[GRASS-SVN] r35733 - grass/trunk/visualization/nviz/scripts
Mon Feb 2 12:59:45 EST 2009
Author: cmbarton
Date: 2009-02-02 12:59:45 -0500 (Mon, 02 Feb 2009)
New Revision: 35733
   grass/trunk/visualization/nviz/scripts/colorPopup.tcl
   grass/trunk/visualization/nviz/scripts/nviz2.2_script
   grass/trunk/visualization/nviz/scripts/panel_main.tcl
   grass/trunk/visualization/nviz/scripts/panel_sdiff.tcl
   grass/trunk/visualization/nviz/scripts/widgets.tcl
Updating NVIZ in GRASS 7 with TclTk fixes made in the GRASS 6 line when TclTk was removed from GRASS 7 (about a month ago).
Modified: grass/trunk/visualization/nviz/scripts/colorPopup.tcl
--- grass/trunk/visualization/nviz/scripts/colorPopup.tcl	2009-02-01 22:34:07 UTC (rev 35732)
+++ grass/trunk/visualization/nviz/scripts/colorPopup.tcl	2009-02-02 17:59:45 UTC (rev 35733)
@@ -1,212 +1,31 @@
 # mkColorPopup w name color
-# Create a dialog box with sliders and buttons to adjust current color
+# Replaced legacy custom dialog box which no longer works on Mac with aqua (and maybe other platforms?)
+#	with native color picker called from tk_chooseColor widget
+# Kept old function name and arguments to avoid having to change call in many different modules
 # Arguments:
-#    w -	Name to use for new top-level window.
+#    w -	Name to use for new top-level window (no longer used)
 #    name -     Label for ColorPopup
 #    color -    CurrentColor
+#    mode - 	Made window modal (no longer used)
 global CurrColor
-proc mkColorPopup {w name {color "#000000"} {mode 0}} {
+proc mkColorPopup {w {name "Choose color"} {color "#000000"} {mode 0}} {
     global CurrColor
-    catch {destroy $w}
-    toplevel $w -class Dialog
-    wm title $w "Select Color"
-    wm iconname $w "Color"
-    wm geometry $w 300x450
-    wm minsize $w 50 100
-    wm resizable $w false false
-    set tmp [tcl_to_rgb $color]
-    set r [expr ($tmp&0xff0000)>>16]
-    set g [expr ($tmp&0x00ff00)>>8]
-    set b [expr ($tmp&0x0000ff)]
-    set tmp $color
-    # Create two frames in the main window. The top frame will hold the
-    # sliders that interactively change color and the bottom one will hold
-    # the buttons for predefined color.
-    frame $w.top -relief raised -border 1
-    frame $w.bot -relief raised -border 1
-    pack $w.top $w.bot -side top -fill both -expand yes
-    # Note that these sliders are now floating sliders since tk4.0
-    # supports these.  This means that color values should be
-    # specified in the range 0.0-1.0.  For ease of use, most routines
-    # just convert from 00-FF to 0.0-1.0.
-    frame $w.top.left
-    Nv_mkColorScale $w.top.left Red $r red  $w.top.color
-    Nv_mkColorScale $w.top.left Green $g green  $w.top.color
-    Nv_mkColorScale $w.top.left Blue $b blue  $w.top.color
-    # ACS One line: without next line, the scales and $w.top.color are set to white next time
-    # after a color button (not sliders) has been used, regardless $color. Don't know why
-    setScales $w.top.left $color
-    pack $w.top.left.red $w.top.left.green $w.top.left.blue -side top -expand 1
-    set CurrColor $color
-    label $w.top.color -bg $color -width 5
-    pack $w.top.left  -side left -expand 1
-    pack $w.top.color -side left  -padx 10 -pady 10 -fill both -expand yes
+    set CurrColor [tk_chooseColor -initialcolor $color -title $name]
-    tkwait visibility $w
-    frame $w.bot.buttonframe
-    button $w.bot.buttonframe.ok -text OK -command "destroy $w" -bd 1
-    button $w.bot.buttonframe.cancel  -bd 1 \
-		-text Cancel  -command "set CurrColor $tmp; destroy $w"
-    label $w.bot.buttonframe.label -text $name
-    pack $w.bot.buttonframe.label  -side left -expand yes -padx 10
-    pack $w.bot.buttonframe.cancel $w.bot.buttonframe.ok -side right -expand 1
-    pack $w.bot.buttonframe -side bottom -fill x
-    mkColorButtons $w.bot.bf $w.top.left $w.top.color
-    pack $w.bot.bf -padx 3 -pady 6 -side top -expand 1
-    bind $w <Any-Enter> [list focus $w]
-    focus $w
-    # If the caller desires, make everything else wait until a color
-    # has been selected or this popup has been dismissed.
