[GRASS-SVN] r35784 - in grass/trunk/vector/lidar: v.outlier
v.surf.bspline
svn_grass at osgeo.org
Fri Feb 6 02:20:20 EST 2009
Author: hamish
Date: 2009-02-06 02:20:17 -0500 (Fri, 06 Feb 2009)
New Revision: 35784
grass/trunk/vector/lidar/v.outlier/main.c
grass/trunk/vector/lidar/v.surf.bspline/main.c
typos (merge from devbr6)
Modified: grass/trunk/vector/lidar/v.outlier/main.c
--- grass/trunk/vector/lidar/v.outlier/main.c 2009-02-06 07:19:11 UTC (rev 35783)
+++ grass/trunk/vector/lidar/v.outlier/main.c 2009-02-06 07:20:17 UTC (rev 35784)
@@ -108,7 +108,7 @@
lambda_f_opt->key = "lambda_i";
lambda_f_opt->type = TYPE_DOUBLE;
lambda_f_opt->required = NO;
- lambda_f_opt->description = _("Thychonov regularization weigth");
+ lambda_f_opt->description = _("Tykhonov regularization weight");
lambda_f_opt->answer = "0.1";
Thres_O_opt = G_define_option();
Modified: grass/trunk/vector/lidar/v.surf.bspline/main.c
--- grass/trunk/vector/lidar/v.surf.bspline/main.c 2009-02-06 07:19:11 UTC (rev 35783)
+++ grass/trunk/vector/lidar/v.surf.bspline/main.c 2009-02-06 07:20:17 UTC (rev 35784)
@@ -139,7 +139,7 @@
lambda_f_opt->answer = "1";
lambda_f_opt->guisection = _("Settings");
