[GRASS-SVN] r35782 - in
grass/branches/releasebranch_6_4/vector/lidar: v.outlier
v.surf.bspline
svn_grass at osgeo.org
Fri Feb 6 02:13:41 EST 2009
Author: hamish
Date: 2009-02-06 02:13:40 -0500 (Fri, 06 Feb 2009)
New Revision: 35782
grass/branches/releasebranch_6_4/vector/lidar/v.outlier/main.c
grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c
typos (merge from devbr6)
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.outlier/main.c
--- grass/branches/releasebranch_6_4/vector/lidar/v.outlier/main.c 2009-02-06 06:26:59 UTC (rev 35781)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.outlier/main.c 2009-02-06 07:13:40 UTC (rev 35782)
@@ -106,7 +106,7 @@
lambda_f_opt->key = "lambda_i";
lambda_f_opt->type = TYPE_DOUBLE;
lambda_f_opt->required = NO;
- lambda_f_opt->description = _("Thychonov regularization weigth");
+ lambda_f_opt->description = _("Tykhonov regularization weight");
lambda_f_opt->answer = "0.1";
Thres_O_opt = G_define_option();
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c
--- grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c 2009-02-06 06:26:59 UTC (rev 35781)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c 2009-02-06 07:13:40 UTC (rev 35782)
@@ -137,7 +137,7 @@
lambda_f_opt->answer = "1";
lambda_f_opt->guisection = _("Settings");