-    if {$mode} {grab $w}
-    tkwait window $w
+    if {$CurrColor==""} {set CurrColor #000000}
     return $CurrColor
-proc mkColorButtons { B S L } {
-    global CurrColor
-    frame $B
-    set clist [mkColorList]
-    for {set i 0; set k 0} {$i < 9 } {incr i} {
-	# make frame to hold buttons in this row
-	frame $B.f$i
-	for {set j 0} {$j < 5 } {incr j; incr k} {
-	    set color [lindex $clist $k]
-	    button $B.f$i.$j -bg $color \
-		-activeforeground $color \
-		-activebackground $color \
-		-width 0 -height 0 \
-		-highlightthickness 1 \
-		-padx 7 -pady 0 \
-                -command "setScales $S $color; $L config -bg $color; set CurrColor $color"
-	    pack $B.f$i.$j -side top -expand 1
-	pack $B.f$i -side left
-proc getColorfromScales {S} {
-    # Have to convert colors back to #XXXXXX since that is what
-    # everyone else expects
-    set r [expr int([$S.red.scale get] * 255.0)]
-    set g [expr int([$S.green.scale get] * 255.0)]
-    set b [expr int([$S.blue.scale get] * 255.0)]
-    set r [hexval $r]
-    set g [hexval $g]
-    set b [hexval $b]
-    return #$r$g$b
-proc setLabelfromScales {S L args} {
-    global CurrColor
-    # Convert back to #XXXXXX
-    set r [hexval $r]
-    set g [hexval $g]
-    set b [hexval $b]
-    $L config -bg #$r$g$b
-    set CurrColor #$r$g$b
-proc setScales {S c} {
-    set color [tcl_to_rgb $c]
-    set r [expr ($color&0xff0000)>>16]
-    set g [expr ($color&0x00ff00)>>8]
-    set b [expr ($color&0x0000ff)]
-    $S.red.scale set [expr ($r + 0.0)/255.0]
-    $S.green.scale set [expr ($g + 0.0)/255.0]
-    $S.blue.scale set [expr ($b + 0.0)/255.0]
-proc mkColorList {} {
-    set ramp 0
-    set colorlist {}
-    set maxval ff
-    set minval 00
-    for {set r 4; set i 0} {$r < 16} {incr r 5} {
-        for {set g 4} {$g < 16} {incr g 5} {
-            for {set b 4} {$b < 16 && $i < 40} {incr b 5} {
-		set tmpr [hexval [expr $r/15.0*255]]
-		set tmpg [hexval [expr $g/15.0*255]]
-		set tmpb [hexval [expr $b/15.0*255]]
-		set color #$tmpr$tmpg$tmpb
-		set colorlist [concat $colorlist $color]
-		incr i
-	    if {$ramp == 0} {
-		set colorlist [concat $colorlist #ff0000 #00ffff]
-		incr ramp 2
-		incr i 2
-	    } elseif {$ramp < 10} {
-	        set tmpg [hexval [expr $ramp/9.0*255]]
-		set color #$maxval$tmpg$minval
-		incr ramp
-		incr i
-	        set tmpg [hexval [expr (1.0 - $ramp/9.0)*255]]
-		set color #$minval$tmpg$maxval
-		incr ramp
-		incr i
-	    } elseif {$ramp < 16} {
-	        set tmpb [hexval [expr ($ramp-10)/7.0*255]]
-		set color #$maxval$maxval$tmpb
-		incr ramp
-		incr i
-	        set tmpb [hexval [expr (1.0 - ($ramp-10)/7.0)*255]]
-		set color #$minval$minval$tmpb
-		incr ramp
-		incr i
-    for {set gray 0} {$gray < 5} {incr gray} {
-	set g [hexval [expr (1.0 - $gray/4.0)*255]]
-	set color #$g$g$g
-    return $colorlist
 proc hexval { n }  {
+    # this proc might be used by some other modules
     set n [expr int($n)]
     if {$n > 15} {
@@ -215,39 +34,10 @@
     return [format "0%x" $n]
-# procedure to make sliders
-proc Nv_mkColorScale { P {name " "} {curr 200}\
-    {color ""} {chip ""}} {
-    set S $P.$color
-    frame $S
