item = self.OutputVarianceMapName, flag = wx.EXPAND | wx.ALL,
-                             pos = (1, 1))
-        self.OverwriteCheckBox = wx.CheckBox(self, id = wx.ID_ANY,
-                                             label = _("Allow output files to overwrite existing files"))
-        self.OverwriteCheckBox.SetValue(state = False)
-        OutputParameters.Add(item = self.OverwriteCheckBox,
-                             pos = (2, 0), span = (1, 2))
-        OutputSizer.Add(OutputParameters, proportion = 0, flag = wx.EXPAND | wx.ALL, border = self.border)
-        #    4. Run Button and Quit Button
-        ButtonSizer = wx.BoxSizer(wx.HORIZONTAL)
-        HelpButton = wx.Button(self, id = wx.ID_HELP)
-        HelpButton.Bind(wx.EVT_BUTTON, self.OnHelpButton)
-        QuitButton = wx.Button(self, id = wx.ID_EXIT)
-        QuitButton.Bind(wx.EVT_BUTTON, self.OnCloseWindow)
-        self.RunButton = wx.Button(self, id = wx.ID_ANY, label = _("&Run")) # no stock ID for Run button..
-        self.RunButton.Bind(wx.EVT_BUTTON, self.OnRunButton)
-        self.RunButton.Enable(False) # disable it on loading the interface, as input map is not set
-        ButtonSizer.Add(HelpButton, proportion = 0, flag = wx.ALIGN_LEFT | wx.ALL, border = self.border)
-        ButtonSizer.Add(QuitButton, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = self.border)
-        ButtonSizer.Add(self.RunButton, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = self.border)
-        #    Main Sizer. Add each child sizer as soon as it is ready.
-        Sizer = wx.BoxSizer(wx.VERTICAL)
-        Sizer.Add(InputBoxSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = self.border)
-        Sizer.Add(KrigingSizer, proportion = 1, flag = wx.EXPAND | wx.ALL, border = self.border)
-        Sizer.Add(OutputSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = self.border)
-        Sizer.Add(ButtonSizer, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = self.border)
-        self.SetSizerAndFit(Sizer)
-        # last action of __init__: update imput data list.
-        # it's performed in the few seconds gap while user examines interface before clicking anything.
-        #@TODO: implement a splashcreen IF the maps cause a noticeable lag [markus' suggestion]
-        self.InputDataMap.GetElementList()
-    def CreatePage(self, package):
-        """ Creates the three notebook pages, one for each R package """
-        for package in ["gstat"]:
-            classobj = eval("RBook"+package+"Panel")
-            setattr(self, "RBook"+package+"Panel", (classobj(self, id = wx.ID_ANY)))
-            self.RPackagesBook.AddPage(page = getattr(self, "RBook"+package+"Panel"), text = package)
-    def OnButtonRefresh(self, event):
-        """ Forces refresh of list of available layers. """
-    def OnCloseWindow(self, event):
-        """ Cancel button pressed"""
-        self.parent.Close()
-        event.Skip()
-    def OnHelpButton(self, event):
-        # file = os.path.join(os.getenv("GISBASE"), "docs", "html", "v.krige.html")
-        # file = os.path.join(os.path.curdir, "description.html")
-        # @TODO fix HelpWindow
-        # helpFrame = help.HelpWindow(parent=self, id=wx.ID_ANY,
-        #                            title=_("GRASS - Help page for v.krige"),
-        #                            size=(640, 480),
-        #                            file=file)
-        # helpFrame.Show(True)
-        grass.run_command('g.manual', entry = 'v.krige')
-        event.Skip()
-    def OnInputDataChanged(self, event):
-        """ Refreshes list of columns and fills output map name TextCtrl """
-        MapName = event.GetString()
-        self.InputDataColumn.InsertColumns(vector = MapName,
-                                   layer = 1, excludeKey = True,
-                                   type = ['integer', 'double precision'])
-        self.RunButton.Enable(self.InputDataColumn.GetSelection() is not -1)
-        self.RBookgstatPanel.PlotButton.Enable(self.InputDataColumn.GetSelection() is not -1)
-        if self.InputDataColumn.GetSelection() is not -1:
-            self.OutputMapName.SetValue(MapName.split("@")[0]+"_kriging")
-            self.OutputVarianceMapName.SetValue(MapName.split("@")[0]+"_kriging_var")
-        else:
-            self.OutputMapName.SetValue('')
-            self.OutputVarianceMapName.SetValue('')
-    def OnRunButton(self,event):
-        """ Execute R analysis. """
-        #@FIXME: send data to main method instead of running it here.
