[GRASS-SVN] r40087 - grass/trunk/raster/r.solute.transport
svn_grass at osgeo.org
Sun Dec 20 08:02:40 EST 2009
Author: martinl
Date: 2009-12-20 08:02:39 -0500 (Sun, 20 Dec 2009)
New Revision: 40087
grass/trunk/raster/r.solute.transport/main.c
r.solute.transport: standard options + i18n
Modified: grass/trunk/raster/r.solute.transport/main.c
--- grass/trunk/raster/r.solute.transport/main.c 2009-12-20 12:42:29 UTC (rev 40086)
+++ grass/trunk/raster/r.solute.transport/main.c 2009-12-20 13:02:39 UTC (rev 40087)
@@ -9,7 +9,7 @@
* PURPOSE: Calculates transient two dimensional solute transport
* in porous media
-* COPYRIGHT: (C) 2006 by the GRASS Development Team
+* COPYRIGHT: (C) 2006-2009 by Soeren Gebbert, and the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -54,128 +54,82 @@
void set_params()
- param.c = G_define_option();
+ param.c = G_define_standard_option(G_OPT_R_INPUT);
param.c->key = "c";
- param.c->type = TYPE_STRING;
- param.c->required = YES;
- param.c->gisprompt = "old,raster,raster";
param.c->description = _("The initial concentration in [kg/m^3]");
- param.phead = G_define_option();
+ param.phead = G_define_standard_option(G_OPT_R_INPUT);
param.phead->key = "phead";
- param.phead->type = TYPE_STRING;
- param.phead->required = YES;
- param.phead->gisprompt = "old,raster,raster";
param.phead->description = _("The piezometric head in [m]");
- param.hc_x = G_define_option();
+ param.hc_x = G_define_standard_option(G_OPT_R_INPUT);
param.hc_x->key = "hc_x";
- param.hc_x->type = TYPE_STRING;
- param.hc_x->required = YES;
- param.hc_x->gisprompt = "old,raster,raster";
param.hc_x->description =
_("The x-part of the hydraulic conductivity tensor in [m/s]");
- param.hc_y = G_define_option();
+ param.hc_y = G_define_standard_option(G_OPT_R_INPUT);
param.hc_y->key = "hc_y";
- param.hc_y->type = TYPE_STRING;
- param.hc_y->required = YES;
- param.hc_y->gisprompt = "old,raster,raster";
param.hc_y->description =
_("The y-part of the hydraulic conductivity tensor in [m/s]");
- param.status = G_define_option();
+ param.status = G_define_standard_option(G_OPT_R_INPUT);
param.status->key = "status";
- param.status->type = TYPE_STRING;
- param.status->required = YES;
- param.status->gisprompt = "old,raster,raster";
param.status->description =
- _
- ("The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - dirichlet- and 3 - transfer boundary condition");
+ _("The status for each cell, = 0 - inactive cell, 1 - active cell, "
+ "2 - dirichlet- and 3 - transfer boundary condition");
- param.diff_x = G_define_option();
+ param.diff_x = G_define_standard_option(G_OPT_R_INPUT);
param.diff_x->key = "diff_x";
- param.diff_x->type = TYPE_STRING;
- param.diff_x->required = YES;
- param.diff_x->gisprompt = "old,raster,raster";
param.diff_x->description =
_("The x-part of the diffusion tensor in [m�/s]");
- param.diff_y = G_define_option();
+ param.diff_y = G_define_standard_option(G_OPT_R_INPUT);
param.diff_y->key = "diff_y";
- param.diff_y->type = TYPE_STRING;
- param.diff_y->required = YES;
- param.diff_y->gisprompt = "old,raster,raster";
param.diff_y->description =
_("The y-part of the diffusion tensor in [m�/s]");
- param.q = G_define_option();
+ param.q = G_define_standard_option(G_OPT_R_INPUT);
param.q->key = "q";
- param.q->type = TYPE_STRING;
param.q->required = NO;
- param.q->gisprompt = "old,raster,raster";
- param.q->description = _("groundwater sources and sinks in [m^3/s]");
+ param.q->description = _("Groundwater sources and sinks in [m^3/s]");
- param.cin = G_define_option();
+ param.cin = G_define_standard_option(G_OPT_R_INPUT);
param.cin->key = "cin";
- param.cin->type = TYPE_STRING;
param.cin->required = NO;
- param.cin->gisprompt = "old,raster,raster";
- param.cin->description = _("concentration sources and sinks in [kg/m^3]");
+ param.cin->description = _("Concentration sources and sinks in [kg/m^3]");
- param.cs = G_define_option();
+ param.cs = G_define_standard_option(G_OPT_R_INPUT);
param.cs->key = "cs";
- param.cs->type = TYPE_STRING;
- param.cs->required = YES;
- param.cs->gisprompt = "old,raster,raster";
- param.cs->description = _("concentration sources and sinks in [kg/m^3]");
+ param.cs->description = _("Concentration sources and sinks in [kg/m^3]");
- param.r = G_define_option();
+ param.r = G_define_standard_option(G_OPT_R_INPUT);
param.r->key = "R";
- param.r->type = TYPE_STRING;
- param.r->required = YES;
- param.r->gisprompt = "old,raster,raster";
param.r->description = _("Retardation factor [-]");
- param.nf = G_define_option();
+ param.nf = G_define_standard_option(G_OPT_R_INPUT);
param.nf->key = "nf";
- param.nf->type = TYPE_STRING;
- param.nf->required = YES;
- param.nf->gisprompt = "old,raster,raster";
param.nf->description = _("Effective porosity [-]");
- param.top = G_define_option();
+ param.top = G_define_standard_option(G_OPT_R_INPUT);