-    frame $S.f
-    # Make a global variable shared by this scale and its entry
-    global $S.val
-    set $S.val [expr ($curr + 0.0)/255.0]
-    scale $S.scale -from 0.0 -length 140 -showvalue 0 -orient h \
-	-digits 3 -resolution 0.01 -tickinterval 0 -to 1.0 -width 13 \
-	-command "setLabelfromScales $P $chip " \
-        -activebackground gray80 -background gray90 -bg $color \
-	-variable $S.val
-    label $S.f.label -text $name
-    $S.scale set $curr
-    entry $S.f.entry -width 5 -borderwidth 2 -relief sunken -textvariable $S.val
-    bind $S.f.entry <Return> "set $S.val [$S.f.entry get]"
-    pack $S.scale $S.f -side top
-    pack $S.f.label $S.f.entry -side left
-    return $S
 proc tcl_to_rgb {c} {
+    # this proc is used by some other modules
     regsub # $c 0x newcolor
     return $newcolor
Modified: grass/trunk/visualization/nviz/scripts/nviz2.2_script
--- grass/trunk/visualization/nviz/scripts/nviz2.2_script	2009-02-01 22:34:07 UTC (rev 35732)
+++ grass/trunk/visualization/nviz/scripts/nviz2.2_script	2009-02-02 17:59:45 UTC (rev 35733)
@@ -8,7 +8,7 @@
 # Major update of GUI Nov 2006, Michael Barton, Arizona State University
-# COPYRIGHT:	(C) 1999 - 2006 by Michael Barton and the GRASS Development Team
+# COPYRIGHT:	(C) 1999 - 2008 by Michael Barton and the GRASS Development Team
 #		This program is free software under the GNU General Public
 #		License (>=v2). Read the file COPYING that comes with GRASS
@@ -63,7 +63,7 @@
 set Nv_(TOP)	".middle.draw"
 set Nv_(APP)	"."
 set Nv_(P_AREA) ".middle.panelarea.panels"
-set Nv_(PAREA)	 ".middle.panelarea"
+set Nv_(PAREA)	".middle.panelarea"
 set Nv_(AREA)	".top"
 set Nv_(CALLED_SET_FOCUS) no
 set Nv_(CurrSurf) 0
@@ -71,6 +71,7 @@
 set Nv_(CurrSite) 0
 set Nv_(CurrSdiff) 0
 set Nv_(CurrVol) 0
+set Nv_(hidemenus) 1
 # Some quick code to initialize the CurrSurf, CurrVect and CurrSite variables
 set temp [Nget_surf_list]
@@ -185,37 +186,32 @@
-# Procedure to hide menus
+# Procedure to hide or reveal panels
-proc hide_menus {} {
-	global Nv_ bit_map_path
+proc hide_menus { } {
+	global Nv_
+	global bit_map_path
+	if {$Nv_(hidemenus) == "1" } {
+		set Nv_(hidemenus) 0
+		$Nv_(PAREA).canvas configure -width 0
+		$Nv_(PAREA).f1.b1 configure -bitmap @$bit_map_path/right \
+			-width 12 -height 18 -command "hide_menus"
+		help $Nv_(PAREA).f1.b1 balloon "Show Panels"
+		#$Nv_(AREA).menu.config.m entryconfigure 1 -label "Show Panels" -command "show_menus"
+	} else {
+		set Nv_(hidemenus) 1
+		$Nv_(PAREA).canvas configure -width [winfo width $Nv_(P_AREA)]
+		$Nv_(PAREA).f1.b1 configure -bitmap @$bit_map_path/left \
+		help $Nv_(PAREA).f1.b1 balloon "Hide Panels"
+		#$Nv_(AREA).menu.config.m entryconfigure 1 -label "Hide Panels" -command "hide_menus"
+	update
-	$Nv_(PAREA).canvas	configure -width 0
-	$Nv_(PAREA).f1.b1 configure -bitmap @$bit_map_path/right \
-			-width 8 -height 12 -command "show_menus"
-	help $Nv_(PAREA).f1.b1 balloon "Show Panels"
-	$Nv_(AREA).menu.config.m entryconfigure 1 -label "Show Panels" -command "show_menus"
-# Procedure to reveal menus
-proc show_menus {} {
-	$Nv_(PAREA).canvas	configure -width [winfo width $Nv_(P_AREA)]
