[GRASS-SVN] r35742 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Feb 2 16:31:18 EST 2009
Author: martinl
Date: 2009-02-02 16:31:17 -0500 (Mon, 02 Feb 2009)
New Revision: 35742
grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/sqlbuilder.py
wxGUI: remove unused methods of gcmd.Command
(merge from trunk r35741)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py 2009-02-02 21:29:25 UTC (rev 35741)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py 2009-02-02 21:31:17 UTC (rev 35742)
@@ -358,11 +358,11 @@
os.linesep, os.linesep,
_("Details:"),
os.linesep,
- _("Error: ") + self.GetError()))
+ _("Error: ") + self.__GetError()))
elif rerr == sys.stderr: # redirect message to sys
stderr.write("Execution failed: '%s'" % (' '.join(self.cmd)))
stderr.write("%sDetails:%s%s" % (os.linesep,
- _("Error: ") + self.GetError(),
+ _("Error: ") + self.__GetError(),
os.linesep))
else:
pass # nop
@@ -394,17 +394,7 @@
return lineList
- def ReadStdOutput(self):
- """Read standard output and return list of lines"""
- if self.cmdThread.stdout:
- stream = self.cmdThread.stdout # use redirected stream instead
- stream.seek(0)
- else:
- stream = self.cmdThread.module.stdout
- return self.__ReadOutput(stream)
- def ReadErrOutput(self):
+ def __ReadErrOutput(self):
"""Read standard error output and return list of lines"""
return self.__ReadOutput(self.cmdThread.module.stderr)
@@ -415,7 +405,7 @@
@return list of (type, message)
if self.stderr is None:
- lines = self.ReadErrOutput()
+ lines = self.__ReadErrOutput()
else:
lines = self.cmdThread.error.strip('%s' % os.linesep). \
split('%s' % os.linesep)
@@ -444,7 +434,7 @@
return msg
- def GetError(self):
+ def __GetError(self):
"""Get error message or ''"""
if not self.cmdThread.module:
return _("Unable to exectute command: '%s'") % ' '.join(self.cmd)
@@ -455,28 +445,6 @@
return ''
- def PrintModuleOutput(self, error=True, warning=False, message=False):
- """Print module errors, warnings, messages to output
- @param error print errors
- @param warning print warnings
- @param message print messages
- @return string
- msgString = ""
- for type, msg in self.__ProcessStdErr():
- if type:
- if (type == 'ERROR' and error) or \
- (type == 'WARNING' and warning) or \
- (type == 'MESSAGE' and message):
- msgString += " " + type + ": " + msg + "%s" % os.linesep
- else:
- msgString += " " + msg + "%s" % os.linesep
- return msgString
class CommandThread(Thread):
"""Create separate thread for command
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2009-02-02 21:29:25 UTC (rev 35741)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2009-02-02 21:31:17 UTC (rev 35742)
@@ -1009,16 +1009,17 @@
ret = gcmd.RunCommand('v.in.dxf',
quiet = True,
parent = self,
+ read = True,
flags = 'l',
input = path)
- if ret != 0:
+ if not ret:
self.list.LoadData()
self.btn_run.Enable(False)
return
data = []
if self.inputType == 'dxf':
- for line in cmd.ReadStdOutput():
+ for line in ret.splitlines():
layerId = line.split(':')[0].split(' ')[1]
layerName = line.split(':')[1].strip()
grassName = utils.GetValidLayerName(layerName)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/sqlbuilder.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/sqlbuilder.py 2009-02-02 21:29:25 UTC (rev 35741)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/sqlbuilder.py 2009-02-02 21:31:17 UTC (rev 35742)
@@ -220,13 +220,14 @@
def GetColumns(self):
"""Get columns"""
- dbDescribe = gcmd.RunCommand('db.describe',
- quiet = True,
- flags = 'c',
- table = self.tablename)
+ ret = gcmd.RunCommand('db.describe',
+ quiet = True,
+ read = True,
+ flags = 'c',
+ table = self.tablename)
# skip ncols and nrows lines
- for line in dbDescribe.ReadStdOutput()[2:]:
num, name, ctype, length = line.strip().split(":")
name.strip()
#self.columns_names.append(name)