-        #-1: get the selected notebook page. The user shall know that [s]he can modify settings in all
-        # pages, but only the selected one will be executed when Run is pressed.
-        SelectedPanel = self.RPackagesBook.GetCurrentPage()
-        if self.RPackagesBook.GetPageText(self.RPackagesBook.GetSelection()) == 'Command output':
-            self.goutput.WriteError("No parameters for running. Please select \"gstat\" tab, check parameters and re-run.")
-            return False # no break invoked by above function
-        # mount command string as it would have been written on CLI
-        command = ["v.krige", "input=" + self.InputDataMap.GetValue(),
-                   "column=" + self.InputDataColumn.GetValue(),
-                   "output=" + self.OutputMapName.GetValue(),
-                   "package=" + '%s' % self.RPackagesBook.GetPageText(self.RPackagesBook.GetSelection())]
-        if not hasattr(SelectedPanel, 'VariogramCheckBox') or not SelectedPanel.VariogramCheckBox.IsChecked():
-            command.append("model=" + '%s' % SelectedPanel.ModelChoicebox.GetStringSelection().split(" ")[0])
-        for i in ['Sill', 'Nugget', 'Range']:
-            if getattr(SelectedPanel, i+"ChextBox").IsChecked():
-                command.append(i.lower() + "=" + '%s' % getattr(SelectedPanel, i+'Ctrl').GetValue())
-        if SelectedPanel.KrigingRadioBox.GetStringSelection() == "Block kriging":
-            command.append("block=" + '%s' % SelectedPanel.BlockSpinBox.GetValue())
-        if self.OverwriteCheckBox.IsChecked():
-            command.append("--overwrite")
-        if self.VarianceRasterCheckbox.IsChecked():
-            command.append("output_var=" + self.OutputVarianceMapName.GetValue())
-        # give it to the output console
-        #@FIXME: it runs the command as a NEW instance. Reimports data, recalculates variogram fit..
-        #otherwise I can use Controller() and mimic RunCmd behaviour.
-        self.goutput.RunCmd(command, switchPage = True)
-    def OnVarianceCBChecked(self, event):
-        self.OutputVarianceMapName.Enable(event.IsChecked())
-class KrigingModule(wx.Frame):
-    """ Kriging module for GRASS GIS. Depends on R and its packages gstat and geoR. """
-        wx.Frame.__init__(self, parent, *args, **kwargs)
-        # setting properties and all widgettery
-        self.SetTitle(_("Kriging Module"))
-        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_dialog.ico'), wx.BITMAP_TYPE_ICO))
-        self.log = Log(self)
-        self.CreateStatusBar()
-        self.log.message(_("Ready."))