-	$Nv_(PAREA).f1.b1 configure -bitmap @$bit_map_path/left \
-			-width 8 -height 12 -command "hide_menus"
-	help $Nv_(PAREA).f1.b1 balloon "Hide Panels"
-	$Nv_(AREA).menu.config.m entryconfigure 1 -label "Hide Panels" -command "hide_menus"
 # add key bindings so that menu shortcut keys can be used
@@ -238,7 +234,7 @@
 	wm sizefrom . user
 	#Use three base frames
-	frame .top -relief flat -bd 0
+	frame $Nv_(AREA) -relief flat -bd 0
 	frame .middle -relief flat -bd 0
 	frame .bottom -relief flat -bd 0
@@ -258,8 +254,8 @@
 	pack $Nv_(PAREA) -side left -fill y -expand no
 	#togl canvas
-	frame .middle.draw -relief groove -bd 2
-	pack .middle.draw -side left -fill both -expand yes
+	frame $Nv_(TOP) -relief groove -bd 2
+	pack $Nv_(TOP) -side left -fill both -expand yes
 	entry .bottom.entry -relief sunken -state disabled \
 		-background #FFFFFF -textvariable Nv_(text)
@@ -267,29 +263,29 @@
 	set cwidth [exec $src_boot/bin/g.gisenv X3D_WIDTH]
 	set cheight [exec $src_boot/bin/g.gisenv X3D_HEIGHT]
 	if {$cwidth > 0 && $cheight > 0} {
-		togl .middle.draw.canvas -rgba true -double true -depth true \
+		togl $Nv_(TOP).canvas -rgba true -double true -depth true \
 				-width $cwidth -height $cheight
-		pack .middle.draw.canvas -side top -expand no
+		pack $Nv_(TOP).canvas -side top -expand no
 	} elseif {$cwidth == "" && $cheight > 0} {
 				-height $cheight
-		pack .middle.draw.canvas -side top -fill x -expand yes
+		pack $Nv_(TOP).canvas -side top -fill x -expand yes
 	} elseif {$cheight == "" && $cwidth > 0} {
 				-width $cwidth
-		pack .middle.draw.canvas -side top -fill y -expand yes
+		pack $Nv_(TOP).canvas -side top -fill y -expand yes
 	} else {
 	#nothing set
 	set constrained 1
-		pack .middle.draw.canvas -side top -fill both -expand yes
+		pack $Nv_(TOP).canvas -side top -fill both -expand yes
-	bind .middle.draw.canvas <Expose> {Nv_expose %W}
-	bind .middle.draw.canvas <Configure> {set Nv_(height) %h}
-	set tags [bindtags .middle.draw.canvas]
+	bind $Nv_(TOP).canvas <Expose> {Nv_expose %W}
+	bind $Nv_(TOP).canvas <Configure> {set Nv_(height) %h}
+	set tags [bindtags $Nv_(TOP).canvas]
 	# the Togl widget can't be redrawn until the main panel has been created
 	#	 update
@@ -300,7 +296,7 @@
 	#Moved the following packing here to satisfy some TCL versions
 	#Prevents minimized GUI
 	#top frame for menubar
-	pack .top -side top -fill x -expand no
+	pack $Nv_(AREA) -side top -fill x -expand no
 	#middle frame for menus and togl canvas
 	pack .middle  -side top -fill both -expand yes
 	#botom frame for statusbar
@@ -313,24 +309,25 @@
 	# make	panel area
 	canvas $Nv_(PAREA).canvas -yscrollcommand "$Nv_(PAREA).f1.scrolly set" \
-	-borderwidth 2 -relief sunken
+            -borderwidth 2 -relief sunken
 	frame $Nv_(PAREA).f1 -borderwidth 0 -relief flat
-	scrollbar $Nv_(PAREA).f1.scrolly -command "$Nv_(PAREA).canvas yview"
+	scrollbar $Nv_(PAREA).f1.scrolly -command "$Nv_(PAREA).canvas yview"
+        bind all <MouseWheel> {$Nv_(PAREA).canvas yview scroll [expr -1 * %D] units}
 	button $Nv_(PAREA).f1.b1 -bitmap @$bit_map_path/left \
 	frame $Nv_(P_AREA) -relief flat
 # DEBUG
 if {$DEBUG} {puts "panel area made"}
