[GRASS-SVN] r35726 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Feb 1 17:04:18 EST 2009
Author: martinl
Date: 2009-02-01 17:04:18 -0500 (Sun, 01 Feb 2009)
New Revision: 35726
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI: multiple layer selection fixes
(merge from devbr6, r35725)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2009-02-01 21:58:39 UTC (rev 35725)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2009-02-01 22:04:18 UTC (rev 35726)
@@ -1651,7 +1651,7 @@
point = wx.GetMousePosition()
zoommenu = wx.Menu()
# Add items to the menu
- zoommap = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to selected map'))
+ zoommap = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to selected map(s)'))
zoommenu.AppendItem(zoommap)
self.Bind(wx.EVT_MENU, self.MapWindow.OnZoomToMap, zoommap)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2009-02-01 21:58:39 UTC (rev 35725)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2009-02-01 22:04:18 UTC (rev 35726)
@@ -86,37 +86,54 @@
def OnZoomToRaster(self, event):
pass
- def GetSelectedLayer(self, type='layer'):
+ def GetSelectedLayer(self, type = 'layer', multi = False):
Get selected layer from layer tree
@param type 'item' / 'layer' / 'nviz'
+ @param multi return first selected layer or all
@return layer / map layer properties / nviz properties
- @return None on failure
+ @return None / [] on failure
- # get currently selected map layer
- if not self.tree or not self.tree.GetSelection():
- return None
+ ret = []
+ if not self.tree or \
+ not self.tree.GetSelection():
+ if multi:
+ return []
+ else:
+ return None
- item = self.tree.GetSelection()
- if not item.IsChecked():
- return None
+ if multi and \
+ type == 'item':
+ return self.tree.GetSelections()
+ for item in self.tree.GetSelections():
+ if not item.IsChecked():
+ if multi:
+ continue
+ else:
+ return None
- if type == 'item':
- return item
+ if type == 'item': # -> multi = False
+ return item
- try:
- if type == 'nviz':
- layer = self.tree.GetPyData(item)[0]['nviz']
+ try:
+ if type == 'nviz':
+ layer = self.tree.GetPyData(item)[0]['nviz']
+ else:
+ layer = self.tree.GetPyData(item)[0]['maplayer']
+ except:
+ layer = None
+ if multi:
+ ret.append(layer)
else:
- layer = self.tree.GetPyData(item)[0]['maplayer']
- except:
- layer = None
+ return layer
- return layer
+ return ret
class BufferedWindow(MapWindow, wx.Window):
A Buffered window class.
@@ -2342,7 +2359,7 @@
self.ZoomToMap(zoom=True)
- def ZoomToMap(self, layer=None, zoom=False):
+ def ZoomToMap(self, layer = None, zoom = False):
Set display extents to match selected raster
or vector map.
@@ -2350,40 +2367,40 @@
zoomreg = {}
if not layer:
- layer = self.GetSelectedLayer()
+ layer = self.GetSelectedLayer(multi = True)
- if layer is None:
+ if not layer:
return
+ rast = []
+ vect = []
+ updated = False
+ for l in layer:
+ # only raster/vector layers are currently supported
+ if l.type == 'raster':
+ rast.append(l.name)
+ elif l.type == 'vector':
+ if self.parent.digit and l.name == self.parent.digit.map and \
+ self.parent.digit.type == 'vdigit':
+ w, s, b, e, n, t = self.parent.digit.driver.GetMapBoundingBox()
+ self.Map.GetRegion(n=n, s=s, w=w, e=e,
+ update=True)
+ updated = True
+ else:
+ vect.append(l.name)
- Debug.msg (3, "BufferedWindow.ZoomToMap(): layer=%s, type=%s" % \
- (layer.name, layer.type))
- # selected layer must be a valid map
- if layer.type in ('raster', 'rgb', 'his', 'shaded', 'arrow'):
- if layer.type == 'raster':
- self.Map.region = self.Map.GetRegion(rast="%s" % layer.name)
- else:
- elif layer.type in ('vector', 'thememap', 'themechart'):
- if self.parent.digit and layer.name == self.parent.digit.map and \
- self.parent.digit.type == 'vdigit':
- w, s, b, e, n, t = self.parent.digit.driver.GetMapBoundingBox()
- self.Map.region = self.Map.GetRegion(n=n, s=s, w=w, e=e)
- else:
- self.Map.region = self.Map.GetRegion(vect="%s" % layer.name)
- else:
- return
- ### self.Map.SetRegion()
- ### self.Map.AlignExtentFromDisplay()
+ if not updated:
+ self.Map.GetRegion(rast = rast,
+ vect = vect,
+ update = True)
self.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
self.Map.region['e'], self.Map.region['w'])
self.UpdateMap()
self.parent.StatusbarUpdate()
def ZoomToWind(self, event):
Set display geometry to match computational
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2009-02-01 21:58:39 UTC (rev 35725)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2009-02-01 22:04:18 UTC (rev 35726)
@@ -580,9 +580,9 @@
self.height = 480
return False
- def GetRegion(self, rast=None, zoom=False, vect=None,
- n=None, s=None, e=None, w=None, default=False,
- update=False):
+ def GetRegion(self, rast = [], zoom = False, vect = [],
+ n = None, s = None, e = None, w = None, default = False,
+ update = False):
Get region settings (g.region -upgc)
@@ -627,21 +627,21 @@
if rast:
if zoom:
- cmdList.append('zoom=%s' % rast)
+ cmdList.append('zoom=%s' % ','.join(rast))
else:
- cmdList.append('rast=%s' % rast)
+ cmdList.append('rast=%s' % ','.join(rast))
if vect:
- cmdList.append('vect=%s' % vect)
+ cmdList.append('vect=%s' % ','.join(vect))
try:
cmdRegion = gcmd.Command(cmdList)
except gcmd.CmdError, e:
if rast:
- e.message = _("Unable to zoom to raster map <%s>.") % rast + \
+ e.message = _("Unable to zoom to raster map <%s>.") % rast[0] + \
'%s%s' % (os.linesep, os.linesep) + e.message
elif vect:
- e.message = _("Unable to zoom to vector map <%s>.") % vect + \
+ e.message = _("Unable to zoom to vector map <%s>.") % vect[0] + \
print >> sys.stderr, e
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py 2009-02-01 21:58:39 UTC (rev 35725)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py 2009-02-01 22:04:18 UTC (rev 35726)
@@ -399,6 +399,7 @@
def __writeLayer(self, mapTree, item):
"""Write bunch of layers to GRASS Workspace XML file"""
self.indent += 4
+ itemSelected = mapTree.GetSelections()
while item and item.IsOk():
type = mapTree.GetPyData(item)[0]['type']
if type != 'group':
