[GRASS-SVN] r35736 - grass-addons/vector/v.in.gshhs
svn_grass at osgeo.org
Mon Feb 2 14:13:34 EST 2009
Author: mmetz
Date: 2009-02-02 14:13:34 -0500 (Mon, 02 Feb 2009)
New Revision: 35736
grass-addons/vector/v.in.gshhs/description.html
grass-addons/vector/v.in.gshhs/main.c
fix for attribute table and feature selection by bounding box
Modified: grass-addons/vector/v.in.gshhs/description.html
--- grass-addons/vector/v.in.gshhs/description.html 2009-02-02 18:11:24 UTC (rev 35735)
+++ grass-addons/vector/v.in.gshhs/description.html 2009-02-02 19:13:34 UTC (rev 35736)
@@ -9,11 +9,11 @@
<p>
Shorelines are imported as lines, not boundaries.
<p>
-The categories in layer 1 refer to the type of shoreline: shore, land,
-lake, island in lake, pond in island in lake. The field <tt>type</tt> is
-set to these descriptions. All lines of the same type have the same
-category. The categories in layer 2 refer to the GSHHS ID of each
-imported line. Each line has as category value the GSHHS ID in
+The categories in layer 1 refer to the type of shoreline: 1 = land,
+2 = lake, 3 = island in lake, 4 = pond in island in lake. The field
+<tt>type</tt> is set to these descriptions. All lines of the same type
+have the same category. The categories in layer 2 refer to the GSHHS ID
+of each imported line. Each line has as category value the GSHHS ID in
layer 2, that may be useful for further processing. An attribute table
for layer 2 is not created.
<p>
@@ -34,15 +34,21 @@
<li>l: low resolution
<li>c: coarse resolution
</ul>
+Recommended are the full and high resolution data.
<p>
The generated table for layer 1 allows a fast query of the shoreline type.
If needed a table for layer 2 can be added with <em>v.db.addtable</em>.
-The new table can be populated with category values from layer 2 (unique
+The new table can be populated with category values from layer 2 (GSHHS
line ID) with <em>v.to.db</em>. Shoreline type can be uploaded from
layer 1 to layer 2 with <em>v.to.db</em>.
<p>
Lines can be converted to boundaries with <em>v.type</em>.
<p>
+To create a land mask, extract all lines with category = 1 in layer 1,
+convert them to boundaries, add missing centroids, convert area vector
+to raster. Accordingly for lakes, islands in lakes, and ponds in islands
+in lakes.
+<p>
Import of world borders and world rivers also included in the zip archive
is currently not supported but works, just ignore the attribute table.
These world borders and rivers are however outdated and not very accurate.
Modified: grass-addons/vector/v.in.gshhs/main.c
--- grass-addons/vector/v.in.gshhs/main.c 2009-02-02 18:11:24 UTC (rev 35735)
+++ grass-addons/vector/v.in.gshhs/main.c 2009-02-02 19:13:34 UTC (rev 35736)
@@ -42,16 +42,17 @@
double minx = -180., maxx = 180., miny = -90., maxy = 90.;
char *dataname, *outname;
char buf[2000], source;
- static char *slevel[] = { "shore", "land", "lake", "island in lake",
- "pond in island in lake"
- int shore_levels = 5;
+ static char *slevel[] = { "land", "lake", "island in lake",
+ "pond in island in lake" };
+ int shore_levels = 4;
+ /* taken from gshhs.c, keep in sync */
FILE *fp;
int k, i, n_read, flip, level, version, greenwich, src;
int max_east = 180000000; /* max_east = 270000000: confuses GRASS */
int cnt = 0, getme = 0;
struct GSHHS_POINT p; /* renamed to avoid conflict */
struct GSHHS h;
+ /* GRASS specific */
struct pj_info info_in;
struct pj_info info_out;
struct Key_Value *out_proj_keys, *out_unit_keys;
@@ -278,6 +279,9 @@
G_message(_("Using lat/lon bounds N=%f S=%f E=%f W=%f\n"), maxy, miny,
maxx, minx);
+ if (maxx < minx)
+ maxx += 360.; /* easier to get overlapping features */
/* open GSHHS shoreline for reading */
if ((fp = fopen(dataname, "rb")) == NULL) {
G_fatal_error(_("Could not find file %s."), dataname);
@@ -300,7 +304,7 @@
/* read header from GSHHS database */
n_read = fread((void *)&h, (size_t) sizeof(struct GSHHS), (size_t) 1, fp);
version = (h.flag >> 8) & 255;
- flip = (version < 6); /* Take as sign that byte-swapping is needed */
+ flip = (version < 4); /* Take as sign that byte-swapping is needed */
if (flip) {
version = swabi4((unsigned int)h.flag);
version = (version >> 8) & 255;
@@ -308,6 +312,7 @@
/* read lines from GSHHS database */
while (n_read == 1) {
if (flip) {
h.id = swabi4((unsigned int)h.id);
h.n = swabi4((unsigned int)h.n);
@@ -330,27 +335,20 @@
source = (src == 1) ? 'W' : 'C'; /* Either WVS or CIA (WDBII) pedigree */
area = 0.1 * h.area; /* Now im km^2 */
- if (h.west > max_east)
+ /* GRASS specific, max_east must always be 180 */
+ while (w > 180.)
w -= 360.0;
- if (h.east > max_east)
+ while (e > 180.)
e -= 360.0;
- if (e < w)
- e += 360;
+ if (maxx > 180. && w < 0)
+ w += 360.;
+ if (maxx > 180. && e < 0)
+ e += 360.;
- /* got line header now read in points if line box falls into region */
- /* what if the datum border is crossed?
- * then maxx < minx and both w and e should be >= minx or <=maxx */
- getme = 1;
- if (maxx > minx) {
- if (w > maxx || e < minx || s > maxy || n < miny) /* that should get any overlapping line */
- getme = 0;
- else {
- /* e and w < minx and e and w > maxx */
- if ((w < minx && e < minx && w > maxx && e > maxx) || s > maxy || n < miny)
- getme = 0;
+ getme = 0;
+ if (w < maxx && e > minx && s < maxy && n > miny)
+ getme = 1;
if (getme) {
Vect_reset_line(Points);
@@ -407,7 +405,8 @@
fseek(fp, (long)(h.n * sizeof(struct GSHHS_POINT)), SEEK_CUR);
cnt++;
- /* max_east = 180000000; *//* Only Eurasiafrica needs 270: only needed for GMT not for GRASS */
+ /* 270 only needed for GMT not for GRASS, GRASS wraps around */
+ /* max_east = 180000000; *//* Only Eurasiafrica needs 270 */
n_read =
@@ -425,7 +424,7 @@
version);
Vect_set_comment(&VectMap, buf);
- /* create table and link new vector to table, code taken from v.in.ogr */
+ /* create table for layer 1 and link new vector to table, code taken from v.in.ogr */
db_init_string(&sql);
db_init_string(&strval);
@@ -482,6 +481,8 @@
db_commit_transaction(driver);
db_close_database_shutdown_driver(driver);
+ /* table for layer 1 created */
if (flag.topo->answer) {
G_message(_("Run \"v.build map=%s option=build\" to build topology"),
outname);