 	# make	menubar
-	frame $Nv_(AREA).menu  -relief flat -borderwidth 1
-	pack $Nv_(AREA).menu -side top -fill x -expand no
+	frame $Nv_(AREA).menu  -relief flat -borderwidth 0
+	#pack $Nv_(AREA).menu -side top -fill x -expand no
 	pack $Nv_(PAREA).canvas -side top -fill both -expand yes
 	pack $Nv_(PAREA).f1 -side left -before $Nv_(PAREA).canvas -fill y
@@ -346,19 +343,20 @@
 	$Nv_(PAREA).canvas create window 0 0 -window $Nv_(P_AREA) -anchor nw
 	bind $Nv_(P_AREA) <Configure> "set_scrollsize"
-	pack [Nv_mkMenu $Nv_(AREA).menu.help Help \
+        set helpmenu [Nv_mkMenu $Nv_(AREA).menu.help "Help   " \
 		{"NVIZ Help" "About NVIZ" "NVIZ - Bugs / ToDo"} \
 		{0 0 0} \
-		{"nviz_browse nviz_toc.html" "nviz_browse nviz_desc.html" "nviz_browse bugs_todo.html"} ] \
-		-side right -fill none -expand no -anchor e
+		{"nviz_browse nviz_toc.html" "nviz_browse nviz_desc.html" "nviz_browse bugs_todo.html"} ]
+#	#pack  $helpmenu -side right -fill none -expand yes -anchor e
 	# DEBUG
 	if {$DEBUG} {puts "Help menu made"}
-	set leftmenu [frame $Nv_(AREA).menu.left -relief flat -bd 0]
+	#set Nv_(AREA).menu [frame $Nv_(AREA).menu.left -relief flat -bd 0]
 	# file menu
-	set filemenu [Nv_mkMenu $leftmenu.file File \
+	set filemenu [Nv_mkMenu $Nv_(AREA).menu.file "File   " \
 			  {"Load State ..." "Save State ..." \
 				"Set Canvas Size ..."
@@ -379,7 +377,7 @@
 				"Separator" \
 				"reset_Nviz" "Nv_close_scripting ; exit ; puts"}]
-	pack $filemenu -side left -fill x -expand no
+#	pack $filemenu -side left -fill x -expand no
 # DEBUG
@@ -392,17 +390,17 @@
 # DEBUG
 if {$DEBUG} {puts "disabled made"}
-	pack [Nv_mkConfigMenu $leftmenu.config] -side left -fill x -expand no
+#	pack [Nv_mkConfigMenu $Nv_(AREA).menu.config] -side left -fill x -expand no
-	pack [Nv_mkPanelMenu $leftmenu.panel] -side left -fill x -expand no
+#	pack [Nv_mkPanelMenu $Nv_(AREA).menu.panel] -side left -fill x -expand no
 # DEBUG
 if {$DEBUG} {puts "scripting menu 0 made"}
 	# Make a menu entry for scripting
-	menubutton $leftmenu.scripting -text Scripting \
-		-menu $leftmenu.scripting.m -underline 0
-	set scriptingmenu [menu $leftmenu.scripting.m]
+	set scriptingbtn [menubutton $Nv_(AREA).menu.scripting -text "Scripting   " \
+		-menu $Nv_(AREA).menu.scripting.m -underline 0 ]
+	set scriptingmenu [menu $Nv_(AREA).menu.scripting.m]
 	$scriptingmenu add checkbutton -label "On" \
 		-onvalue 1 -offvalue 0 -variable ScriptState \
@@ -432,18 +430,21 @@
 	$scriptingmenu add command -label "Script Tools" \
 		-underline 1 -command {exec nviz -f $default_panel_path/script_tools -q &}
-	pack $leftmenu.scripting -side left -fill x -expand no
+        set configmenu [Nv_mkConfigMenu $Nv_(AREA).menu.config]
+        set panelmenu [Nv_mkPanelMenu $Nv_(AREA).menu.panel]
+	pack $helpmenu -side right -fill none -expand no -anchor e
+	pack $filemenu $configmenu $panelmenu $scriptingbtn -side left -fill none -expand no -anchor w
 # DEBUG
 if {$DEBUG} {puts "scripting menu made"}
-	pack $leftmenu -side left -fill x -expand no
+	pack $Nv_(AREA).menu -side left -fill x -expand yes
+	tk_menuBar $Nv_(AREA).menu
