[GRASS-SVN] r40152 - grass/trunk/raster/r.watershed/front
svn_grass at osgeo.org
Mon Dec 28 05:16:05 EST 2009
Author: mmetz
Date: 2009-12-28 05:16:04 -0500 (Mon, 28 Dec 2009)
New Revision: 40152
grass/trunk/raster/r.watershed/front/main.c
grass/trunk/raster/r.watershed/front/r.watershed.html
cleaning up, maintenance
Modified: grass/trunk/raster/r.watershed/front/main.c
--- grass/trunk/raster/r.watershed/front/main.c 2009-12-27 18:23:54 UTC (rev 40151)
+++ grass/trunk/raster/r.watershed/front/main.c 2009-12-28 10:16:04 UTC (rev 40152)
@@ -53,10 +53,10 @@
struct Option *opt10;
struct Option *opt11;
struct Option *opt12;
+ struct Option *opt13;
struct Option *opt14;
struct Option *opt15;
struct Option *opt16;
- struct Option *opt17;
struct Flag *flag_sfd;
struct Flag *flag_flow;
struct Flag *flag_seg;
@@ -70,7 +70,8 @@
G_add_keyword(_("raster"));
module->description = _("Watershed basin analysis program.");
- opt1 = G_define_standard_option(G_OPT_R_ELEV);
+ opt1 = G_define_standard_option(G_OPT_R_INPUT);
+ opt1->key = "elevation";
opt1->description =
_("Input map: elevation on which entire analysis is based");
opt1->guisection = _("Input_options");
@@ -171,52 +172,42 @@
opt12->gisprompt = "new,cell,raster";
opt12->guisection = _("Output_options");
-/* to be removed completely. visual display of results is now done with accumulation output
opt13 = G_define_option();
- opt13->key = "visual";
+ opt13->key = "length_slope";
opt13->description =
- _("Output map: useful for visual display of results");
+ _("Output map: slope length and steepness (LS) factor for USLE");
opt13->required = NO;
opt13->type = TYPE_STRING;
opt13->gisprompt = "new,cell,raster";
opt13->guisection = _("Output_options");
opt14 = G_define_option();
- opt14->key = "length_slope";
- opt14->description =
- _("Output map: slope length and steepness (LS) factor for USLE");
+ opt14->key = "slope_steepness";
+ opt14->description = _("Output map: slope steepness (S) factor for USLE");
opt14->required = NO;
opt14->type = TYPE_STRING;
opt14->gisprompt = "new,cell,raster";
opt14->guisection = _("Output_options");
opt15 = G_define_option();
- opt15->key = "slope_steepness";
- opt15->description = _("Output map: slope steepness (S) factor for USLE");
+ opt15->key = "convergence";
+ opt15->type = TYPE_INTEGER;
opt15->required = NO;
- opt15->type = TYPE_STRING;
- opt15->gisprompt = "new,cell,raster";
- opt15->guisection = _("Output_options");
+ opt15->answer = "5";
+ opt15->label = _("Convergence factor for MFD (1-10)");
+ opt15->description =
+ _("1 = most diverging flow, 10 = most converging flow. Recommended: 5");
opt16 = G_define_option();
- opt16->key = "convergence";
+ opt16->key = "memory";
opt16->type = TYPE_INTEGER;
opt16->required = NO;
- opt16->answer = "5";
- opt16->label = _("Convergence factor for MFD (1-10)");
- opt16->description =
- _("1 = most diverging flow, 10 = most converging flow. Recommended: 5");
+ opt16->answer = "300"; /* 300MB default value, please keep r.terraflow in sync */
+ opt16->description = _("Maximum memory to be used with -m flag (in MB)");
- opt17 = G_define_option();
- opt17->key = "memory";
- opt17->type = TYPE_INTEGER;
- opt17->required = NO;
- opt17->answer = "300"; /* 300MB default value, please keep in sync with r.terraflow */
- opt17->description = _("Maximum memory to be used with -m flag (in MB)");
flag_sfd = G_define_flag();
flag_sfd->key = 's';
- flag_sfd->label = _("SFD (D8) flow (default is MFD)"); /* copied straight from terraflow */