-        self.Panel = KrigingPanel(self)
-        self.SetMinSize(self.GetBestSize())
-        self.SetSize(self.GetBestSize())
-class Log:
-    """ The log output is redirected to the status bar of the containing frame. """
-    def __init__(self, parent):
-    def message(self, text_string):
-        """ Updates status bar """
-        self.parent.SetStatusText(text_string.strip())
-class RBookPanel(wx.Panel):
-    """ Generic notebook page with shared widgets and empty kriging functions. """
-        self.VariogramSizer = wx.StaticBoxSizer(wx.StaticBox(self,
-                                                             id = wx.ID_ANY,
-                                                             label = _("Variogram fitting")),
-                                                wx.HORIZONTAL)
-        self.LeftSizer = wx.BoxSizer(wx.VERTICAL)
-        self.RightSizer = wx.BoxSizer(wx.VERTICAL)
-        self.ParametersSizer = wx.GridBagSizer(vgap = 5, hgap = 5)
-        self.VariogramSizer.Add(self.LeftSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = parent.border)
-        self.VariogramSizer.Add(self.RightSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = parent.border)
-        # left side of Variogram fitting. The checkboxes and spinctrls.
-        self.PlotButton = wx.Button(self, id = wx.ID_ANY, label = _("Plot/refresh variogram")) # no stock ID for Run button..
-        self.PlotButton.Bind(wx.EVT_BUTTON, self.OnPlotButton)
-        self.PlotButton.Enable(False) # grey it out until a suitable layer is available
-        self.LeftSizer.Add(self.PlotButton, proportion = 0, flag =  wx.ALL, border = parent.border)
-        self.LeftSizer.Add(self.ParametersSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = parent.border)
-        self.ParametersList = ["Sill", "Nugget", "Range"]
-        MinValues = [0,0,1]
-        for n in self.ParametersList:
-            setattr(self, n+"ChextBox", wx.CheckBox(self,
-                                                    id = self.ParametersList.index(n),
-                                                    label = _(n + ":")))
-            setattr(self, n+"Ctrl", (wx.SpinCtrl(self,
-                                                 id = wx.ID_ANY,
-                                                 min = MinValues[self.ParametersList.index(n)],
-                                                 max = maxint)))
-            getattr(self, n+"ChextBox").Bind(wx.EVT_CHECKBOX,
-                                             self.UseValue,
-                                             id = self.ParametersList.index(n))
-            setattr(self, n+"Sizer", (wx.BoxSizer(wx.HORIZONTAL)))
-            self.ParametersSizer.Add(getattr(self, n+"ChextBox"),
-                                     pos = (self.ParametersList.index(n),0))
-            self.ParametersSizer.Add(getattr(self, n+"Ctrl"),
-                                     flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL,
-                                     pos = (self.ParametersList.index(n),1))
-        # right side of the Variogram fitting. The plot area.
-        #Plot = wx.StaticText(self, id= wx.ID_ANY, label = "Check Plot Variogram to interactively fit model.")
-        #PlotPanel = wx.Panel(self)
-        #self.PlotArea = plot.PlotCanvas(PlotPanel)
-        #self.PlotArea.SetInitialSize(size = (250,250))
-        #self.RightSizer.Add(PlotPanel, proportion=0, flag= wx.EXPAND|wx.ALL, border=parent.border)
-        self.KrigingSizer = wx.StaticBoxSizer(wx.StaticBox(self,
-                                                             id = wx.ID_ANY,
-                                                             label = _("Kriging techniques")),
-                                                wx.VERTICAL)
-        KrigingList = ["Ordinary kriging", "Block kriging"]#, "Universal kriging"] #@FIXME: i18n on the list?
-        self.KrigingRadioBox = wx.RadioBox(self,
-                                           id = wx.ID_ANY,
-                                           choices = KrigingList,
-                                           majorDimension = 1,
-                                           style = wx.RA_SPECIFY_COLS)
-        self.KrigingRadioBox.Bind(wx.EVT_RADIOBOX, self.HideBlockOptions)
-        self.KrigingSizer.Add(self.KrigingRadioBox, proportion = 0, flag = wx.EXPAND | wx.ALL, border = parent.border)
-        # block kriging parameters. Size.