+	#tk_menuBar $Nv_(AREA).menu $filemenu $Nv_(AREA).menu.panel \
+	#$scriptingbtn
-	tk_menuBar $Nv_(AREA).menu $Nv_(AREA).menu.file $Nv_(AREA).menu.panel \
-	$Nv_(AREA).menu.scripting
 	set Nv_(Q) [Q_init 2]
 #pack $Nv_(AREA).menu.wait_pls -side left -fill x -expand yes
@@ -456,8 +457,12 @@
 # DEBUG
 if {$DEBUG} {puts "menubar made"}
-	focus $Nv_(AREA).menu
+	raise .bottom
+	raise .middle
+	raise $Nv_(AREA)
+	focus -force $Nv_(AREA).menu
 	return $BASE
@@ -627,7 +632,7 @@
 # procedure to make	 PANEL pulldown menu
-proc Nv_mkPanelMenu { P { name Visualize } } {
+proc Nv_mkPanelMenu { P { name "Visualize   " } } {
 	global Nv_ DEBUG
 	menubutton $P -text $name -menu $P.m -underline 0
@@ -660,7 +665,7 @@
 # procedure to make	 CONFIG pulldown menu
-proc Nv_mkConfigMenu { P { name Appearance } } {
+proc Nv_mkConfigMenu { P { name "Appearance   " } } {
 	global Nv_ DEBUG
@@ -669,7 +674,7 @@
 	if {$DEBUG} {puts "Nv_mkConfigMenu 1"}
 	set j 0
-	$P.m add command -label "Hide Panels" -command hide_menus
+	$P.m add command -label "Hide Panels" -command "hide_menus"
 	$P.m add separator
 	foreach i $Nv_(config) {
@@ -702,15 +707,13 @@
 	global Nv_
 	global BGColor
-#	 if [$W islinked] then {
 	if {$Nv_(First)} then {
 		init_graphics
 		set Nv_(First) 0
 	} else {
-			Nbackground $BGColor
+		Nbackground $BGColor
 		Nquick_draw
 proc save_3dview { dummy } {
@@ -807,10 +810,10 @@
 	button .canvas_size.f2.b1 -text "Close" \
 		-command {
 			if {$constrained} {
-					pack $Nv_(TOP).canvas -side top -fill both -expand yes
 			} else {
-					$Nv_(TOP).canvas configure -width $cwidth -height $cheight
-					pack $Nv_(TOP).canvas -side top -expand no -fill none
+				$Nv_(TOP).canvas configure -width $cwidth -height $cheight
+				pack $Nv_(TOP).canvas -side top -expand no -fill none
 				#Need Nset_viewport to make sure reshape is called
 				Nset_viewport $cwidth $cheight
@@ -888,13 +891,13 @@
 	# Go through each of the panels one at a time and force them to open
 	# This should update them all so they display correctly
-        Nv_openPanel $i
-        update
+		Nv_openPanel $i
+		update
 	foreach i $Nv_(panels) {
-        Nv_openPanel $i
-        update
+		Nv_openPanel $i
+		update
 	Nv_closeAllPanels
@@ -919,32 +922,32 @@
 	set tmp_list $Nv_(panels)
 	lappend tmp_list main
-        set cmd_name "Nviz_$i"
-        append cmd_name "_reset"
-        if {[catch {$cmd_name} error_code] != 0} then {
-            puts "Diagnostic: $error_code --  Reset procedure for panel $i may not be defined"
+		set cmd_name "Nviz_$i"
+		append cmd_name "_reset"
+		if {[catch {$cmd_name} error_code] != 0} then {
+			puts "Diagnostic: $error_code --  Reset procedure for panel $i may not be defined"
-        Nv_openPanel $i
-        update
+		Nv_openPanel $i
+		update
-        Nv_openPanel $i
-        update
+		Nv_openPanel $i
+		update
 	Nv_closeAllPanels
@@ -964,31 +967,31 @@
 	foreach i $tmp_list {
-        Nv_openPanel $i
-        update
+		Nv_openPanel $i
+		update
-        Nv_openPanel $i
-        update
+		Nv_openPanel $i
+		update
 	Nv_closeAllPanels
@@ -1006,12 +1009,12 @@
 	# append ".nviz" extension to the filename if it doesn't already have one