+ flag_sfd->label = _("SFD (D8) flow (default is MFD)");
flag_sfd->description =
_("SFD: single flow direction, MFD: multiple flow direction");
@@ -264,9 +255,9 @@
/* half_basin and basin threshold */
err += (opt12->answer != NULL && opt6->answer == NULL);
/* LS factor and basin threshold */
- err += (opt14->answer != NULL && opt6->answer == NULL);
+ err += (opt13->answer != NULL && opt6->answer == NULL);
/* S factor and basin threshold */
- err += (opt15->answer != NULL && opt6->answer == NULL);
+ err += (opt14->answer != NULL && opt6->answer == NULL);
if (err) {
G_message(_("Sorry, if any of the following options are set:\n"
@@ -304,11 +295,11 @@
do_opt(opt10);
do_opt(opt11);
do_opt(opt12);
-/* do_opt(opt13); */
+ do_opt(opt13);
do_opt(opt14);
do_opt(opt15);
- do_opt(opt16);
- do_opt(opt17);
+ if (flag_seg->answer)
+ do_opt(opt16);
new_argv[new_argc++] = NULL;
G_debug(1, "Mode: %s", flag_seg->answer ? "Segmented" : "All in RAM");
@@ -325,7 +316,7 @@
opt1->answer, flag_seg->answer, flag_sfd->answer);
if (opt9->answer)
write_hist(opt9->answer,
- "Watershed drainage direction (divided by 45deg)",
+ "Watershed drainage direction (CCW from East divided by 45deg)",
if (opt10->answer)
write_hist(opt10->answer,
@@ -339,16 +330,12 @@
write_hist(opt12->answer,
"Watershed half-basins", opt1->answer, flag_seg->answer,
flag_sfd->answer);
- /* if (opt13->answer)
+ if (opt13->answer)
write_hist(opt13->answer,
- "Watershed visualization map (filtered accumulation map)",
- opt1->answer, flag_seg->answer, flag_sfd->answer); */
- if (opt14->answer)
- write_hist(opt14->answer,
"Watershed slope length and steepness (LS) factor",
- if (opt15->answer)
- write_hist(opt15->answer,
+ if (opt14->answer)
+ write_hist(opt14->answer,
"Watershed slope steepness (S) factor",
Modified: grass/trunk/raster/r.watershed/front/r.watershed.html
--- grass/trunk/raster/r.watershed/front/r.watershed.html 2009-12-27 18:23:54 UTC (rev 40151)
+++ grass/trunk/raster/r.watershed/front/r.watershed.html 2009-12-28 10:16:04 UTC (rev 40152)
@@ -5,7 +5,7 @@
2) the LS and S factors of the Revised Universal Soil Loss Equation (RUSLE).
<p>
-<!-- Interactive mode not activated in GRASS 6.
+<!-- Interactive mode not activated in GRASS 7.
<em>r.watershed</em> can be run either interactively or non-interactively.
The interactive version of
<em>r.watershed</em> can prepare inputs to lumped-parameter hydrologic models.
@@ -24,9 +24,8 @@
<dd>Without this flag set, the entire analysis is run in memory
maintained by the operating system. This can be limiting, but is
-very fast. Setting the flag causes the program to manage memory
-on disk which allows larger maps to be processed but is considerably
-slower.
+very fast. Setting this flag causes the program to manage memory
+on disk which allows very large maps to be processed but is slower.
<dt><em>-s</em>
@@ -243,7 +242,9 @@
or the swap space size needs to be increased. If <em>seg</em> runs out of
memory, additional disk space needs to be freed up for the program to run.
The <em>r.terraflow</em> module was specifically designed with huge
-regions in mind and may be useful here as an alternative.
+regions in mind and may be useful here as an alternative, although disk
+space requirements of <em>r.terraflow</em> are several times higher than
+of <em>seg</em>.
<h4>Large regions with many cells</h4>
In some situations, the region size (number of cells) may be too large for