-        BlockSizer = wx.BoxSizer(wx.HORIZONTAL)
-        BlockLabel = wx.StaticText(self, id = wx.ID_ANY, label = _("Block size:"))
-        self.BlockSpinBox = wx.SpinCtrl(self, id = wx.ID_ANY, min = 1, max = maxint)
-        self.BlockSpinBox.Enable(False) # default choice is Ordinary kriging so block param is disabled
-        BlockSizer.Add(BlockLabel, flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL, border = parent.border)
-        BlockSizer.Add(self.BlockSpinBox, flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border = parent.border)
-        self.KrigingSizer.Add(BlockSizer, flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border = parent.border)
-        self.Sizer = wx.BoxSizer(wx.VERTICAL)
-        self.Sizer.Add(self.VariogramSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = parent.border)
-        self.Sizer.Add(self.KrigingSizer,  proportion = 0, flag = wx.EXPAND | wx.ALL, border = parent.border)
-    def HideBlockOptions(self, event):
-        self.BlockSpinBox.Enable(event.GetInt() == 1)
-    def OnPlotButton(self,event):
-        """ Plots variogram with current options. """
-        pass
-    def UseValue(self, event):
-        """ Enables/Disables the SpinCtrl in respect of the checkbox. """
-        n = self.ParametersList[event.GetId()]
-        getattr(self, n+"Ctrl").Enable(event.IsChecked())
-class RBookgstatPanel(RBookPanel):
-    """ Subclass of RBookPanel, with specific gstat options and kriging functions. """
-        RBookPanel.__init__(self, parent, *args, **kwargs)
-        if robjects.r.require('automap')[0]:
-            self.VariogramCheckBox = wx.CheckBox(self, id = wx.ID_ANY, label = _("Auto-fit variogram"))
-            self.LeftSizer.Insert(0,
-                                  self.VariogramCheckBox,
-                                  proportion = 0,
-                                  flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL,
-                                  border = 4)
-            self.SetSizerAndFit(self.Sizer)
-            self.VariogramCheckBox.Bind(wx.EVT_CHECKBOX, self.HideOptions)
-            self.VariogramCheckBox.SetValue(state = True) # check it by default
-        ModelFactor = robjects.r.vgm().r['long']
-        ModelList = robjects.r.levels(ModelFactor[0])
-        #@FIXME: no other way to let the Python pick it up..
-        # and this is te wrong place where to load this list. should be at the very beginning.
-        self.ModelChoicebox = wx.Choice(self, id = wx.ID_ANY, choices = ModelList)
-        # disable model parameters' widgets by default
-        for n in ["Sill", "Nugget", "Range"]:
-            getattr(self, n+"Ctrl").Enable(False)
-        self.ModelChoicebox.Enable(False)
-        VariogramSubSizer = wx.BoxSizer(wx.HORIZONTAL)
-        VariogramSubSizer.Add(item = wx.StaticText(self,
-                                                 id =  wx.ID_ANY,
-                                                 label = _("Model: ")),
-                              flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL,
-                              border = 4)
-        VariogramSubSizer.Add(item = self.ModelChoicebox,
-                              border = 4)
-        self.LeftSizer.Insert(2, item = VariogramSubSizer)
-    def HideOptions(self, event):
-        self.ModelChoicebox.Enable(not event.IsChecked())
-            if not event.IsChecked():
-                getattr(self, n+"Ctrl").Enable(True)
-                getattr(self, n+ "ChextBox").SetValue(True)
-                getattr(self, n+ "ChextBox").Enable(False) # grey it out keeping it checked.. improvable
-            else:
-                getattr(self, n+ "ChextBox").SetValue(False)
-                getattr(self, n+ "ChextBox").Enable(True)
-        #@FIXME: was for n in self.ParametersSizer.GetChildren(): n.Enable(False) but doesn't work
-        ## BIG WARNING: smell of code duplication. Fix this asap.