 	if { [string compare [file extension $new_file] ".nviz"] != 0 } then {
-        append new_file ".nviz"
+		append new_file ".nviz"
 	if {[catch {set file_hook [open $new_file w]} error_code] != 0} then {
-        display_error "While opening file: $error_code"
-        return
+		display_error "While opening file: $error_code"
+		return
 	# Show that we are busy
@@ -1020,11 +1023,11 @@
 	# Now call each of the panels one at a time and pass the
 	# file hook so that each panel can write out its state
 	foreach i $Nv_(panelstate) {
-        append cmd_name "_save"
-        if {[catch {$cmd_name $file_hook} error_code] != 0} then {
-            puts "Diagnostic: $error_code --  Save procedure for panel $i may not be defined"
+		append cmd_name "_save"
+		if {[catch {$cmd_name $file_hook} error_code] != 0} then {
+		    puts "Diagnostic: $error_code --  Save procedure for panel $i may not be defined"
 	# Finally, close the file and exit
@@ -1046,7 +1049,7 @@
 Nset_cancel_func update
 # and start the ball rolling...
-Nv_makeGUI .top
+Nv_makeGUI $Nv_(AREA)
 # Center the view on initialization
 look_center
@@ -1074,13 +1077,12 @@
 # Automatically load state file from command line
 if {[catch {set NvizLoadState}] == 0} then {
+	global Nv_
-global Nv_
+	appBusy
+	load_state_aux $NvizLoadState
-appBusy
-load_state_aux $NvizLoadState
-appNotBusy
+	appNotBusy
 if {$DEBUG} {puts "Finished loading, call draw all"}
Modified: grass/trunk/visualization/nviz/scripts/panel_main.tcl
--- grass/trunk/visualization/nviz/scripts/panel_main.tcl	2009-02-01 22:34:07 UTC (rev 35732)
+++ grass/trunk/visualization/nviz/scripts/panel_main.tcl	2009-02-02 17:59:45 UTC (rev 35733)
@@ -130,12 +130,12 @@
 	menubutton $BASE.redrawf.f11.m1 -menu $BASE.redrawf.f11.m1.m \
 		-text "Main features..." -underline 0 -justify left \
 		-indicator on -anchor center -relief raised -bd 1
-	help $BASE.redrawf.f11.m1 balloon "Select main draw features"
+	#help $BASE.redrawf.f11.m1 balloon "Select main draw features"
 	menubutton $BASE.redrawf.f11.m2 -menu $BASE.redrawf.f11.m2.m \
 		-text "Decorations..." -underline 0	 -justify left \
-	help $BASE.redrawf.f11.m2 balloon "Select misc. draw features"
+	#help $BASE.redrawf.f11.m2 balloon "Select misc. draw features"
Modified: grass/trunk/visualization/nviz/scripts/panel_sdiff.tcl
--- grass/trunk/visualization/nviz/scripts/panel_sdiff.tcl	2009-02-01 22:34:07 UTC (rev 35732)
+++ grass/trunk/visualization/nviz/scripts/panel_sdiff.tcl	2009-02-02 17:59:45 UTC (rev 35733)
@@ -121,7 +121,7 @@
     set name [Nget_current sdiff]
     if {$name == 0} {
-	set name "none selected"
+	set name "None selected   "
     } else {
 	set n [lsearch $list $name]
 	set list [lreplace $list $n $n]
Modified: grass/trunk/visualization/nviz/scripts/widgets.tcl
--- grass/trunk/visualization/nviz/scripts/widgets.tcl	2009-02-01 22:34:07 UTC (rev 35732)
+++ grass/trunk/visualization/nviz/scripts/widgets.tcl	2009-02-02 17:59:45 UTC (rev 35733)
@@ -420,7 +420,7 @@
 		incr j
 	return $P
@@ -593,7 +593,7 @@
 	set name [Nget_current $type]
 	if {[llength $list] == 0} {
-		set name "None Loaded"
+		set name "None Loaded   "
 	} else {