param.top->key = "top";
- param.top->type = TYPE_STRING;
- param.top->required = YES;
- param.top->gisprompt = "old,raster,raster";
param.top->description = _("Top surface of the aquifer in [m]");
- param.bottom = G_define_option();
+ param.bottom = G_define_standard_option(G_OPT_R_INPUT);
param.bottom->key = "bottom";
- param.bottom->type = TYPE_STRING;
- param.bottom->required = YES;
- param.bottom->gisprompt = "old,raster,raster";
param.bottom->description = _("Bottom surface of the aquifer in [m]");
- param.output = G_define_option();
- param.output->key = "output";
- param.output->type = TYPE_STRING;
- param.output->required = YES;
- param.output->gisprompt = "new,raster,raster";
+ param.output = G_define_standard_option(G_OPT_R_OUTPUT);
param.output->description =
- _
- ("The result of the numericalsolute transport calculation will be written to this map. [kg/m�]");
+ _("The result of the numericalsolute transport calculation "
+ "will be written to this map. [kg/m�]");
- param.vector = G_define_option();
+ param.vector = G_define_standard_option(G_OPT_R_OUTPUT);
param.vector->key = "velocity";
- param.vector->type = TYPE_STRING;
param.vector->required = NO;
- param.vector->gisprompt = "new,raster,raster";
param.vector->description =
- _
- ("Calculate the groundwater distance velocity vector field and write the x, and y components to maps named name_(xy), [m/s]");
+ _("Calculate the groundwater distance velocity vector "
+ "field and write the x, and y components to maps named name_(xy), [m/s]");
param.dt = N_define_standard_option(N_OPT_CALC_TIME);
param.maxit = N_define_standard_option(N_OPT_MAX_ITERATIONS);
@@ -220,16 +174,12 @@
param.sparse = G_define_flag();
param.sparse->key = 's';
param.sparse->description =
- _
- ("Use a sparse linear equation system, only available with iterative solvers");
+ _("Use a sparse linear equation system, only available with iterative solvers");
param.cfl = G_define_flag();
param.cfl->key = 'c';
param.cfl->description =
- _
- ("Use the Courant-Friedrichs-Lewy criteria for time step calculation");
+ _("Use the Courant-Friedrichs-Lewy criteria for time step calculation");
@@ -263,8 +213,7 @@
G_add_keyword(_("raster"));
G_add_keyword(_("solute transport"));
module->description =
- _
- ("Numerical calculation program for transient, confined and unconfined solute transport in two dimensions");
+ _("Numerical calculation program for transient, confined and unconfined solute transport in two dimensions.");
/* Get parameters from user */
set_params();
@@ -283,11 +232,9 @@
solver = param.solver->answer;
if (strcmp(solver, G_MATH_SOLVER_DIRECT_LU) == 0 && param.sparse->answer)
- G_fatal_error(_
- ("The direct LU solver do not work with sparse matrices"));
+ G_fatal_error(_("The direct LU solver do not work with sparse matrices"));
if (strcmp(solver, G_MATH_SOLVER_DIRECT_GAUSS) == 0 && param.sparse->answer)
- G_fatal_error(_
- ("The direct Gauss solver do not work with sparse matrices"));
+ G_fatal_error(_("The direct Gauss solver do not work with sparse matrices"));
/*get the current region */
@@ -399,8 +346,8 @@
time_step = 1*length / fabs(data->grad->min);
- G_message("The Courant-Friedrichs-Lewy criteria is %g it should be within [0:1]", cfl);
- G_message("The largest stable time step is %g", time_step);
+ G_message(_("The Courant-Friedrichs-Lewy criteria is %g it should be within [0:1]"), cfl);
+ G_message(_("The largest stable time step is %g"), time_step);
/*Set the number of inner loops and the time step*/
if (data->dt > time_step && param.cfl->answer) {
@@ -409,12 +356,12 @@
time_loops = data->dt / time_step;
time_loops = floor(time_loops) + 1;
data->dt = data->dt / time_loops;
- G_message("Number of inner loops is %g", time_loops);
- G_message("Time step for each loop %g", data->dt);
+ G_message(_("Number of inner loops is %g"), time_loops);
+ G_message(_("Time step for each loop %g"), data->dt);
else {
if(data->dt > time_step)
- G_warning("The time step is to large: %gs. The largest time step should be of size %gs.", data->dt, time_step);
+ G_warning(_("The time step is to large: %gs. The largest time step should be of size %gs."), data->dt, time_step);
time_loops = loops;
data->dt = data->dt / loops;
@@ -426,7 +373,7 @@
/*Compute for each time step*/
for (i = 0; i < time_loops; i++) {
- G_message("Time step %i with time sum %g", i + 1, (i + 1)*data->dt);
+ G_message(_("Time step %i with time sum %g"), i + 1, (i + 1)*data->dt);
/*assemble the linear equation system and solve it */
les = create_solve_les(geom, data, call, solver, maxit, error, sor);
@@ -574,8 +521,7 @@
G_math_solver_gauss(les->A, les->x, les->b, les->rows);
if (les == NULL)
- G_fatal_error(_
- ("Could not create and solve the linear equation system"));
+ G_fatal_error(_("Could not create and solve the linear equation system"));
return les;