-        controller = Controller()
-        map = self.parent.InputDataMap.GetValue()
-        column = self.parent.InputDataColumn.GetValue()
-        # import data or pick them up
-            globals()["InputData"] = controller.ImportMap(map = map,
-                                                          column = column)
-        # fit the variogram or pick it up
-        Formula = controller.ComposeFormula(column = column,
-                                            isblock = self.KrigingRadioBox.GetStringSelection() == "Block kriging",
-                                            inputdata = globals()['InputData'])
-        #if globals()["Variogram"] is None:
-        if hasattr(self, 'VariogramCheckBox') and self.VariogramCheckBox.IsChecked():
-            self.model = ''
-            for each in ("Sill","Nugget","Range"):
-                if getattr(self, each+'ChextBox').IsChecked():
-                    setattr(self, each.lower(), getattr(self, each+"Ctrl").GetValue())
-                else:
-                    setattr(self, each.lower(), robjects.r('''NA'''))
-        else:
-            self.model = self.ModelChoicebox.GetStringSelection().split(" ")[0]
-                if getattr(self, each+'ChextBox').IsChecked(): #@FIXME will be removed when chextboxes will be frozen
-        globals()["Variogram"] = controller.FitVariogram(Formula,
-                                                         InputData,
-                                                         model = self.model,
-                                                         sill = self.sill,
-                                                         nugget = self.nugget,
-                                                         range = self.range)
-        ## A: use wx.plot library. Does not draw lines from f(x), damn.
-        ## convert R dataframe (data variogram) - points
-        ##print Variogram['datavariogram']
-        #PointList = []
-        #for n in range(len(Variogram['datavariogram'].r['dist'][0])): #@FIXME: so less Pythonic!!
-        #    dist = Variogram['datavariogram'].r['dist'][0][n]
-        #    gamma = Variogram['datavariogram'].r['gamma'][0][n]
-        #    PointList.append((dist,gamma))
-        #DataPoints = plot.PolyMarker(PointList, legend='points', colour='black', marker='circle',size=1)
-        ## convert R dataframe (model variogram) - line
-        #LineList = []
-        #textplot = robjects.r.plot(Variogram['datavariogram'], Variogram['variogrammodel'])
-        #print textplot
-        ##for n in range(len(Variogram['variogrammodel'].r['dist'][0])): #@FIXME: so less Pythonic!!
-        ##    dist = Variogram['datavariogram'].r['dist'][0][n]
-        ##    gamma = Variogram['datavariogram'].r['gamma'][0][n]
-        ##    LineList.append((dist,gamma))
-        ### give them to plot.PolyPoints and plot.PolyLine
-        ## plot it
-        #VariogramPlot = plot.PlotGraphics([DataPoints])#,
-        #                          #title = "Wa",
-        #                          #xlabel = "Distance",
-        #                          #ylabel = "Gamma") #([DataPoints, line], title, xlabel, ylabel)
-        #self.PlotArea.Draw(VariogramPlot)
-        # B: use R plot function, in a separate window.
-        thread.start_new_thread(self.plot, ())
-        #self.plot()
-    def plot(self):
-        #robjects.r.X11()
-        #robjects.r.png("variogram.png")
-        textplot = robjects.r.plot(Variogram['datavariogram'], Variogram['variogrammodel'])
-        print textplot
-        self.refresh()
-        #robjects.r['dev.off']()
-    def refresh(self):
-        while True:
-            rinterface.process_revents()
-            time.sleep(0.1)
-class RBookgeoRPanel(RBookPanel):
-    """ Subclass of RBookPanel, with specific geoR options and kriging functions. """
-        #@TODO: change these two lines as soon as geoR f(x)s are integrated.
-        for n in self.GetChildren():
-            n.Hide()
-        self.Sizer.Add(wx.StaticText(self, id = wx.ID_ANY, label = _("Work in progress! No functionality provided.")))
-def main(argv = None):
-    #@FIXME: solve this double ifelse. the control should not be done twice.
-    if argv is None:
-        importR()
-        argv = sys.argv[1:] #stripping first item, the full name of this script
-        # wxGUI call.
