[GRASS-SVN] r40167 -
grass/branches/releasebranch_6_4/raster/r.in.xyz
svn_grass at osgeo.org
Wed Dec 30 22:35:23 EST 2009
Author: hamish
Date: 2009-12-30 22:35:23 -0500 (Wed, 30 Dec 2009)
New Revision: 40167
grass/branches/releasebranch_6_4/raster/r.in.xyz/description.html
grass/branches/releasebranch_6_4/raster/r.in.xyz/main.c
(merge from trunk)
better warn about memory use with extended stats;
error msg instead of segfault if zrange= is empty;
more accurate status message
Modified: grass/branches/releasebranch_6_4/raster/r.in.xyz/description.html
--- grass/branches/releasebranch_6_4/raster/r.in.xyz/description.html 2009-12-31 02:57:49 UTC (rev 40166)
+++ grass/branches/releasebranch_6_4/raster/r.in.xyz/description.html 2009-12-31 03:35:23 UTC (rev 40167)
@@ -51,7 +51,10 @@
and coeff_var</em> will use more.
The aggregate functions <em>median, percentile, skewness</em> and
-<em>trimmed mean</em> will also use more memory.
+<em>trimmed mean</em> will use even more memory and may not be appropriate
+for use with arbitrarily large input files<!-- without a small value for percent= -->.
+<!-- explained: memory use for regular stats will be based solely on region size,
+ but for the aggregate fns it will also depend on the number of data points. (?) -->
<p>
Modified: grass/branches/releasebranch_6_4/raster/r.in.xyz/main.c
--- grass/branches/releasebranch_6_4/raster/r.in.xyz/main.c 2009-12-31 02:57:49 UTC (rev 40166)
+++ grass/branches/releasebranch_6_4/raster/r.in.xyz/main.c 2009-12-31 03:35:23 UTC (rev 40167)
@@ -297,7 +297,10 @@
/* parse zrange */
do_zfilter = FALSE;
- if (zrange_opt->answer != NULL) { /* should this be answerS ? */
+ if (zrange_opt->answer != NULL) {
+ if (zrange_opt->answers[0] == NULL)
+ G_fatal_error(_("Invalid zrange"));
sscanf(zrange_opt->answers[0], "%lf", &zrange_min);
sscanf(zrange_opt->answers[1], "%lf", &zrange_max);
do_zfilter = TRUE;
@@ -515,7 +518,7 @@
/* allocate memory for a single row of output data */
raster_row = G_allocate_raster_buf(rtype);
- G_message(_("Scanning data ..."));
+ G_message(_("Reading data ..."));
count_total = 0;