@@ -433,7 +434,7 @@
self.indent += 4
# selected ?
- if item == mapTree.layer_selected:
+ if item in itemSelected:
self.file.write('%s<selected />\n' % (' ' * self.indent))
# layer properties
self.file.write('%s<task name="%s">\n' % (' ' * self.indent, cmd[0]))
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2009-02-01 21:58:39 UTC (rev 35725)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2009-02-01 22:04:18 UTC (rev 35726)
@@ -228,9 +228,6 @@
Debug.msg (4, "LayerTree.OnContextMenu: layertype=%s" % \
ltype)
- ## pos = event.GetPosition()
- ## pos = self.ScreenToClient(pos)
if not hasattr (self, "popupID1"):
self.popupID1 = wx.NewId()
self.popupID2 = wx.NewId()
@@ -249,6 +246,9 @@
self.popupID15 = wx.NewId()
self.popupMenu = wx.Menu()
+ numSelected = len(self.GetSelections())
# general item
self.popupMenu.Append(self.popupID1, text=_("Remove"))
self.Bind(wx.EVT_MENU, self.gismgr.OnDeleteLayer, id=self.popupID1)
@@ -256,7 +256,9 @@
if ltype != "command": # rename
self.popupMenu.Append(self.popupID2, text=_("Rename"))
self.Bind(wx.EVT_MENU, self.RenameLayer, id=self.popupID2)
+ if numSelected > 1:
+ self.popupMenu.Enable(self.popupID2, False)
# map layer items
if ltype != "group" and \
ltype != "command": # properties
@@ -265,11 +267,14 @@
self.Bind(wx.EVT_MENU, self.OnPopupOpacityLevel, id=self.popupID8)
self.popupMenu.Append(self.popupID3, text=_("Properties"))
self.Bind(wx.EVT_MENU, self.OnPopupProperties, id=self.popupID3)
- self.popupMenu.Append(self.popupID9, text=_("Zoom to selected map"))
+ self.popupMenu.Append(self.popupID9, text=_("Zoom to selected map(s)"))
self.Bind(wx.EVT_MENU, self.mapdisplay.MapWindow.OnZoomToMap, id=self.popupID9)
- self.popupMenu.Append(self.popupID10, text=_("Set computational region from selected map"))
+ self.popupMenu.Append(self.popupID10, text=_("Set computational region from selected map(s)"))
self.Bind(wx.EVT_MENU, self.OnSetCompRegFromMap, id=self.popupID10)
+ self.popupMenu.Enable(self.popupID8, False)
+ self.popupMenu.Enable(self.popupID3, False)
# specific items
try:
mltype = self.GetPyData(self.layer_selected)[0]['type']
@@ -328,14 +333,20 @@
self.popupMenu.Append(self.popupID7, _("Metadata"))
self.Bind (wx.EVT_MENU, self.OnMetadata, id=self.popupID7)
+ self.popupMenu.Enable(self.popupID4, False)
+ self.popupMenu.Enable(self.popupID5, False)
+ self.popupMenu.Enable(self.popupID6, False)
+ self.popupMenu.Enable(self.popupID7, False)
+ self.popupMenu.Enable(self.popupID14, False)
# raster layers (specific items)
elif mltype and mltype == "raster":
- self.popupMenu.Append(self.popupID12, text=_("Zoom to selected map (ignore NULLs)"))
+ self.popupMenu.Append(self.popupID12, text=_("Zoom to selected map(s) (ignore NULLs)"))
self.Bind(wx.EVT_MENU, self.mapdisplay.MapWindow.OnZoomToRaster, id=self.popupID12)
- self.popupMenu.Append(self.popupID13, text=_("Set computational region from selected map (ignore NULLs)"))
+ self.popupMenu.Append(self.popupID13, text=_("Set computational region from selected map(s) (ignore NULLs)"))
self.Bind(wx.EVT_MENU, self.OnSetCompRegFromRaster, id=self.popupID13)
self.popupMenu.AppendSeparator()
self.popupMenu.Append(self.popupID15, _("Set color table"))
@@ -350,6 +361,13 @@
self.popupMenu.Append(self.popupID11, _("Nviz properties"))
self.Bind (wx.EVT_MENU, self.OnNvizProperties, id=self.popupID11)
+ self.popupMenu.Enable(self.popupID15, False)
+ self.popupMenu.Enable(self.popupID11, False)
## self.PopupMenu(self.popupMenu, pos)
self.PopupMenu(self.popupMenu)
self.popupMenu.Destroy()
