[GRASS-SVN] r40109 - grass/branches/develbranch_6/gui/tcltk/gis.m
svn_grass at osgeo.org
Tue Dec 22 05:22:07 EST 2009
Author: marisn
Date: 2009-12-22 05:22:06 -0500 (Tue, 22 Dec 2009)
New Revision: 40109
grass/branches/develbranch_6/gui/tcltk/gis.m/labels.tcl
grass/branches/develbranch_6/gui/tcltk/gis.m/maplabels.tcl
gis.m: better PS label position calculation
Modified: grass/branches/develbranch_6/gui/tcltk/gis.m/labels.tcl
--- grass/branches/develbranch_6/gui/tcltk/gis.m/labels.tcl 2009-12-22 09:41:10 UTC (rev 40108)
+++ grass/branches/develbranch_6/gui/tcltk/gis.m/labels.tcl 2009-12-22 10:22:06 UTC (rev 40109)
@@ -10,13 +10,13 @@
namespace eval GmLabels {
- variable array opt # labels current options
+ variable array opt ;# labels current options
variable count 1
- variable array tree # mon
- variable array lfile # labels
- variable array lfilemask # labels
+ variable array tree ;# mon
+ variable array lfile ;# labels
+ variable array lfilemask ;# labels
variable optlist
- variable array dup # layer
+ variable array dup ;# layer
Modified: grass/branches/develbranch_6/gui/tcltk/gis.m/maplabels.tcl
--- grass/branches/develbranch_6/gui/tcltk/gis.m/maplabels.tcl 2009-12-22 09:41:10 UTC (rev 40108)
+++ grass/branches/develbranch_6/gui/tcltk/gis.m/maplabels.tcl 2009-12-22 10:22:06 UTC (rev 40109)
@@ -449,7 +449,7 @@
set opt($id,1,ltxt) [subst -nocommands -novariables $val]
# check to see if there are line breaks in the text
- set newlines [expr [llength [split $opt($id,1,ltxt) "\n"]] - 1]
+ set newlines [llength [split $opt($id,1,ltxt) "\n"]]
# create each label when loop gets to a text line in the labels file
# Here should be set all font related options, that come from labelfile
@@ -460,14 +460,14 @@
# set the label width and height
set linelen [font measure $opt($id,1,lfont) $opt($id,1,ltxt)]
if {$linelen < $opt($id,1,lwidth)} {
- set wid [expr $linelen + 8]
- set lineh [expr $newlines * [font metrics $opt($id,1,lfont) -linespace] + 8]
+ set wid [expr $linelen + 2]
+ set lineh [expr $newlines * [font metrics $opt($id,1,lfont) -linespace]]
} else {
- set wid $opt($id,1,lwidth)
- set lineh [expr $newlines * (ceil($linelen/$opt($id,1,lwidth))+1)\
- * [font metrics $opt($id,1,lfont) -linespace] + 8]
+ set wid $opt($id,1,lwidth); # This is too wide as wrapped text lines might be shorter.
+ set lineh [expr $newlines * (ceil($linelen/($opt($id,1,lwidth)-15.0)))\
+ * [font metrics $opt($id,1,lfont) -linespace]]; # Somtimes font measure gives wrong length. -15.0 is a hack.
- if {$opt($id,1,lopaque) != "yes"} {
+ if {!$opt($id,1,lopaque)} {
set lbackground ""
} else { set lbackground $opt($id,1,lbackground) }
if {!$opt($id,1,lboxbenable)} {
