[GRASS-SVN] r40144 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Dec 25 16:41:28 EST 2009
Author: martinl
Date: 2009-12-25 16:41:28 -0500 (Fri, 25 Dec 2009)
New Revision: 40144
grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
wxGUI/prompt: fix GPromptPopUp
(merge r40142 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py 2009-12-25 21:41:03 UTC (rev 40143)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py 2009-12-25 21:41:28 UTC (rev 40144)
@@ -97,12 +97,11 @@
self.SetChoices(self._choicesCmd)
self.SetMinSize(self.GetSize())
- # read history
- self.SetHistoryItems()
# bindings...
self.Bind(wx.EVT_KILL_FOCUS, self.OnControlChanged)
self.Bind(wx.EVT_TEXT, self.OnEnteredText)
+ self.Bind(wx.EVT_TEXT_ENTER, self.OnRunCmd)
self.Bind(wx.EVT_KEY_DOWN , self.OnKeyDown)
### self.Bind(wx.EVT_LEFT_DOWN, self.OnClick)
@@ -251,30 +250,6 @@
"""!Method required by listmix.ColumnSorterMixin"""
return self.dropdownlistbox
- def SetHistoryItems(self):
- """!Read history file and update combobox items"""
- env = grass.gisenv()
- try:
- fileHistory = open(os.path.join(env['GISDBASE'],
- env['LOCATION_NAME'],
- env['MAPSET'],
- '.bash_history'), 'r')
- except IOError:
- self.SetItems([])
- return
- try:
- hist = []
- for line in fileHistory.readlines():
- hist.append(line.replace('\n', ''))
- self.SetItems(hist)
- finally:
- fileHistory.close()
- return
- self.SetItems([])
def SetChoices(self, choices, type = 'module'):
"""!Sets the choices available in the popup wx.ListBox.
The items will be sorted case insensitively.
@@ -579,9 +554,9 @@
cmd = shlex.split(str(cmdString))
if len(cmd) > 1:
- self.parent.goutput.RunCmd(cmd, switchPage = True)
+ self.parent.RunCmd(cmd, switchPage = True)
else:
- self.parent.goutput.RunCmd(cmd, switchPage = False)
+ self.parent.RunCmd(cmd, switchPage = False)
self.OnUpdateStatusBar(None)
@@ -591,9 +566,9 @@
return
if event is None:
- self.parent.statusbar.SetStatusText("")
+ self.parent.parent.statusbar.SetStatusText("")
else:
- self.parent.statusbar.SetStatusText(_("Type GRASS command and run by pressing ENTER"))
+ self.parent.parent.statusbar.SetStatusText(_("Type GRASS command and run by pressing ENTER"))
event.Skip()
def GetPanel(self):
@@ -616,6 +591,7 @@
value = "",
style = wx.TE_LINEWRAP | wx.TE_PROCESS_ENTER,
statusbar = self.parent.parent.statusbar)
+ self.SetItems(self._readHistory())
except NotImplementedError:
# wx.PopupWindow may be not available in wxMac
# see http://trac.wxwidgets.org/ticket/9377