-        app = wx.App()
-        KrigingFrame = KrigingModule(parent = None)
-        KrigingFrame.Centre()
-        KrigingFrame.Show()
-        app.MainLoop()
-    else:
-        #CLI
-        options, flags = argv
-        #@TODO: Work on verbosity. Sometimes it's too verbose (R), sometimes not enough.
-        if grass.find_file(options['input'], element = 'vector')['fullname'] is '':
-            grass.fatal(_("option: <input>: Vector map not found."))
-        #@TODO: elaborate input string, if contains mapset or not.. thanks again to Bob for testing on 64bit.
-        # create output map name, if not specified
-        if options['output'] is '':
-            try: # to strip mapset name from fullname. Ugh.
-                options['input'] = options['input'].split("@")[0]
-            except:
-                pass
-            options['output'] = options['input'] + '_kriging'
-        # check for output map with same name. g.parser can't handle this, afaik.
-        if grass.find_file(options['output'], element = 'cell')['fullname'] and os.getenv("GRASS_OVERWRITE") == None:
-            grass.fatal(_("option: <output>: Raster map already exists."))
-        if options['output_var'] is not '' and (grass.find_file(options['output_var'], element = 'cell')['fullname'] and os.getenv("GRASS_OVERWRITE") == None):
-            grass.fatal(_("option: <output>: Variance raster map already exists."))
-        importR()
-        if options['model'] is '':
-            try:
-                robjects.r.require("automap")
-            except ImportError, e:
-                grass.fatal(_("R package automap is missing, no variogram autofit available."))
-        else:
-            if options['sill'] is '' or options['nugget'] is '' or options['range'] is '':
-                grass.fatal(_("You have specified model, but forgot at least one of sill, nugget and range."))
-        #@TODO: let GRASS remount its commandstring. Until then, keep that 4 lines below.
-        #print grass.write_command(argv)
-        command = ""
-        notnulloptions = {}
-        for k, v in options.items():
-            if v is not '':
-                notnulloptions[k] = v
-        command = command.join("%s=%s " % (k, v) for k, v in notnulloptions.items())
-        #print command
-        # re-cast integers from strings, as parser() cast everything to string.
-        for each in ("sill","nugget","range"):
-            if options[each] is not '':
-                options[each] = int(options[each])
-            else:
-                options[each] = robjects.r('''NA''')
-        controller.Run(input = options['input'],
-                       column = options['column'],
-                       output = options['output'],
-                       overwrite = os.getenv("GRASS_OVERWRITE") == 1,
-                       package = options['package'],
-                       model = options['model'],
-                       block = options['block'],
-                       sill = options['sill'],
-                       nugget = options['nugget'],
-                       range = options['range'],
-                       output_var = options['output_var'],
-                       logger = grass)
-def importR():
-    # R
-    # unuseful since rpy2 will complain adequately.
-    # try:
-    #    #@FIXME: in Windows, it launches R terminal
-    #    grass.find_program('R')
-    # except:
-    #    sys.exit(_("R is not installed. Install it and re-run, or modify environment variables."))
-    # rpy2
-    global robjects
-    global rinterface
-    try:
-        import rpy2.robjects as robjects
-        import rpy2.rinterface as rinterface #to speed up kriging? for plots.
-        haveRpy2 = True
-    except ImportError:
-        print >> sys.stderr, "Rpy2 not found. Please install it and re-run." # ok for other OSes?
-        haveRpy2 = False
-        if not haveRpy2:
-            sys.exit(1)
-    # R packages check.
-    # @FIXME: it leaves a Rtmpxxxx folder into the make tempfolder and causes make complain. [markus]
-    for each in ["gstat", "spgrass6"]:
-        if not robjects.r.require(each, quietly = True)[0]:
-            sys.exit(_("R package " + each + " is missing. Install it and re-run v.krige."))
-if __name__ == '__main__':
-    if len(sys.argv) > 1:
-        sys.exit(main(argv = grass.parser()))
-    else:
-        main()
