[GRASS-SVN] r35757 - in grass/trunk/raster/r.le: r.le.patch
r.le.pixel r.le.setup r.le.trace
svn_grass at osgeo.org
Tue Feb 3 21:07:07 EST 2009
Author: hamish
Date: 2009-02-03 21:07:07 -0500 (Tue, 03 Feb 2009)
New Revision: 35757
grass/trunk/raster/r.le/r.le.patch/driver.c
grass/trunk/raster/r.le/r.le.patch/patch.c
grass/trunk/raster/r.le/r.le.patch/patch.h
grass/trunk/raster/r.le/r.le.patch/r.le.patch.html
grass/trunk/raster/r.le/r.le.pixel/r.le.pixel.html
grass/trunk/raster/r.le/r.le.setup/r.le.setup.html
grass/trunk/raster/r.le/r.le.trace/r.le.trace.html
GNAME_MAX (trac #416), itc->osgeo (merge from devbr6)
Modified: grass/trunk/raster/r.le/r.le.patch/driver.c
--- grass/trunk/raster/r.le/r.le.patch/driver.c 2009-02-04 02:03:33 UTC (rev 35756)
+++ grass/trunk/raster/r.le/r.le.patch/driver.c 2009-02-04 02:07:07 UTC (rev 35757)
@@ -139,7 +139,7 @@
void open_files()
FILE *fp;
- char path[30];
+ char path[GPATH_MAX];
int i;
if (choice->att[1] || choice->att[2] || choice->att[3] || choice->att[4]) {
@@ -2465,7 +2465,7 @@
FILE *fp;
int i = 0, cnt = 1;
- char *buf, path[30];
+ char *buf, path[GPATH_MAX];
/* VARIABLES
Incoming
@@ -2542,7 +2542,7 @@
FILE *fp;
int i;
- char path[30], *buf;
+ char path[GPATH_MAX], *buf;
sprintf(path, "r.le.para/%s", name);
Modified: grass/trunk/raster/r.le/r.le.patch/patch.c
--- grass/trunk/raster/r.le/r.le.patch/patch.c 2009-02-04 02:03:33 UTC (rev 35756)
+++ grass/trunk/raster/r.le/r.le.patch/patch.c 2009-02-04 02:07:07 UTC (rev 35757)
@@ -42,7 +42,7 @@
PATCH *tmp = patch_list;
int *type_dens, type_coh;
- char path[30];
+ char path[GNAME_MAX+10];
if (!total_patches)
return;
Modified: grass/trunk/raster/r.le/r.le.patch/patch.h
--- grass/trunk/raster/r.le/r.le.patch/patch.h 2009-02-04 02:03:33 UTC (rev 35756)
+++ grass/trunk/raster/r.le/r.le.patch/patch.h 2009-02-04 02:07:07 UTC (rev 35757)
@@ -78,7 +78,7 @@
struct CHOICE
- char fn[30], reg[30], out[30], wrum;
+ char fn[GNAME_MAX], reg[GMAPSET_MAX], out[GNAME_MAX], wrum;
int core2, size2, shape2, edge, fb, coremap, units;
int perim2, trace, patchmap;
int Mx[4];
Modified: grass/trunk/raster/r.le/r.le.patch/r.le.patch.html
--- grass/trunk/raster/r.le/r.le.patch/r.le.patch.html 2009-02-04 02:03:33 UTC (rev 35756)
+++ grass/trunk/raster/r.le/r.le.patch/r.le.patch.html 2009-02-04 02:07:07 UTC (rev 35757)
@@ -18,7 +18,7 @@
landscape structure using the GRASS geographical information system.
Landscape Ecology 7(4):291-302.
<p>
-The <A href="http://grass.itc.it/gdp/landscape/r_le_manual5.pdf"><i>r.le</i>
+The <A href="http://grass.osgeo.org/gdp/landscape/r_le_manual5.pdf"><i>r.le</i>
manual: Quantitative analysis of landscape structures</a> (GRASS 5; 2001)
<h2>SEE ALSO</h2>
Modified: grass/trunk/raster/r.le/r.le.pixel/r.le.pixel.html
--- grass/trunk/raster/r.le/r.le.pixel/r.le.pixel.html 2009-02-04 02:03:33 UTC (rev 35756)
+++ grass/trunk/raster/r.le/r.le.pixel/r.le.pixel.html 2009-02-04 02:07:07 UTC (rev 35757)
@@ -17,7 +17,7 @@
<p>
<h2>SEE ALSO</h2>
Modified: grass/trunk/raster/r.le/r.le.setup/r.le.setup.html
--- grass/trunk/raster/r.le/r.le.setup/r.le.setup.html 2009-02-04 02:03:33 UTC (rev 35756)
+++ grass/trunk/raster/r.le/r.le.setup/r.le.setup.html 2009-02-04 02:07:07 UTC (rev 35757)
@@ -449,7 +449,7 @@
<p>
Modified: grass/trunk/raster/r.le/r.le.trace/r.le.trace.html
--- grass/trunk/raster/r.le/r.le.trace/r.le.trace.html 2009-02-04 02:03:33 UTC (rev 35756)
+++ grass/trunk/raster/r.le/r.le.trace/r.le.trace.html 2009-02-04 02:07:07 UTC (rev 35757)
@@ -19,7 +19,7 @@
<p>
